I use an nRF5340 and nRF7002 on a custom board. My firmware is stable on the nRf7002-DK, but crashes on my custom board most of the time (mostly when connecting to the Cloud or after Wi-Fi provisioning via BLE).
Logs:
[00:00:51.429,687] <err> os: ***** BUS FAULT *****
[00:00:51.429,687] <err> os: Precise data bus error
[00:00:51.429,718] <err> os: BFAR Address: 0x4
[00:00:51.429,748] <err> os: r0/a1: 0x20001d20 r1/a2: 0x0019b6ff r2/a3: 0x20000f10
[00:00:51.429,748] <err> os: r3/a4: 0x00000000 r12/ip: 0x00000000 r14/lr: 0x00070e55
[00:00:51.429,779] <err> os: xpsr: 0x81100225
[00:00:51.429,809] <err> os: s[ 0]: 0x00010000 s[ 1]: 0x00000001 s[ 2]: 0x00000150 s[ 3]: 0x0006f38d
ASSERTION FAIL [z_spin_lock_valid(l)] @ WEST_TOPDIR/zephyr/include/zephyr/spinlock.h:136
Invalid spinlock 0x2000ba70
[00:00:51.429,870] <err> os: ***** HARD FAULT *****
[00:00:51.429,901] <err> os: Fault escalation (see below)
[00:00:51.429,901] <err> os: ARCH_EXCEPT with reason 4
[00:00:51.429,931] <err> os: r0/a1: 0x00000004 r1/a2: 0x00000088 r2/a3: 0x0000000c
[00:00:51.429,962] <err> os: r3/a4: 0x00000004 r12/ip: 0x0000000c r14/lr: 0x00070c67
[00:00:51.429,962] <err> os: xpsr: 0x21000005
[00:00:51.429,992] <err> os: s[ 0]: 0x20002a18 s[ 1]: 0x00005040 s[ 2]: 0x00000000 s[ 3]: 0x000aae01
[00:00:51.430,023] <err> os: s[ 4]: 0x200026e8 s[ 5]: 0x0002048f s[ 6]: 0x00000001 s[ 7]: 0x00000000
[00:00:51.430,023] <err> os: s[ 8]: 0x200026e8 s[ 9]: 0x0002061b s[10]: 0x0000000a s[11]: 0x2005d224
[00:00:51.430,053] <err> os: s[12]: 0x00000004 s[13]: 0x0002061b s[14]: 0x00000028 s[15]: 0x00000000
[00:00:51.430,084] <err> os: fpscr: 0x000b46e8
[00:00:51.430,084] <err> os: Faulting instruction address (r15/pc): 0x000930a8
[00:00:51.430,114] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:00:51.430,145] <err> os: Fault during interrupt handling
[00:00:51.430,175] <err> os: Current thread: 0x20007e58 (idle)
[00:00:51.627,197] <err> os: Halting system
.config file app core:
CONFIG_FLASH_MANAGEMENT=y CONFIG_IMU=y # # Application Workqueue Options # CONFIG_APP_WORKQUEUE_STACK_SIZE=3000 CONFIG_APP_WORKQUEUE_PRIORITY=0 # CONFIG_APP_WORKQUEUE_NO_YIELD is not set # end of Application Workqueue Options CONFIG_AZURE=y CONFIG_CLOUD_CONNECT_RETRIES=10 # CONFIG_AZURE_IOT_HUB_SAMPLE_DEVICE_ID_USE_HW_ID is not set # CONFIG_INTER_IC_UART is not set # # Memfault # CONFIG_QUEVA_MEMFAULT_OTA_POLLING_INTERVAL=3600 # end of Memfault # # Bluetooth Services # CONFIG_DEVICE_NAME_WITH_SN=y CONFIG_DEVICE_NAME="QUEVA0000" CONFIG_BT_CLOUD_NAME=y CONFIG_WIFI_PROVISIONING=y CONFIG_WIFI_PROV_ADV_DATA_UPDATE=y CONFIG_WIFI_PROV_ADV_DATA_UPDATE_INTERVAL=5 # CONFIG_BT_SECURE_SERVICES is not set # end of Bluetooth Services CONFIG_BT_SERVICES=y CONFIG_BT_CUSTOM_SERVICES=y # # Input/Output Sensors # CONFIG_ANALOG_SENSORS=y CONFIG_BATTERY_LEVEL=y CONFIG_BATTERY_LEVEL_READ_INTERVAL=5 CONFIG_BATTERY_EMPTY_CAPACITY=3200 CONFIG_BATTERY_MAX_CAPACITY=4100 CONFIG_DIGITAL_SENSORS=y CONFIG_USB_IN=y CONFIG_REBOOT_ON_USB_IN=y CONFIG_CHARGING_STATUS=y # end of Input/Output Sensors # # Zephyr Kernel # # CONFIG_INPUT is not set CONFIG_WIFI=y CONFIG_NET_L2_ETHERNET=y CONFIG_ADC_INIT_PRIORITY=50 # CONFIG_REGULATOR is not set CONFIG_WIFI_MGMT_AP_MAX_NUM_STA=4 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1536 CONFIG_BT_LONG_WQ_STACK_SIZE=1800 CONFIG_MAIN_STACK_SIZE=4416 CONFIG_FPU=y # CONFIG_LIBLC3 is not set CONFIG_BT_RX_STACK_SIZE=22000 CONFIG_SHELL_STACK_SIZE=4096 CONFIG_SERIAL=y CONFIG_SPI=y # CONFIG_MIPI_DSI is not set # CONFIG_MEMC is not set # CONFIG_MODEM is not set # CONFIG_UART_INTERRUPT_DRIVEN is not set # CONFIG_NET_IPV6 is not set CONFIG_BT_HCI_ACL_FLOW_CONTROL=y CONFIG_BT_HCI_VS=y CONFIG_SRAM_SIZE=448 CONFIG_BOARD_MILO_53=y CONFIG_BT_HCI_IPC=y CONFIG_HEAP_MEM_POOL_ADD_SIZE_BOARD=4096 CONFIG_NUM_IRQS=69 CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768 CONFIG_FLASH_SIZE=1024 CONFIG_FLASH_BASE_ADDRESS=0x0 CONFIG_MP_MAX_NUM_CPUS=1 CONFIG_SOC_RESET_HOOK=y CONFIG_CLOCK_CONTROL=y CONFIG_IDLE_STACK_SIZE=128 CONFIG_ISR_STACK_SIZE=1024 CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768 CONFIG_ROM_START_OFFSET=0 CONFIG_KERNEL_ENTRY="__start" CONFIG_BUILD_OUTPUT_BIN=y CONFIG_XIP=y CONFIG_HAS_FLASH_LOAD_OFFSET=y # CONFIG_COUNTER is not set # CONFIG_SRAM_VECTOR_TABLE is not set CONFIG_CPU_HAS_ARM_MPU=y # CONFIG_SHARED_INTERRUPTS is not set CONFIG_PM_DEVICE=y CONFIG_TICKLESS_KERNEL=y CONFIG_BT_AUTO_PHY_UPDATE=y CONFIG_BT_AUTO_DATA_LEN_UPDATE=y # CONFIG_BT_USER_PHY_UPDATE is not set CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30 CONFIG_USE_DT_CODE_PARTITION=y # CONFIG_MULTI_LEVEL_INTERRUPTS is not set # CONFIG_ZERO_LATENCY_IRQS is not set CONFIG_NUM_PREEMPT_PRIORITIES=15 CONFIG_NUM_METAIRQ_PRIORITIES=0 CONFIG_GEN_IRQ_VECTOR_TABLE=y # CONFIG_DYNAMIC_INTERRUPTS is not set CONFIG_GEN_ISR_TABLES=y CONFIG_INIT_STACKS=y CONFIG_TIMESLICE_SIZE=20 CONFIG_FLASH_LOAD_OFFSET=0x10000 # CONFIG_PM_DEVICE_SYSTEM_MANAGED is not set CONFIG_SYS_CLOCK_EXISTS=y CONFIG_INIT_ARCH_HW_AT_BOOT=y # CONFIG_BUILD_OUTPUT_S19 is not set CONFIG_BUILD_OUTPUT_HEX=y