nRF52833: MTU Exchange Fails and Connection Terminates
Hello Team,
     I am working with nRF52833 configured as a BLE scanner using nRF Connect SDK for VS Code.
Here is my prj.conf:
# Copyright (c) 2018 Nordic Semiconductor
# ─── UART (Async, no console) ───────────────────────────────────────────────
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
# ─── FOR UART STOP and RESTART AT RUNTIME WHEN UART RX ERROR EVT TRIGGERS ─────────────────────
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
# ─── BLE Stack (Central / Scanner) ──────────────────────────────────────────
CONFIG_BT=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_SMP=y
# BLE NCS modules
CONFIG_BT_NUS_CLIENT=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_GATT_DM=y
# MTU / buffer sizing for 40-byte chunks
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
# BLE stack sizes
CONFIG_BT_RX_STACK_SIZE=4096
# Reduce BLE log noise — only errors
CONFIG_BT_LOG_LEVEL_ERR=y
# ─── Stack / Heap ────────────────────────────────────────────────────────────
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=4096
# ─── RTT Logging (no UART backend) ──────────────────────────────────────────
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=y
# 23rd March 2026, RTT BUFFER SIZE increased for crash log capture
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
# ─── GPIO / SPI (needed for nRF21540 FEM) ───────────────────────────────────
CONFIG_GPIO=y
CONFIG_SPI=y
# ─── RTC Calendar ────────────────────────────────────────────────────────────
CONFIG_RTC=y
CONFIG_RTC_UPDATE=y
# ─── Watchdog ────────────────────────────────────────────────────────────────
CONFIG_WATCHDOG=y
CONFIG_REBOOT=y
# ─── Clock (RC low-frequency, 500 ppm) ───────────────────────────────────────
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
# ─── Range Extender: nRF21540 FEM ────────────────────────────────────────────
CONFIG_MPSL=y
CONFIG_MPSL_FEM=y
CONFIG_MPSL_FEM_NRF21540_GPIO_SPI=y
CONFIG_MPSL_FEM_NRF21540_TX_GAIN_DB=20
CONFIG_MPSL_FEM_POWER_MODEL=y
CONFIG_MPSL_FEM_POWER_MODEL_NRF21540_USE_BUILTIN=y
CONFIG_BT_CTLR_TX_PWR_ANTENNA=20
# ─── Assert ──────────────────────────────────────────────────────────────────
CONFIG_ASSERT=y
# ─── Heap runtime stats (optional, useful for debugging) ─────────────────────
CONFIG_SYS_HEAP_RUNTIME_STATS=y
# ─────────── prj.conf ADDDED ON -> 9th MARCH for CRC CHECK ──────────────────────
CONFIG_CRC=y
# ─── Fatal Error Debugging 10th MARCH 2026, ───────────────────────────────────────────────────
CONFIG_RESET_ON_FATAL_ERROR=n       # Prevent immediate reboot so output is visible
CONFIG_THREAD_NAME=y                # Show thread name (e.g. "main") instead of "unknown"
CONFIG_ASSERT=y
CONFIG_ASSERT_VERBOSE=y
CONFIG_ASSERT_NO_COND_INFO=n
CONFIG_ASSERT_NO_MSG_INFO=n
# Stack overflow detection
CONFIG_HW_STACK_PROTECTION=y
CONFIG_INIT_STACKS=y
# Immediate logging ensures crash logs are flushed before halt
CONFIG_LOG_MODE_IMMEDIATE=y
#────────────────────────────  THREAD ANALYZER FOR STACK OVERFLOW DETECTION ──────────────────────
#CONFIG_THREAD_NAME=y
#CONFIG_THREAD_ANALYZER=y
#CONFIG_THREAD_ANALYZER_AUTO=y
#CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y
#CONFIG_THREAD_ANALYZER_USE_LOG=y
#CONFIG_THREAD_ANALYZER_AUTO_INTERVAL=30
#CONFIG_THREAD_ANALYZER_AUTO_STACK_SIZE=2048
#CONFIG_INIT_STACKS=y
AND here is scan/conn Implementaion:
static void discovery_work_handler(struct k_work *work);
static void scan_filter_match(struct bt_scan_device_info *device_info,
    struct bt_scan_filter_match *filter_match,
    bool connectable) {
    bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
   LOG_INF("Filters matched. Address: %s connectable: %d RSSI: %d",addr, connectable, device_info->recv_info->rssi);
  //LOG_INF("Filters matched. ");
 static void scan_connecting_error(struct bt_scan_device_info *device_info)
   // LOG_WRN("Connecting failed");
 static void scan_connecting(struct bt_scan_device_info *device_info,
				   struct bt_conn *conn) {
	 default_conn = bt_conn_ref(conn);
     /* Print pointer value (for debugging) */
    LOG_INF("default_conn pointer: %p in scan_connecting", (void *)default_conn);
 BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
    scan_connecting_error, scan_connecting);
/* Explicit scan parameters: timeout = 0 => infinite scan */
static struct bt_le_scan_param scan_param = {
    .type     = BT_LE_SCAN_TYPE_ACTIVE,
    .options  = BT_LE_SCAN_OPT_NONE,
    .interval = BT_GAP_SCAN_FAST_INTERVAL,
    .window   = BT_GAP_SCAN_FAST_WINDOW,
    .timeout  = 0,   /* infinite scanning */
    static int scan_init(void) {
        int err;
        struct bt_scan_init_param scan_init = {
        .connect_if_match = 1,  //1, // 4th FEB 2026
