Hi folks,
I want to match my IFA PCB antenna to the nRF8001. As Harald recommended a couple times, I am going to measure the antenna of the final PCB with a Vector Network Analyzer, to be aware of the antennas behavior in the final built-up.
I am sure the antenna will not have a nice 50 Ohms impedance, so I wanted to add a PI matching network to the sample schematic for 50 Ohms output (marked red in the attached picture).
Assuming the antenna is matched then to 50 Ohms, I calculated the Impedance that will be seen when looking towards L3. When I calculated right, it is a nearly non complex value of around 28 Ohms (marked green in the attached picture). I calculated C6 and 50 Ohms load in parallel, all together in series with L3 and C5, omega = 15,08 GHz.
Now comes the questions: Obviously this is a bunch of components. Am I right in assuming, that it is possible to calculate equivalent impedance values between feeding point of L3 and the antenna to construct an equivalent circuit containing less components? By doing this it would be the same to get rid of L3, C5 and C6, and then to match the antenna with the PI network to 28 Ohms. Right? Or is there going to be a problem with the balun structure?
A thing thats seems strange to me: Given the 28 Ohms are correct. How does the impedance seen by the pins ANT1 and ANT2 reach the recommended value of 15+j81 Ohms for maximum output?
Thanks in advance, Carl
