nRF9160's RX no longer receiving data
We've designed our own board based on nRF9160 for main CPU w/ LTE and an nRF52 for BLE. Using BMP for debugging.
I've successfully run several boards through the production process:
- update modem firmware to 1.3.6
- use nrfcredstore to generate certs for use with Azure IoTHub w/ at_client (pre-built merged.hex and zephyr.elf from v2.5.2 that has always worked).
- upload firmware
Everything working great and successfully deployed. These cards were produced and installed around new year 2025/206.
Then one of our boards in the field suddenly "lost" its DPS.  I started working on that. Eventually, I realized I had to regenerate the certs to provision the device again.
So: flashed pre-compiled at_client as part of my provisioning script, but then all went wrong:
- USB-TTL said "the device does not respond to AT commands. Flash at_client"
- console output in Minicom is correct, "Booting nRF Connect"-, "The AT Host sample started", "Ready" -- so TX from board to PC works.
- tried another USB-TTL adapter of the same brand -- note: both have been working previously. (Waveshare TTL/485/422 w/ separate header for TTL, set at 3.3v).
- changed cables, tested with multimeter that there's a connection between TX-terminal on USB-TTL and RX-pin on board.
- did a minicom cross-connection test with USB-TTL RX<->TX, worked
- wrote a small test program that toggled LED when state of the RX pin was modified, which works, so there is no problem with the connection.
- wrote a small test program with IRQ for UART RX. same for polling UART RX.
- wrote a small test program that sent AT commands to the modem (internally) and printed out the communication on serial port ie. minicom, so I know AT->OK, AT+CFUN?->CFUN: 0, etc. works - ie. modem fw good.
- rebooted
- tried another computer
- tried another board. and another. and another. and another.
But the exact same results -- nothing on RX. What gives? I have no idea how to continue from here :(
And each of these boards *did* work just a few months ago, haven't touched them. Obviously cannot update modem firmware either.
macOS, MacBook M1 Pro, if that matters.