        .scan_param       = &scan_param,   /* use our params */
        .conn_param       = NULL,          /* BT_LE_CONN_PARAM_DEFAULT */
		bt_scan_init(&scan_init);
		bt_scan_cb_register(&scan_cb);
		err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
		if (err) {
			//LOG_ERR("Scanning filters cannot be set (err %d)", err);
			return err;
		err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
		if (err) {
			//LOG_ERR("Filters cannot be turned on (err %d)", err);
			return err;
		//LOG_INF("Scan module initialized");
		return err;
 /* Connection Callbacks */
 BT_CONN_CB_DEFINE(conn_callbacks) = {
	 .connected = on_connected,
	 .disconnected = on_disconnected,
	 .security_changed = on_security_changed
    if (discovery_conn) {
        int err = start_discovery(discovery_conn);
        if (err) {
            LOG_ERR("start_discovery from work failed (err %d)", err);
 static uint8_t custom_uart_notify(struct bt_conn *conn,
	struct bt_gatt_subscribe_params *params,
	const void *data, uint16_t len) {
	static uint8_t frame_checksum = 0;
	static uint32_t total_bytes_received = 0;
	if (conn) {
     LOG_INF("  DATA LEN : %d",len);
	if (!data) {
		received_frames = 0;
		frame_checksum = 0;
		return BT_GATT_ITER_CONTINUE;
	if (len != FRAME_SIZE) {
		//LOG_ERR("Invalid frame size: %d (expected %d)", len, FRAME_SIZE);
	if (received_frames >= TOTAL_FRAMES) {
		//LOG_WRN("Received extra frame (already have %d frames)", received_frames);
	uint8_t current_checksum = 0;
	for (int i = 0; i < len; i++) {
		current_checksum += ((const uint8_t *)data)[i];
	memcpy(&full_data[received_frames * FRAME_SIZE], data, len);
	received_frames++;
	total_bytes_received += len;
	frame_checksum += current_checksum;
	if (received_frames == TOTAL_FRAMES) {
        uint16_t current_packet_counter = ((full_data[13] << 8) | full_data[14]);
        uint32_t print_epoch_from_tag = ((full_data[15] << 24) | (full_data[16] << 16) | (full_data[17] << 8) | full_data[18]);
        for(int i=1;i<10;i++)
          current_device_name[i-1] =  full_data[i];
        current_device_name[9] = '\0';
        //LOG_INF("*********************************  Device name : %s PACKET COUNTER : %d and epoch_from_tag : %d ***************************",current_device_name,current_packet_counter,print_epoch_from_tag);
		LOG_INF("Name: %s, PKT CNTR: %d, epoch: %d",current_device_name,current_packet_counter,print_epoch_from_tag);
		        frame_checksum = 0;
                data_non_empty_check = true;
                memset(&full_data,0,sizeof(full_data));
                memset(&current_device_name,0,sizeof(current_device_name));
                current_packet_counter = 0;  // 30th DEC 2025, Clear Variable for next cycle
                //21th JAN 2026, Added to terminate ble connection from scanner side, need to test contineously.
                if (epoch_wr_counter_check >= LOGS_PER_WRITE)
                    central_terminate_ble_conn_flag = true;
 static int bt_custom_subscribe_receive(struct bt_custom_client *custom)
	 static struct bt_gatt_subscribe_params subscribe_params;
	 if (!custom || !custom->conn || !custom->value_handle || !custom->cccd_handle)
		 //LOG_ERR("Invalid custom client parameters");
		 return -EINVAL;
	 memset(&subscribe_params, 0, sizeof(subscribe_params));
	 subscribe_params.value_handle = custom->value_handle;
	 subscribe_params.ccc_handle = custom->cccd_handle;
	 subscribe_params.notify = custom_uart_notify;
	 subscribe_params.value = BT_GATT_CCC_NOTIFY;
     int err = bt_gatt_subscribe(custom->conn, &subscribe_params);
     if (err)
		 LOG_ERR("Subscription failed: %d", err);
		 return err;
     LOG_INF("bt_gatt_subscribe err code: %d",err);
	 return 0;
 static uint8_t discover_func(struct bt_conn *conn,
	 const struct bt_gatt_attr *attr,
	 struct bt_gatt_discover_params *params)
	 int err;
	 if (!attr) {
		//LOG_INF("Discovery complete in discover function");
		// Assign discovered handles to your client structure
		my_custom_client.conn = conn;
		my_custom_client.value_handle = my_char_handle;   // Set during characteristic discovery
		my_custom_client.cccd_handle  = my_cccd_handle;   // Set during descriptor discovery
		/*if (bt_custom_subscribe_receive(&my_custom_client)) {
			LOG_INF("Subscription to custom characteristic failed");
    int sub_char_err = bt_custom_subscribe_receive(&my_custom_client);
    if (sub_char_err)
      LOG_ERR("Subscription to custom characteristic failed (err: %d)", sub_char_err);
		return BT_GATT_ITER_STOP;
	if (params->type == BT_GATT_DISCOVER_PRIMARY)
		struct bt_gatt_service_val *svc = (struct bt_gatt_service_val *)attr->user_data;
		LOG_INF("Found service, start_handle: 0x%04x, end_handle: 0x%04x", attr->handle, svc->end_handle);
