I get the following error when trying to build to target: make: *** No rule to make target `nrf52832_xxaa'. Stop.
I am doing the following on the Blinky Example program: Makefile->Make Targets->Build->(Target) flash nrf52832_xxaa->Build
Check your log. You are building a nrf5141422_xxac firmware. You would have to flash it with: flash nrf5141422_xxac
But if you are using a nrf52832 you should use the folder: examples\peripheral\blinky\pca10040\blank\armgcc
Try building that project and flashing it with: flash nrf52832_xxaa
A FIX! I had this error and I was using the correct hardware and firmware as the other comments suggest. However it was just bonking with that error when I tried to flash the device. Compile was fine. Cleaning the project didn't solve the flashing issue. The solution is....[drum roll please]....right click on the target "flash nrf52832_xxaa" and delete it. Then create a new one with the same name. Seriously. It worked.
