S120 Scanner and S110 Peripheral Device pairing and exchange data.
Hi, I have two device. S120 Scanner and S110 Peripheral Device. At Scanner, I use SDK 9.0.0 and S130 1.0.0, At Peripheral Device, I use SDK 9.0.0 and S110 8.0.0 ..
Scanner
  • It is based "ble_app_uart_c_S120-master".
  • I check pairing and exchange data with "NUS example code"
Peripheral Device
  • It is based "ble_app_uart"
  • I added some custom service, flash memory, dfu service.
  • I check exchange data with Smartphone.
When i try to pair My Scanner and My Peripheral Device, At Scanner side, it repeat evt connect. At peripheral side, it is repeat "Connect evt - reset".
So i tried to do some case.
Scanner Side
  • I adjust "device_manager_cnfg.h -> DEVICE_MANAGER_MAX_CONNEDCTIONS" 0 -> 8.
    -> It repeat "Connect - recieve data - Disconnect" a 6 times. After My peripheral device is not working.
Peripheral Side
  • I try to delete dm_ble_evt_handler().
    -> It could pairing and exchange data, but it could't use DFU service.
In order to pairing and exchange data, What should i do ?
Please help me ..
  • Hi Hakjae,
    Most likely there was an error thrown but not handled and trigger a reset in app_error_handler. What you can do is to run in debug mode and add a break point inside app_error_handler(). You may need to add DEBUG preprocessor symbol in the C/C++ project option. Inside that function, you should be able to find the file name and line number caused the issue.
  • Thank you for your help. When I add DEBUG preprocessor symbol in the C/C++ project option, how can I check the file name and line number? uart? or any other things?
  • Please add a breakpoint inside app_error_handler(), and run your peripheral application in debug mode. We don't have device manager in the ble_app_uart, I assume that you added the module in manually?
  • Yes, I added device manager in ble_app_uart.
    When I runing debug mode used F10, debuging ble_stack_init(), it don't run anymore. Cursor point "app_util.h -> first line". Command tap print "*** error 35: undefined line number"
    And, i added a breakpoint inside app_error_handler(), and run my peripheral application in debug mode used F5, It didn't run. Cursor pointed "int main() {".
    What can i check any problem ?
  • @HakJae: What do you mean by it didn't run ? Please don't use F10 to step through the code as the softdevice won't work with stepping. You can have a look here : https://devzone.nordicsemi.com/blogs/821/an-introduction-to-error-handling-in-nrf5-projects/ on how to do debugging.
