Build Issue GNSS application
Hello Team,
I tried building an example application available in SDK v3.0.0 for Thingy 91x_nrf9151. But its showing some build issues. Which I am not able to figure it out.
Will you please guide me how can I solve this, or will you please let me know where I am wrong.
Adding log files with this query.
Thanks and regards,
Vinay
 *  Executing task: nRF Connect: Build [clean]: gnss/build/gnss
Building gnss
west build -t clean --build-dir c:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss
-- west build: running target clean
[2/2] Cleaning all built files...
Cleaning... 326 files.
 *  Executing task: nRF Connect: Build [pristine]: gnss/build
Building gnss
west build --build-dir c:/ncs/v3.0.0/nrf/samples/cellular/gnss/build c:/ncs/v3.0.0/nrf/samples/cellular/gnss --pristine --board thingy91x/nrf9151/ns -- -DCONF_FILE="prj.conf" -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dgnss_DEBUG_THREAD_INFO=On -Dmcuboot_DEBUG_THREAD_INFO=Off -Db0_DEBUG_THREAD_INFO=Off -Ds1_image_DEBUG_THREAD_INFO=Off
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/fd21892d0f/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: C:/ncs/v3.0.0/zephyr/.cache
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: thingy91x, qualifiers: nrf9151/ns
Parsing C:/ncs/v3.0.0/zephyr/share/sysbuild/Kconfig
Loaded configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/_sysbuild/empty.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/_sysbuild/empty.conf'
Configuration saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/zephyr/.config'
Kconfig header saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/_sysbuild/autoconf.h'
   * Running CMake for mcuboot *
-- Application: C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.21.0
-- Zephyr version: 4.0.99 (C:/ncs/v3.0.0/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/fd21892d0f/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151.dts
-- Found devicetree overlay: C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/boards/thingy91x_nrf9151.overlay
-- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot/zephyr/zephyr.dts
-- Generated pickled edt: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration 'C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_defconfig'
Merged configuration 'C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/boards/thingy91x_nrf9151.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/modules/mcuboot/tfm.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/subsys/bootloader/bl_override/override_external_mcuboot.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/subsys/bootloader/image/log_minimal.conf'
Merged configuration 'C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/external_crypto.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot/zephyr/.config.sysbuild'
Configuration saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
MCUBoot bootloader key file: C:/ncs/v3.0.0/bootloader/mcuboot/root-ec-p256.pem
CMake Warning at CMakeLists.txt:393 (message):
  WARNING: Using default MCUboot signing key file, this file is for debug use
  only and is not secure!
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/mcuboot
   * Running CMake for b0 *
-- Application: C:/ncs/v3.0.0/nrf/samples/bootloader
-- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0/zephyr/zephyr.dts
-- Generated pickled edt: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0/zephyr/dts.cmake
Parsing C:/ncs/v3.0.0/zephyr/Kconfig
Merged configuration 'C:/ncs/v3.0.0/nrf/samples/bootloader/prj.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0/zephyr/.config.sysbuild'
Configuration saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0/zephyr/.config'
Kconfig header saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0/zephyr/include/generated/zephyr/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/b0
   * Running CMake for gnss *
-- Application: C:/ncs/v3.0.0/nrf/samples/cellular/gnss
-- Found BOARD.dts: C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_ns.dts
-- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/zephyr.dts
-- Generated pickled edt: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/dts.cmake
warning: UPDATEABLE_IMAGE_NUMBER (defined at
C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x\Kconfig.defconfig.nrf5340:92,
C:/ncs/v3.0.0/nrf\samples\common\mcumgr_bt_ota_dfu/Kconfig:99, subsys/dfu/Kconfig:96) was assigned
