nRF52833: MTU Exchange Fails and Connection Terminates
Hello Team,
     I am working with nRF52833 configured as a BLE scanner using nRF Connect SDK for VS Code.
Here is my prj.conf:
# Copyright (c) 2018 Nordic Semiconductor
# ─── UART (Async, no console) ───────────────────────────────────────────────
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
# ─── FOR UART STOP and RESTART AT RUNTIME WHEN UART RX ERROR EVT TRIGGERS ─────────────────────
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
# ─── BLE Stack (Central / Scanner) ──────────────────────────────────────────
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_SMP=y
# BLE NCS modules
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_GATT_DM=y
# MTU / buffer sizing for 40-byte chunks
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
# BLE stack sizes
CONFIG_BT_RX_STACK_SIZE=4096
# Reduce BLE log noise — only errors
CONFIG_BT_LOG_LEVEL_ERR=y
# ─── Stack / Heap ────────────────────────────────────────────────────────────
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=4096
# ─── RTT Logging (no UART backend) ──────────────────────────────────────────
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=y
# 23rd March 2026, RTT BUFFER SIZE increased for crash log capture
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
# ─── GPIO / SPI (needed for nRF21540 FEM) ───────────────────────────────────
CONFIG_GPIO=y
CONFIG_SPI=y
# ─── RTC Calendar ────────────────────────────────────────────────────────────
CONFIG_RTC=y
CONFIG_RTC_UPDATE=y
# ─── Watchdog ────────────────────────────────────────────────────────────────
CONFIG_WATCHDOG=y
CONFIG_REBOOT=y
# ─── Clock (RC low-frequency, 500 ppm) ───────────────────────────────────────
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
# ─── Range Extender: nRF21540 FEM ────────────────────────────────────────────
CONFIG_MPSL=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB=20
CONFIG_MPSL_FEM_POWER_MODEL=y
CONFIG_MPSL_FEM_POWER_MODEL_NRF21540_USE_BUILTIN=y
CONFIG_BT_CTLR_TX_PWR_ANTENNA=20
# ─── Assert ──────────────────────────────────────────────────────────────────
CONFIG_ASSERT=y
# ─── Heap runtime stats (optional, useful for debugging) ─────────────────────
CONFIG_SYS_HEAP_RUNTIME_STATS=y
# ─────────── prj.conf ADDDED ON -> 9th MARCH for CRC CHECK ──────────────────────
CONFIG_CRC=y
# ─── Fatal Error Debugging 10th MARCH 2026, ───────────────────────────────────────────────────
CONFIG_RESET_ON_FATAL_ERROR=n       # Prevent immediate reboot so output is visible
CONFIG_THREAD_NAME=y                # Show thread name (e.g. "main") instead of "unknown"
CONFIG_ASSERT=y
CONFIG_ASSERT_VERBOSE=y
CONFIG_ASSERT_NO_COND_INFO=n
CONFIG_ASSERT_NO_MSG_INFO=n
# Stack overflow detection
CONFIG_HW_STACK_PROTECTION=y
CONFIG_INIT_STACKS=y
# Immediate logging ensures crash logs are flushed before halt
CONFIG_LOG_MODE_IMMEDIATE=y
#────────────────────────────  THREAD ANALYZER FOR STACK OVERFLOW DETECTION ──────────────────────
#CONFIG_THREAD_NAME=y
#CONFIG_THREAD_ANALYZER=y
#CONFIG_THREAD_ANALYZER_AUTO=y
#CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y
#CONFIG_THREAD_ANALYZER_USE_LOG=y
#CONFIG_THREAD_ANALYZER_AUTO_INTERVAL=30
#CONFIG_THREAD_ANALYZER_AUTO_STACK_SIZE=2048
#CONFIG_INIT_STACKS=y
AND here is scan/conn Implementaion:
static void discovery_work_handler(struct k_work *work);
static void scan_filter_match(struct bt_scan_device_info *device_info,
    struct bt_scan_filter_match *filter_match,
    bool connectable) {
    bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
   LOG_INF("Filters matched. Address: %s connectable: %d RSSI: %d",addr, connectable, device_info->recv_info->rssi);
  //LOG_INF("Filters matched. ");
