nRF Connect SDK v3.2.3, nRF9160.
I'm working on a project which has MCUBoot enabled (dual slot) for firmware updates over cellular connection. I did not have a pm_static.yml file created originally, but I noticed this warning during compilation.
--------------------------------------------------------------------- --- WARNING: Using a bootloader without pm_static.yml. --- --- There are cases where a deployed product can consist of --- --- multiple images, and only a subset of these images can be --- --- upgraded through a firmware update mechanism. In such cases, --- --- the upgradable images must have partitions that are static --- --- and are matching the partition map used by the bootloader --- --- programmed onto the device. --- ---------------------------------------------------------------------
I went to the build folder and found the auto generated pm.yml file, then copy-pasted the sections related to flash into my own pm_static.yml file. This appears to work and resolved the build warning. Is there another way to setup the partitions without taking it from a generated file? I'm using the defaults for dual slot MCUBoot, with the addition of NVS at the end of the primary flash.
I can see from an older thread this was suggested.
"You could build normally, with a dynamic partition allocation for the first release, and for future releases use <build_folder>/partitions.yml as your pm_static. "
devzone.nordicsemi.com/.../partition-manager-documentation-of-pm_static-yml-regions
I haven't copied the generated file completely, only the parts related to primary flash. Could I get confirmation that this is a proper setup to define static partitions in the context of dual slot MCUBoot? Also is there anything here which isn't strictly necessary (i.e. partitions, as well as information like spans)? Is there any risk to omitting the SRAM sections?
Thank you
pm_static.yml
EMPTY_0: address: 0xc000 end_address: 0x10000 placement: before: - mcuboot_pad region: flash_primary size: 0x4000 app: address: 0x18000 end_address: 0x80000 region: flash_primary size: 0x68000 mcuboot: address: 0x0 end_address: 0xc000 placement: align: end: 0x1000 before: - mcuboot_primary region: flash_primary size: 0xc000 mcuboot_pad: address: 0x10000 end_address: 0x10200 placement: align: start: 0x8000 before: - mcuboot_primary_app region: flash_primary size: 0x200 mcuboot_primary: address: 0x10000 end_address: 0x80000 orig_span: &id001 - tfm - app - mcuboot_pad region: flash_primary sharers: 0x1 size: 0x70000 span: *id001 mcuboot_primary_app: address: 0x10200 end_address: 0x80000 orig_span: &id002 - app - tfm region: flash_primary size: 0x6fe00 span: *id002 mcuboot_secondary: address: 0x80000 end_address: 0xf0000 placement: after: - mcuboot_primary align: start: 0x8000 region: flash_primary share_size: - mcuboot_primary size: 0x70000 nonsecure_storage: address: 0xf0000 end_address: 0x100000 orig_span: &id004 - nvs_storage region: flash_primary size: 0x10000 span: *id004 nvs_storage: address: 0xf0000 end_address: 0x100000 inside: - nonsecure_storage placement: align: start: 0x8000 before: - end region: flash_primary size: 0x10000 tfm: address: 0x10200 end_address: 0x18000 inside: - mcuboot_primary_app placement: before: - app region: flash_primary size: 0x7e00 tfm_nonsecure: address: 0x18000 end_address: 0x80000 orig_span: &id008 - app region: flash_primary size: 0x68000 span: *id008 tfm_secure: address: 0x10000 end_address: 0x18000 orig_span: &id009 - mcuboot_pad - tfm region: flash_primary size: 0x8000 span: *id009
MCUBoot config
# Enable MCUMGR CONFIG_MCUMGR=y # Enable MCUMGR management for both OS and Images CONFIG_MCUMGR_GRP_OS=y CONFIG_MCUMGR_GRP_IMG=y # MCUBOOT CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_IMG_MANAGER=y CONFIG_STREAM_FLASH=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_SECURE_BOOT=y CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n # Configure dependencies for MCUBOOT CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_FCB=y
