Overwriting UICR (NFCPINS) on nRF52833 (BC833M) – how to enable readback protection without losing configuration?
I’m working with the Raytac BC833M module (nRF52833) and programming it via nrfjprog in a batch script.
I need to:
  1. Program my application firmware
  2. Configure a UICR register (NFCPINS) to disable NFC and enable GPIO usage for I2C
  3. Enable readback protection (APPROTECT)
My issue is I am writing to the NFCPINS register (UICR) at:
0x1000120C
using:
nrfjprog --memwr 0x1000120C --val 0xFFFFFFFE
This works correctly — I can confirm the value is written using --memrd, and it persists after reset.
However, when I then run:
nrfjprog --rbp all
the register is reverted back to:
0xFFFFFFFF
which re-enables NFC functionality and breaks my I2C communication.
What is the correct way to enable readback protection without overwriting other UICR registers like NFCPINS?
Additional Info:
  • Device: nRF52833 (BC833M)
  • Toolchain: nrfjprog (latest version)
  • Programming via J-Link
  • I wanted to provide an update on my previous issue regarding configuring UICR and enabling protection on a BC833M (nRF52833).
    I am now generating a separate UICR HEX file and merging it with my application using mergehex:
    :020000041000EA
    :04120C00FEFFFFFFE3   ; NFCPINS = GPIO
    :0412080000000000E2   ; APPROTECT enabled
    :00000001FF
    Merge command:
    mergehex.exe -m application.hex uicr_config.hex -o combined.hex
    After programming:
    nrfjprog.exe -f NRF52 --program combined.hex --verify
    I then read back the registers:
    nrfjprog.exe -f NRF52 --memrd 0x1000120C
    nrfjprog.exe -f NRF52 --memrd 0x10001208
    Both return the expected values:
    • NFCPINS = 0xFFFFFFFE
    • APPROTECT = 0x00000000
    However, when I subsequently connect a debugger, I observe that the NFC pins are no longer configured as GPIO (i.e., behavior suggests NFCPINS has reverted). I assume that the read is reading a non-latched value and once I connect a debugger to confirm the state, I am resetting and the register NFCPINS is as well.
    Are there methods to have this written value persist through a reset?
    Is there a known interaction between APPROTECT and UICR configuration that could cause this?
  • You may be observing correct behaviour; once APPROTECT has been set at the noted address it will take effect following the next reset. Once APPROTECT is in force - following that first reset - all UICR registers are unreadable (all FF) and debug is disabled. Forcing the debugger to connect will erase the UICR to clear APPROTECT to allow debugging, which clobbers NFC io setting.
    Bottom line is to test the NFC in the debugger APPROTECT must not be enabled. (unofficial response; hope it helps)