 static void scan_connecting_error(struct bt_scan_device_info *device_info)
   // LOG_WRN("Connecting failed");
 static void scan_connecting(struct bt_scan_device_info *device_info,
				   struct bt_conn *conn) {
	 default_conn = bt_conn_ref(conn);
     /* Print pointer value (for debugging) */
    LOG_INF("default_conn pointer: %p in scan_connecting", (void *)default_conn);
 BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
    scan_connecting_error, scan_connecting);
/* Explicit scan parameters: timeout = 0 => infinite scan */
static struct bt_le_scan_param scan_param = {
    .type     = BT_LE_SCAN_TYPE_ACTIVE,
    .options  = BT_LE_SCAN_OPT_NONE,
    .interval = BT_GAP_SCAN_FAST_INTERVAL,
    .window   = BT_GAP_SCAN_FAST_WINDOW,
    .timeout  = 0,   /* infinite scanning */
    static int scan_init(void) {
        int err;
        struct bt_scan_init_param scan_init = {
        .connect_if_match = 1,  //1, // 4th FEB 2026
        .scan_param       = &scan_param,   /* use our params */
        .conn_param       = NULL,          /* BT_LE_CONN_PARAM_DEFAULT */
		bt_scan_init(&scan_init);
		bt_scan_cb_register(&scan_cb);
		err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
		if (err) {
			//LOG_ERR("Scanning filters cannot be set (err %d)", err);
			return err;
		err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
		if (err) {
			//LOG_ERR("Filters cannot be turned on (err %d)", err);
			return err;
		//LOG_INF("Scan module initialized");
		return err;
 /* Connection Callbacks */
 BT_CONN_CB_DEFINE(conn_callbacks) = {
	 .connected = on_connected,
	 .disconnected = on_disconnected,
	 .security_changed = on_security_changed
    if (discovery_conn) {
        int err = start_discovery(discovery_conn);
        if (err) {
            LOG_ERR("start_discovery from work failed (err %d)", err);
 static uint8_t custom_uart_notify(struct bt_conn *conn,
	struct bt_gatt_subscribe_params *params,
	const void *data, uint16_t len) {
	static uint8_t frame_checksum = 0;
	static uint32_t total_bytes_received = 0;
	if (conn) {
     LOG_INF("  DATA LEN : %d",len);
	if (!data) {
		received_frames = 0;
		frame_checksum = 0;
		return BT_GATT_ITER_CONTINUE;
	if (len != FRAME_SIZE) {
		//LOG_ERR("Invalid frame size: %d (expected %d)", len, FRAME_SIZE);
	if (received_frames >= TOTAL_FRAMES) {
		//LOG_WRN("Received extra frame (already have %d frames)", received_frames);
	uint8_t current_checksum = 0;
	for (int i = 0; i < len; i++) {
		current_checksum += ((const uint8_t *)data)[i];
	memcpy(&full_data[received_frames * FRAME_SIZE], data, len);
	received_frames++;
	total_bytes_received += len;
	frame_checksum += current_checksum;
	if (received_frames == TOTAL_FRAMES) {
        uint16_t current_packet_counter = ((full_data[13] << 8) | full_data[14]);
        uint32_t print_epoch_from_tag = ((full_data[15] << 24) | (full_data[16] << 16) | (full_data[17] << 8) | full_data[18]);
        for(int i=1;i<10;i++)
          current_device_name[i-1] =  full_data[i];
        current_device_name[9] = '\0';
        //LOG_INF("*********************************  Device name : %s PACKET COUNTER : %d and epoch_from_tag : %d ***************************",current_device_name,current_packet_counter,print_epoch_from_tag);
		LOG_INF("Name: %s, PKT CNTR: %d, epoch: %d",current_device_name,current_packet_counter,print_epoch_from_tag);
		        frame_checksum = 0;
                data_non_empty_check = true;
                memset(&full_data,0,sizeof(full_data));
                memset(&current_device_name,0,sizeof(current_device_name));
                current_packet_counter = 0;  // 30th DEC 2025, Clear Variable for next cycle
                //21th JAN 2026, Added to terminate ble connection from scanner side, need to test contineously.