CONFIG_FLASH_FILL_BUFFER_SIZE=32 CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y CONFIG_FLASH=y CONFIG_HW_STACK_PROTECTION=y CONFIG_NET_TCP_CHECKSUM=y CONFIG_NET_UDP_CHECKSUM=y # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set # CONFIG_HCI_NXP_SET_CAL_DATA is not set CONFIG_BT_BUF_EVT_RX_COUNT=10 CONFIG_BT_BUF_ACL_TX_COUNT=3 # CONFIG_POWER_DOMAIN is not set # CONFIG_MFD is not set # CONFIG_HCI_NXP_RX_THREAD is not set CONFIG_GPIO=y # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set # CONFIG_NET_L2_IEEE802154 is not set # CONFIG_CODE_DATA_RELOCATION_SRAM is not set # CONFIG_CACHE is not set CONFIG_LOG=y CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y # CONFIG_CODE_DATA_RELOCATION is not set # CONFIG_ROMSTART_RELOCATION_ROM is not set CONFIG_DCACHE_LINE_SIZE=32 # CONFIG_RESET is not set CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4 CONFIG_PM_DEVICE_RUNTIME_DEFAULT_ENABLE=y CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y CONFIG_LOG_DOMAIN_NAME="" CONFIG_ASSERT=y CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048 CONFIG_PM_DEVICE_RUNTIME=y # CONFIG_DEVICE_DEPS is not set CONFIG_PM_DEVICE_POWER_DOMAIN=y CONFIG_SOC_HAS_TIMING_FUNCTIONS=y # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set # CONFIG_SYSCON is not set CONFIG_CONSOLE=y # CONFIG_WINSTREAM is not set CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1 CONFIG_GEN_SW_ISR_TABLE=y CONFIG_REBOOT=y CONFIG_FLASH_INIT_PRIORITY=50 CONFIG_GEN_IRQ_START_VECTOR=0 CONFIG_SRAM_OFFSET=0 CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4 CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set CONFIG_BOOTLOADER_MCUBOOT=y # CONFIG_SCHED_CPU_MASK is not set CONFIG_BT_BUF_CMD_TX_COUNT=1 CONFIG_KERNEL_MEM_POOL=y CONFIG_MULTITHREADING=y # CONFIG_OUTPUT_DISASSEMBLY is not set # CONFIG_WATCHDOG is not set CONFIG_ICACHE_LINE_SIZE=32 CONFIG_BT_BUF_CMD_TX_SIZE=65 CONFIG_BT_BUF_EVT_RX_SIZE=68 CONFIG_BT_BUF_ACL_TX_SIZE=151 CONFIG_BT_BUF_ACL_RX_SIZE=151 CONFIG_BT_L2CAP_TX_MTU=147 # # Devicetree Info # CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF53_HFXO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF53_LFXO_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF53_OSCILLATORS_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF53X_REGULATOR_HV_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF53X_REGULATORS_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y CONFIG_DT_HAS_NORDIC_NRF7002_SPI_ENABLED=y CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y CONFIG_DT_HAS_NORDIC_WLAN_ENABLED=y CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y CONFIG_DT_HAS_ST_LSM6DSO_ENABLED=y CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y CONFIG_DT_HAS_ZEPHYR_BT_HCI_IPC_ENABLED=y CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y # end of Devicetree Info # # Modules # # CONFIG_BUILD_ONLY_NO_BLOBS is not set # # Available modules. # # # nrf (C:/ncs/v3.2.4/nrf) # # CONFIG_NRF_802154_SER_HOST is not set CONFIG_NEWLIB_LIBC_NANO=y CONFIG_LOG_BUFFER_SIZE=1024 # CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set # CONFIG_MBEDTLS_SSL_MAX_FRAGMENT_LENGTH is not set CONFIG_MBEDTLS_MPI_MAX_SIZE=512 CONFIG_MBEDTLS_ENTROPY_C=y CONFIG_MBEDTLS_CIPHER_MODE_CBC=y CONFIG_MBEDTLS_CIPHER_MODE_CTR=y CONFIG_MBEDTLS_CHACHA20_C=y CONFIG_MBEDTLS_POLY1305_C=y CONFIG_MBEDTLS_CHACHAPOLY_C=y CONFIG_MBEDTLS_DHM_C=y CONFIG_MBEDTLS_RSA_C=y CONFIG_MBEDTLS_SHA512_C=y CONFIG_MBEDTLS_GCM_C=y CONFIG_MBEDTLS_SSL_SRV_C=y CONFIG_MBEDTLS_SSL_COOKIE_C=y CONFIG_MBEDTLS_SSL_CLI_C=y CONFIG_MBEDTLS_SSL_TLS_C=y CONFIG_MBEDTLS_HEAP_SIZE=65536 CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32 CONFIG_MPSL_WORK_STACK_SIZE=1024 CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096 CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=8192 CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y # CONFIG_ZMS is not set CONFIG_NVS=y # CONFIG_NVS_LOOKUP_CACHE is not set CONFIG_NET_PKT_RX_COUNT=10 CONFIG_NET_PKT_TX_COUNT=10 # CONFIG_NET_PKT_TXTIME is not set # CONFIG_NET_PKT_TIMESTAMP is not set CONFIG_NET_RX_STACK_SIZE=1024 CONFIG_NET_TX_STACK_SIZE=1024 CONFIG_MBEDTLS_SHA1_C=y CONFIG_MBEDTLS=y CONFIG_MBEDTLS_TLS_VERSION_1_2=y CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set CONFIG_MBEDTLS_MD_C=y CONFIG_MBEDTLS_TLS_LIBRARY=y CONFIG_MBEDTLS_X509_LIBRARY=y CONFIG_MBEDTLS_ENABLE_HEAP=y CONFIG_MBEDTLS_ECP_C=y CONFIG_MBEDTLS_CTR_DRBG_C=y CONFIG_MBEDTLS_CMAC_C=y CONFIG_MBEDTLS_CCM_C=y # CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C is not set CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y # # Nordic nRF Connect # CONFIG_WARN_EXPERIMENTAL=y CONFIG_NORDIC_QSPI_NOR=y CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_NRF_SECURITY_ENABLER=y # CONFIG_NCS_SAMPLES_DEFAULTS is not set # # Image build variants # # CONFIG_NCS_MCUBOOT_IN_BUILD is not set # end of Image build variants # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=16 CONFIG_UPDATEABLE_IMAGE_NUMBER=1 CONFIG_NRF53_UPGRADE_NETWORK_CORE=y # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set # # Subsystems # # # Bootloader # # CONFIG_SECURE_BOOT is not set CONFIG_PM_PARTITION_SIZE_PROVISION=0x280 # CONFIG_B0_MIN_PARTITION_SIZE is not set CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000 # CONFIG_IS_SECURE_BOOTLOADER is not set # CONFIG_NRF53_ENFORCE_IMAGE_VERSION_EQUALITY is not set # # Secure Boot firmware validation # CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483 CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1 CONFIG_SB_VALIDATION_INFO_VERSION=2 CONFIG_SB_VALIDATION_METADATA_OFFSET=0 CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y CONFIG_SB_VALIDATE_FW_SIGNATURE=y # end of Secure Boot firmware validation # CONFIG_SECURE_BOOT_STORAGE is not set # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set # CONFIG_NCS_MCUBOOT_BOOTLOADER_SIGN_MERGED_BINARY is not set # CONFIG_NCS_MCUBOOT_MANIFEST_UPDATES is not set # end of Bootloader # # Bluetooth Low Energy # CONFIG_BT_COMPANY_ID_NORDIC=0x0059 CONFIG_BT_COMPANY_ID=0x0059 CONFIG_BT_MAX_CONN=1 CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y CONFIG_BT_HCI_TX_STACK_SIZE=1024 # CONFIG_BT_NRF_CONN_SET_LTK is not set # # BLE Libraries # # CONFIG_BT_GATT_POOL is not set # CONFIG_BT_GATT_DM is not set # CONFIG_BT_ADV_PROV is not set # CONFIG_BT_CONN_CTX is not set # # Bluetooth Services # CONFIG_BT_NRF_SERVICES=y # CONFIG_BT_AMS_CLIENT is not set # CONFIG_BT_ANCS_CLIENT is not set # CONFIG_BT_BAS_CLIENT is not set # CONFIG_BT_BMS is not set # CONFIG_BT_CTS_CLIENT is not set # CONFIG_BT_DFU_SMP is not set # CONFIG_BT_GATTP is not set # CONFIG_BT_HIDS is not set # CONFIG_BT_HOGP is not set # CONFIG_BT_LBS is not set # CONFIG_BT_NSMS is not set # CONFIG_BT_NUS is not set # CONFIG_BT_NUS_CLIENT is not set # CONFIG_BT_RSCS is not set # CONFIG_BT_THROUGHPUT is not set # CONFIG_BT_LATENCY is not set # CONFIG_BT_LATENCY_CLIENT is not set # CONFIG_BT_HRS_CLIENT is not set # CONFIG_BT_DDFS is not set # CONFIG_BT_MDS is not set # CONFIG_BT_CGMS is not set # CONFIG_BT_FAST_PAIR is not set CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1 CONFIG_BT_GATT_AUTO_SEC_REQ=y CONFIG_BT_WIFI_PROV=y # CONFIG_BT_WIFI_PROV_LOG_LEVEL_OFF is not set # CONFIG_BT_WIFI_PROV_LOG_LEVEL_ERR is not set # CONFIG_BT_WIFI_PROV_LOG_LEVEL_WRN is not set # CONFIG_BT_WIFI_PROV_LOG_LEVEL_INF is not set # CONFIG_BT_WIFI_PROV_LOG_LEVEL_DBG is not set CONFIG_BT_WIFI_PROV_LOG_LEVEL_DEFAULT=y CONFIG_BT_WIFI_PROV_LOG_LEVEL=3 # end of Bluetooth Services # # BLE over nRF RPC # # CONFIG_BT_RPC is not set CONFIG_HEAP_MEM_POOL_SIZE=32768 # CONFIG_BT_SHELL is not set CONFIG_BT_CONN_DYNAMIC_CALLBACKS=y # CONFIG_BT_RPC_STACK is not set # CONFIG_BT_CENTRAL is not set CONFIG_BT_PERIPHERAL=y # CONFIG_BT_OBSERVER is not set CONFIG_BT_BROADCASTER=y CONFIG_BT_CONN=y # CONFIG_BT_REMOTE_VERSION is not set CONFIG_BT_PHY_UPDATE=y CONFIG_BT_DATA_LEN_UPDATE=y # CONFIG_BT_EXT_ADV is not set CONFIG_BT_LOG=y # CONFIG_BT_LOG_LEVEL_OFF is not set # CONFIG_BT_LOG_LEVEL_ERR is not set # CONFIG_BT_LOG_LEVEL_WRN is not set # CONFIG_BT_LOG_LEVEL_INF is not set # CONFIG_BT_LOG_LEVEL_DBG is not set CONFIG_BT_LOG_LEVEL_DEFAULT=y CONFIG_BT_LOG_LEVEL=3 CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3 # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y CONFIG_BT_RPA_LOG_LEVEL=3 # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set # CONFIG_BT_RPA_LOG_LEVEL_INF is not set # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y CONFIG_BT_CRYPTO_LOG_LEVEL=3 # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set # CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y CONFIG_BT_ATT_LOG_LEVEL=3 # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set # CONFIG_BT_ATT_LOG_LEVEL_INF is not set # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y CONFIG_BT_GATT_LOG_LEVEL=3 # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set # CONFIG_BT_GATT_LOG_LEVEL_INF is not set # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y CONFIG_BT_L2CAP_LOG_LEVEL=3 # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y CONFIG_BT_HCI_CORE_LOG_LEVEL=3 # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y CONFIG_BT_CONN_LOG_LEVEL=3 # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set # CONFIG_BT_CONN_LOG_LEVEL_INF is not set # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y CONFIG_BT_KEYS_LOG_LEVEL=3 # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y CONFIG_BT_SMP_LOG_LEVEL=3 # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set # CONFIG_BT_SMP_LOG_LEVEL_INF is not set # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set # CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y CONFIG_BT_SERVICE_LOG_LEVEL=3 # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set # CONFIG_BT_DIS is not set # CONFIG_BT_CTS is not set # CONFIG_BT_HRS is not set # CONFIG_BT_TPS is not set # CONFIG_BT_ZEPHYR_NUS is not set # CONFIG_BT_IAS is not set # CONFIG_BT_IAS_CLIENT is not set # CONFIG_BT_OTS is not set # CONFIG_BT_OTS_CLIENT is not set # CONFIG_BT_BAS is not set # CONFIG_BT_BAS_BLS is not set CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=1 