Is there any AT command to enable/disable HW Flow Control RTS/CTS for nRF9151?
I tried AT+IFC=0,0; AT+IFC=2,2; AT+IFC? commands but getting error.
Thanks
Thanks
The AT command AT+IFC is not supported on the nRF9151, so there isn’t an AT command available to enable or disable hardware flow control (RTS/CTS). Are you using the Serial LTE, or a custom application on the device? What is the specific reason you need to enable or disable RTS/CTS hardware flow control?
Could you share some more details on your use case?
Kind Regards,
Abhijith
Yes, we are using UART. CTS/RTS are at P0.27 and P0.28, respectively. In our case, we plan to test the RTS/CTS signals themselves during production. Is there a way to enable/disable them on the fly without changing the FW?
Thanks.
The Serial Modem add-on doesn't support the AT+IFC command. You would need to add it to the application to be able to change the hardware flow control at runtime.
You can try this fork of the Serial Modem add-on to see if it works for you:
https://github.com/mgolu/ncs-serial-modem/tree/add_at_ifc_command
Mariano