                if (epoch_wr_counter_check >= LOGS_PER_WRITE)
                    central_terminate_ble_conn_flag = true;
 static int bt_custom_subscribe_receive(struct bt_custom_client *custom)
	 static struct bt_gatt_subscribe_params subscribe_params;
	 if (!custom || !custom->conn || !custom->value_handle || !custom->cccd_handle)
		 //LOG_ERR("Invalid custom client parameters");
		 return -EINVAL;
	 memset(&subscribe_params, 0, sizeof(subscribe_params));
	 subscribe_params.value_handle = custom->value_handle;
	 subscribe_params.ccc_handle = custom->cccd_handle;
	 subscribe_params.notify = custom_uart_notify;
	 subscribe_params.value = BT_GATT_CCC_NOTIFY;
     int err = bt_gatt_subscribe(custom->conn, &subscribe_params);
     if (err)
		 LOG_ERR("Subscription failed: %d", err);
		 return err;
     LOG_INF("bt_gatt_subscribe err code: %d",err);
	 return 0;
 static uint8_t discover_func(struct bt_conn *conn,
	 const struct bt_gatt_attr *attr,
	 struct bt_gatt_discover_params *params)
	 int err;
	 if (!attr) {
		//LOG_INF("Discovery complete in discover function");
		// Assign discovered handles to your client structure
		my_custom_client.conn = conn;
		my_custom_client.value_handle = my_char_handle;   // Set during characteristic discovery
		my_custom_client.cccd_handle  = my_cccd_handle;   // Set during descriptor discovery
		/*if (bt_custom_subscribe_receive(&my_custom_client)) {
			LOG_INF("Subscription to custom characteristic failed");
    int sub_char_err = bt_custom_subscribe_receive(&my_custom_client);
    if (sub_char_err)
      LOG_ERR("Subscription to custom characteristic failed (err: %d)", sub_char_err);
		return BT_GATT_ITER_STOP;
	if (params->type == BT_GATT_DISCOVER_PRIMARY)
		struct bt_gatt_service_val *svc = (struct bt_gatt_service_val *)attr->user_data;
		LOG_INF("Found service, start_handle: 0x%04x, end_handle: 0x%04x", attr->handle, svc->end_handle);
		discover_params.uuid = NULL; // Discover all characteristics
		discover_params.start_handle = attr->handle + 1;
		discover_params.end_handle = svc->end_handle;
		discover_params.type = BT_GATT_DISCOVER_CHARACTERISTIC;
		discover_params.func = discover_func;
		err = bt_gatt_discover(conn, &discover_params);
		if (err) {
			LOG_INF("Characteristic discovery failed (err %d)", err);
    else if (params->type == BT_GATT_DISCOVER_CHARACTERISTIC)
		struct bt_gatt_chrc *chrc = (struct bt_gatt_chrc *)attr->user_data;
		//LOG_INF("Characteristic UUID type: 0x%x", chrc->uuid->type);
		my_char_handle = chrc->value_handle;
		LOG_INF("Characteristic handle: 0x%04x", my_char_handle);
		// Start descriptor (CCCD) discovery for this characteristic
		discover_params.uuid = BT_UUID_GATT_CCC;
		discover_params.start_handle = my_char_handle + 1;
		discover_params.end_handle = params->end_handle;
		discover_params.type = BT_GATT_DISCOVER_DESCRIPTOR;
		if (err) {
			LOG_INF("Descriptor discovery failed (err %d)", err);
    else if (params->type == BT_GATT_DISCOVER_DESCRIPTOR)
		// Check if this is the CCCD
		if (bt_uuid_cmp(attr->uuid, BT_UUID_GATT_CCC) == 0) {
			my_cccd_handle = attr->handle;
			LOG_INF("CCCD handle: 0x%04x", my_cccd_handle);
		// Continue to next attribute if needed
 //static
 int start_discovery(struct bt_conn *conn)
	 int err;
	 //LOG_INF("Starting discovery for custom UUID");
     // Print the conn pointer address to confirm it is non-NULL
    LOG_INF("start_discovery: conn pointer = %p", (void *)conn);
	 char uuid_str[37];
	 bt_uuid_to_str(&custom_uart_uuid.uuid, uuid_str, sizeof(uuid_str));
	 //LOG_INF("Custom UUID: %s", uuid_str);
	 discover_params.uuid = &custom_uart_uuid.uuid;
	 discover_params.start_handle = BT_ATT_FIRST_ATTRIBUTE_HANDLE;
	 discover_params.end_handle = BT_ATT_LAST_ATTRIBUTE_HANDLE;
	 discover_params.type = BT_GATT_DISCOVER_PRIMARY;
	 if (err) {
		 LOG_ERR("Custom service discovery failed (err %d)", err);
		 return err;
	 return 0;
 static void exchange_func(struct bt_conn *conn, uint8_t err,struct bt_gatt_exchange_params *params)
    if (!err) {
        uint16_t mtu = bt_gatt_get_mtu(conn);
        LOG_INF("Negotiated MTU size is: %d", mtu);
    } else {
        LOG_WRN("MTU exchange failed (err %" PRIu8 "), proceeding with default MTU", err);
    // Defer discovery to system workqueue (outside BT RX thread)
    discovery_conn = conn;
    k_work_submit(&discovery_work);
 void on_connected(struct bt_conn *conn, uint8_t err) {
    ble_evt_in_process_flag = true; // 8th JAN 2026, added to check ble event for scan timer timeout execution
	 if (err) {
        LOG_INF("Conn fail err code: %d",err);
		 if (default_conn == conn)
			LOG_INF("default_conn pointer: %p in on_Connected", (void *)default_conn);
            bt_conn_unref(default_conn);
			default_conn = NULL;
         ble_connection_error_flag = true; // 31st DEC 2025
		 return;
     LOG_INF("--------------------  CONNECTED to BLE DEVICE ---------------------");
     int scan_stop_err = bt_scan_stop();
     if (scan_stop_err == -EALREADY)
        LOG_INF(" ################# scan already stop (err %d)", scan_stop_err);
	 static struct bt_gatt_exchange_params exchange_params;
	 exchange_params.func = exchange_func;
	 err = bt_gatt_exchange_mtu(conn, &exchange_params);
	 LOG_INF("MTU exchange request (err %d)", err);
 static void on_disconnected(struct bt_conn *conn, uint8_t reason) {
   LOG_INF(" -------------------- Disconnected... (reason 0x%02x) -------------------------", reason);
    // Reset state and clean up
    my_char_handle = 0;
    my_cccd_handle = 0;
    ble_data_ready_flag = true;
Expected Execution Sequence:
  1. Scanner starts scanning for nearby devices
  2. Filters device based on matching service UUID
  3. Initiates connection upon match
  4. On successful connection:
    • MTU exchange request is initiated
    • On MTU exchange callback → start service discovery
    • On discovery completion → subscribe to characteristic
    • Connected tag sends data log
Data Transfer Details:
  • Total log size: 1040 bytes
  • Sent in 26 frames
  • Each frame: 40 bytes
Issue Observed:
  • Occasionally, the full data log is received successfully
  • However, most of the time, device disconnecting as:
    • MTU exchange fails, Error 0x3E (Connection Failed to be Established / Timeout)
    • MTU exchnage and sunscription succ, Error 0x13 (Remote User Terminated Connection)
  • RTT logs (showing both successful and failing cases)
00> *** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
00> *** Using Zephyr OS v3.7.99-ca954a6216c9 ***
00> [00:00:00.002,471] <inf> combined_ble:
00>
00>
00>
00> [00:00:00.011,352] <inf> combined_ble: Bluetooth initialized initially...
00> [00:00:00.011,779] <inf> combined_ble: UART_RX_BUF_REQUEST
00> [00:00:00.012,115] <inf> combined_ble: uart_init returns err code : 0
00> [00:00:00.014,160] <inf> combined_ble:  Scan Resume err code : 0
00> [00:00:23.358,306] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -66
00> [00:00:23.362,304] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:00:23.381,774] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:00:23.383,087] <inf> combined_ble: MTU exchange request (err 0)
00> [00:00:23.583,343] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:00:23.683,319] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:00:23.783,721] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:00:23.883,300] <inf> combined_ble: CCCD handle: 0x0013