		discover_params.uuid = NULL; // Discover all characteristics
		discover_params.start_handle = attr->handle + 1;
		discover_params.end_handle = svc->end_handle;
		discover_params.type = BT_GATT_DISCOVER_CHARACTERISTIC;
		discover_params.func = discover_func;
		err = bt_gatt_discover(conn, &discover_params);
		if (err) {
			LOG_INF("Characteristic discovery failed (err %d)", err);
    else if (params->type == BT_GATT_DISCOVER_CHARACTERISTIC)
		struct bt_gatt_chrc *chrc = (struct bt_gatt_chrc *)attr->user_data;
		//LOG_INF("Characteristic UUID type: 0x%x", chrc->uuid->type);
		my_char_handle = chrc->value_handle;
		LOG_INF("Characteristic handle: 0x%04x", my_char_handle);
		// Start descriptor (CCCD) discovery for this characteristic
		discover_params.uuid = BT_UUID_GATT_CCC;
		discover_params.start_handle = my_char_handle + 1;
		discover_params.end_handle = params->end_handle;
		discover_params.type = BT_GATT_DISCOVER_DESCRIPTOR;
		if (err) {
			LOG_INF("Descriptor discovery failed (err %d)", err);
    else if (params->type == BT_GATT_DISCOVER_DESCRIPTOR)
		// Check if this is the CCCD
		if (bt_uuid_cmp(attr->uuid, BT_UUID_GATT_CCC) == 0) {
			my_cccd_handle = attr->handle;
			LOG_INF("CCCD handle: 0x%04x", my_cccd_handle);
		// Continue to next attribute if needed
 //static
 int start_discovery(struct bt_conn *conn)
	 int err;
	 //LOG_INF("Starting discovery for custom UUID");
     // Print the conn pointer address to confirm it is non-NULL
    LOG_INF("start_discovery: conn pointer = %p", (void *)conn);
	 char uuid_str[37];
	 bt_uuid_to_str(&custom_uart_uuid.uuid, uuid_str, sizeof(uuid_str));
	 //LOG_INF("Custom UUID: %s", uuid_str);
	 discover_params.uuid = &custom_uart_uuid.uuid;
	 discover_params.start_handle = BT_ATT_FIRST_ATTRIBUTE_HANDLE;
	 discover_params.end_handle = BT_ATT_LAST_ATTRIBUTE_HANDLE;
	 discover_params.type = BT_GATT_DISCOVER_PRIMARY;
	 if (err) {
		 LOG_ERR("Custom service discovery failed (err %d)", err);
		 return err;
	 return 0;
 static void exchange_func(struct bt_conn *conn, uint8_t err,struct bt_gatt_exchange_params *params)
    if (!err) {
        uint16_t mtu = bt_gatt_get_mtu(conn);
        LOG_INF("Negotiated MTU size is: %d", mtu);
    } else {
        LOG_WRN("MTU exchange failed (err %" PRIu8 "), proceeding with default MTU", err);
    // Defer discovery to system workqueue (outside BT RX thread)
    discovery_conn = conn;
    k_work_submit(&discovery_work);
 void on_connected(struct bt_conn *conn, uint8_t err) {
    ble_evt_in_process_flag = true; // 8th JAN 2026, added to check ble event for scan timer timeout execution
	 if (err) {
        LOG_INF("Conn fail err code: %d",err);
		 if (default_conn == conn)
			LOG_INF("default_conn pointer: %p in on_Connected", (void *)default_conn);
            bt_conn_unref(default_conn);
			default_conn = NULL;
         ble_connection_error_flag = true; // 31st DEC 2025
		 return;
     LOG_INF("--------------------  CONNECTED to BLE DEVICE ---------------------");
     int scan_stop_err = bt_scan_stop();
     if (scan_stop_err == -EALREADY)
        LOG_INF(" ################# scan already stop (err %d)", scan_stop_err);
	 static struct bt_gatt_exchange_params exchange_params;
	 exchange_params.func = exchange_func;
	 err = bt_gatt_exchange_mtu(conn, &exchange_params);
	 LOG_INF("MTU exchange request (err %d)", err);
 static void on_disconnected(struct bt_conn *conn, uint8_t reason) {
   LOG_INF(" -------------------- Disconnected... (reason 0x%02x) -------------------------", reason);
    // Reset state and clean up
    my_char_handle = 0;
    my_cccd_handle = 0;
    ble_data_ready_flag = true;
Expected Execution Sequence:
  1. Scanner starts scanning for nearby devices
  2. Filters device based on matching service UUID
  3. Initiates connection upon match
  4. On successful connection:
    • MTU exchange request is initiated
    • On MTU exchange callback → start service discovery
    • On discovery completion → subscribe to characteristic
    • Connected tag sends data log
Data Transfer Details:
  • Total log size: 1040 bytes
  • Sent in 26 frames
  • Each frame: 40 bytes
Issue Observed:
  • Occasionally, the full data log is received successfully
  • However, most of the time, device disconnecting as:
    • MTU exchange fails, Error 0x3E (Connection Failed to be Established / Timeout)
    • MTU exchnage and sunscription succ, Error 0x13 (Remote User Terminated Connection)
  • RTT logs (showing both successful and failing cases)
00> *** Booting nRF Connect SDK v2.9.1-60d0d6c8d42d ***
00> *** Using Zephyr OS v3.7.99-ca954a6216c9 ***
00> [00:00:00.002,471] <inf> combined_ble:
00>
00>
00>
00> [00:00:00.011,352] <inf> combined_ble: Bluetooth initialized initially...
