I am trying to set up a secure boot chain on nRF54L15dk with NCS 3.2.3 and an upgradable bootloader.
My intended boot chain is:
- B0 / NSIB
- S0 / S1 for the second-stage bootloader (MCUboot, so that MCUboot itself is upgradable)
- mcuboot_primary / mcuboot_secondary for the application
The application secondary slot is located in external flash.
I am currently using a static partition layout and building with sysbuild.
b0:
address: 0x00000
region: flash_primary
provision:
address: 0x0C000
b0_container:
address: 0x00000
span:
- b0
- provision
s0_pad:
address: 0x10000
mcuboot:
address: 0x10800
s0_image:
address: 0x10800
span:
- mcuboot
s0:
address: 0x10000
span:
- s0_pad
- s0_image
s1_pad:
address: 0x20000
s1_image:
address: 0x20800
s1:
address: 0x20000
span:
- s1_pad
- s1_image
mcuboot_pad:
address: 0x30000
mcuboot_primary:
address: 0x30000
span:
- mcuboot_pad
- app
mcuboot_primary_app:
address: 0x30800
span:
- app
settings_storage:
address: 0x155000
mcuboot_secondary:
address: 0x000000
region: external_flash
external_reserved:
address: 0x0E4000
littlefs_storage:
address: 0x1C0000
size: 0x040000My sysbuild.conf:
# Enabele partition manager for sysbuild multi-image support SB_CONFIG_PARTITION_MANAGER=y # Immutable first stage + upgradable second stage SB_CONFIG_SECURE_BOOT_APPCORE=y SB_CONFIG_BOOTLOADER_MCUBOOT=y # Put the application secondary slot into external SPI NOR SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y # nRF54L secure boot / signing # Use real keys in production. Absolute paths are the least painful. SB_CONFIG_SECURE_BOOT_SIGNATURE_TYPE_ED25519=y #SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y # Use swap-based updates, which are more robust than overwrite-based updates. SB_CONFIG_MCUBOOT_MODE_OVERWRITE_ONLY=y #SB_CONFIG_MCUBOOT_MODE_SWAP_USING_MOVE=y SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="b0_dev_key.pem" # Optional, but recommended on nRF54L if you want MCUboot to validate # with keys provisioned in KMU too, instead of only compiled-in keys. #SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU=y # Helpful during development: # generate keyfile.json so provisioning can be tied to flashing #SB_CONFIG_SECURE_BOOT_GENERATE_DEFAULT_KMU_KEYFILE=n #SB_CONFIG_MCUBOOT_GENERATE_DEFAULT_KMU_KEYFILE=y # Protect S0/S1 bootloader updates in B0 SB_CONFIG_SECURE_BOOT_MCUBOOT_VERSION="1.0.0+0" SB_CONFIG_SECURE_BOOT_MONOTONIC_COUNTER=n # Do NOT protect application downgrades in MCUboot #SB_CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION=n # SB_CONFIG_MCUBOOT_HW_DOWNGRADE_PREVENTION_COUNTER_VALUE=1
My b0.conf:
# b0 logging CONFIG_LOG=y CONFIG_LOG_MODE_MINIMAL=y CONFIG_SECURE_BOOT_VALIDATION_LOG_LEVEL_INF=y CONFIG_CONSOLE=y CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_UART_CONSOLE=n # Flash support for secure bootloader CONFIG_FLASH=y CONFIG_FLASH_MAP=y # Disable SPI and SPI NOR in b0 CONFIG_SPI=n CONFIG_SPI_NOR=n #CONFIG_PM_DEVICE=n
Goal
I want:
- B0/NSIB as first-stage bootloader
- MCUboot as upgradable second-stage bootloader in S0/S1
- Application in mcuboot_primary
- Application update image in mcuboot_secondary in external flash
Current configuration idea
I currently want to use:
- Ed25519 key for NSIB/B0
- MCUboot signed with your dev key
- No KMU for MCUboot yet
- KMU only where required for NSIB/B0 on nRF54L15
I also temporarily disabled the monotonic counter to simplify bring-up.
Problem
Initially I got this error:
00> Fprotect disabled. No protection applied. 00> Attempting to boot slot 0. 00> Attempting to boot from address 0x10800. 00> I: Trying to get Firmware version 00> E: Error getting monotonic counter 00> E: Cannot read the firmware version. -22 00> Failed to validate, permanently invalidating! 00> Attempting to boot slot 1. 00> Attempting to boot from address 0x20800. 00> I: Trying to get Firmware version 00> E: Error getting monotonic counter 00> E: Cannot read the firmware version. -22 00> Failed to validate, permanently invalidating! 00> No bootable image found. Aborting boot.
After disabling the monotonic counter, I now get:
00> Attempting to boot from address 0x10800. 00> I: Trying to get Firmware version 00> E: verify_public_keys() returned -113. 00> I: A public key contains 0xFFFF, which is unsupported 00> Failed to validate, permanently invalidating! 00> Attempting to boot slot 1. 00> Attempting to boot from address 0x20800. 00> I: Trying to get Firmware version 00> E: verify_public_keys() returned -113. 00> I: A public key contains 0xFFFF, which is unsupported 00> Failed to validate, permanently invalidating! 00> No bootable image found. Aborting boot.
What I tried:
west build -> ok nrfjprog --recover -> ok build$ west ncs-provision upload -s nrf54l15 -k ../b0_dev_key.pem --keyname BL_PUBKEY nrfutil device x-provision-keys --key-file /tmp/nrfutil__o9cxm52/keyfile.json --traits jlink Uploaded! -> ok west flash -> ok
I also tried to use different ED25519 keys.
I also tried to use:
If you could help me out here, I would be very happy.
Daniel