00> [00:00:23.883,758] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:00:24.233,581] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.234,466] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.283,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.333,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.383,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.433,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.483,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.533,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.583,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.633,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.683,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.733,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.883,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.933,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.983,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.033,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.083,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.133,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.183,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.283,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.333,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.383,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.433,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.483,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.533,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.583,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.583,984] <inf> combined_ble: Name: S1IAD1902, PKT CNTR: 9105, epoch: 1774530000
00> [00:00:27.633,148] <inf> combined_ble:   DATA LEN : 0
00> [00:00:27.633,514] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:00:00.014,312] <inf> combined_ble:  Scan Resume err code : 0
00> [00:00:07.774,078] <inf> combined_ble: Filters matched. Address: E4:36:13:61:FA:F1 (random) connectable: 0 RSSI: -75
00> [00:00:07.777,496] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:00:07.805,419] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:00:07.806,732] <inf> combined_ble: MTU exchange request (err 0)
00> [00:00:08.056,976] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:00:08.057,342] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:00:08.156,951] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:00:08.357,299] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:00:08.506,958] <inf> combined_ble: CCCD handle: 0x0013
00> [00:00:08.507,385] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:00:08.657,226] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.658,111] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.707,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.757,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.807,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.857,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.907,287] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.957,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.007,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.057,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.107,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.157,257] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.207,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.257,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.307,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.357,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.407,287] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.457,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.507,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.557,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.607,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.657,257] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.757,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.807,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.857,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.907,257] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.907,623] <inf> combined_ble: Name: S1IAD1640, PKT CNTR: 1454, epoch: 1774530000
00> [00:00:11.956,787] <inf> combined_ble:   DATA LEN : 0
00> [00:00:11.957,153] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:00:12.028,747] <inf> combined_ble:  Scan Resume err code : 0
00> [00:00:12.029,113] <inf> combined_ble:
00>
00>
00>
00>
00> [00:01:32.874,420] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -66
00> [00:01:32.876,892] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:32.897,308] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:01:32.898,590] <inf> combined_ble: MTU exchange request (err 0)
00> [00:01:33.148,895] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:01:33.149,291] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:01:33.149,749] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:01:33.150,268] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:01:33.212,829] <inf> combined_ble:  Scan Resume err code : 0
00> [00:01:33.213,195] <inf> combined_ble:
00>
00>
00>
00>
00> [00:01:38.499,298] <inf> combined_ble: Filters matched. Address: DC:BF:AF:86:1F:0E (random) connectable: 0 RSSI: -70
00> [00:01:38.505,981] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:41.507,904] <inf> combined_ble: Conn fail err code: 2
00> [00:01:41.508,270] <inf> combined_ble: default_conn pointer: 0x20002d18 in on_Connected
00> [00:01:41.523,010] <inf> combined_ble:  Scan Resumed err code : 0
00> [00:01:42.030,883] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -68
00> [00:01:42.035,430] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:42.055,511] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:01:42.056,823] <inf> combined_ble: MTU exchange request (err 0)
00> [00:01:42.307,098] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:01:42.307,495] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:01:42.307,983] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:01:42.308,502] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:01:42.326,446] <inf> combined_ble:  Scan Resume err code : 0
00> [00:01:42.326,812] <inf> combined_ble:
00>
00>
00>
00>
00> [00:01:42.346,130] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -71
00> [00:01:42.349,578] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:42.373,321] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:01:42.374,633] <inf> combined_ble: MTU exchange request (err 0)
00> [00:01:42.774,810] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:01:42.775,207] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:01:42.874,938] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:01:42.975,128] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:01:43.124,847] <inf> combined_ble: CCCD handle: 0x0013
00> [00:01:43.125,274] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:01:43.274,658] <inf> combined_ble:   DATA LEN : 0
00> [00:01:43.275,054] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:01:43.330,352] <inf> combined_ble:  Scan Resume err code : 0
00> [00:01:43.330,718] <inf> combined_ble:
00>
00>
00>
00>
00> [00:02:11.426,574] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -73
00> [00:02:11.428,527] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:02:11.457,458] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:02:11.458,770] <inf> combined_ble: MTU exchange request (err 0)
00> [00:02:11.709,045] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:02:11.709,442] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:02:11.709,930] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:02:11.710,449] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:02:11.762,542] <inf> combined_ble:  Scan Resume err code : 0
00> [00:02:11.762,908] <inf> combined_ble:
00>
00>
00>
00>
00> [00:02:11.827,209] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -75