00> [00:00:00.011,779] <inf> combined_ble: UART_RX_BUF_REQUEST
00> [00:00:00.012,115] <inf> combined_ble: uart_init returns err code : 0
00> [00:00:00.014,160] <inf> combined_ble:  Scan Resume err code : 0
00> [00:00:23.358,306] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -66
00> [00:00:23.362,304] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:00:23.381,774] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:00:23.383,087] <inf> combined_ble: MTU exchange request (err 0)
00> [00:00:23.583,343] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:00:23.683,319] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:00:23.783,721] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:00:23.883,300] <inf> combined_ble: CCCD handle: 0x0013
00> [00:00:23.883,758] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:00:24.233,581] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.234,466] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.283,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.333,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.383,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.433,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.483,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.533,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.583,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.633,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.683,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.733,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.883,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.933,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:24.983,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.033,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.083,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.133,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.183,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.283,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.333,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.383,605] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.433,624] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.483,612] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.533,630] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.583,618] <inf> combined_ble:   DATA LEN : 40
00> [00:00:25.583,984] <inf> combined_ble: Name: S1IAD1902, PKT CNTR: 9105, epoch: 1774530000
00> [00:00:27.633,148] <inf> combined_ble:   DATA LEN : 0
00> [00:00:27.633,514] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:00:00.014,312] <inf> combined_ble:  Scan Resume err code : 0
00> [00:00:07.774,078] <inf> combined_ble: Filters matched. Address: E4:36:13:61:FA:F1 (random) connectable: 0 RSSI: -75
00> [00:00:07.777,496] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:00:07.805,419] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:00:07.806,732] <inf> combined_ble: MTU exchange request (err 0)
00> [00:00:08.056,976] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:00:08.057,342] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:00:08.156,951] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:00:08.357,299] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:00:08.506,958] <inf> combined_ble: CCCD handle: 0x0013
00> [00:00:08.507,385] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:00:08.657,226] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.658,111] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.707,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.757,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.807,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.857,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.907,287] <inf> combined_ble:   DATA LEN : 40
00> [00:00:08.957,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.007,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.057,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.107,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.157,257] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.207,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.257,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.307,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.357,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.407,287] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.457,275] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.507,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.557,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.607,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.657,257] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.757,263] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.807,281] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.857,269] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.907,257] <inf> combined_ble:   DATA LEN : 40
00> [00:00:09.907,623] <inf> combined_ble: Name: S1IAD1640, PKT CNTR: 1454, epoch: 1774530000
00> [00:00:11.956,787] <inf> combined_ble:   DATA LEN : 0
00> [00:00:11.957,153] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:00:12.028,747] <inf> combined_ble:  Scan Resume err code : 0
00> [00:00:12.029,113] <inf> combined_ble:
00>
00>
00>
00>
00> [00:01:32.874,420] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -66
00> [00:01:32.876,892] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:32.897,308] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:01:32.898,590] <inf> combined_ble: MTU exchange request (err 0)
00> [00:01:33.148,895] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:01:33.149,291] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:01:33.149,749] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:01:33.150,268] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:01:33.212,829] <inf> combined_ble:  Scan Resume err code : 0
00> [00:01:33.213,195] <inf> combined_ble:
00>
00>
00>
00>
00> [00:01:38.499,298] <inf> combined_ble: Filters matched. Address: DC:BF:AF:86:1F:0E (random) connectable: 0 RSSI: -70
00> [00:01:38.505,981] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:41.507,904] <inf> combined_ble: Conn fail err code: 2
00> [00:01:41.508,270] <inf> combined_ble: default_conn pointer: 0x20002d18 in on_Connected
00> [00:01:41.523,010] <inf> combined_ble:  Scan Resumed err code : 0
00> [00:01:42.030,883] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -68
00> [00:01:42.035,430] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:42.055,511] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:01:42.056,823] <inf> combined_ble: MTU exchange request (err 0)
00> [00:01:42.307,098] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:01:42.307,495] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:01:42.307,983] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:01:42.308,502] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:01:42.326,446] <inf> combined_ble:  Scan Resume err code : 0
00> [00:01:42.326,812] <inf> combined_ble:
00>
00>
00>
00>
00> [00:01:42.346,130] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -71
00> [00:01:42.349,578] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:01:42.373,321] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:01:42.374,633] <inf> combined_ble: MTU exchange request (err 0)
00> [00:01:42.774,810] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:01:42.775,207] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:01:42.874,938] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:01:42.975,128] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:01:43.124,847] <inf> combined_ble: CCCD handle: 0x0013
00> [00:01:43.125,274] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:01:43.274,658] <inf> combined_ble:   DATA LEN : 0
00> [00:01:43.275,054] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:01:43.330,352] <inf> combined_ble:  Scan Resume err code : 0
00> [00:01:43.330,718] <inf> combined_ble:
00>
00>
00>
00>
00> [00:02:11.426,574] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -73
00> [00:02:11.428,527] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:02:11.457,458] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:02:11.458,770] <inf> combined_ble: MTU exchange request (err 0)
00> [00:02:11.709,045] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:02:11.709,442] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:02:11.709,930] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:02:11.710,449] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:02:11.762,542] <inf> combined_ble:  Scan Resume err code : 0
