nRF Cloud CoAP connection fails with err -111 (self-signed CA certificate)
I'm developing a custom board based on nRF9151 (similar to Thingy:91X) and trying to connect to nRF Cloud for location services (A-GNSS, Wi-Fi location, Cellular location).
## Environment
- nRF Connect SDK: v3.1.1
- Modem firmware: mfw_nrf91x1_2.0.4
- Board: Custom board with nRF9151 + nRF7002 (Wi-Fi) + GD25LE255E (external flash)
- nRF Cloud Plan: Developer (free)
## What I've done
1. **Claimed the device** using Attestation Token (`AT%ATTESTTOKEN`)
2. **Created Provisioning Rule** with:
- Client Private Key Generation (Succeeded)
- Certificate Signing Request (Succeeded)
- Server Certificate - AWS Root CA (Succeeded)
- Client Certificate - self-signed with my own CA (Succeeded)
3. **Installed certificates** to modem (security tag 16842753):
AT%CMNG=1,16842753 %CMNG: 16842753,0,"..." ← Server Certificate (AWS Root CA) %CMNG: 16842753,1,"..." ← Client Certificate (self-signed) %CMNG: 16842753,2,"..." ← Public Key
4. **Also tried security tag 16** (factory JITP), but it only has Public Key (Type 2), no Client Certificate.
## Problem
Connection to nRF Cloud CoAP always fails with error -111 (ECONNREFUSED):
transport: Connecting to nRF Cloud CoAP with client ID: 50433155-3335-4269-80e2-1a066ffdc628 nrf_cloud_coap_transport: Could not connect to nRF Cloud CoAP server coap.nrfcloud.com, port: 13334. err: -111
## Configuration (prj.conf)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_INTERNAL_UUID=y CONFIG_NRF_CLOUD_COAP_SEC_TAG=16842753
## Questions
1. **Is it possible to use a self-signed CA certificate with the Developer (free) plan?**
- Or do I need Pro/Enterprise plan to register my own CA?
2. **What is the correct provisioning workflow for custom boards (not Nordic DKs)?**
- Nordic DKs come with factory-provisioned certificates, but custom boards don't have them.
3. **Is there an alternative way to provision certificates for custom nRF9151 boards?**
Thank you for your help!
  • Update: Still getting -111 error after nRF Cloud auto-onboarding
    I tried a different approach using the attestation token and "Create new rule for onboarding to nRF Cloud" option as described in the nRF9151 Connect Kit guide.
    Steps I followed:
    1. Flashed nrf_provisioning sample to custom board
    2. Got attestation token using nrf_provisioning token command
    3. In nRF Cloud UI: Claim Device → pasted attestation token → enabled "Create new rule for onboarding to nRF Cloud" → Create Rule and Claim Device
    4. Rebooted device - provisioning completed successfully
    5. nRF Cloud UI shows device status as READY with:
      • Cloud Access Key Generation: Succeeded
      • Server Certificate: Succeeded (Generated for nRF Cloud auto-onboarding)
      • Client Certificate: Succeeded (Generated for nRF Cloud auto-onboarding)
    Verification:
    AT%CMNG=1,16842753
    %CMNG: 16842753,0,"F6EEF665B61C4F9852AC3C84747D0EE92D0E79B24C187ABB7CEEF7A85E173534"
    %CMNG: 16842753,1,"E882E67370D8457A30341D0FC89E1E0E5D95F517263578A1DE547A459E0F1662"
    %CMNG: 16842753,2,"79EB6167AACF3A9333FFA8CF9F15EC351AF898F637499264B94F4F77444D59A0"
    Server CA (Type 0) content is identical to factory-provisioned Thingy:91 X (SEC_TAG 4242):
    • Amazon Root CA 1
    • nRF Cloud CoAP CA
    But still getting -111 error:
    Additional observation:
    • Factory Thingy:91 X with SEC_TAG=4242 → Works ✓
    • Factory Thingy:91 X with SEC_TAG=16842753 (auto-onboarded) → Does NOT work ✗
    • Custom board with SEC_TAG=16842753 (auto-onboarded) → Does NOT work ✗
    It seems like the Client Certificate signed by nRF Cloud auto-onboarding is being rejected during TLS handshake, even though the Server CA is correct.
    Questions:
    1. Is there a difference between factory-provisioned certificates (SEC_TAG 4242) and auto-onboarded certificates (SEC_TAG 16842753)?
    2. Is there any additional configuration needed for auto-onboarded devices to use CoAP?
    3. How can I verify that the Client Certificate is correctly signed and trusted by nRF Cloud?
  • Hello Min Kim,
    You don't need to do the step 3 and 4 that you mention in your ticket description. The auto-onboarding will handle a remote provisioning of your device so please avoid doing it locally.
    Please follow the next steps:
    nrfcredstore <YOUR_PORT> deleteall
    Pascal.
  • Hello Min Kim,
    Do you still need help on this or can we close this ticket?
    Pascal.