00> [00:02:11.830,688] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:02:11.857,421] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:02:11.858,734] <inf> combined_ble: MTU exchange request (err 0)
00> [00:02:12.109,008] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:02:12.109,405] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:02:12.109,893] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:02:12.110,412] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:02:12.165,863] <inf> combined_ble:  Scan Resume err code : 0
00> [00:02:12.166,229] <inf> combined_ble:
00>
00>
00>
00>
00> [00:02:21.975,708] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -67
00> [00:02:21.978,240] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:02:24.980,163] <inf> combined_ble: Conn fail err code: 2
00> [00:02:24.980,529] <inf> combined_ble: default_conn pointer: 0x20002d18 in on_Connected
00> [00:02:24.982,971] <inf> combined_ble:  Scan Resumed err code : 0
00> [00:03:02.798,858] <inf> combined_ble: Filters matched. Address: E4:36:13:61:FA:F1 (random) connectable: 0 RSSI: -73
00> [00:03:02.801,147] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:03:02.824,401] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:03:02.825,714] <inf> combined_ble: MTU exchange request (err 0)
00> [00:03:03.075,988] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:03:03.076,385] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:03:03.076,873] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:03:03.077,392] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:03:03.123,596] <inf> combined_ble:  Scan Resume err code : 0
00> [00:03:03.123,962] <inf> combined_ble:
00>
00>
00>
00>
00> [00:03:05.355,743] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -64
00> [00:03:05.361,755] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:03:05.378,845] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:03:05.380,157] <inf> combined_ble: MTU exchange request (err 0)
00> [00:03:05.630,462] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:03:05.630,828] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:03:05.631,317] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:03:05.631,835] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:03:05.729,095] <inf> combined_ble:  Scan Resume err code : 0
00> [00:03:05.729,461] <inf> combined_ble:
00>
00>
00>
00>
00> [00:03:05.750,457] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -73
00> [00:03:05.752,227] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:03:05.773,315] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:03:05.774,627] <inf> combined_ble: MTU exchange request (err 0)
00> [00:03:06.024,871] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:03:06.025,238] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:03:06.174,835] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:03:06.275,238] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:03:06.374,847] <inf> combined_ble: CCCD handle: 0x0013
00> [00:03:06.375,274] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:03:06.625,122] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.625,976] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.675,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.725,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.775,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.825,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.875,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.925,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.975,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.025,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.075,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.125,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.175,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.225,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.275,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.325,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.375,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.425,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.475,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.525,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.575,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.625,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.675,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.725,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.775,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.825,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.825,500] <inf> combined_ble: Name: S1IAD1885, PKT CNTR: 7646, epoch: 1774529400
00> [00:03:09.874,664] <inf> combined_ble:   DATA LEN : 0
00> [00:03:09.875,030] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:03:09.936,126] <inf> combined_ble:  Scan Resume err code : 0
00> [00:03:09.936,492] <inf> combined_ble:
00>
00>
00>
00>
00> [00:04:27.888,671] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -68
00> [00:04:27.894,287] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:04:27.915,344] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:04:27.916,687] <inf> combined_ble: MTU exchange request (err 0)
00> [00:04:28.116,912] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:04:28.117,279] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:04:28.216,888] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:04:28.317,291] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:04:28.416,900] <inf> combined_ble: CCCD handle: 0x0013
00> [00:04:28.417,327] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:04:28.767,181] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.768,035] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.817,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.867,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.967,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.017,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.067,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.117,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.167,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.217,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.317,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.367,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.417,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.467,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.517,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.567,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.617,218] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.667,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.717,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.767,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.817,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.867,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.917,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.017,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.067,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.117,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.117,553] <inf> combined_ble: Name: S1IAD1902, PKT CNTR: 9105, epoch: 1774530000
00> [00:04:32.166,717] <inf> combined_ble:   DATA LEN : 0
00> [00:04:32.167,083] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:04:32.220,703] <inf> combined_ble:  Scan Resume err code : 0
00> [00:04:32.221,069] <inf> combined_ble:
00>
00>
00>
00>
00> [00:04:37.027,069] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -71