CONFIG_BT_HAS_HCI_VS=y # CONFIG_BT_HCI_VS_EXT_DETECT is not set # CONFIG_BT_WAIT_NOP is not set CONFIG_BT_RPA=y CONFIG_BT_ASSERT=y CONFIG_BT_ASSERT_VERBOSE=y # CONFIG_BT_ASSERT_PANIC is not set # CONFIG_BT_HCI_ERR_TO_STR is not set CONFIG_BT_DEBUG_NONE=y # CONFIG_BT_DEBUG_MONITOR_UART is not set CONFIG_BT_LONG_WQ=y CONFIG_BT_LONG_WQ_PRIO=10 CONFIG_BT_LONG_WQ_INIT_PRIO=50 CONFIG_BT_HCI_HOST=y # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set CONFIG_BT_HCI_TX_PRIO=7 # CONFIG_BT_RECV_WORKQ_SYS is not set CONFIG_BT_RECV_WORKQ_BT=y CONFIG_BT_RX_PRIO=8 CONFIG_BT_DRIVER_RX_HIGH_PRIO=6 # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set # CONFIG_BT_AUDIO is not set CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43 CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3 CONFIG_BT_HOST_CRYPTO=y CONFIG_BT_HOST_CRYPTO_PRNG=y # CONFIG_BT_SETTINGS is not set # CONFIG_BT_FILTER_ACCEPT_LIST is not set CONFIG_BT_LIM_ADV_TIMEOUT=30 CONFIG_BT_CONN_TX_USER_DATA_SIZE=16 CONFIG_BT_CONN_FRAG_COUNT=1 CONFIG_BT_CONN_TX_MAX=3 # CONFIG_BT_CONN_PARAM_ANY is not set # CONFIG_BT_CONN_CHECK_NULL_BEFORE_CREATE is not set # CONFIG_BT_USER_DATA_LEN_UPDATE is not set # CONFIG_BT_REMOTE_INFO is not set CONFIG_BT_SMP=y # CONFIG_BT_SECURITY_ERR_TO_STR is not set # CONFIG_BT_SMP_ERR_TO_STR is not set # CONFIG_BT_PASSKEY_KEYPRESS is not set # CONFIG_BT_PRIVACY is not set # CONFIG_BT_SIGNING is not set # CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set CONFIG_BT_SMP_SC_PAIR_ONLY=y # CONFIG_BT_SMP_SC_ONLY is not set # CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set # CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set # CONFIG_BT_ID_AUTO_SWAP_MATCHING_BONDS is not set # CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set # CONFIG_BT_FIXED_PASSKEY is not set # CONFIG_BT_APP_PASSKEY is not set # CONFIG_BT_USE_DEBUG_KEYS is not set # CONFIG_BT_BONDABLE is not set # CONFIG_BT_BONDABLE_PER_CONNECTION is not set # CONFIG_BT_STORE_DEBUG_KEYS is not set CONFIG_BT_SMP_ENFORCE_MITM=y # CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=16 CONFIG_BT_L2CAP_TX_BUF_COUNT=3 CONFIG_BT_L2CAP_TX_FRAG_COUNT=2 # CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set # CONFIG_BT_L2CAP_SEG_RECV is not set # CONFIG_BT_L2CAP_RECONFIGURE_EXPLICIT is not set # CONFIG_BT_ATT_ERR_TO_STR is not set CONFIG_BT_ATT_TX_COUNT=3 CONFIG_BT_ATT_PREPARE_COUNT=0 CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y # CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set CONFIG_BT_GATT_SERVICE_CHANGED=y # CONFIG_BT_GATT_DYNAMIC_DB is not set CONFIG_BT_GATT_CACHING=y # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y # CONFIG_BT_GATT_CLIENT is not set CONFIG_BT_GATT_READ_MULTIPLE=y CONFIG_BT_GATT_READ_MULT_VAR_LEN=y CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40 CONFIG_BT_PERIPHERAL_PREF_LATENCY=0 CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=75 CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y # CONFIG_DEVICE_NAME_GATT_WRITABLE_NONE is not set CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=y # CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN is not set # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set CONFIG_BT_MAX_PAIRED=1 CONFIG_BT_CREATE_CONN_TIMEOUT=3 CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000 CONFIG_BT_CONN_PARAM_RETRY_COUNT=3 CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000 CONFIG_BT_DEVICE_NAME_DYNAMIC=y CONFIG_BT_DEVICE_NAME_MAX=28 CONFIG_BT_DEVICE_NAME="Zephyr" # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set CONFIG_BT_DEVICE_APPEARANCE=0 CONFIG_BT_ID_MAX=1 # CONFIG_BT_DF is not set CONFIG_BT_ECC=y # CONFIG_BT_HOST_CCM is not set # CONFIG_BT_LOG_SNIFFER_INFO is not set # CONFIG_BT_TESTING is not set # CONFIG_BT_CLASSIC is not set # CONFIG_BT_HCI_VS_EVT_USER is not set CONFIG_BT_CRYPTO=y # end of BLE over nRF RPC # end of Bluetooth Low Energy # # DFU # # CONFIG_DFU_MULTI_IMAGE is not set CONFIG_DFU_TARGET=y CONFIG_DFU_TARGET_MCUBOOT=y CONFIG_DFU_TARGET_STREAM=y # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set # CONFIG_DFU_TARGET_STREAM_SAVE_PROGRESS is not set # CONFIG_DFU_TARGET_STREAM_SYNCHRONOUS is not set # CONFIG_DFU_TARGET_CUSTOM is not set # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set # CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y CONFIG_DFU_TARGET_LOG_LEVEL=3 # end of DFU # CONFIG_ESB is not set # CONFIG_EMDS is not set # # Peripheral CPU DFU (PCD) # # CONFIG_PCD is not set # CONFIG_PCD_APP is not set CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046 # CONFIG_PCD_NET is not set # end of Peripheral CPU DFU (PCD) # # Networking # # # Application protocols # # CONFIG_NRF_CLOUD is not set # CONFIG_REST_CLIENT is not set CONFIG_DOWNLOADER=y # # Thread and stack buffers # CONFIG_DOWNLOADER_STACK_SIZE=2048 CONFIG_DOWNLOADER_MAX_HOSTNAME_SIZE=256 CONFIG_DOWNLOADER_MAX_FILENAME_SIZE=255 CONFIG_DOWNLOADER_MAX_REDIRECTS=10 CONFIG_DOWNLOADER_TRANSPORT_PARAMS_SIZE=256 CONFIG_DOWNLOADER_TRANSPORT_HTTP=y # CONFIG_DOWNLOADER_LOG_LEVEL_OFF is not set # CONFIG_DOWNLOADER_LOG_LEVEL_ERR is not set # CONFIG_DOWNLOADER_LOG_LEVEL_WRN is not set # CONFIG_DOWNLOADER_LOG_LEVEL_INF is not set # CONFIG_DOWNLOADER_LOG_LEVEL_DBG is not set CONFIG_DOWNLOADER_LOG_LEVEL_DEFAULT=y CONFIG_DOWNLOADER_LOG_LEVEL=3 CONFIG_FOTA_DOWNLOAD=y CONFIG_FOTA_SOCKET_RETRIES=10 CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y CONFIG_FOTA_CLIENT_AUTOSCHEDULE_UPDATE=y CONFIG_FOTA_DOWNLOAD_MCUBOOT_FLASH_BUF_SZ=4096 CONFIG_FOTA_DOWNLOAD_BUF_SZ=2048 # CONFIG_FOTA_DOWNLOAD_NATIVE_TLS is not set CONFIG_FOTA_DOWNLOAD_FILE_NAME_LENGTH=128 CONFIG_FOTA_DOWNLOAD_HOST_NAME_LENGTH=128 CONFIG_FOTA_DOWNLOAD_RESOURCE_LOCATOR_LENGTH=512 CONFIG_FOTA_DOWNLOAD_SEC_TAG_LIST_SIZE_MAX=5 # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_OFF is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_ERR is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_WRN is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_INF is not set # CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DBG is not set CONFIG_FOTA_DOWNLOAD_LOG_LEVEL_DEFAULT=y CONFIG_FOTA_DOWNLOAD_LOG_LEVEL=3 # CONFIG_AWS_IOT is not set # CONFIG_AWS_JOBS is not set # CONFIG_AWS_FOTA is not set CONFIG_AZURE_FOTA=y CONFIG_AZURE_FOTA_VERSION_MAX_LEN=64 CONFIG_AZURE_FOTA_JOB_ID_MAX_LEN=40 # CONFIG_AZURE_FOTA_APP_VERSION_AUTO is not set CONFIG_AZURE_FOTA_APP_VERSION="v1.3.0-b2" CONFIG_AZURE_FOTA_TLS=y CONFIG_AZURE_FOTA_SEC_TAG=10 CONFIG_AZURE_FOTA_DOWNLOAD_PORT=443 # CONFIG_AZURE_FOTA_LOG_LEVEL_OFF is not set # CONFIG_AZURE_FOTA_LOG_LEVEL_ERR is not set # CONFIG_AZURE_FOTA_LOG_LEVEL_WRN is not set # CONFIG_AZURE_FOTA_LOG_LEVEL_INF is not set # CONFIG_AZURE_FOTA_LOG_LEVEL_DBG is not set CONFIG_AZURE_FOTA_LOG_LEVEL_DEFAULT=y CONFIG_AZURE_FOTA_LOG_LEVEL=3 CONFIG_AZURE_IOT_HUB=y CONFIG_AZURE_IOT_HUB_DEVICE_ID="" CONFIG_AZURE_IOT_HUB_HOSTNAME="Queva-CanEast.azure-devices.net" CONFIG_AZURE_IOT_HUB_AUTO_DEVICE_TWIN_REQUEST=y CONFIG_AZURE_IOT_HUB_DPS=y CONFIG_AZURE_IOT_HUB_USER_NAME_BUF_SIZE=160 CONFIG_AZURE_IOT_HUB_TOPIC_MAX_LEN=100 CONFIG_AZURE_IOT_HUB_MSG_PROPERTY_RECV_MAX_COUNT=3 CONFIG_AZURE_IOT_HUB_MSG_PROPERTY_BUFFER_SIZE=128 CONFIG_AZURE_IOT_HUB_DPS_ID_SCOPE="0ne00C9FA5A" CONFIG_AZURE_IOT_HUB_DPS_REG_ID="device_49" CONFIG_AZURE_IOT_HUB_DPS_HOSTNAME="global.azure-devices-provisioning.net" CONFIG_AZURE_IOT_HUB_DPS_TIMEOUT_SEC=90 CONFIG_AZURE_IOT_HUB_DPS_HOSTNAME_MAX_LEN=64 CONFIG_AZURE_IOT_HUB_DPS_DEVICE_ID_MAX_LEN=128 CONFIG_AZURE_IOT_HUB_DPS_TOPIC_BUFFER_SIZE=224 CONFIG_AZURE_IOT_HUB_DPS_USER_NAME_BUFFER_SIZE=256 CONFIG_AZURE_IOT_HUB_DPS_OPERATION_ID_BUFFER_SIZE=68 # CONFIG_AZURE_IOT_HUB_LOG_LEVEL_OFF is not set # CONFIG_AZURE_IOT_HUB_LOG_LEVEL_ERR is not set # CONFIG_AZURE_IOT_HUB_LOG_LEVEL_WRN is not set # CONFIG_AZURE_IOT_HUB_LOG_LEVEL_INF is not set # CONFIG_AZURE_IOT_HUB_LOG_LEVEL_DBG is not set CONFIG_AZURE_IOT_HUB_LOG_LEVEL_DEFAULT=y CONFIG_AZURE_IOT_HUB_LOG_LEVEL=3 # # Self-Registration (Zi ZHu Ce) # # end of Self-Registration (Zi ZHu Ce) # CONFIG_ICAL_PARSER is not set # CONFIG_FTP_CLIENT is not set # CONFIG_LWM2M_CLIENT_UTILS is not set CONFIG_TLS_MAX_CREDENTIALS_NUMBER=6 # CONFIG_WIFI_READY_LIB is not set CONFIG_MQTT_HELPER=y # CONFIG_MQTT_HELPER_NATIVE_TLS is not set CONFIG_MQTT_HELPER_PORT=8883 CONFIG_MQTT_HELPER_SEC_TAG=10 CONFIG_MQTT_HELPER_SEND_TIMEOUT=y CONFIG_MQTT_HELPER_SEND_TIMEOUT_SEC=60 CONFIG_MQTT_HELPER_STATIC_IP_ADDRESS="" CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG=11 CONFIG_MQTT_HELPER_STACK_SIZE=2784 CONFIG_MQTT_HELPER_RX_TX_BUFFER_SIZE=256 CONFIG_MQTT_HELPER_PAYLOAD_BUFFER_LEN=4096 CONFIG_MQTT_HELPER_PROVISION_CERTIFICATES=y CONFIG_MQTT_HELPER_CERTIFICATES_FOLDER="certs" # CONFIG_MQTT_HELPER_LAST_WILL is not set # CONFIG_MQTT_HELPER_LOG_LEVEL_OFF is not set # CONFIG_MQTT_HELPER_LOG_LEVEL_ERR is not set # CONFIG_MQTT_HELPER_LOG_LEVEL_WRN is not set # CONFIG_MQTT_HELPER_LOG_LEVEL_INF is not set # CONFIG_MQTT_HELPER_LOG_LEVEL_DBG is not set CONFIG_MQTT_HELPER_LOG_LEVEL_DEFAULT=y CONFIG_MQTT_HELPER_LOG_LEVEL=3 # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_DISABLED=y # CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_XIP is not set # CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_STORE is not set CONFIG_CUSTOM_LINKER_SCRIPT="C:/ncs/v3.2.4/zephyr/../nrf/subsys/net/lib/nrf70_fw_ext/rpu_fw_patches.ld" CONFIG_HOSTAP_CRYPTO_ALT_LEGACY_PSA=y # CONFIG_HOSTAP_CRYPTO_ALT_PSA is not set CONFIG_WIFI_NM_WPA_SUPPLICANT_WPA3=y # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE is not set CONFIG_WIFI_PROV_CORE=y # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_OFF is not set # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_ERR is not set # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_WRN is not set # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_INF is not set # CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DBG is not set CONFIG_WIFI_PROV_CORE_LOG_LEVEL_DEFAULT=y CONFIG_WIFI_PROV_CORE_LOG_LEVEL=3 # end of Application protocols # CONFIG_OPENTHREAD_RPC is not set CONFIG_L2_WIFI_CONNECTIVITY=y CONFIG_L2_WIFI_CONN_WQ_STACK_SIZE=512 