Getting more information on FATAL ERROR: SecureFault on nRF9151
I'm working with the nRF9151, and I want to get useful information when a NULL pointer dereference happens, as I am used to on other devices. However, when a NULL pointer dereference happens, all I get in my log is
Assert:stdio_init,0x00000060
I read on devacademy that because of TrustZone, I cannot get more info when a NULL pointer dereferences happens. But I cannot choose what errors I encounter, and NULL pointer dereferences are a common bug! Is there really nothing I can do to get e.g. the program counter or something? When I cause a crash in other ways (e.g. __asm__("udf #0");) I get a list of all the registers in the CPU including the PC printed in my terminal.
Any help is appreciated,
-Fridtjof
  • Here is a log showing two power cycles. One where it crashes due to an undefined instruction, giving a nice debug dump, and one where it crashes due to null ptr deref, and doesn't give a nice dump.
    All pins have been configured as non-secure
    Booting TF-M v2.1.1-ncs4-2
    [Sec Thread] Secure image initializing!
    *** Booting nRF Connect SDK v3.0.1-9eb5615da66b ***
    *** Using Zephyr OS v4.0.99-77f865b8f8d0 ***
    [00:00:00.250,671] <inf> main: #########
    [00:00:00.250,671] <inf> main: # Start #
    [00:00:00.250,701] <inf> main: Initialization complete!
    [00:00:01.250,885] <err> os: ***** USAGE FAULT *****
    [00:00:01.250,915] <err> os:   Attempt to execute undefined instruction
    [00:00:01.250,915] <err> os: r0/a1:  0x00000000  r1/a2:  0x00007fff  r2/a3:  0x00000000
    [00:00:01.250,946] <err> os: r3/a4:  0x0002a093 r12/ip:  0x00000001 r14/lr:  0x00023b9f
    [00:00:01.250,946] <err> os:  xpsr:  0x61000000
    [00:00:01.250,976] <err> os: Faulting instruction address (r15/pc): 0x0002045c
    [00:00:01.251,007] <err> os: >>> ZEPHYR FATAL ERROR 36: Unknown error on CPU 0
    [00:00:01.251,037] <err> os: Current thread: 0x2000ce60 (main)
    [00:00:01.308,197] <err> os: Halting system
    [00:00:00.250,732] <inf> main: #########
    [00:00:00.250,762] <inf> main: # Start #
    [00:00:00.250,762] <inf> main: #########
    [00:00:00.250,762] <inf> main: Initialization complete!
    Here is code to reproduce the issue. Line 6 of main.c can be commented in and out to change whether the program crashes with an undefined instruction or a NULL ptr deref.
    0363.sample.zip
    I just tried your sample and I can't reproduce your output. I always get the full crash dump... I tried with NCS 3.0.2 and 3.2.4, and I got the same result in both.
    I just did the following modification to see in which configuration I am.
    main.c : LOG_WRN(...):
    #include <zephyr/kernel.h>
    LOG_MODULE_REGISTER(main);
    #define NULLPTR_CRASH
    int main(void) {
        LOG_INF("#########");
        LOG_INF("# Start #");
        LOG_INF("Initialization complete!");
        k_sleep(K_MSEC(1000));
        #ifdef NULLPTR_CRASH
        LOG_WRN("Crashing by dereferencing NULL pointer...");
        volatile int *a = NULL;
        *a = 0;
        #else
        LOG_WRN("Crashing by executing undefined instruction...");
        __asm__("udf #0");
        /* Main-loop */
        while (true) {
            LOG_INF("Looping...\n");
            k_sleep(K_MSEC(5000));
    prj.conf: CONFIG_LOG_MODE_IMMEDIATE=y
    # UART
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    # Debug
    CONFIG_DEBUG=y
    CONFIG_THREAD_NAME=y
    CONFIG_STACK_USAGE=y
    CONFIG_THREAD_ANALYZER=y
    CONFIG_THREAD_ANALYZER_USE_PRINTK=y
    # Logging / Printing
    CONFIG_LOG=y
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # Watchdog:
    CONFIG_WATCHDOG=y
    CONFIG_WDT_DISABLE_AT_BOOT=n
    My output :
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Image index: 0, Swap type: none
    I: Bootloader chainload address offset: 0x10000
    I: Image version: v0.0.0
    *** Booting nRF Connect SDK v3.2.4-4c3fc0d44534 ***
    *** Using Zephyr OS v4.2.99-9673eec75908 ***
    [00:00:00.264,831] <inf> main: #########
    [00:00:00.270,812] <inf> main: # Start #
    [00:00:00.276,824] <inf> main: #########
    [00:00:00.282,806] <inf> main: Initialization complete!
    [00:00:01.290,802] <wrn> main: Crashing by dereferencing NULL pointer...
    [00:00:01.304,138] <err> os: ***** SECURE FAULT *****
    [00:00:01.309,936] <err> os:   Address: 0x0
    [00:00:01.314,880] <err> os:   Attribution unit violation
    [00:00:01.321,075] <err> os: r0/a1:  0x0002c7e0  r1/a2:  0x00000000  r2/a3:  0x00000000
    [00:00:01.329,925] <err> os: r3/a4:  0x000289e7 r12/ip:  0x0000000f r14/lr:  0x00021173
    [00:00:01.338,745] <err> os:  xpsr:  0x01000000
    [00:00:01.344,055] <err> os: Faulting instruction address (r15/pc): 0x00020498
    [00:00:01.352,081] <err> os: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
    [00:00:01.360,137] <err> os: Current thread: 0x2000c8c0 (main)
    [00:00:01.366,729] <err> os: Halting system
    *** Booting MCUboot v2.3.0-dev-d537e5b5d244 ***
    *** Using nRF Connect SDK v3.2.4-4c3fc0d44534 ***
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.264,678] <inf> main: #########
    [00:00:00.270,629] <inf> main: # Start #
    [00:00:00.276,580] <inf> main: #########
    [00:00:00.282,531] <inf> main: Initialization complete!
