How to read data by using fstorage
Hii all,
I am working on a project where I need to store data to persistent storage and retrieve back when the board is restart. but now we are migrated to simultaneous central and peripheral role and I found some thing like fstorage and I read this is just like pstorage but efficient than pstorage
So I would like to use this for my operation but its something wondering like when I look at the doc of fstorage we only have fs_store() and fs_erase() but nothing like fs_load(). Can any one suggest me is there any way to do that
I'm using nRF5_SDK_11.0.0_89a8197 Thank you
  • After calling fs_store() you will receive the FS_EVT_STORE event in the fs_evt_handler() when the flash operation is finished. Within the fs_evt_t structure you'll find the pointer to the data that was written to flash.
    To retrieve the data, you must create a pointer variable that should be used to store the pointer that points to the data in flash, i.e.
    const uint32_t * stored_data;
    and when you get the FS_EVT_STORE, simply set the pointer to point to the same address as the pointer that is returned in the fs_evt_handler(), i.e.
    static void fs_evt_handler(fs_evt_t const * const evt, fs_ret_t result)
        switch(evt->id)
            case FS_EVT_STORE:
                if(result == FS_SUCCESS)
                    stored_data = evt->store.p_data;
                    SEGGER_RTT_printf(0,"Stored Data: %X \n",*stored_data);
            case FS_EVT_ERASE:
                // Handle erase event
                //Do nothing
    This is provided that you run the following code snippet in main()
    FS_REGISTER_CFG(fs_config_t fs_config) =
            .callback  = fs_evt_handler,    // Function for event callbacks.
            .num_pages = 1,                 // Number of physical flash pages required.
            .priority  = 0xFE               // Priority for flash usage.
    fs_ret_t ret = fs_init();
    if (ret != FS_SUCCESS)
        SEGGER_RTT_printf(0,"FS ERROR OCCURED\n");
        // An error occurred.
    //Data to be written to flash
    static uint32_t data = 0x12345678;
    ret = fs_store(&fs_config, fs_config.p_start_addr, &data, 1);
    and that you have added the fs_sys_event_handler() function in sys_evt_dispatch(), i.e.
    static void sys_evt_dispatch(uint32_t sys_evt)
        ble_advertising_on_sys_evt(sys_evt);
        fs_sys_event_handler(sys_evt);
    -Bjørn
  • Yes, this is what i wrote a couple of comments up:
    You can store your data chunks at a specific flash address so that you know where to retrieve the data by dereferencing the pointer to that specific flash address.