00> [00:04:37.028,869] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:04:37.045,806] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:04:37.047,119] <inf> combined_ble: MTU exchange request (err 0)
00> [00:04:37.397,308] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:04:37.397,705] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:04:37.497,436] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:04:37.597,625] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:04:37.697,357] <inf> combined_ble: CCCD handle: 0x0013
00> [00:04:37.697,784] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:04:37.897,613] <inf> combined_ble:   DATA LEN : 40
00> [00:04:37.898,498] <inf> combined_ble:   DATA LEN : 40
00> [00:04:37.947,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:37.997,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.047,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.097,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.147,674] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.197,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.247,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.297,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.347,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.397,644] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.447,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.497,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.547,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.597,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.647,674] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.697,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.747,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.847,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.897,674] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.947,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.997,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.047,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.097,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.147,644] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.148,010] <inf> combined_ble: Name: S1IAD1588, PKT CNTR: 1454, epoch: 1774530000
00> [00:04:41.197,174] <inf> combined_ble:   DATA LEN : 0
00> [00:04:41.197,540] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:04:41.232,727] <inf> combined_ble:  Scan Resume err code : 0
00> [00:04:41.233,093] <inf> combined_ble:
00>
00>
00>
00>
00> [00:05:06.514,251] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -90
00> [00:05:06.520,874] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:05:06.533,538] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:05:06.534,851] <inf> combined_ble: MTU exchange request (err 0)
00> [00:05:06.785,125] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:05:06.785,522] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:05:06.786,010] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:05:06.786,529] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:05:06.861,541] <inf> combined_ble:  Scan Resume err code : 0
00> [00:05:06.861,907] <inf> combined_ble:
00>
00>
00>
00>
00> [00:06:32.020,843] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -71
00> [00:06:32.024,719] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:06:32.048,004] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:06:32.049,316] <inf> combined_ble: MTU exchange request (err 0)
00> [00:06:32.299,591] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:06:32.299,987] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:06:32.300,476] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:06:32.300,994] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:06:32.349,822] <inf> combined_ble:  Scan Resume err code : 0
00> [00:06:32.350,189] <inf> combined_ble:
00>
00>
00>
00>
00> [00:06:32.359,039] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -70
00> [00:06:32.361,907] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:06:32.384,704] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:06:32.385,986] <inf> combined_ble: MTU exchange request (err 0)
00> [00:06:32.636,291] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:06:32.636,657] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:06:32.637,145] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:06:32.637,664] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:06:32.653,045] <inf> combined_ble:  Scan Resume err code : 0
00> [00:06:32.653,411] <inf> combined_ble:
00>
00>
00>
00>
00> [00:06:32.670,288] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -68
00> [00:06:32.676,208] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:06:32.690,795] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:06:32.692,108] <inf> combined_ble: MTU exchange request (err 0)
00> [00:06:32.992,309] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:06:32.992,675] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:06:33.092,437] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:06:33.192,626] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:06:33.292,327] <inf> combined_ble: CCCD handle: 0x0013
00> [00:06:33.292,755] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:06:33.542,602] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.543,487] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.592,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.642,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.742,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.792,633] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.842,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.892,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.942,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.992,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.092,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.142,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.192,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.242,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.292,633] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.342,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.392,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.442,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.492,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.542,633] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.592,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.642,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.842,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.892,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.942,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.992,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.993,011] <inf> combined_ble: Name: S1IAD1876, PKT CNTR: 9101, epoch: 1774530000
00> [00:06:37.042,175] <inf> combined_ble:   DATA LEN : 0
00> [00:06:37.042,541] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:06:37.060,272] <inf> combined_ble:  Scan Resume err code : 0
00> [00:06:37.060,638] <inf> combined_ble:
00>
00>
00>
00>
00> [00:07:12.610,198] <inf> combined_ble: Filters matched. Address: E4:36:13:61:FA:F1 (random) connectable: 0 RSSI: -76
00> [00:07:12.612,670] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:07:12.628,509] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:07:12.629,821] <inf> combined_ble: MTU exchange request (err 0)
00> [00:07:12.880,096] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:07:12.880,493] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:07:12.880,981] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:07:12.881,500] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:07:12.898,803] <inf> combined_ble:  Scan Resume err code : 0