    [00:00:01.290,435] <wrn> main: Crashing by executing undefined instruction...
    [00:00:01.301,055] <err> os: ***** USAGE FAULT *****
    [00:00:01.306,793] <err> os:   Attempt to execute undefined instruction
    [00:00:01.314,239] <err> os: r0/a1:  0x0002c7e4  r1/a2:  0x00000000  r2/a3:  0x00000000
    [00:00:01.323,059] <err> os: r3/a4:  0x000289e7 r12/ip:  0x0000000f r14/lr:  0x00021173
    [00:00:01.331,878] <err> os:  xpsr:  0x01000000
    [00:00:01.337,188] <err> os: Faulting instruction address (r15/pc): 0x00020498
    [00:00:01.345,245] <err> os: >>> ZEPHYR FATAL ERROR 36: Unknown error on CPU 0
    [00:00:01.353,271] <err> os: Current thread: 0x2000c8c0 (main)
    [00:00:01.359,893] <err> os: Halting system
    I believe there must be a difference in how we build the project. Can you try using nRF Connect for VS Code extension ?
    Simon D-M
  • I installed Code and the nRF extension, and have managed to build and flash an image with NCS v3.0.2. I still get the different outputs. I modified my code so that it is random whether it crashes due to udf or null ptr to make testing faster.
    I notice that your output also has a bootloader info log which I don't have.
    Something else: When it crashes, the device locks up and needs to be recovered.
    Here is the build command that the VS Code extension uses on a pristine build. Maybe we can compare?
    west build --build-dir <project path>/app/build <project path>/app --pristine --board nrf9151dk/nrf9151/ns -- -DCONF_FILE="prj.conf" -DDTC_OVERLAY_FILE="boards/myboard.overlay" -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dapp_DEBUG_THREAD_INFO=On -Dmcuboot_DEBUG_THREAD_INFO=Off
    Output:
    *** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
    *** Using Zephyr OS v4.0.99-f791c49f492c ***
    [00:00:00.259,674] <inf> main: #########
    [00:00:00.264,434] <inf> main: # Start #
    [00:00:00.269,195] <inf> main: #########
    [00:00:00.273,956] <inf> main: Initialization complete!
    [00:00:00.280,731] <wrn> main: Crashing due to Undefined Instruction...
    [00:00:01.288,787] <err> os: ***** USAGE FAULT *****
    [00:00:01.294,342] <err> os:   Attempt to execute undefined instruction
    [00:00:01.301,574] <err> os: r0/a1:  0x00000000  r1/a2:  0x00007fff  r2/a3:  0x00000000
    [00:00:01.310,180] <err> os: r3/a4:  0x00027fb5 r12/ip:  0x00000001 r14/lr:  0x000232cb
    [00:00:01.318,756] <err> os:  xpsr:  0x61000000
    [00:00:01.323,944] <err> os: Faulting instruction address (r15/pc): 0x000204e8
    [00:00:01.331,756] <err> os: >>> ZEPHYR FATAL ERROR 36: Unknown error on CPU 0
    [00:00:01.339,599] <err> os: Current thread: 0x2000c938 (main)
    [00:00:01.346,038] <err> os: Halting system
    [00:00:00.280,731] <wrn> main: Crashing due to NULL PTR...
    Code:
    #include <zephyr/random/random.h>
    int main(void) {
        int rand = sys_rand32_get();
        if (rand % 2 == 0) {
            LOG_WRN("Crashing due to NULL PTR...");
            *a = 0;
        } else {
            LOG_WRN("Crashing due to Undefined Instruction...");
            __asm__("udf #0");
        /* Main-loop */
        while (true) {
    prj.conf:
    # Random
    CONFIG_ENTROPY_GENERATOR=y
    # UART
    CONFIG_SERIAL=y
    # Debug
    CONFIG_DEBUG=y
    CONFIG_LOG=y
    CONFIG_CONSOLE=y
    Ok, I was able to reproduce your issue if I use your overlay. I think I found what is happening...
    I wasn't using your overlay file before as I was testing on an nRF9151 DK, but then the difference between the two configuration was that I was using UART0 and you were using UART1. (This is also why I had some more MCUboot logs)
    By default, the UART1 is used as the "secure" UART and to get the error logs of a Usage fault, you need a non-secure UART.
    To make the UART1 non-secure, you can add the config CONFIG_TFM_SECURE_UART0=y so that the UART0 will become the secure one, thus releasing the UART1.
    prj.conf:
    # Random
    # UART
    CONFIG_SERIAL=y
    # Debug
    CONFIG_DEBUG=y
    CONFIG_LOG=y
    CONFIG_CONSOLE=y
    Please, tell me if this worked for you too!
    Simon D-M
  • I can successfully get the full crash dump in the NULL PTR case if I either implement your change, setting the secure uart to uart0; or setting the log uart to 0.
    Is there any other differences between the UARTs on nrf9151 that I should keep in mind when choosing which one to use for what? In the PS it seems like they are pretty much interchangable.
