Error When Reading Characteristic
I am using nRF5 SDK v17.2.0 on a legacy product. I have code that looks like this:
    ret_code_t rc = sd_ble_gatts_rw_authorize_reply(event->evt.common_evt.conn_handle, &authParams);
    if (rc == NRF_SUCCESS)
        NRF_LOG_INFO("Event history - read %d events starting at %d", eventListContent.events().get_length(), originalOffset);
        NRF_LOG_ERROR("Failed to reply to event history read request. RC: %d", rc);
When reading the characteristic repeatedly, I sometimes see something like this printed out:
00> <info> app: Event history - read 8 events starting at 0
00> <info> app: Event history - read 8 events starting at 8
00> <info> app: Event history - read 8 events starting at 16
00> <info> app: Event history - read 8 events starting at 24
00> <info> app: Event history - read 8 events starting at 32
00> <error> app: Failed to reply to event history read request. RC: 8
00> <info> app: Event history - read 8 events starting at 48
00> <info> app: Event history - read 8 events starting at 56
00> <info> app: Event history - read 0 events starting at 64
Return code of 8 corresponds to NRF_ERROR_INVALID_STATE. Why would I get that?
    From the API documenation for sd_ble_gatts_rw_authorize_reply() it can return NRF_ERROR_INVALID_STATE due to "Invalid Connection State or no authorization request pending".
    I assume you would have logged if there was a disconnect, so that is probably not the case? A next step then could be to logg all BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST events and all calls you make to sd_ble_gatts_rw_authorize_reply() to make sure you never call is when there is no active authorize request. If you do, the error is expected.
    Thank you for your reply. My code looks something like this:
    Header file:
    NRF_SDH_BLE_OBSERVER(_name ## _obs, 2, OnBleEvt, &_name)
    Source file:
    void OnBleEvt(ble_evt_t const *event, [[maybe_unused]] void *context)
        ble_gatts_evt_rw_authorize_request_t const *eventAuthorize =
            &event->evt.gatts_evt.params.authorize_request;
        switch (eventAuthorize->type)
        case BLE_GATTS_AUTHORIZE_TYPE_READ:
            switch (eventAuthorize->request.read.uuid.uuid)
            case CTFS_CHAR_EVENT_HISTORY_UUID:
                OnAuthorizeHandleReadEventHistory(event);
            // more characteristics here
    "sd_ble_gatts_rw_authorize_reply()" is called in the "OnAuthorizeHandleReadEventHistory()" up above. So I don't think I'm calling this in a wrong place.
    I am not able to see the larger picture from these snippets. I have also had a look at the SoftDevice implementation, and I believe the two reasons described in he API documentation are the only two possible explanations for getting NRF_ERROR_INVALID_STATE returned from sd_ble_gatts_rw_authorize_reply().
    So my recommendation remain to debug and get a clear picture of when you get the event and when sd_ble_gatts_rw_authorize_reply() is called. Note that sd_ble_gatts_rw_authorize_reply() can be called from SDK code as well (and if it is, you cannot call it again from the same request, as the second call will then fail with NRF_ERROR_INVALID_STATE, as i should as the request is then already handled).
  • My firmware has quite a few characteristics. If some of them are read on an interval, with similar logic in place (sd_ble_gatts_rw_authorize_reply() for each one), would it be possible that more than one read is happening and thus the firmware failing with this error?
  • That should not be the case. Only one authorized read/write operation is allowed at a time per connection. (If your device has multiple concurrent connections there is of perhaps a bigger potential for a mixup here, but I do not know if that is the case?)
  • I did a Wireshark capture while the mobile app was reading the characteristic in a loop. Everything matched up and I did not see anything that would stand out. At the same time, I did see "NRF_ERROR_INVALID_STATE" on the firmware side. I think the idea that "sd_ble_gatts_rw_authorize_reply()" is somehow called twice (or more times) makes sense.
    I searched through the codebase for calls to "OnAuthorizeHandleReadEventHistory" function which is calling the "sd_ble_gatts_rw_authorize_reply()". I only found one result, which is the switch statement I showed earlier.
    Could you explain? I have a custom service / characteristic. How does SDK come into play here?
    sd_ble_gatts_rw_authorize_reply() can be called from quite a few places, depening on which modules you use (it is part of the implementation for servics in the SDK code, and also in the queued write module). I do not have the knowledge about your code to suggest where it could be called in your applicaton, but one way is to simply log at every possible call to sd_ble_gatts_rw_authorize_reply() (search the codebase and add logging), to see where it happens in your application.
