Problem with fstorage and ble active in Release mode
I'm using nRF52832 SoC with nRF5_SDK17.1.0 and SoftDevice v7.3.0. I'm using following code to write data into flash.
 err_code = nrf_fstorage_write(&g_fs, write_addr, buffer32, 128, NULL);
  wait_while_fs_busy(&g_fs);
/* Wait helper: sleep while fstorage is busy (write/erase are async). */
static void wait_while_fs_busy(nrf_fstorage_t const * p_fs)
    uint32_t waited_ms = 0;
    while (nrf_fstorage_is_busy(p_fs))
      if ((p_fs->p_api == &nrf_fstorage_sd) && nrf_sdh_is_enabled())
           __enable_irq();
           __set_BASEPRI(0);
           (void)sd_app_evt_wait();
            __WFE();
      (void)NRF_LOG_PROCESS();
      waited_ms++;
      if (waited_ms > 5000)
         NRF_LOG_ERROR("fstorage wait timeout");
      NRF_LOG_PROCESS();
It works fine when compiled in debug mode.
Whenever it's compiled in release mode and fstorage is used while ble is connected, the code enters 2 to 3 times sd_app_evt_wait(); an then hangs in this function.
Whenever it's compiled in release mode and fstorage is used after ble is disconnected, the code enters sd_app_evt_wait(); and hangs in this function immediately.
--> I guess no event is generated any more or masked.
Why this is happening?
  • Hi
    Sorry, I did not get to testing this further yet. I will follow your instructions and look further into this today. I'll get back to you with more details on Friday at the latest.
    Simon
  • Hi Simon - do you have any news? we have a milestone meeting this afternoon and any info would be helpful...
    Coming back to my question earlier in this topic:  could you provide code where BT communication and fstorage runs in compiled mode. Then we could add our application step by step to it.
    Best
    Stephan
  • Hi Stephan
    Sorry I didn't get back to you yesterday.
    I have done some more testing now, and tried writing and reading the device name characteristic from the nRF Connect for Mobile app, and that seems to work. The Device name (characteristic data) does not change before the device has been reset though, which is expected, since the Bluetooth controller (SoftDevice) needs to reinitialize with the new name for it to take effect, so that might be what you're seeing here.
    It still seems to behave the same in debug mode and release mode to me. Where it advertises for a short amount of time upon starting where I can connect to it and stay connected for as long as I want. The service and characteristic works as expected from what I can see, where you need to uninit and reinitialize the application for the device name changes to take effect. I'm also able to reconnect after connecting -> changing the device name -> resetting the device -> reconnect
    You say you do "Build and debug" and see the name is not changed. This is expected, as that would mean you flash the application with the original device name again when flashing the device in debug mode again. So it's also expected that the registers wouldn't change when you flash the device before going into debug mode.
    Simon
  • Hi Simon - thanks for your effort you made.
    Have you explicitly checked and can you confirm that when programmed with 'Build and Run' the new name (actually the whole 128 byte package of the struct 'dev_block.info') is being written to the flash on a following start address in the same flash page? See the red marked 128 byte block under g) in my previous description from March 23rd.
    Siede note: in a page is space for 32 blocks of 128 byte; we use only 31 blocks.
    The problem is not that the new name is not immediately adopted for BT advertising without a restart. Our issue is that the new name or data is not written into the flash memory in this mode.
    Best
    Stephan
  • Hi Stephan
    No I did not, but I did just now on my end. Please see the readout from the address where the device names are here. Sorry for the weird names, but there are a lot of devices around the office, so I have to name them something I remember to find them when searching. Device name was changed from "ostepop" to "flexboi".
    PS C:\ncs\nrf-bm\v1.0.0> nrfutil device read --address 0x0007D000 --bytes 1000
    682030708
    0x0007D000: 6574736F 00706F70 00003041 00000000   |ostepop.A0......|
    0x0007D010: 00000000 00000000 00000000 00000000   |................|
    0x0007D020: 44414544 46454542 0C0B0A00 100F0E0D   |DEADBEEF........|
    0x0007D030: 14131211 18171615 1C1B1A19 201F1E1D   |............... |
    0x0007D040: 24232221 28272625 2C2B2A29 302F2E2D   |!"#$%&'()*+,-./0|
    0x0007D050: 34333231 38373635 3C3B3A39 403F3E3D   |123456789:;<=>?@|
    0x0007D060: 44434241 00000000 00000000 00000000   |ABCD............|
    0x0007D070: 00000000 00000000 00000000 01451401   |..............E.|
    0x0007D080: 78656C66 00696F62 00003041 00000000   |flexboi.A0......|
    0x0007D090: 00000000 00000000 00000000 00000000   |................|
    0x0007D0A0: 44414544 46454542 0C0B0A00 100F0E0D   |DEADBEEF........|
    0x0007D0B0: 14131211 18171615 1C1B1A19 201F1E1D   |............... |
    0x0007D0C0: 24232221 28272625 2C2B2A29 302F2E2D   |!"#$%&'()*+,-./0|
    0x0007D0D0: 34333231 38373635 3C3B3A39 403F3E3D   |123456789:;<=>?@|
    0x0007D0E0: 44434241 00000000 00000000 00000000   |ABCD............|
    0x0007D0F0: 00000000 00000000 00000000 01451401   |..............E.|
    0x0007D100: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF   |................|
    Simon