00> [00:02:11.762,908] <inf> combined_ble:
00>
00>
00>
00>
00> [00:02:11.827,209] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -75
00> [00:02:11.830,688] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:02:11.857,421] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:02:11.858,734] <inf> combined_ble: MTU exchange request (err 0)
00> [00:02:12.109,008] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:02:12.109,405] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:02:12.109,893] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:02:12.110,412] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:02:12.165,863] <inf> combined_ble:  Scan Resume err code : 0
00> [00:02:12.166,229] <inf> combined_ble:
00>
00>
00>
00>
00> [00:02:21.975,708] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -67
00> [00:02:21.978,240] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:02:24.980,163] <inf> combined_ble: Conn fail err code: 2
00> [00:02:24.980,529] <inf> combined_ble: default_conn pointer: 0x20002d18 in on_Connected
00> [00:02:24.982,971] <inf> combined_ble:  Scan Resumed err code : 0
00> [00:03:02.798,858] <inf> combined_ble: Filters matched. Address: E4:36:13:61:FA:F1 (random) connectable: 0 RSSI: -73
00> [00:03:02.801,147] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:03:02.824,401] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:03:02.825,714] <inf> combined_ble: MTU exchange request (err 0)
00> [00:03:03.075,988] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:03:03.076,385] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:03:03.076,873] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:03:03.077,392] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:03:03.123,596] <inf> combined_ble:  Scan Resume err code : 0
00> [00:03:03.123,962] <inf> combined_ble:
00>
00>
00>
00>
00> [00:03:05.355,743] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -64
00> [00:03:05.361,755] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:03:05.378,845] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:03:05.380,157] <inf> combined_ble: MTU exchange request (err 0)
00> [00:03:05.630,462] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:03:05.630,828] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:03:05.631,317] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:03:05.631,835] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:03:05.729,095] <inf> combined_ble:  Scan Resume err code : 0
00> [00:03:05.729,461] <inf> combined_ble:
00>
00>
00>
00>
00> [00:03:05.750,457] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -73
00> [00:03:05.752,227] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:03:05.773,315] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:03:05.774,627] <inf> combined_ble: MTU exchange request (err 0)
00> [00:03:06.024,871] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:03:06.025,238] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:03:06.174,835] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:03:06.275,238] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:03:06.374,847] <inf> combined_ble: CCCD handle: 0x0013
00> [00:03:06.375,274] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:03:06.625,122] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.625,976] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.675,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.725,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.775,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.825,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.875,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.925,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:06.975,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.025,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.075,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.125,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.175,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.225,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.275,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.325,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.375,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.425,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.475,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.525,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.575,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.625,152] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.675,140] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.725,158] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.775,146] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.825,164] <inf> combined_ble:   DATA LEN : 40
00> [00:03:07.825,500] <inf> combined_ble: Name: S1IAD1885, PKT CNTR: 7646, epoch: 1774529400
00> [00:03:09.874,664] <inf> combined_ble:   DATA LEN : 0
00> [00:03:09.875,030] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:03:09.936,126] <inf> combined_ble:  Scan Resume err code : 0
00> [00:03:09.936,492] <inf> combined_ble:
00>
00>
00>
00>
00> [00:04:27.888,671] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -68
00> [00:04:27.894,287] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:04:27.915,344] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:04:27.916,687] <inf> combined_ble: MTU exchange request (err 0)
00> [00:04:28.116,912] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:04:28.117,279] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:04:28.216,888] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:04:28.317,291] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:04:28.416,900] <inf> combined_ble: CCCD handle: 0x0013
00> [00:04:28.417,327] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:04:28.767,181] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.768,035] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.817,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.867,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:28.967,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.017,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.067,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.117,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.167,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.217,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.317,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.367,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.417,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.467,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.517,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.567,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.617,218] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.667,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.717,193] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.767,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.817,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.867,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:29.917,205] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.017,211] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.067,199] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.117,187] <inf> combined_ble:   DATA LEN : 40
00> [00:04:30.117,553] <inf> combined_ble: Name: S1IAD1902, PKT CNTR: 9105, epoch: 1774530000
00> [00:04:32.166,717] <inf> combined_ble:   DATA LEN : 0
00> [00:04:32.167,083] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:04:32.220,703] <inf> combined_ble:  Scan Resume err code : 0
00> [00:04:32.221,069] <inf> combined_ble:
00>
00>
00>
00>
00> [00:04:37.027,069] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -71
00> [00:04:37.028,869] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:04:37.045,806] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:04:37.047,119] <inf> combined_ble: MTU exchange request (err 0)
00> [00:04:37.397,308] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:04:37.397,705] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:04:37.497,436] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:04:37.597,625] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:04:37.697,357] <inf> combined_ble: CCCD handle: 0x0013
00> [00:04:37.697,784] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:04:37.897,613] <inf> combined_ble:   DATA LEN : 40