the value '1' but got the value ''. See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UPDATEABLE_IMAGE_NUMBER and/or look up
UPDATEABLE_IMAGE_NUMBER in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: PM_DEVICE_RUNTIME (defined at C:/ncs/v3.0.0/zephyr/soc/nordic\nrf54h\Kconfig.defconfig:45,
subsys/pm/Kconfig:96) was assigned the value 'y' but got the value 'n'. Check these unsatisfied
dependencies: ((SOC_SERIES_NRF54HX && SOC_FAMILY_NORDIC_NRF) || PM_DEVICE) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM_DEVICE_RUNTIME and/or look up
PM_DEVICE_RUNTIME in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: MCUBOOT_UPDATE_FOOTER_SIZE (defined at subsys/dfu/Kconfig:55) was assigned the value
'0x3000' but got the value ''. Check these unsatisfied dependencies: MCUBOOT_IMG_MANAGER (=n),
IMG_MANAGER (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE and/or look up
MCUBOOT_UPDATE_FOOTER_SIZE in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
Parsing C:/ncs/v3.0.0/nrf/samples/cellular/gnss/Kconfig
Loaded configuration 'C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_ns_defconfig'
Merged configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/prj.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/misc/generated/extra_kconfig_options.conf'
Merged configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/.config.sysbuild'
Configuration saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/.config'
Kconfig header saved to 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/include/generated/zephyr/autoconf.h'
[0m=========== Generating psa_crypto_config ===============
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
[0mBackup: CONFIG_MBEDTLS_THREADING: False
Backup: CONFIG_MBEDTLS_THREADING_ALT: False
=========== Checkpoint: backup ===============0m
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
[0mRestore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
Restore: CONFIG_MBEDTLS_THREADING: False
[0mRestore: CONFIG_MBEDTLS_THREADING_ALT: False
0m=========== End psa_crypto_config ===============
[0m=========== Generating psa_crypto_library_config ===============
[0mBackup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False
mBackup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
0mBackup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
=========== Checkpoint: backup ===============m
[0mRestore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
m=========== End psa_crypto_library_config ===============
-- Including signing script: C:/ncs/v3.0.0/nrf/cmake/sysbuild/image_signing.cmake
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss
   * Running CMake for s1_image *
-- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/s1_image/zephyr/zephyr.dts
-- Generated pickled edt: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/s1_image/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/s1_image/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/s1_image/zephyr/dts.cmake
[33mCMake Warning at CMakeLists.txt:393 (message):
-- Configuring done
-- Generating done
CMake Warning:
  Manually-specified variables were not used by the project:
    EXTRA_KCONFIG_TARGETS
    FORCED_CONF_FILE
-- Build files have been written to: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/s1_image
-- Found partition manager static configuration : C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf9151_pm_static.yml
Partition 'b0' is not included in the dynamic resolving since it is statically defined.
Partition 'b0_container' is not included in the dynamic resolving since it is statically defined.
Partition 's0' is not included in the dynamic resolving since it is statically defined.
Partition 's0_pad' is not included in the dynamic resolving since it is statically defined.
Partition 's0_image' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 's1' is not included in the dynamic resolving since it is statically defined.
Partition 's1_pad' is not included in the dynamic resolving since it is statically defined.
Partition 's1_image' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'tfm_secure' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'app_image' is not included in the dynamic resolving since it is statically defined.
Partition 'tfm' is not included in the dynamic resolving since it is statically defined.
Partition 'tfm_nonsecure' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
Dropping partition 'nonsecure_storage' since it is empty.
