Unable to Flash nRF54L15 Using nRF52840 DK (J-Link OB) – Read Works but Programming Fails
I checked the information about nRF52840 DK versions supporting Cortex-M33 devices.
In my case, I am using an nRF52840 DK, but I am facing the following behavior:
  • The debugger detects the nRF54L15 over SWD
  • I am able to read the device ID
  • However, flashing fails (erase/write does not work)
Could you please help clarify:
  1. Does the J-Link OB on nRF52840 DK fully support flashing (erase/write) for nRF54L15, or is the support limited?
  2. Are there any specific requirements such as:
    • Minimum DK version (v3.0.0 or later)?
    • Required J-Link firmware version?
    • Required nRF Connect SDK / tools version?
  3. Is there any known limitation when using J-Link OB with nRF54L15 RRAM?
I want to confirm whether this setup is officially supported for programming, or if using an nRF54L15 DK / external J-Link is recommended.
Thanks!
  • Hi Pavanreddy0,
    The nRF52840DK should be able to flash the nrf54L15DK
    Minimum nRF52840DK version: v3.0.0 and newer can program Cortex M33 based nRF's (nRF53, nRF91, nRF54)
    Required J-Link: You should get at least V8.16 but I recommend getting something new like v9.24a
    SDK/tools: At least v2.9 but for the SDK but I recommend just using the latest version v3.2.4, nrfutil device should be v2.17.4 and newer.
    Also you should use a short cable (<10 cm)
    Thank you