CONFIG_L2_WIFI_CONNECTIVITY_CONNECT_TIMEOUT_SECONDS=20 # CONFIG_L2_WIFI_CONNECTIVITY_CONNECTION_PERSISTENCE is not set CONFIG_L2_WIFI_CONNECTIVITY_AUTO_CONNECT=y # CONFIG_L2_WIFI_CONNECTIVITY_AUTO_DOWN is not set # end of Networking # # NFC # # CONFIG_NFC_NDEF is not set # CONFIG_NFC_NDEF_PARSER is not set # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set # CONFIG_NFC_T2T_PARSER is not set # CONFIG_NFC_T4T_NDEF_FILE is not set # CONFIG_NFC_T4T_ISODEP is not set # CONFIG_NFC_T4T_APDU is not set # CONFIG_NFC_T4T_CC_FILE is not set # CONFIG_NFC_T4T_HL_PROCEDURE is not set # CONFIG_NFC_TNEP_TAG is not set # CONFIG_NFC_TNEP_POLLER is not set # CONFIG_NFC_TNEP_CH is not set # CONFIG_NFC_RPC is not set # end of NFC # CONFIG_APP_EVENT_MANAGER is not set # CONFIG_NRF_PROFILER is not set CONFIG_FW_INFO=y # CONFIG_FW_INFO_API is not set CONFIG_FW_INFO_OFFSET=0x200 CONFIG_FW_INFO_FIRMWARE_VERSION=1 CONFIG_FW_INFO_MAGIC_COMMON=0x281ee6de CONFIG_FW_INFO_MAGIC_FIRMWARE_INFO=0x8fcebb4c CONFIG_FW_INFO_MAGIC_EXT_API=0xb845acea CONFIG_FW_INFO_HARDWARE_ID=53 CONFIG_FW_INFO_VERSION=2 CONFIG_FW_INFO_CRYPTO_ID=0 CONFIG_FW_INFO_MAGIC_COMPATIBILITY_ID=0 CONFIG_FW_INFO_MAGIC_LEN=12 CONFIG_FW_INFO_VALID_VAL=0x9102FFFF CONFIG_EXT_API_SUPPORTED=y CONFIG_EXT_API_PROVIDE_EXT_API_UNUSED=y # CONFIG_EXT_API_PROVIDE_EXT_API_OPTIONAL is not set # CONFIG_EXT_API_PROVIDE_EXT_API_REQUIRED is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ENABLED is not set # CONFIG_EXT_API_PROVIDE_EXT_API_ATLEAST_OPTIONAL is not set # # Debug # # CONFIG_NRF_CPU_LOAD is not set # CONFIG_PPI_TRACE is not set CONFIG_PPI_TRACE_PIN_CNT=8 # end of Debug # CONFIG_SHELL_BT_NUS is not set # CONFIG_SHELL_IPC is not set # # Multiprotocol service layer (MPSL) # # CONFIG_MPSL_FEM_ONLY is not set # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y CONFIG_MPSL_FEM_LOG_LEVEL=3 CONFIG_MPSL_CX_ANY_SUPPORT=y # CONFIG_MPSL_CX is not set CONFIG_MPSL_THREAD_COOP_PRIO=8 CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0 # CONFIG_MPSL_ASSERT_HANDLER is not set CONFIG_MPSL_LOW_PRIO_IRQN=26 CONFIG_MPSL_HFCLK_LATENCY=1400 CONFIG_MPSL_INIT_PRIORITY=40 # CONFIG_MPSL_LOG_LEVEL_OFF is not set # CONFIG_MPSL_LOG_LEVEL_ERR is not set # CONFIG_MPSL_LOG_LEVEL_WRN is not set # CONFIG_MPSL_LOG_LEVEL_INF is not set # CONFIG_MPSL_LOG_LEVEL_DBG is not set CONFIG_MPSL_LOG_LEVEL_DEFAULT=y CONFIG_MPSL_LOG_LEVEL=3 # end of Multiprotocol service layer (MPSL) # # Partition Manager # CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_FLASH_MAP_CUSTOM=y CONFIG_SRAM_BASE_ADDRESS=0x20000000 # # Zephyr subsystem configurations # CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000 CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x4000 # CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL is not set CONFIG_PM_PARTITION_ALIGN_SETTINGS_STORAGE=0x4000 # end of Zephyr subsystem configurations # # NCS subsystem configurations # CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y CONFIG_PM_EXTERNAL_FLASH_BASE=0 CONFIG_PM_EXTERNAL_FLASH_ENABLED=y CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@50000000/qspi@2b000/mx25r6435f@0" CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=67108864 # CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY is not set CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y CONFIG_PM_SRAM_BASE=0x20000000 CONFIG_PM_SRAM_SIZE=0x80000 # end of Partition Manager # # nRF RPC (Remote Procedure Call) library # # end of nRF RPC (Remote Procedure Call) library # # Full Modem Firmware Update Management(FMFU) # # end of Full Modem Firmware Update Management(FMFU) # # Additional MCUmgr configuration # # # Additional MCUmgr group configuration # # # Additional MCUmgr OS group management functionality # # end of Additional MCUmgr OS group management functionality # # Additional MCUmgr image management group functionality # # end of Additional MCUmgr image management group functionality # end of Additional MCUmgr group configuration # end of Additional MCUmgr configuration # CONFIG_CAF is not set # CONFIG_DM_MODULE is not set # # nRF Security # # CONFIG_NORDIC_SECURITY_BACKEND is not set CONFIG_NRF_SECURITY=y # # Nordic-added meta types # CONFIG_PSA_HAS_AEAD_SUPPORT=y CONFIG_PSA_HAS_ASYM_ENCRYPT_SUPPORT=y CONFIG_PSA_HAS_ASYM_SIGN_SUPPORT=y CONFIG_PSA_HAS_CIPHER_SUPPORT=y CONFIG_PSA_HAS_HASH_SUPPORT=y CONFIG_PSA_HAS_KEY_AGREEMENT=y CONFIG_PSA_HAS_KEY_DERIVATION=y CONFIG_PSA_HAS_KEY_SUPPORT=y CONFIG_PSA_HAS_MAC_SUPPORT=y # # Nordic added alg types # # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set # CONFIG_PSA_WANT_ALG_ED25519PH is not set # CONFIG_PSA_WANT_ALG_ED448PH is not set # CONFIG_PSA_WANT_ALG_HSS is not set # CONFIG_PSA_WANT_ALG_LMS is not set # CONFIG_PSA_WANT_ALG_ML_DSA is not set # CONFIG_PSA_WANT_ALG_XMSS is not set # CONFIG_PSA_WANT_ALG_XMSS_MT is not set # CONFIG_PSA_WANT_ALG_ML_KEM is not set # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW=y CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT=y # CONFIG_PSA_WANT_ALG_SHA_256_192 is not set # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC is not set # CONFIG_PSA_WANT_ALG_SRP_6 is not set # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set # CONFIG_PSA_WANT_ALG_XTS is not set CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y CONFIG_PSA_WANT_ALG_CHACHA20=y # CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set # CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set # CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set # CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set # CONFIG_PSA_WANT_ALG_AES_KW is not set # CONFIG_PSA_WANT_ALG_AES_KWP is not set # CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set # # Nordic added ECC curve types # # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set # # Nordic addded RNG configuration # CONFIG_PSA_WANT_GENERATE_RANDOM=y # # Nordic added key types # # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set # CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set # CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set # CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set # CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set # CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set CONFIG_MBEDTLS_CFG_FILE="nrf-config.h" CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h" CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h" CONFIG_MBEDTLS_X509_USE_C=y # CONFIG_MBEDTLS_X509_CREATE_C is not set CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y CONFIG_MBEDTLS_X509_CRL_PARSE_C=y CONFIG_MBEDTLS_X509_CSR_PARSE_C=y CONFIG_MBEDTLS_X509_CRT_PARSE_C=y # CONFIG_MBEDTLS_X509_CSR_WRITE_C is not set # CONFIG_MBEDTLS_X509_CRT_WRITE_C is not set CONFIG_MBEDTLS_X509_REMOVE_INFO=y # CONFIG_MBEDTLS_PKCS7_C is not set CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y CONFIG_MBEDTLS_SSL_ENCRYPT_THEN_MAC=y CONFIG_MBEDTLS_SSL_EXTENDED_MASTER_SECRET=y # CONFIG_MBEDTLS_DEBUG_C is not set # CONFIG_MBEDTLS_MEMORY_DEBUG is not set CONFIG_MBEDTLS_SSL_ALL_ALERT_MESSAGES=y CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION=y # CONFIG_MBEDTLS_SSL_DEBUG_ALL is not set # CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE is not set # CONFIG_MBEDTLS_SSL_RENEGOTIATION is not set # CONFIG_MBEDTLS_SSL_SESSION_TICKETS is not set CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y # CONFIG_MBEDTLS_SSL_CACHE_C is not set # CONFIG_MBEDTLS_SSL_TICKET_C is not set CONFIG_MBEDTLS_SSL_EXPORT_KEYS=y CONFIG_MBEDTLS_SSL_CIPHERSUITES="" # CONFIG_MBEDTLS_SSL_PROTO_TLS1_3 is not set # # TLS/DTL Cipher Suites # CONFIG_MBEDTLS_HAS_CBC_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_GCM_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_CCM_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_CHACHAPOLY_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_RSA_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_HAS_ECJPAKE_CIPHERSUITE_REQUIREMENTS=y CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED=y CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED=y # end of TLS/DTL Cipher Suites CONFIG_MBEDTLS_PSA_CRYPTO_C=y CONFIG_PSA_CORE_OBERON=y # # PSA Driver Support # CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y CONFIG_PSA_CRYPTO_DRIVER_OBERON=y # CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set # # Choose DRBG algorithm # CONFIG_PSA_WANT_ALG_CTR_DRBG=y # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set CONFIG_PSA_USE_CTR_DRBG_DRIVER=y # end of Choose DRBG algorithm # # CryptoCell PSA Driver Configuration # CONFIG_PSA_USE_CC3XX_CTR_DRBG_DRIVER=y # end of CryptoCell PSA Driver Configuration # # CRACEN PSA Driver Configuration # # end of CRACEN PSA Driver Configuration # # AES key size configuration # CONFIG_PSA_WANT_AES_KEY_SIZE_128=y CONFIG_PSA_WANT_AES_KEY_SIZE_192=y CONFIG_PSA_WANT_AES_KEY_SIZE_256=y # end of AES key size configuration # # RSA key size configuration # # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set CONFIG_PSA_WANT_RSA_KEY_SIZE_2048=y # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set CONFIG_PSA_MAX_RSA_KEY_BITS=2048 # end of RSA key size configuration CONFIG_PSA_ACCEL_GENERATE_RANDOM=y CONFIG_PSA_NEED_CC3XX_CTR_DRBG_DRIVER=y # CONFIG_CRACEN_LOG_LEVEL_OFF is not set # CONFIG_CRACEN_LOG_LEVEL_ERR is not set # CONFIG_CRACEN_LOG_LEVEL_WRN is not set # CONFIG_CRACEN_LOG_LEVEL_INF is not set # CONFIG_CRACEN_LOG_LEVEL_DBG is not set CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y CONFIG_CRACEN_LOG_LEVEL=3 CONFIG_PSA_NEED_OBERON_CCM_AES=y CONFIG_PSA_NEED_OBERON_GCM_AES=y CONFIG_PSA_NEED_OBERON_CHACHA20_POLY1305=y CONFIG_PSA_NEED_OBERON_AEAD_DRIVER=y CONFIG_PSA_NEED_OBERON_CTR_AES=y CONFIG_PSA_NEED_OBERON_CBC_NO_PADDING_AES=y CONFIG_PSA_NEED_OBERON_CBC_PKCS7_AES=y CONFIG_PSA_NEED_OBERON_ECB_NO_PADDING_AES=y CONFIG_PSA_NEED_OBERON_STREAM_CIPHER_CHACHA20=y CONFIG_PSA_NEED_OBERON_CIPHER_DRIVER=y CONFIG_PSA_NEED_OBERON_ECDH_SECP_R1_256=y CONFIG_PSA_NEED_OBERON_ECDH=y CONFIG_PSA_NEED_OBERON_KEY_AGREEMENT_DRIVER=y CONFIG_PSA_NEED_OBERON_ECDSA_SECP_R1_256=y CONFIG_PSA_NEED_OBERON_ECDSA_VERIFY=y CONFIG_PSA_NEED_OBERON_ECDSA_SIGN=y