Building prj.conf
Hi everyone i have a problem with building a project, i dont know what i did wrong, before everything was building fine, but now if i pristine build any project some lines in prj.conf arent included in the build. For example this one
CONFIG_UART_INTERRUPT_DRIVEN=y     In build : n
and msg
CONFIG_UART_INTERRUPT_DRIVEN was assigned the value y, but got the value n. Missing dependencies:
SHIELD_SPARKFUN_CARRIER_ASSET_TRACKER || (NETWORKING && SHIELD_SPARKFUN_SARA_R4) || (NETWORKING && SHIELD_WNC_M14A2A) || (SERIAL && SOC_EOS_S3) || (SERIAL_SUPPORT_INTERRUPT && SERIAL)
UART Interrupt support
Type: bool
Value: n
This option enables interrupt support for UART allowing console input and other UART based drivers.
Value has changed in the build.
I have tried everything, multiple pristibe builds, sys build, default build, west build and i dont know why but in every project that i know it was working fine, when i do now a pristine build its same result as this one. Im using a Visual Studio Code, did someone also had similar exp, and how can i resolve this. Btw this is my prj.conf
CONFIG_CONSOLE=y
CONFIG_SERIAL=y
CONFIG_PRINTK=y
CONFIG_PWM=y
CONFIG_GPIO=y
CONFIG_LOG=y
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=y
CONFIG_USB_CDC_ACM=y
CONFIG_USB_DEVICE_PRODUCT="STEP MOTOR"
CONFIG_USB_CDC_ACM_RINGBUF_SIZE=16384
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_RTT_CONSOLE=n
Thank u.