00> [00:04:37.898,498] <inf> combined_ble:   DATA LEN : 40
00> [00:04:37.947,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:37.997,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.047,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.097,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.147,674] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.197,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.247,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.297,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.347,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.397,644] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.447,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.497,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.547,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.597,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.647,674] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.697,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.747,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.847,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.897,674] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.947,662] <inf> combined_ble:   DATA LEN : 40
00> [00:04:38.997,650] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.047,668] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.097,656] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.147,644] <inf> combined_ble:   DATA LEN : 40
00> [00:04:39.148,010] <inf> combined_ble: Name: S1IAD1588, PKT CNTR: 1454, epoch: 1774530000
00> [00:04:41.197,174] <inf> combined_ble:   DATA LEN : 0
00> [00:04:41.197,540] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:04:41.232,727] <inf> combined_ble:  Scan Resume err code : 0
00> [00:04:41.233,093] <inf> combined_ble:
00>
00>
00>
00>
00> [00:05:06.514,251] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -90
00> [00:05:06.520,874] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:05:06.533,538] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:05:06.534,851] <inf> combined_ble: MTU exchange request (err 0)
00> [00:05:06.785,125] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:05:06.785,522] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:05:06.786,010] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:05:06.786,529] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:05:06.861,541] <inf> combined_ble:  Scan Resume err code : 0
00> [00:05:06.861,907] <inf> combined_ble:
00>
00>
00>
00>
00> [00:06:32.020,843] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -71
00> [00:06:32.024,719] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:06:32.048,004] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:06:32.049,316] <inf> combined_ble: MTU exchange request (err 0)
00> [00:06:32.299,591] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:06:32.299,987] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:06:32.300,476] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:06:32.300,994] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:06:32.349,822] <inf> combined_ble:  Scan Resume err code : 0
00> [00:06:32.350,189] <inf> combined_ble:
00>
00>
00>
00>
00> [00:06:32.359,039] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -70
00> [00:06:32.361,907] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:06:32.384,704] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:06:32.385,986] <inf> combined_ble: MTU exchange request (err 0)
00> [00:06:32.636,291] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:06:32.636,657] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:06:32.637,145] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:06:32.637,664] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:06:32.653,045] <inf> combined_ble:  Scan Resume err code : 0
00> [00:06:32.653,411] <inf> combined_ble:
00>
00>
00>
00>
00> [00:06:32.670,288] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -68
00> [00:06:32.676,208] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:06:32.690,795] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:06:32.692,108] <inf> combined_ble: MTU exchange request (err 0)
00> [00:06:32.992,309] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:06:32.992,675] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:06:33.092,437] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:06:33.192,626] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:06:33.292,327] <inf> combined_ble: CCCD handle: 0x0013
00> [00:06:33.292,755] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:06:33.542,602] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.543,487] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.592,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.642,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.742,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.792,633] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.842,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.892,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.942,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:33.992,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.092,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.142,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.192,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.242,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.292,633] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.342,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.392,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.442,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.492,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.542,633] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.592,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.642,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.842,651] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.892,639] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.942,626] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.992,645] <inf> combined_ble:   DATA LEN : 40
00> [00:06:34.993,011] <inf> combined_ble: Name: S1IAD1876, PKT CNTR: 9101, epoch: 1774530000
00> [00:06:37.042,175] <inf> combined_ble:   DATA LEN : 0
00> [00:06:37.042,541] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:06:37.060,272] <inf> combined_ble:  Scan Resume err code : 0
00> [00:06:37.060,638] <inf> combined_ble:
00>
00>
00>
00>
00> [00:07:12.610,198] <inf> combined_ble: Filters matched. Address: E4:36:13:61:FA:F1 (random) connectable: 0 RSSI: -76
00> [00:07:12.612,670] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:07:12.628,509] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:07:12.629,821] <inf> combined_ble: MTU exchange request (err 0)
00> [00:07:12.880,096] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:07:12.880,493] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:07:12.880,981] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:07:12.881,500] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:07:12.898,803] <inf> combined_ble:  Scan Resume err code : 0
00> [00:07:12.899,169] <inf> combined_ble:
00>
00>
00>
00>
00> [00:08:37.878,631] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -77
00> [00:08:37.881,988] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:37.907,287] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:08:37.908,630] <inf> combined_ble: MTU exchange request (err 0)
00> [00:08:38.108,856] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:08:38.109,222] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:08:38.258,850] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:08:38.359,252] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:08:38.458,831] <inf> combined_ble: CCCD handle: 0x0013
