MCU:NRF54L15,NCS SDK V3.2.4,android 7.0, nrf connect 4.26.1, cannot connect stably.
about 40 seconeds, the connect will disconnect, the android 7.0 side:reason is 0x08, the nrf54l15 side, reason is 0x22
prj.conf
prj.conf
Does it only happen to Android 7.0? Could you try another newer Android version?
Could you provide the nRF-Sniffer-for-Bluetooth-LE log?
prj.conf
CONFIG_BT_AUTO_PHY_UPDATE=nCONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
Does it work if you remove these two configs?
Might I know any special reason to disable automatic PHY updates and connection parameter updates?
Are you able to reproduce the issue on nRF54L15DK? Or does it only happen on your custom board?
Amanda H.
On my board,no nRF-Sniffer-for-Bluetooth-LE log, android 14, nrf connect 4.49, work ok.
Nordfield said:android 14, nrf connect 4.49, work ok.
Seems the issue is on Android 7.0, which might have a restricted connection parameter requirement.
Does it work if you remove "CONFIG_BT_AUTO_PHY_UPDATE=n" and "CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n"?
Maybe that, The Copilot can not fit it too.
But, the nrf53832,sdk 17.0, android 7.0 , work ok.
