Cannot connect nRF52840DK to PC anymore
I have two nRF52840DK boards that I was working with recently.
PCA10056
3.0.2
2024.33
I flashed one board with a BLE peripheral device code from the nRF connect sample projects. The problem is that for one board, I cannot connect to it through my PC anymore, while the other one works fine.
I am using the IMCU USB port to connect it to the PC, SW9 is set to VDD, SW6 to Default, Vext is set to off, flow control is on. Checking the device manager, there is no change when I connect it. Interestingly the BLE firmware is running correctly since I can see the device when I open the bluetooth interface from my phone, but I am unable to reflash or connect it to the PC.
Holding the reset button, while restarting the board also doesn't help.
Trying nrfutil device recover, returns the error
Error: No devices with requested serial number(s) or trait(s) found
Interestingly, turning on the board without a micro usb cable connected and with the SW9 set to VDD, would make the BLE firmware run and the LEDs are blinking and operating normal.
Switching SW9 to USB, leads to the LEDs 1-4 to blink quickly and faintly, but no more changes. The same setup on the other board work fine and I am able to connect it to the PC. I am not sure what went wrong or how to fix it, could you please help me how to re-establish the connection to the PC again?
