# Console disabled - uart30 used exclusively for MCUmgr SMP
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_PRINTK=y
CONFIG_LOG=y
CONFIG_MAIN_STACK_SIZE=8192
# ENABLE INTERNAL OSCILLATOR
# ENABLE SPI NOR FLASH
CONFIG_SPI=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_SPI_NOR=y
CONFIG_FILE_SYSTEM=y
CONFIG_FILE_SYSTEM_LITTLEFS=y
CONFIG_FILE_SYSTEM_MKFS=y
CONFIG_FS_LITTLEFS_READ_SIZE=4096
CONFIG_FS_LITTLEFS_PROG_SIZE=4096
CONFIG_FS_LITTLEFS_CACHE_SIZE=4096
CONFIG_FS_LITTLEFS_LOOKAHEAD_SIZE=128
CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x1000000
CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_MCUMGR=y
CONFIG_MCUMGR_TRANSPORT_UART=y
CONFIG_UART_MCUMGR=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_FS=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
CONFIG_BASE64=y
CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=2048
CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=8
CONFIG_MCUMGR_GRP_FS_DL_CHUNK_SIZE=512
#include <flash_map_pm.h>
#include <pm_config.h>
#include <zephyr/fs/fs.h>
#include <zephyr/fs/littlefs.h>
#include <zephyr/kernel.h>
#include <stdbool.h>
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#define LOG_LEVEL LOG_LEVEL_DBG
#define LFS_PARTITION_ID PM_littlefs_storage_ID
#define LFS_MOUNT_POINT "/lfs"
#define LFS_HEX_FILE LFS_MOUNT_POINT "/hex30.bin"
#define LFS_BIN_FILE_PREFIX LFS_MOUNT_POINT "/data30000_"
#define LOOP_DELAY_S 5
#define HEX_DATA_LEN 30
#define BIN_DATA_LEN 30000
#define BIN_CHUNK_SIZE 32
#define BIN_SEGMENT_SIZE 960
FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(lfs_cfg);
static struct fs_mount_t lfs_mnt = {
.type = FS_LITTLEFS,
.mnt_point = LFS_MOUNT_POINT,
.fs_data = &lfs_cfg,
.storage_dev = (void *)LFS_PARTITION_ID,
static bool lfs_is_mounted;
static int littlefs_mount_with_format(void)
if (lfs_is_mounted)
printk("LittleFS already mounted at %s\n", LFS_MOUNT_POINT);
return 0;
int ret = fs_mount(&lfs_mnt);
if (ret == 0)
lfs_is_mounted = true;
return 0;
printk("LittleFS mount failed (%d)\n", ret);
#if defined(CONFIG_FILE_SYSTEM_MKFS) && CONFIG_FILE_SYSTEM_MKFS
printk("Formatting LittleFS partition and retrying mount...\n");
ret = fs_mkfs(FS_LITTLEFS, (uintptr_t)lfs_mnt.storage_dev, lfs_mnt.fs_data, 0);
if (ret != 0)
printk("LittleFS format failed: %d\n", ret);
return ret;
if (ret != 0)
printk("LittleFS mount after format failed: %d\n", ret);
return ret;
return 0;
#else
printk("Enable CONFIG_FILE_SYSTEM_MKFS to auto-format on first boot\n");
return ret;
void read_file(void)
struct fs_file_t file;
char buf[128]; // small buffer is fine
fs_file_t_init(&file);
int ret = fs_open(&file, "/lfs/myfile6.txt", FS_O_READ);
if (ret < 0)
printk("Open failed: %d\n", ret);
return;
while (1)
ret = fs_read(&file, buf, sizeof(buf));
if (ret <= 0)
printk("Bytes read: %d\n", ret);
for (int i = 2; i < ret; i += 2)
printk("%c", buf[i]);
printk("\n--- END ---\n");
fs_close(&file);
int ret;
ret = littlefs_mount_with_format();
if (ret != 0)
printk("LittleFS mount failed: %d\n", ret);
printk("LittleFS mounted\n");
while (1)
// printk("print test\n");
read_file(); //
read file every loop
k_sleep(K_SECONDS(3));
aliases {
whiteled = &led0;
greenled = &led1;
redled = &led2;
blueled = &led0;
chosen {
nordic,pm-ext-flash = &w25q128;
zephyr,console = &uart30;
zephyr,shell-uart = &uart30;
zephyr,uart-mcumgr = &uart30;
leds {
compatible = "gpio-leds";
led0: led_0 {
gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; // Change pin as needed
label = "white-led";
led1: led_1 {
gpios = <&gpio0 1 GPIO_ACTIVE_LOW>;
label = "Green-led";
led2: led_2 {
gpios = <&gpio0 4 GPIO_ACTIVE_LOW>;
label = "Red-led";
//enable wdt30
&wdt30 {
status = "okay";
// Pin control configuration for SPI
&pinctrl {
spi20_default: spi20_default {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 1, 12)>,
<NRF_PSEL(SPIM_MOSI, 1, 13)>,
<NRF_PSEL(SPIM_MISO, 1, 8)>; // MISO pin
spi20_sleep: spi20_sleep {
group1 {
// low-power-enable;
// Enable SPI0 interface
&spi20 {
status = "okay";
pinctrl-0 = <&spi20_default>;
pinctrl-1 = <&spi20_sleep>;
cs-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
w25q128: w25q128@0 {
compatible = "jedec,spi-nor";
status = "okay";
reg = <0>;
spi-max-frequency = <8000000>;
jedec-id = [ef 40 18];
size = <0x1000000>;
&button0 {
gpios = <&gpio1 2 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
&wdt30 {
status = "okay";
&button2 {
gpios = <&gpio1 0 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
&uart30_sleep {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 2)>,
<NRF_PSEL(UART_RX, 0, 3)>,
<NRF_PSEL(UART_RTS, 1, 4)>,
<NRF_PSEL(UART_CTS, 1, 5)>;
&uart30_default {
group2 {
psels = <NRF_PSEL(UART_RX, 0, 3)>, <NRF_PSEL(UART_CTS, 1, 5)>;
group1 {
psels = <NRF_PSEL(UART_TX, 0, 2)>, <NRF_PSEL(UART_RTS, 1, 4)>;
// &button3 {
// gpios = <&gpio0 2 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
&button0 {
&button1 {
gpios = <&gpio2 9 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
&button2 {
gpios = <&gpio2 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
&uart20 {
status = "disabled";
&uart30 {
status = "okay";
current-speed = <115200>;
pinctrl-0 = <&uart30_default>;
pinctrl-1 = <&uart30_sleep>;
i am trying to upload the file which has almost 3kb data but it is getting failed at around 1k+ or - this is error PS D:\nrf_projects\little_fs_nrf54l05> newtmgr --conntype serial --connstring "dev=COM5,baud=115200,mtu=120" fs upload myfile.txt /lfs/myfile.txt
28
55
82
109
136
163
190
217
244
271
297
323
349
375
401
427
453
479
505
531
557
583
609
635
661
687
713
739
765
791
817
843
869
895
921
947
973
999
0
Error: 1
28
55
82
109
136
163
190
217
244
271
297
323
349
375
401
427
453
479
505
531
557
583
609
635
661
687
713
739
765
791
817
843
869
895
921
947
973
999
0
Error: 1
