Maximum data size incorrect in USB CDC ACM DFU (nRF52840) documentation
Hi everyone,
I believe that the documentation has an off by 1 error.
"The MTU includes the SLIP encapsulation, which means that the maximum data size that can be sent is (MTU/2) - 2."
https://docs.nordicsemi.com/bundle/nrf5_SDK_v17.1.1/page/lib_dfu_transport_serial.html
If we plug in MTU=2051 into the equation we get 1023.5, which seemed off to me.
Since max_size during firmware image transfer is 4096, the value of 1024 seemed to be more appropriate.
After looking through the nordic device side code I found this file:
nordic\DeviceDownload\nRF5_SDK_17.1.0_ddde560\components\libraries\bootloader\serial_dfu\nrf_dfu_serial_usb.c
#define RX_BUF_SIZE (1024)
#define SLIP_MTU        (2 * (RX_BUF_SIZE + 1) + 1)
Which shows us that the value is not 1023.5, but exactly 1024.
Strongato
 * Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
#include <string.h>
#include "nrf_dfu_req_handler.h"
#include "nrf_dfu_transport.h"
#include "slip.h"
#include "nrf_balloc.h"
#include "nrf_drv_power.h"
#include "nrf_drv_clock.h"
#include "nrf_drv_usbd.h"
#include "nrf_dfu_serial.h"
#include "app_scheduler.h"
#include "app_usbd.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_core.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_serial_num.h"
#define NRF_LOG_MODULE_NAME nrf_dfu_serial_usb
#include "nrf_log.h"
NRF_LOG_MODULE_REGISTER();
/**@file
 * @defgroup nrf_dfu_serial_usb DFU Serial USB CDC ACM transport
 * @ingroup  nrf_dfu
 * @brief    Device Firmware Update (DFU) transport layer using USB CDC ACM.
#define NRF_SERIAL_OPCODE_SIZE          (sizeof(uint8_t))
#define NRF_USB_MAX_RESPONSE_SIZE_SLIP  (2 * NRF_SERIAL_MAX_RESPONSE_SIZE + 1)
#define OPCODE_OFFSET                   (sizeof(uint32_t) - NRF_SERIAL_OPCODE_SIZE)
#define DATA_OFFSET                     (OPCODE_OFFSET + NRF_SERIAL_OPCODE_SIZE)
#define CDC_ACM_COMM_INTERFACE          0
#define CDC_ACM_COMM_EPIN               NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE          1
#define CDC_ACM_DATA_EPIN               NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT              NRF_DRV_USBD_EPOUT1
 * @brief Enable power USB detection
 * Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
 * @brief Interfaces list passed to @ref APP_USBD_CDC_ACM_GLOBAL_DEF
#define CDC_ACM_INTERFACES_CONFIG()        \
    APP_USBD_CDC_ACM_CONFIG(CDC_ACM_COMM_INTERFACE,                                                \
                            CDC_ACM_COMM_EPIN,                                                     \
                            CDC_ACM_DATA_INTERFACE,                                                \
                            CDC_ACM_DATA_EPIN,                                                     \
                            CDC_ACM_DATA_EPOUT)
/*lint -save -e26 -e64 -e505 -e651 */
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_cdc_acm_user_event_t event);
/**@brief CDC_ACM class instance. */
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            APP_USBD_CDC_COMM_PROTOCOL_NONE);
/*lint -restore */
NRF_BALLOC_DEF(m_payload_pool, (SLIP_MTU+1), NRF_DFU_SERIAL_USB_RX_BUFFERS);
static nrf_dfu_serial_t m_serial;
static slip_t m_slip;
static uint8_t m_rsp_buf[NRF_USB_MAX_RESPONSE_SIZE_SLIP];
static uint8_t m_rx_buf[NRF_DRV_USBD_EPSIZE];
static nrf_dfu_observer_t m_observer;
static uint32_t usb_dfu_transport_init(nrf_dfu_observer_t observer);
static uint32_t usb_dfu_transport_close(nrf_dfu_transport_t const * p_exception);
DFU_TRANSPORT_REGISTER(nrf_dfu_transport_t const usb_dfu_transport) =
    .init_func  = usb_dfu_transport_init,
    .close_func = usb_dfu_transport_close,
static void payload_free(void * p_buf)
    uint8_t * p_buf_root = ((uint8_t *)(p_buf)) - DATA_OFFSET; //pointer is shifted to point to data
    nrf_balloc_free(&m_payload_pool, p_buf_root);
static ret_code_t rsp_send(uint8_t const * p_data, uint32_t length)
    ASSERT(p_data);
    ASSERT(length != 0);
    uint32_t slip_len;
    // Cannot fail if inputs are non-NULL.