00> [00:07:12.899,169] <inf> combined_ble:
00>
00>
00>
00>
00> [00:08:37.878,631] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -77
00> [00:08:37.881,988] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:37.907,287] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:08:37.908,630] <inf> combined_ble: MTU exchange request (err 0)
00> [00:08:38.108,856] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:08:38.109,222] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:08:38.258,850] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:08:38.359,252] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:08:38.458,831] <inf> combined_ble: CCCD handle: 0x0013
00> [00:08:38.459,289] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:08:38.759,124] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.759,979] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.809,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.859,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.909,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.959,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.009,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.059,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.109,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.209,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.309,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.359,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.409,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.509,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.609,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.659,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.709,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.759,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.809,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.859,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.909,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.959,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.009,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.059,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.109,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.159,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.159,515] <inf> combined_ble: Name: S1IAD1902, PKT CNTR: 9105, epoch: 1774530000
00> [00:08:42.258,666] <inf> combined_ble:   DATA LEN : 0
00> [00:08:42.259,033] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:08:42.289,886] <inf> combined_ble:  Scan Resume err code : 0
00> [00:08:42.290,252] <inf> combined_ble:
00>
00>
00>
00>
00> [00:08:42.774,871] <inf> combined_ble: Filters matched. Address: DC:BF:AF:86:1F:0E (random) connectable: 0 RSSI: -68
00> [00:08:42.778,045] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:42.798,889] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:08:42.800,170] <inf> combined_ble: MTU exchange request (err 0)
00> [00:08:43.050,537] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:08:43.050,933] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:08:43.051,422] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:08:43.051,940] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:08:43.093,597] <inf> combined_ble:  Scan Resume err code : 0
00> [00:08:43.093,963] <inf> combined_ble:
00>
00>
00>
00>
00> [00:08:43.120,483] <inf> combined_ble: Filters matched. Address: DC:BF:AF:86:1F:0E (random) connectable: 0 RSSI: -74
00> [00:08:43.125,976] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:46.127,899] <inf> combined_ble: Conn fail err code: 2
00> [00:08:46.128,265] <inf> combined_ble: default_conn pointer: 0x20002d18 in on_Connected
00> [00:08:46.198,364] <inf> combined_ble:  Scan Resumed err code : 0
00> [00:08:46.939,636] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -70
00> [00:08:46.941,528] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:46.966,552] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:08:46.967,864] <inf> combined_ble: MTU exchange request (err 0)
00> [00:08:47.218,139] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:08:47.218,536] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:08:47.219,024] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:08:47.219,543] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:08:47.302,093] <inf> combined_ble:  Scan Resume err code : 0
00> [00:08:47.302,459] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:16.413,360] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -79
00> [00:09:16.415,222] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:16.432,281] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:16.433,593] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:16.683,868] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:16.684,265] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:16.684,753] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:16.685,272] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:16.733,978] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:16.734,344] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:16.750,762] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -68
00> [00:09:16.757,110] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:16.777,954] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:16.779,235] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:17.029,541] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:17.029,907] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:17.030,395] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:17.030,914] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:17.037,200] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:17.037,567] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:27.020,965] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -86
00> [00:09:27.024,597] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:27.051,422] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:27.052,734] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:27.303,009] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:27.303,405] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:27.303,894] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:27.304,412] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:27.350,250] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:27.350,616] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:27.602,722] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -82
00> [00:09:27.605,865] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:27.632,354] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:27.633,666] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:27.883,941] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:27.884,338] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:27.884,826] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:27.885,345] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:27.953,765] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:27.954,132] <inf> combined_ble:
00>
00>
00>
00>
00> [00:10:10.257,507] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -66
00> [00:10:10.261,413] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:10:10.280,731] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:10:10.282,043] <inf> combined_ble: MTU exchange request (err 0)
00> [00:10:10.482,299] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:10:10.482,666] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:10:10.582,275] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:10:10.682,678] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:10:10.832,275] <inf> combined_ble: CCCD handle: 0x0013
