Buttonless USB DFU does not work with new USB stack
I am trying to develop an application with USB DFU support using nRF Connect v3.2.2. I followed the lesson posted under Nordic Dev Academy on USB DFU.
The board that I am working with does not have a button, so I ran into some compile errors; however, I was able to get around the compile errors with this in my mcuboot.conf.
# mcuboot.conf
CONFIG_LOG=n
CONFIG_MCUBOOT_SERIAL=y
CONFIG_UART_CONSOLE=n
CONFIG_SINGLE_APPLICATION_SLOT=y
CONFIG_MCUBOOT_INDICATION_LED=y
CONFIG_BOOT_SERIAL_CDC_ACM=y
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x11000
CONFIG_BOOT_MAX_IMG_SECTORS=512
CONFIG_BOOT_SERIAL_ENTRANCE_GPIO=n
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=y
CONFIG_BOOT_SERIAL_BOOT_MODE=n
CONFIG_BOOT_SERIAL_PIN_RESET=n
But I am running into a new issue with the device USB not showing up on the host computer. The only way that I can get the USB to show up on the host computer and have USB DFU is if I use the old USB stack. Is there anything that I might be missing when it comes to the configuration?
  • Hi Tom,
    Could you try this on the l9_e4_sol project and add the following configs into sysbuild/mcuboot.conf?
    # Enable wait for DFU functionality
    CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=5000
    Amanda H.
  • Hi Amanda,
    I added those configs to mcuboot.conf in l9_e4_sol and I added "CONFIG_BOOT_SERIAL_ENTRANCE_GPIO=n" as well since the devkit (rak4631/nrf52840) I am working with does not have a button and things were not compiling. The board boots up into mcuboot and spends 5 seconds in the bootloader as expected. During that time, I can see the USB being enumerated by the host computer. When it enters into the application, it no longer get enumerated by the host computer which is unexpected behavior.
    Tom
  • Ok,
    After some hacking around today (I continued using the deprecated stack for a few months), I was able to get the new stack to work. The first thing that I did was upgrade the SDK from v3.2.2 to v3.3.1.
    The here is the mcuboot.overlay and mcuboot.conf for reference.
    	aliases {
    		mcuboot-led0 = &green_led;
    &zephyr_udc0 {
    	cdc_acm_uart0: cdc_acm_uart0 {
    		compatible = "zephyr,cdc-acm-uart";
    CONFIG_LOG=y
    CONFIG_MCUBOOT_LOG_LEVEL_WRN=y
    CONFIG_SINGLE_APPLICATION_SLOT=n
    CONFIG_BOOT_SERIAL_NO_APPLICATION=y
    Tom
  • Tested the same overlay and configs with v3.2.2 and found they worked on that version too.
