Probability of HARD FAULT occurring during the BLE connection process
Hi all,
       During the Bluetooth connection process, there is a small probability of the following phenomena occurring (both of which are the same firmware, with the similarity being that I2C will read data every 50ms at this time. I don't know if this will have an impact). In each of these phenomena, there is an assert, but no log corresponding to the number of rows for the asset is seen (CONFIG_RESET_ON_FATAL_ERROR=n  CONFIG_ASSERT=y). Do you have any suggestions for me to eliminate the following phenomena.
     Error Phenomenon 1:
13> [00:08:29.757,840] <err> os: ***** HARD FAULT *****
13> [00:08:29.757,979] <err> os: Fault escalation (see below)
13> [00:08:29.758,123] <err> os: ARCH_EXCEPT with reason 4
13>
13> [00:08:29.758,272] <err> os: r0/a1: 0x00000004 r1/a2: 0x0000013b r2/a3: 0x00000026
13> [00:08:29.758,465] <err> os: r3/a4: 0x00000004 r12/ip: 0x00027961 r14/lr: 0x00056bd7
13> [00:08:29.758,651] <err> os: xpsr: 0x290000f5
13> [00:08:29.758,787] <err> os: Faulting instruction address (r15/pc): 0x0006b164
13> [00:08:29.758,963] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
13> [00:08:29.759,129] <err> os: Fault during interrupt handling
13>
13> [00:08:29.759,271] <err> os: Current thread: 0x200053e0 (main)
13> [00:08:29.759,417] [1;31m<err> os: Halting system[0m
Note:
addr2line -e zephyr.elf -f 0x0006b164
assert_post_action
zephyr/lib/os/assert.c:44
addr2line -e zephyr.elf -f 0x00056bd7
sdc_assertion_handler
nrf/subsys/bluetooth/controller/hci_driver.c:315
  Error Phenomenon 2:
13> [00:03:55.820,388] <err> os: ***** HARD FAULT *****
13> [00:03:55.820,527] <err> os: Fault escalation (see below)
13> [00:03:55.820,671] <err> os: ARCH_EXCEPT with reason 4
13>
13> [00:03:55.820,820] <err> os: r0/a1: 0x00000004 r1/a2: 0x00000133 r2/a3: 0x00000015
13> [00:03:55.821,014] <err> os: r3/a4: 0x00000004 r12/ip: 0x007072a0 r14/lr: 0x0005785f
13> [00:03:55.821,202] <err> os: xpsr: 0x210000f5
13> [00:03:55.821,339] <err> os: Faulting instruction address (r15/pc): 0x0006b164
13> [00:03:55.821,519] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
13> [00:03:55.821,695] <err> os: Fault during interrupt handling
13>
13> [00:03:55.821,846] <err> os: Current thread: 0x20005318 (idle)
13> [00:03:55.822,000] [1;31m<err> os: Halting system[0m
Note:
assert_post_action
addr2line -e zephyr.elf -f 0x0005785f
m_assert_handler
nrf/subsys/mpsl/init/mpsl_init.c:307
V3.1.0,NRF54L15
Looking  forward to your reply!
  • HI
         Sorry for replying to you only now. The reason is that this issue is difficult to reproduce, so it took a long time. During this period, I obtained two phenomena.
        The first phenomenon is that the above logs have not been added yet, but the watchdog has been turned off in order to be able to use VS code to view the scene. However, this time there were no error logs when the problem occurred. Then I connected the board to another computer's jlink  and used the "Attach Debugger to Tager" function of VS code. I saw the following situation, but I cannot analyze it and am not sure if this method of capturing logs is reliable
    JLinkGDBServerCL: =thread-group-added,id="i1" =cmd-param-changed,param="pagination",value="off" arch_system_halt (reason=reason@entry=31) at E:/ncs/v3.1.0/zephyr/kernel/fatal.c:30 30 for (;;) { Program received signal SIGTRAP, Trace/breakpoint trap. arch_system_halt (reason=reason@entry=31) at E:/ncs/v3.1.0/zephyr/kernel/fatal.c:30 30 for (;;) {
        The second phenomenon is that the above log was added to the main, but the watchdog was still turned off, but the device still restarted without any error logs. However, I saw that the reason for the restart was Reset from CPU lockout detected.
        Can you help me explain the above phenomenon, or do you have any suggestions? I have no direction left.