00> [00:08:38.459,289] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:08:38.759,124] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.759,979] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.809,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.859,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.909,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:38.959,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.009,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.059,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.109,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.209,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.309,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.359,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.409,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.509,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.609,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.659,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.709,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.759,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.809,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.859,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.909,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:39.959,136] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.009,155] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.059,143] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.109,161] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.159,149] <inf> combined_ble:   DATA LEN : 40
00> [00:08:40.159,515] <inf> combined_ble: Name: S1IAD1902, PKT CNTR: 9105, epoch: 1774530000
00> [00:08:42.258,666] <inf> combined_ble:   DATA LEN : 0
00> [00:08:42.259,033] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:08:42.289,886] <inf> combined_ble:  Scan Resume err code : 0
00> [00:08:42.290,252] <inf> combined_ble:
00>
00>
00>
00>
00> [00:08:42.774,871] <inf> combined_ble: Filters matched. Address: DC:BF:AF:86:1F:0E (random) connectable: 0 RSSI: -68
00> [00:08:42.778,045] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:42.798,889] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:08:42.800,170] <inf> combined_ble: MTU exchange request (err 0)
00> [00:08:43.050,537] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:08:43.050,933] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:08:43.051,422] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:08:43.051,940] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:08:43.093,597] <inf> combined_ble:  Scan Resume err code : 0
00> [00:08:43.093,963] <inf> combined_ble:
00>
00>
00>
00>
00> [00:08:43.120,483] <inf> combined_ble: Filters matched. Address: DC:BF:AF:86:1F:0E (random) connectable: 0 RSSI: -74
00> [00:08:43.125,976] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:46.127,899] <inf> combined_ble: Conn fail err code: 2
00> [00:08:46.128,265] <inf> combined_ble: default_conn pointer: 0x20002d18 in on_Connected
00> [00:08:46.198,364] <inf> combined_ble:  Scan Resumed err code : 0
00> [00:08:46.939,636] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -70
00> [00:08:46.941,528] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:08:46.966,552] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:08:46.967,864] <inf> combined_ble: MTU exchange request (err 0)
00> [00:08:47.218,139] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:08:47.218,536] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:08:47.219,024] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:08:47.219,543] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:08:47.302,093] <inf> combined_ble:  Scan Resume err code : 0
00> [00:08:47.302,459] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:16.413,360] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -79
00> [00:09:16.415,222] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:16.432,281] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:16.433,593] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:16.683,868] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:16.684,265] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:16.684,753] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:16.685,272] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:16.733,978] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:16.734,344] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:16.750,762] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -68
00> [00:09:16.757,110] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:16.777,954] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:16.779,235] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:17.029,541] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:17.029,907] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:17.030,395] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:17.030,914] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:17.037,200] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:17.037,567] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:27.020,965] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -86
00> [00:09:27.024,597] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:27.051,422] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:27.052,734] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:27.303,009] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:27.303,405] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:27.303,894] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:27.304,412] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:27.350,250] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:27.350,616] <inf> combined_ble:
00>
00>
00>
00>
00> [00:09:27.602,722] <inf> combined_ble: Filters matched. Address: C7:5C:04:2A:9E:85 (random) connectable: 0 RSSI: -82
00> [00:09:27.605,865] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:09:27.632,354] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:09:27.633,666] <inf> combined_ble: MTU exchange request (err 0)
00> [00:09:27.883,941] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:09:27.884,338] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:09:27.884,826] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:09:27.885,345] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:09:27.953,765] <inf> combined_ble:  Scan Resume err code : 0
00> [00:09:27.954,132] <inf> combined_ble:
00>
00>
00>
00>
00> [00:10:10.257,507] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -66
00> [00:10:10.261,413] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:10:10.280,731] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:10:10.282,043] <inf> combined_ble: MTU exchange request (err 0)
00> [00:10:10.482,299] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:10:10.482,666] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:10:10.582,275] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:10:10.682,678] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:10:10.832,275] <inf> combined_ble: CCCD handle: 0x0013
00> [00:10:10.832,702] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:10:11.132,537] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.133,422] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.182,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.232,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.332,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.382,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.432,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.482,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.532,592] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.582,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.632,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.732,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.782,592] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.832,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.882,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.932,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:11.982,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.032,592] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.082,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.132,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.182,586] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.282,562] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.332,580] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.382,568] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.482,574] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.532,562] <inf> combined_ble:   DATA LEN : 40
00> [00:10:12.532,928] <inf> combined_ble: Name: S1IAD1885, PKT CNTR: 7648, epoch: 1774530600
00> [00:10:14.582,092] <inf> combined_ble:   DATA LEN : 0
00> [00:10:14.582,458] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:10:14.602,783] <inf> combined_ble:  Scan Resume err code : 0
00> [00:10:14.603,149] <inf> combined_ble:
00>
00>
00>
00>
00> [00:11:32.856,781] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -74
