Hi:
There arenot 10uH or 15nH at my board,how can i disable the dcdc in the code?
Hi:
For NCS v2.9.0 and later (which applies to v2.9.1), the DCDC regulator configuration has moved to the device tree rather than Kconfig. You need to add the following to your board overlay file:
®1 {
regulator-initial-mode = <NRF5X_REG_MODE_LDO>;
};Ref: RE: What exactly is required to run USB on an nRF52840 without an external crystal?
Håkon
To disable the DCDC, modify the board file for your custom board to specify using LDO instead like this (you can also put this in an overlay file):
®1 {
};hi, I added the following to the board overlay file:
®1 {
when i power on the board,it don't work.
and when i power on it and connected the jlink,it works well.
what's wrong?
I assume your design does not have an external LFCLK src?
Try setting this to enable internal 32k RC oscillator:
Håkon
