Config and Pinout
Hi, I'm using a WisBlock setup with:
• RAK19001 base board
• RAK4631 core
RAK18030 microphone in IO slot A
• RAK15002 microSD in IO slot B
I'm running Zephyr / nRF Connect SDK v3.2.4 on nRF52840.
The SD card works and WAV files are written correctly. The PDM driver also initializes and captures buffers successfully. However, the captured microphone data is not real audio. The raw blocks show a large startup transient, then an exponential decay, and then all samples become a constant value (around 7). Speaking or playing a tone directly into the microphone does not change the captured pattern.
We have already tested multiple PDM pin combinations in the Zephyr overlay, different channel selections, and also tried another microphone module. The behavior stays the same.
Could you please confirm the correct routing / pinapping / enable requirements for using RAK18030 on RAK19001 with RAK4631, specifically with RAK152 also installed in the other IO slot?
    You need to ensure that the pins you are using are correctly configured. I.e. that NFC are pins configured as GPIOS with &uicr { nfct-pins-as-gpios; }; in your board overlay if you are using them, or that the module have the pins accessible/routed to the base board. Other than that you should be able to choose pins freely.
    May I ask if you are using some sample firmware for your application? I.e. the DMIC driver sample? Please note that the frequency settings need to be changed in main.c to reflect the frequencies the ones which the RAK18030 microphone supports.
    It is also possible to share your overlay to get a second opinion on it from me (or community members), but please note that I am not familiar with the WisBlock system, so I would need some time to get to know it to provide proper feedback.
    Maria
  • Hi, thanks for swift answer, this is how our overlay looks like.:
    aliaser
    disk0 = &sdhc0;
    /* Aktiver PDM */
    &pdm0 {
    status = "ok";
    pinctrl-0 = <&pdm0_standard>;
    pinctrl-navn = "standard";
    /* Definer PDM-pinner */
    &pinctrl {
    pdm0_standard: pdm0_standard {
    gruppe1
    psels = <NRF_PSEL(PDM_CLK, 0, 20)>,
    <NRF_PSEL(PDM_DIN, 0, 19)>;
    /* Aktiver SPI0 for SD-kort */
    &spi0 {
    status = "ok";
    kompatibel = "nordisk, nrf-spim";
    cs-gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
    sdhc0: sdhc@0 {
    kompatibel = "zephyr, sdhc-spi-spor";
    reg = <0>;
    status = "ok";
    spi-maks-frekvens = <400000>;
    mmc
    kompatibel = "zephyr, sdmmc-disk";
    disknavn = "SD";
    status = "ok";
  • That overlay looks like it gotten heavily maimed by AI translation. You MUST NOT translate overlay files - switch any information source to native english without any translation active.
  • Hi, sorry did not see that. But its my mailsystem that "helps". Here is the code from VSC.
        aliases {
            disk0 = &sdhc0;
    /* Enable PDM */
    &pdm0 {
        status = "okay";
        pinctrl-0 = <&pdm0_default>;
        pinctrl-names = "default";
    /* Define PDM pins */
    &pinctrl {
        pdm0_default: pdm0_default {
            group1 {
    /* Enable SPI0 for SD card */
    &spi0 {
        status = "okay";
        sdhc0: sdhc@0 {
            compatible = "zephyr,sdhc-spi-slot";
            reg = <0>;
            status = "okay";
            spi-max-frequency = <400000>;
            mmc {
                compatible = "zephyr,sdmmc-disk";
                disk-name = "SD";
                status = "okay";
    Thank you for your patience and for updating with the proper overlay file.
    Pins P0.20 and P0.19 are configured to uart0 by default. Where do you disable uart0 or change its pin configuration? Potentially, choose other pins for PDM if you are using uart0.
    If the pins are not the issue, verifying the PDM clock frequency is a good next step.
    Maria