00> [00:11:32.860,931] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:11:32.884,185] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:11:32.885,498] <inf> combined_ble: MTU exchange request (err 0)
00> [00:11:33.335,723] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:11:33.336,090] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:11:33.435,699] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:11:33.536,102] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:11:33.635,711] <inf> combined_ble: CCCD handle: 0x0013
00> [00:11:33.636,138] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:11:33.835,510] <inf> combined_ble:   DATA LEN : 0
00> [00:11:33.835,937] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:11:33.884,979] <inf> combined_ble:  Scan Resume err code : 0
00> [00:11:33.885,345] <inf> combined_ble:
00>
00>
00>
00>
00> [00:11:41.896,392] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -68
00> [00:11:41.898,040] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:11:41.918,243] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:11:41.919,555] <inf> combined_ble: MTU exchange request (err 0)
00> [00:11:42.169,830] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:11:42.170,227] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:11:42.170,715] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:11:42.171,234] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:11:42.196,075] <inf> combined_ble:  Scan Resume err code : 0
00> [00:11:42.196,441] <inf> combined_ble:
00>
00>
00>
00>
00> [00:11:42.207,397] <inf> combined_ble: Filters matched. Address: D4:D7:B8:24:41:E6 (random) connectable: 0 RSSI: -69
00> [00:11:42.209,228] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:11:42.234,741] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:11:42.236,022] <inf> combined_ble: MTU exchange request (err 0)
00> [00:11:42.686,248] <inf> combined_ble: Negotiated MTU size is: 247
00> [00:11:42.686,614] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:11:42.786,346] <inf> combined_ble: Found service, start_handle: 0x0010, end_handle: 0x0015
00> [00:11:42.886,535] <inf> combined_ble: Characteristic handle: 0x0012
00> [00:11:43.036,254] <inf> combined_ble: CCCD handle: 0x0013
00> [00:11:43.036,712] <inf> combined_ble: bt_gatt_subscribe err code: 0
00> [00:11:43.136,077] <inf> combined_ble:   DATA LEN : 0
00> [00:11:43.136,474] <inf> combined_ble:  -------------------- Disconnected... (reason 0x13) -------------------------
00> [00:11:43.199,981] <inf> combined_ble:  Scan Resume err code : 0
00> [00:11:43.200,347] <inf> combined_ble:
00>
00>
00>
00>
00> [00:12:11.420,471] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -76
00> [00:12:11.423,156] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:12:11.444,396] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:12:11.445,709] <inf> combined_ble: MTU exchange request (err 0)
00> [00:12:11.695,983] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:12:11.696,380] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:12:11.696,868] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:12:11.697,387] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:12:11.731,628] <inf> combined_ble:  Scan Resume err code : 0
00> [00:12:11.731,994] <inf> combined_ble:
00>
00>
00>
00>
00> [00:12:11.761,138] <inf> combined_ble: Filters matched. Address: D4:72:A9:51:FD:79 (random) connectable: 0 RSSI: -74
00> [00:12:11.764,007] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:12:11.788,238] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:12:11.789,550] <inf> combined_ble: MTU exchange request (err 0)
00> [00:12:12.039,825] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:12:12.040,222] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:12:12.040,710] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:12:12.041,229] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:12:12.134,948] <inf> combined_ble:  Scan Resume err code : 0
00> [00:12:12.135,314] <inf> combined_ble:
00>
00>
00>
00>
00> [00:13:05.206,451] <inf> combined_ble: Filters matched. Address: CC:0D:F5:68:F7:4D (random) connectable: 0 RSSI: -67
00> [00:13:05.208,099] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:13:05.230,499] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:13:05.231,781] <inf> combined_ble: MTU exchange request (err 0)
00> [00:13:05.482,086] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:13:05.482,482] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:13:05.482,971] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:13:05.483,459] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:13:05.490,692] <inf> combined_ble:  Scan Resume err code : 0
00> [00:13:05.491,058] <inf> combined_ble:
00>
00>
00>
00>
00> [00:14:27.825,225] <inf> combined_ble: Filters matched. Address: E5:F7:69:AF:E8:21 (random) connectable: 0 RSSI: -74
00> [00:14:27.828,826] <inf> combined_ble: default_conn pointer: 0x20002d18 in scan_connecting
00> [00:14:27.850,372] <inf> combined_ble: --------------------  CONNECTED to BLE DEVICE ---------------------
00> [00:14:27.851,684] <inf> combined_ble: MTU exchange request (err 0)
00> [00:14:28.101,959] <wrn> combined_ble: MTU exchange failed (err 14)
00> [00:14:28.102,355] <inf> combined_ble: start_discovery: conn pointer = 0x20002d18
00> [00:14:28.102,844] <err> combined_ble: Custom service discovery failed (err -128)
00> [00:14:28.103,363] <inf> combined_ble:  -------------------- Disconnected... (reason 0x3e) -------------------------
00> [00:14:28.175,506] <inf> combined_ble:  Scan Resume err code : 0
00> [00:14:28.175,872] <inf> combined_ble:
00>
00>
While debugging the peripheral-side logs s, I am observing an error code: - 128
  Could you please help identify the possible root cause of:
  • MTU exchange failure
  • Unexpected BLE disconnections
  • And whether the peripheral error -128 could be related to this issue
  Also, please suggest any configuration or implementation changes required to stabilize the connection.
  • Hi
    I'm not able to see any good indications of what exactly is causing the disconnects in these sniffer logs, as they just seem to do normal transmissions before suddenly the peripheral terminates the connection. If you select which device to sniff, you get a better overview of just that device and the connections it's in. Do you do any kind of encryption (pairing/bonding) during connection? If so we might be missing vital encrypted packets here that can be found if you follow the documentation here: https://docs.nordicsemi.com/bundle/nrfutil/page/nrfutil-ble-sniffer/guides/common_sniffing_actions.html
    The error 0x3e can also be due to the internal clock configuration being wrong as well. Are you working on custom boards or with a DK?
    Simon
  • Hello Simon,
    I m using custom board and using internal RC configuration.
    In connection i m coonectinf device with uuid once connection is established then discovery started and notify and got data .
    these are some logs [00:13:56.085,479] <inf> main: CONNECTED
    [00:13:56.387,237] <inf> main: MTU: 247
    [00:13:56.487,579] <inf> main: Starting discovery for custom UUID
    [00:13:56.587,158] <inf> main: Found service, start_handle: 0x0010, end_handle: 0x0015
    [00:13:56.687,927] <inf> main: Characteristic handle: 0x0012
    [00:13:56.787,170] <inf> main: CCCD handle: 0x0013
    [00:13:56.887,268] <inf> main: Discovery complete in discover function
    [00:13:58.887,023] <inf> main: Received notification from F8:E2:EC:CB:B5:83 (random), with valide data len: 0
    [00:13:58.887,512] <inf> main: Disconnected: 0x13
    From logs discovery complete and notification received from tag is time is about  2sec . is because of this connection is terminating.
    Thanks ,
    Ms. Ashwini L Pujari.
    Embedded Firmware Developer,
    EMBEL Technologies Pvt Ltd.
  • Hi Ashwini
    I'm sorry about the late reply here, but I've been indisposed the last week and are only now catching up to my case queue.
    In order to get more logging information, can you set these configs in your project's .conf file so it's easier to see if we get more from the logging on this side. The disconnect reason from your log here seems to point to it being the device on the other end that initiates the disconnection in the first place.
    CONFIG_BT_LOG_LEVEL_DBG=y
    CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=8192
    CONFIG_LOG_BUFFER_SIZE=8192
    Simon
