NRF54L15 ADC sampling gets stuck inside adc_read
Hi Dev,
Development platform: NRF54L15 + NCS 3.2.3
We are facing an issue with ADC sampling. The code occasionally gets stuck/hangs inside the adc_read function. This issue does not occur every time — it happens sporadically after long-term operation or under certain unknown conditions.
I have already narrowed down the issue and confirmed that the hang occurs inside adc_read.
Here is the code snippet:
c
int adc_single_channel_poll(uint8_t chan)
    if (chan >= ADC_CH_COUNT) return -EINVAL;
    int16_t             local_sample = 0;
    struct adc_sequence seq          = {
                 .channels    = BIT(channel_cfgs[chan].channel_id),
                 .buffer      = &local_sample,
                 .buffer_size = sizeof(local_sample),
                 .resolution  = 12,
    int err = adc_read(adc_dev, &seq);
    if (likely(err == 0))
        adc_raw[chan] = (local_sample < 0) ? 0 : local_sample;
    return err;
The execution gets stuck at adc_read() and never returns.
Could you please help clarify:
  1. Is this a driver-layer bug in the ADC driver provided with NCS 3.2.3?
  2. Or could it be a hardware issue with the NRF54L15 device itself?
  3. Are there any known issues or errata related to ADC on NRF54L15 that could cause occasional hangs in adc_read?
Any suggestions on how to further debug or work around this issue would be greatly appreciated.
Chen
  • Thanks, this observation is useful. I am trying to understand how the driver is working with this and it seems to be consistent of what you are saying.
    • calibrate = true is the only case where adc_read() runs through a multi-stage path: calibration must complete and fire CALIBRATEDONE, and only then does the driver start the actual conversion. The semaphore that adc_read() waits on is released only after that conversion finishes.
    • If the calibration step does not reach its CALIBRATEDONE callback, the conversion seems to be never started and adc_read() waits forever. The driver even has a branch that abandons the sequence without calling the callback if a STOP event arrives before CALIBRATEDONE.
    So this hang seems to be tied specifically to calibrate = true points to this calibration path, and it gives us a deterministic way to reproduce it, Once I reproduce this at my side, I will create an internal ticket and will try to see if I have the capability to debug it. I will treat this thread as a bug report.
  • Hi   and  ,
    Following up on my case about the nRF54L15 SAADC hang inside adc_read().
    Has the root cause been identified yet? Has it been fixed in a newer NCS/SDK release? If yes, which version contains the fix? If not, is there an internal ticket or known-issue entry I can track, and what is the expected timeline?
    I'd appreciate a direct answer on the root cause and fix status so I can plan accordingly.
    Chen
  • Hi Chen,
    Sorry, I lost track of this ticket during the summer holidays rush.
    Nothing has been done yet. I asked AI to make me a test application, and I'm currently running tests to reproduce the issue and test a fix AI suggested. Each test need to run for quite long periods so it will take some time before I'll get back to you. But you can be reassured that we are working on it now.
    I'll get back to you to share my findings before the end of the week.
    Simon
  • Hi Chen,
    Sorry, I was busier than expected, so I wasn't able to make a lot of progress.
    I tried to do some testing, but I haven't been able to reproduce the issue reliably yet.
    I'm still working on it.
    Simon
  • Hi Simon,
    Thanks for the update — understood, and thanks for continuing to look into it.
    Please just let us know once you have any findings or a conclusion, and we'll plan accordingly from there.
    Thanks again for your help.
    Chen
