Change to NFC library
In ncs/v3.1.0/modules/hal/nordic/nrfx/drivers/include/nrfx_nfct.h, the enum 'nrfx_nfct_param_id_t' is defined as:
/** @brief NFCT driver parameter types. */
typedef enum
    NRFX_NFCT_PARAM_ID_FDT,     ///< NFC-A Frame Delay Time parameter.
    NRFX_NFCT_PARAM_ID_FDT_MIN, ///< NFC-A Frame Delay Time Min parameter.
    NRFX_NFCT_PARAM_ID_SEL_RES, ///< Value of the 'Protocol' field in the NFC-A SEL_RES frame.
    NRFX_NFCT_PARAM_ID_NFCID1,  ///< NFC-A NFCID1 setting (NFC tag identifier).
} nrfx_nfct_param_id_t;
In the nrfx support libraries shipped to us with a vendor Bluetooth stack, the enum is defined as:
typedef enum
We are using the NFC libraries (libnfc_t2t.a and libnfc_t4t.a) from SDK v3.1.0 so it appears that v3.1.0 libraries are incompatible with the nrfx support libraries shipped with the Bluetooth stack.
Can you advise in which SDK version the above enum was changed? I'm thinking that I should use the libnfc_t2t.a and libnfc_t4t.a libraries from an SDK version prior to the change.
Andrew Coad
