Dear support team,
I'm using:
- nrf9151
- nRF Connect SDK v3.2.3
I'm currently working on a project where I need to use MQTT and CoAP simultaneously, it works for around 2-3 minutes and then the MQTT disconnects it's session giving this error:
<err> mqtt_helper: Socket error: POLLERR
<err> mqtt_helper: Connection was unexpectedly closed
<wrn> mqtt_module: MQTT disconnected: -113
<wrn> mqtt_module: MQTT reconnect triggered
<err> mqtt_helper: getaddrinfo() failed, error -10
I'm using the mqtt_helper lib provided by nordic that sits on top of the zephyr MQTT API. I tried a couple of methods like:
- Giving time intervals between sending the MQTT message and CoAP message( around 10 seconds delay between them).
- Also, tried to make the MQTT wait and not send unless RRC is connected.
- Then I tried to send 1 MQTT message then 20 CoAP messages then another 1 MQTT message. The first MQTT is sent and then the 20 CoAP messages but before sending the last MQTT message the broker disconnects again.
- Tried with disabling PSM and EDRX and tried with them enabled as well.
Is it a problem with the configurations or how can I use MQTT and CoAP together? and are there limitations to using them similtaniously?
Note: the MQTT and CoAP works just fine when I use only one of them on alone as soon as I use them together MQTT disconnects.
Mohamed Selim