00> [00:10:10.832,702] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:10:11.132,537] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.133,422] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.182,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.232,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.332,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.382,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.432,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.482,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.532,592] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.582,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.632,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.732,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.782,592] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.832,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.882,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.932,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.982,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.032,592] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.082,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.132,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.182,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.282,562] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.332,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.382,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.482,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.532,562] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.532,928] <inf> combined_ble: Name: S1IAD1885, PKT CNTR: 7648, epoch: 1774530600
00> [00:10:14.582,092] <inf> combined_ble:   DATA LEN : 0
00> [00:10:14.582,458] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:10:14.602,783] <inf> combined_ble:  Scan Resume err code : 0
00> [00:10:14.603,149] <inf> combined_ble:
00>
00>
00>
00>
00> [00:11:32.856,781] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -74
00> [00:11:32.860,931] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:11:32.884,185] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:11:32.885,498] <inf> combined_ble: MTU exchange request (err 0)
00> [00:11:33.335,723] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:11:33.336,090] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:11:33.435,699] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:11:33.536,102] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:11:33.635,711] <inf> combined_ble: CCCD handle: 0x0013
00> [00:11:33.636,138] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:11:33.835,510] <inf> combined_ble:   DATA LEN : 0
00> [00:11:33.835,937] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:11:33.884,979] <inf> combined_ble:  Scan Resume err code : 0
00> [00:11:33.885,345] <inf> combined_ble:
00>
00>
00>
00>
00> [00:11:41.896,392] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -68
00> [00:11:41.898,040] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:11:41.918,243] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:11:41.919,555] <inf> combined_ble: MTU exchange request (err 0)
00> [00:11:42.169,830] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:11:42.170,227] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:11:42.170,715] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:11:42.171,234] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:11:42.196,075] <inf> combined_ble:  Scan Resume err code : 0
00> [00:11:42.196,441] <inf> combined_ble:
00>
00>
00>
00>
00> [00:11:42.207,397] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -69
00> [00:11:42.209,228] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:11:42.234,741] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:11:42.236,022] <inf> combined_ble: MTU exchange request (err 0)
00> [00:11:42.686,248] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:11:42.686,614] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:11:42.786,346] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:11:42.886,535] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:11:43.036,254] <inf> combined_ble: CCCD handle: 0x0013
00> [00:11:43.036,712] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:11:43.136,077] <inf> combined_ble:   DATA LEN : 0
00> [00:11:43.136,474] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:11:43.199,981] <inf> combined_ble:  Scan Resume err code : 0
00> [00:11:43.200,347] <inf> combined_ble:
00>
00>
00>
00>
00> [00:12:11.420,471] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -76
00> [00:12:11.423,156] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:12:11.444,396] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:12:11.445,709] <inf> combined_ble: MTU exchange request (err 0)
00> [00:12:11.695,983] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:12:11.696,380] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:12:11.696,868] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:12:11.697,387] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:12:11.731,628] <inf> combined_ble:  Scan Resume err code : 0
00> [00:12:11.731,994] <inf> combined_ble:
00>
00>
00>
00>
00> [00:12:11.761,138] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -74
00> [00:12:11.764,007] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:12:11.788,238] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:12:11.789,550] <inf> combined_ble: MTU exchange request (err 0)
00> [00:12:12.039,825] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:12:12.040,222] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:12:12.040,710] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:12:12.041,229] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:12:12.134,948] <inf> combined_ble:  Scan Resume err code : 0
00> [00:12:12.135,314] <inf> combined_ble:
00>
00>
00>
00>
00> [00:13:05.206,451] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -67
00> [00:13:05.208,099] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:13:05.230,499] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:13:05.231,781] <inf> combined_ble: MTU exchange request (err 0)
00> [00:13:05.482,086] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:13:05.482,482] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:13:05.482,971] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:13:05.483,459] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:13:05.490,692] <inf> combined_ble:  Scan Resume err code : 0
00> [00:13:05.491,058] <inf> combined_ble:
00>
00>
00>
00>
00> [00:14:27.825,225] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -74
00> [00:14:27.828,826] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:14:27.850,372] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:14:27.851,684] <inf> combined_ble: MTU exchange request (err 0)
00> [00:14:28.101,959] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:14:28.102,355] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:14:28.102,844] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:14:28.103,363] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:14:28.175,506] <inf> combined_ble:  Scan Resume err code : 0
00> [00:14:28.175,872] <inf> combined_ble:
00>
00>
While debugging the peripheral-side logs s, I am observing an error code: - 128
  Could you please help identify the possible root cause of:
  • MTU exchange failure
  • Unexpected BLE disconnections
  • And whether the peripheral error -128 could be related to this issue
  Also, please suggest any configuration or implementation changes required to stabilize the connection.