    (void) slip_encode(m_rsp_buf, (uint8_t *)(p_data), length, &slip_len);
    return app_usbd_cdc_acm_write(&m_app_cdc_acm, m_rsp_buf, slip_len);
static void on_rx_complete(nrf_dfu_serial_t * p_transport, uint8_t * p_data, uint8_t len)
    ret_code_t ret_code;
    for (uint32_t i = 0; i < len; i++)
        ret_code = slip_decode_add_byte(&m_slip, p_data[i]);
        if (ret_code != NRF_SUCCESS)
            continue;
        nrf_dfu_serial_on_packet_received(p_transport,
                                          (uint8_t const *)(m_slip.p_buffer),
                                          m_slip.current_index);
        uint8_t * p_rx_buf = nrf_balloc_alloc(&m_payload_pool);
        if (p_rx_buf == NULL)
            NRF_LOG_ERROR("Failed to allocate buffer!");
            return;
        NRF_LOG_DEBUG("Allocated buffer %x", p_rx_buf);
        // reset the slip decoding
        m_slip.p_buffer      = &p_rx_buf[OPCODE_OFFSET];
        m_slip.current_index = 0;
        m_slip.state         = SLIP_STATE_DECODING;
 * @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
            ret_code = app_usbd_cdc_acm_read(&m_app_cdc_acm, m_rx_buf, 1);
            NRF_LOG_WARNING("Could not read from CDC. Error: 0x%x.", ret_code);
        } break;
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            do
                on_rx_complete(&m_serial, m_rx_buf, 1);
            } while (ret_code == NRF_SUCCESS);
        } break;
static void usbd_dfu_transport_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
            if (m_observer)
                m_observer(NRF_DFU_EVT_TRANSPORT_ACTIVATED);
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
            if (m_observer)
                m_observer(NRF_DFU_EVT_TRANSPORT_DEACTIVATED);
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
static void usbd_sched_event_handler(void * p_event_data, uint16_t event_size)
    app_usbd_event_execute(p_event_data);
static void usbd_event_handler(app_usbd_internal_evt_t const * const p_event)
    if (p_event->type == APP_USBD_EVT_DRV_SOF)
        app_usbd_event_execute(p_event);
        ret_code = app_sched_event_put(p_event,
                                       sizeof(app_usbd_internal_evt_t),
                                       usbd_sched_event_handler);
            NRF_LOG_ERROR("Could not schedule USB event!");
    uint32_t err_code;
    /* Execute event directly in interrupt handler */
    static const app_usbd_config_t usbd_config =
        .ev_handler    = usbd_event_handler,
        .ev_state_proc = usbd_dfu_transport_ev_handler
    (void) nrf_balloc_init(&m_payload_pool); //Result is checked by checking result of _alloc().
    m_observer = observer;
        NRF_LOG_ERROR("Could not allocate payload pool.");
        return NRF_ERROR_INTERNAL;
    m_slip.buffer_len    = SLIP_MTU;
    m_serial.rsp_func          = rsp_send;
    m_serial.payload_free_func = payload_free;
    m_serial.mtu               = SLIP_MTU;
    m_serial.p_rsp_buf         = &m_rsp_buf[NRF_USB_MAX_RESPONSE_SIZE_SLIP -
                                            NRF_SERIAL_MAX_RESPONSE_SIZE];
    m_serial.p_low_level_transport = &usb_dfu_transport;
    NRF_LOG_DEBUG("Initializing drivers.");
    err_code = nrf_drv_clock_init();
    if (err_code != NRF_ERROR_MODULE_ALREADY_INITIALIZED)
        VERIFY_SUCCESS(err_code);
    err_code = nrf_drv_power_init(NULL);
    app_usbd_serial_num_generate();
    err_code = app_usbd_init(&usbd_config);
    app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    err_code                                    = app_usbd_class_append(class_cdc_acm);
    NRF_LOG_DEBUG("Starting USB");
    if (USBD_POWER_DETECTION)
        err_code = app_usbd_power_events_enable();
        NRF_LOG_DEBUG("No USB power detection enabled, starting USB now");
        app_usbd_enable();
        app_usbd_start();
    NRF_LOG_DEBUG("USB Transport initialized");
    return err_code;
    return NRF_SUCCESS;
