SPI Not Working on MDBT Dev Kit
Hi there,
I am using MDBT dev kit based on MDBT53-1M module. I have a simple application of reading an SD card and printing the data on the LOG. While the current application runs perfectly on the nRF5340 dev kit, MDBT dev kit is refusing to let the SPI module run.
nRF Connect SDK version 3.00
Toolchain version 3.00
prj.conf:
# Copyright (c) 2018 Nordic Semiconductor
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_PRINTK=y
CONFIG_PWM=y
CONFIG_FAULT_DUMP=2
CONFIG_SERIAL=y
CONFIG_SPI=y
CONFIG_GPIO=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=1
CONFIG_LOG_BUFFER_SIZE=8192
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=n
# Debugging Needs for the Application
CONFIG_ASSERT=y
CONFIG_DEBUG=y
CONFIG_DEBUG_INFO=y
CONFIG_FAULT_DUMP=2
# Thread Stack Tracking
CONFIG_INIT_STACKS=y
CONFIG_THREAD_STACK_INFO=y
# Related to Sending the Data to Console
CONFIG_RING_BUFFER=y
# About both threads distributing their time
CONFIG_TIMESLICING=y
# UART Asynchronous API aand data sending
# Configuration options for SD Card and the drive access
#Allows printing floating-points (used to print voltage)
CONFIG_CBPRINTF_FP_SUPPORT=y
#System will reset upon reaching a fatal error, disabled to allow for debugging
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_DISK_ACCESS=y
CONFIG_DISK_DRIVERS=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_FILE_SYSTEM=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_MAIN_STACK_SIZE=2048
# regarding Power Setup
# FIFO operation in Zephyr
CONFIG_DATA_FIFO=y
# FIle name operations in Zephyr
CONFIG_FS_FATFS_LFN=y
CONFIG_FS_FATFS_MAX_LFN=255
overlay:
&clock {
	status = "okay";
	hfclkaudio-frequency = <11289600>;
&gpio_fwd {
    status = "disabled";
&gpio0 {
    status = "okay";
&gpio1 {
    status = "okay";
&spi1 {
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
	cs-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; //CS for SD
    sdhc0: sdhc@0 {
        compatible = "zephyr,sdhc-spi-slot";
        reg = <0>;
        status = "okay";
        label = "SDHC0";
		spi-max-frequency = <400000>;
		mmc {
			compatible = "zephyr,sdmmc-disk";
			status = "okay";
			disk-name = "SD";
&pinctrl {
	spi1_default: spi1_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 1, 0)>,
					<NRF_PSEL(SPIM_MOSI, 1, 1)>,
					<NRF_PSEL(SPIM_MISO, 0, 10)>;
	spi1_sleep: spi1_sleep {
		group1 {
				// psels = <NRF_PSEL(SPIM_SCK, 0, 14)>, // 26 on MDBT dev kit
				// 	<NRF_PSEL(SPIM_MOSI, 0, 17)>,  // 27 on MDBT dev kit
				// 	<NRF_PSEL(SPIM_MISO, 0, 10)>;
				low-power-enable;
&uart1{
	status="disabled";
&i2c1{
	status="disabled";
Pin assignment for CS is 0.07.
The application is too big to be pasted here. But I believe it is an issue with the overlay and prj.conf files.
Here is the trace from logic analyzer:
As you can see, there is no activity on SCK and MOSI. Strangely CS oscillates.
Any pointers on what configuration settings I may be missing?
Update: The log results from printing the returning state after trying to initialize the SPI module and the SD card are as follows:
*** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***<\r><\n>
*** Using Zephyr OS v4.0.99-3e0ce7636fa6 ***<\r><\n>
[00014093] <27>[0m<inf> Main: Starting main thread<27>[0m<\r><\n>
[00014096] <27>[0m<inf> Main: Set up LED on gpio@842500 pin 28<27>[0m<\r><\n>
[00014096] <27>[0m<inf> SDCard: Initializing SPI device...<\n><27>[0m<\r><\n>
[00014096] <27>[0m<inf> SDCard: SPI initialization successful!<27>[0m<\r><\n>
[00020921] <27>[1;31m<err> sd: Card error on CMD0<27>[0m<\r><\n>
disk_access_init failed. Error code: -116 ()<\r><\n>
[00027629] <27>[1;31m<err> SDCard: Failed to initialize SD card<\n><27>[0m<\r><\n>
[00027630] <27>[1;31m<err> Main: Failed to initialize SPI<27>[0m<\r><\n>