-- Configuring done
-- Generating done
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
Loaded configuration 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/.config'
No change to configuration in 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/.config'
No change to Kconfig header in 'C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/include/generated/zephyr/autoconf.h'
0mBackup: CONFIG_MBEDTLS_THREADING_ALT: False
-- Configuring done
-- Generating done
[4/360] Generating include/generated/zephyr/version.h
-- Zephyr version: 4.0.99 (C:/ncs/v3.0.0/zephyr), build: v4.0.99-ncs1
[10/360] Generating ../../tfm/CMakeCache.txt
-- Found Git: C:/ncs/toolchains/fd21892d0f/mingw64/bin/git.exe (found version "2.52.0.windows.1")
-- Found Python3: C:/ncs/toolchains/fd21892d0f/opt/bin/python.exe (found version "3.12.4") found components: Interpreter
-- Configuring done
-- Generating done
-- Build files have been written to: C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/tfm
[7/140] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/target_cfg.o
In file included from C:/ncs/v3.0.0/modules/hal/nordic/nrfx/nrfx.h:38,
                 from C:/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/board/tfm_peripherals_config.h:15,
                 from C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:21:
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c: In function 'nvic_interrupt_target_state_cfg':
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:891:72: warning: iteration 1 invokes undefined behavior [-Waggressive-loop-optimizations]
  891 |                 NVIC_ClearTargetState(NRFX_IRQ_NUMBER_GET(spu_instances[i]));
C:/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/nrfx_common.h:570:66: note: in definition of macro 'NRFX_PERIPHERAL_ID_GET'
  570 | #define NRFX_PERIPHERAL_ID_GET(base_addr) (uint16_t)(((uint32_t)(base_addr) >> 12) & 0x000001FF)
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:891:39: note: in expansion of macro 'NRFX_IRQ_NUMBER_GET'
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:890:26: note: within this loop
  890 |         for(int i = 0; i < ARRAY_SIZE(spu_instances); i++) {
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c: In function 'nvic_interrupt_enable':
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:916:71: warning: iteration 1 invokes undefined behavior [-Waggressive-loop-optimizations]
  916 |                 NVIC_ClearPendingIRQ(NRFX_IRQ_NUMBER_GET(spu_instances[i]));
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:916:38: note: in expansion of macro 'NRFX_IRQ_NUMBER_GET'
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:915:26: note: within this loop
  915 |         for(int i = 0; i < ARRAY_SIZE(spu_instances); i++) {
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c: In function 'spu_periph_init_cfg':
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:1495:60: warning: iteration 29 invokes undefined behavior [-Waggressive-loop-optimizations]
 1495 |         spu_peripheral_config_non_secure(target_peripherals[i], SPU_LOCK_CONF_UNLOCKED);
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:1494:23: note: within this loop
 1494 |     for (int i = 0; i < ARRAY_SIZE(target_peripherals); i++) {
In file included from C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.h:25,
                 from C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:31:
In function 'nrf_spu_gpio_config_set',
    inlined from 'spu_periph_init_cfg' at C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:1518:3:
C:/ncs/v3.0.0/modules/hal/nordic/nrfx/hal/nrf_spu.h:914:37: warning: iteration 1 invokes undefined behavior [-Waggressive-loop-optimizations]
  914 |     p_reg->GPIOPORT[gpio_port].PERM = gpio_mask;
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:1517:32: note: within this loop
 1517 |         for(int port = 0; port < ARRAY_SIZE(secure_pins); port++){
C:/ncs/v3.0.0/modules/hal/nordic/nrfx/hal/nrf_spu.h:914:20: warning: array subscript 1 is above array bounds of 'volatile SPU_GPIOPORT_Type[1]' [-Warray-bounds]
In file included from C:/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk/nrf.h:273,
                 from C:/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/board/RTE_Device.h:18,
