BLE Sample code fails to pair after unpairing
We are running some sample code on the nrf54l15 mcu, specifically:
/modules/lib/memfault-firmware-sdk/examples/nrf-connect-sdk/nrf5/memfault_demo_app
We can connect and pair successfully (with the nRF Memfault iOS app) but then when we unpair on the mobile phone and try to connect again, we get a pairing failure. If we catch this and then call bt_unpair in the pairing_failed callback then after the second connection attempt pairing works. But this is not desirable for the user experience.
shell output with pairing failure debug message:
shell:~$ Connected 73:A8:B8:B1:B2:C5 (random)
Connected: 73:A8:B8:B1:B2:C5 (random)
Remote LMP version 5.3 (0x0c) subversion 0x0276 manufacturer 0x000f
LE Features: 0x000000000001792d
[00:00:39.548,118] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
shell:~$ Security changed: 73:A8:B8:B1:B2:C5 (random) level 2
Identity resolved 73:A8:B8:B1:B2:C5 (random) -> AC:86:A3:07:32:F5 (public)
shell:~$ Pairing completed: AC:86:A3:07:32:F5 (public), bonded: 1
LE conn param updated: int 0x0024 lat 0 to 42
shell:~$ Disconnected, reason 0x13
Disconnected: AC:86:A3:07:32:F5 (public) (reason 0x13)
shell:~$ Connection object available from previous conn. Disconnect is complete!
Advertising successfully started
Connected AC:86:A3:07:32:F5 (public)
Connected: AC:86:A3:07:32:F5 (public)
[00:01:10.565,274] <wrn> bt_l2cap: Ignoring data for unknown channel ID 0x003a
------ this the failure
shell:~$ Security failed: AC:86:A3:07:32:F5 (public) level 1 err 4 BT_SECURITY_ERR_AUTH_REQUIREMENT
Security failed: AC:86:A3:07:32:F5 (public) level 1 reason: Authentication requirements (4)
shell:~$ Pairing failed conn: AC:86:A3:07:32:F5 (public), reason 4 BT_SECURITY_ERR_AUTH_REQUIREMENT
---------- this is where we catch the failure and call bt_unpair
Clearing bond and retrying...
Disconnected, reason 0x16
Disconnected: AC:86:A3:07:32:F5 (public) (reason 0x16)
------ if we try to connect a second time it will work now
Is there away to avoid this issue?
