Separate Code from main.c for Nordic Development (separate c file for initialization)
hello,
Every example of nordic is done with only one main.c file , i want to have a separtate new.c and new.h file and take all the code from main.c and put it to the new.c and new.h , In the main file i just want to call only one initialization function this initialization call function will be in the new.c and new.h file
but i was not able to do it i get error , can some one post a sample code for this it will make code clean for me. thanks
looking for ward to answers , with examples would be great
  • This is very easy to do if you format your files properly and include the correct header files. Its always best to modulate your code as much as possible (though C does make this a bit for difficult than an OOP)
  • "Modulate"? I think you mean "modularise"
  • Dividing a 'C' program into separate files has nothing to do with Nordic; the principles are the same for any host system - so any 'C' textbook or reference should help.
    Here are some 'C' learning & reference resources: blog.antronics.co.uk/.../
    What error, exactly, are you getting?
  • I think all of the Nordic examples consist of multiple files?
    Again, it is nothing special or specific to Nordic - it's all standard 'C' stuff.
  • There are several things that must be done correctly and that could go wrong when moving code between files. the question is very general. What errors do you get?