                 from c:\ncs\v3.0.0\modules\tee\tf-m\trusted-firmware-m\platform\ext\target\nordic_nrf\common\core\nrfx_config.h:35,
                 from C:/ncs/v3.0.0/modules/hal/nordic/nrfx/nrfx.h:37:
C:/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk/nrf9120.h: In function 'spu_periph_init_cfg':
C:/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk/nrf9120.h:1448:27: note: while referencing 'GPIOPORT'
 1448 |   __IOM SPU_GPIOPORT_Type GPIOPORT[1];          /*!< (@ 0x000004C0) Unspecified                                                */
C:/ncs/v3.0.0/modules/hal/nordic/nrfx/hal/nrf_spu.h:918:24: warning: array subscript 1 is above array bounds of 'volatile SPU_GPIOPORT_Type[1]' [-Warray-bounds]
  918 |         p_reg->GPIOPORT[gpio_port].LOCK = (SPU_GPIOPORT_LOCK_LOCK_Msk);
[101/140] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c: In function 'spu_enable_interrupts':
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c:105:17: warning: iteration 1 invokes undefined behavior [-Waggressive-loop-optimizations]
  105 |                 nrf_spu_int_enable(spu_instances[i], mask);
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c:104:26: note: within this loop
  104 |         for(int i = 0; i < ARRAY_SIZE(spu_instances); i++) {
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c: In function 'spu_events_get':
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c:114:45: warning: iteration 1 invokes undefined behavior [-Waggressive-loop-optimizations]
  114 |         if(nrf_spu_event_check(spu_instances[i], NRF_SPU_EVENT_PERIPHACCERR)){
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c:113:22: note: within this loop
  113 |     for(int i = 0; i < ARRAY_SIZE(spu_instances); i++) {
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c: In function 'spu_clear_events':
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c:158:17: warning: iteration 1 invokes undefined behavior [-Waggressive-loop-optimizations]
  158 |                 nrf_spu_event_clear(spu_instances[i], NRF_SPU_EVENT_RAMACCERR);
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers/spu.c:156:26: note: within this loop
  156 |         for(int i = 0; i < ARRAY_SIZE(spu_instances); i++) {
[103/140] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/hw_init.o
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/hw_init.c: In function 'hw_init_reset_on_boot':
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/hw_init.c:115:31: warning: iteration 16 invokes undefined behavior [-Waggressive-loop-optimizations]
  115 |                 NVIC->ICER[i] = 0xFFFFFFFF;
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/hw_init.c:114:27: note: within this loop
  114 |         for (int i = 0; i < ARRAY_SIZE(NVIC->ICER); i++) {
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/hw_init.c:119:31: warning: iteration 16 invokes undefined behavior [-Waggressive-loop-optimizations]
  119 |                 NVIC->ICPR[i] = 0xFFFFFFFF;
C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/hw_init.c:118:27: note: within this loop
  118 |         for (int i = 0; i < ARRAY_SIZE(NVIC->ICPR); i++) {
[136/140] Linking C executable bin\tfm_s.axf
           FLASH:       31564 B      32256 B     97.85%
             RAM:       10404 B        40 KB     25.40%
[17/360] Performing install step for 'tfm'
-- Install configuration: "MinSizeRel"
----- Installing platform NS -----
[99/360] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
In file included from C:/ncs/v3.0.0/zephyr/include/zephyr/sys/atomic.h:18,
                 from C:/ncs/v3.0.0/zephyr/include/zephyr/kernel_includes.h:25,
                 from C:/ncs/v3.0.0/zephyr/include/zephyr/kernel.h:17,
                 from C:/ncs/v3.0.0/zephyr/lib/os/fdtable.c:21:
C:/ncs/v3.0.0/zephyr/lib/os/fdtable.c: In function 'zvfs_fileno':
C:/ncs/v3.0.0/zephyr/include/zephyr/sys/util.h:164:49: warning: array subscript 17 is above array bounds of 'struct fd_entry[16]' [-Warray-bounds]
  164 |          POINTER_TO_UINT(ptr) < POINTER_TO_UINT(&(array)[ARRAY_SIZE(array)]) &&                    \
C:/ncs/v3.0.0/zephyr/include/zephyr/sys/util.h:48:42: note: in definition of macro 'POINTER_TO_UINT'
   48 | #define POINTER_TO_UINT(x) ((uintptr_t) (x))
C:/ncs/v3.0.0/zephyr/lib/os/fdtable.c:427:14: note: in expansion of macro 'IS_ARRAY_ELEMENT'
  427 |         if (!IS_ARRAY_ELEMENT(fdtable, file)) {
C:/ncs/v3.0.0/zephyr/lib/os/fdtable.c:45:24: note: while referencing 'fdtable'
   45 | static struct fd_entry fdtable[CONFIG_ZVFS_OPEN_MAX] = {
[110/360] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
FAILED: modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
C:\ncs\toolchains\fd21892d0f\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DK_HEAP_MEM_POOL_SIZE=2048 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF9120_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPICOLIBC_DOUBLE_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/include/generated/zephyr -IC:/ncs/v3.0.0/zephyr/include -IC:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/include/generated -IC:/ncs/v3.0.0/zephyr/soc/nordic -IC:/ncs/v3.0.0/zephyr/include/zephyr/posix -IC:/ncs/v3.0.0/zephyr/soc/nordic/nrf91/. -IC:/ncs/v3.0.0/zephyr/soc/nordic/common/. -IC:/ncs/v3.0.0/nrf/include -IC:/ncs/v3.0.0/nrf/lib/at_parser/include -IC:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/tfm/api_ns/interface/include -IC:/ncs/v3.0.0/nrf/modules/trusted-firmware-m/. -IC:/ncs/v3.0.0/nrf/include/tfm -IC:/ncs/v3.0.0/nrf/tests/include -IC:/ncs/v3.0.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v3.0.0/zephyr/modules/cmsis/. -IC:/ncs/v3.0.0/nrf/modules/hal_nordic/. -IC:/ncs/v3.0.0/modules/hal/nordic/nrfx -IC:/ncs/v3.0.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v3.0.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v3.0.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v3.0.0/nrfxlib/nrf_modem/include -IC:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/generated/interface_nrf_security_psa -IC:/ncs/v3.0.0/nrf/subsys/nrf_security/include -IC:/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include -IC:/ncs/v3.0.0/nrf/subsys/nrf_security/src/utils -IC:/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/library -IC:/ncs/v3.0.0/modules/crypto/mbedtls/library -IC:/ncs/v3.0.0/modules/crypto/mbedtls/include -IC:/ncs/v3.0.0/modules/crypto/mbedtls/include/library -IC:/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include -IC:/ncs/v3.0.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -isystem C:/ncs/v3.0.0/zephyr/lib/libc/common/include -fno-strict-aliasing -Os -imacros C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/gnss/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/fd21892d0f/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v3.0.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v3.0.0/nrf/samples/cellular/gnss=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v3.0.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v3.0.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -D_POSIX_THREADS -std=c99 -MD -MT modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj -MF modules\nrf\subsys\fw_info\CMakeFiles\..__nrf__subsys__fw_info.dir\fw_info.c.obj.d -o modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj -c C:/ncs/v3.0.0/nrf/subsys/fw_info/fw_info.c
In file included from C:/ncs/v3.0.0/zephyr/include/zephyr/toolchain.h:50,
                 from C:/ncs/v3.0.0/nrf/include/fw_info.h:16,
                 from C:/ncs/v3.0.0/nrf/subsys/fw_info/fw_info.c:7:
C:/ncs/v3.0.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "Mismatch in the number of allowed offsets."
   87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert((EXPR), "" MSG)
C:/ncs/v3.0.0/nrf/include/fw_info.h:153:1: note: in expansion of macro 'BUILD_ASSERT'
  153 | BUILD_ASSERT(ARRAY_SIZE(fw_info_allowed_offsets) == FW_INFO_OFFSET_COUNT,
[119/360] Linking C static library zephyr\libzephyr.a
[21/53] No configure step for 's1_image'
FAILED: _sysbuild/sysbuild/images/gnss-prefix/src/gnss-stamp/gnss-build C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build/_sysbuild/sysbuild/images/gnss-prefix/src/gnss-stamp/gnss-build
cmd.exe /C "cd /D C:\ncs\v3.0.0\nrf\samples\cellular\gnss\build\gnss && C:\ncs\toolchains\fd21892d0f\opt\bin\cmake.exe --build ."
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\fd21892d0f\opt\bin\cmake.EXE' --build C:/ncs/v3.0.0/nrf/samples/cellular/gnss/build
 *  The terminal process terminated with exit code: 1.