CONFIG_PSA_NEED_OBERON_ECDSA_DETERMINISTIC=y CONFIG_PSA_NEED_OBERON_ECDSA_RANDOMIZED=y CONFIG_PSA_NEED_OBERON_SHA_1=y CONFIG_PSA_NEED_OBERON_SHA_224=y CONFIG_PSA_NEED_OBERON_SHA_256=y CONFIG_PSA_NEED_OBERON_SHA_384=y CONFIG_PSA_NEED_OBERON_SHA_512=y CONFIG_PSA_NEED_OBERON_HASH_DRIVER=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_SECP_R1_256=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_R1_256=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_R1_256=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_R1_256=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_R1_256=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_SECP=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_RSA_PUBLIC_KEY=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_RSA_KEY_PAIR_IMPORT=y CONFIG_PSA_NEED_OBERON_KEY_TYPE_RSA_KEY_PAIR_EXPORT=y CONFIG_PSA_NEED_OBERON_KEY_MANAGEMENT_DRIVER=y CONFIG_PSA_NEED_OBERON_HMAC=y CONFIG_PSA_NEED_OBERON_CMAC=y CONFIG_PSA_NEED_OBERON_MAC_DRIVER=y CONFIG_PSA_NEED_OBERON_HKDF=y CONFIG_PSA_NEED_OBERON_TLS12_PRF=y CONFIG_PSA_NEED_OBERON_TLS12_PSK_TO_MS=y CONFIG_PSA_NEED_OBERON_PBKDF2_AES_CMAC_PRF_128=y CONFIG_PSA_NEED_OBERON_TLS12_ECJPAKE_TO_PMS=y CONFIG_PSA_NEED_OBERON_KEY_DERIVATION_DRIVER=y CONFIG_PSA_NEED_OBERON_RSA_KEY_SIZE_2048=y CONFIG_PSA_NEED_OBERON_ANY_RSA_KEY_SIZE=y CONFIG_PSA_NEED_OBERON_RSA_PSS=y CONFIG_PSA_NEED_OBERON_RSA_PKCS1V15_SIGN=y CONFIG_PSA_NEED_OBERON_RSA_ANY_VERIFY=y CONFIG_PSA_NEED_OBERON_RSA_ANY_SIGN=y CONFIG_PSA_NEED_OBERON_RSA_PKCS1V15_CRYPT=y CONFIG_PSA_NEED_OBERON_RSA_OAEP=y CONFIG_PSA_NEED_OBERON_RSA_ANY_CRYPT=y CONFIG_PSA_NEED_OBERON_ASYMMETRIC_ENCRYPTION_DRIVER=y CONFIG_PSA_NEED_OBERON_ASYMMETRIC_SIGNATURE_DRIVER=y # # PSA API support # # CONFIG_MBEDTLS_USE_PSA_CRYPTO is not set # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set CONFIG_PSA_CRYPTO_SYS_INIT=y # end of PSA API support CONFIG_MBEDTLS_PLATFORM_MEMORY=y CONFIG_MBEDTLS_PLATFORM_C=y CONFIG_MBEDTLS_MEMORY_C=y CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y CONFIG_MBEDTLS_THREADING_C=y CONFIG_MBEDTLS_BASE64_C=y CONFIG_MBEDTLS_OID_C=y CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y CONFIG_MBEDTLS_THREADING_ALT=y CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y CONFIG_MBEDTLS_AES_DECRYPT_ALT=y CONFIG_MBEDTLS_CHACHA20_ALT=y CONFIG_MBEDTLS_POLY1305_ALT=y CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y CONFIG_MBEDTLS_ECJPAKE_ALT=y CONFIG_MBEDTLS_SHA1_ALT=y CONFIG_MBEDTLS_SHA224_ALT=y CONFIG_MBEDTLS_SHA256_ALT=y CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1 CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y # CONFIG_NRF_SECURITY_ADVANCED is not set CONFIG_OBERON_ONLY_PSA_ENABLED=y CONFIG_OBERON_ONLY_ENABLED=y # # Legacy mbed TLS crypto APIs # CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6 # CONFIG_CC3XX_BACKEND is not set # CONFIG_OBERON_BACKEND is not set CONFIG_MBEDTLS_HMAC_DRBG_C=y CONFIG_MBEDTLS_AES_C=y # # Cipher Selection # # # CBC cipher padding modes # CONFIG_MBEDTLS_CIPHER_PADDING_PKCS7=y CONFIG_MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS=y CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN=y CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS=y # CONFIG_MBEDTLS_AES_FEWER_TABLES is not set CONFIG_MBEDTLS_AES_ROM_TABLES=y # end of CBC cipher padding modes # CONFIG_MBEDTLS_AES_ONLY_128_BIT_KEY_LENGTH is not set # # AEAD - Authenticated Encryption with Associated Data # # end of AEAD - Authenticated Encryption with Associated Data CONFIG_MBEDTLS_ECDH_C=y CONFIG_MBEDTLS_ECDSA_C=y CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y CONFIG_MBEDTLS_ECJPAKE_C=y # # ECC curves # # CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED is not set CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y # CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED is not set # CONFIG_MBEDTLS_ECP_DP_CURVE448_ENABLED is not set # end of ECC curves CONFIG_MBEDTLS_HKDF_C=y # # RSA Encoding Selection # CONFIG_MBEDTLS_GENPRIME=y CONFIG_MBEDTLS_PKCS1_V15=y CONFIG_MBEDTLS_PKCS1_V21=y # # SHA - Secure Hash Algorithm # CONFIG_MBEDTLS_MD5_C=y CONFIG_MBEDTLS_SHA224_C=y CONFIG_MBEDTLS_SHA256_C=y # CONFIG_MBEDTLS_SHA256_SMALLER is not set CONFIG_MBEDTLS_SHA384_C=y # CONFIG_MBEDTLS_512_SMALLER is not set # end of SHA - Secure Hash Algorithm # CONFIG_MBEDTLS_FORCE_LEGACY_MD is not set # CONFIG_MBEDTLS_FORCE_LEGACY_CIPHER is not set CONFIG_MBEDTLS_CIPHER_C=y CONFIG_MBEDTLS_PK_C=y CONFIG_MBEDTLS_PKCS5_C=y CONFIG_MBEDTLS_PK_WRITE_C=y CONFIG_MBEDTLS_PK_PARSE_C=y CONFIG_MBEDTLS_PK_PARSE_EC_EXTENDED=y # CONFIG_MBEDTLS_PEM_PARSE_C is not set # CONFIG_MBEDTLS_PEM_WRITE_C is not set # end of Legacy mbed TLS crypto APIs # # Zephyr legacy configurations # # CONFIG_MBEDTLS_DTLS is not set CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED=y # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set CONFIG_MBEDTLS_CIPHER=y CONFIG_MBEDTLS_MD=y # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set # end of Zephyr legacy configurations CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y # end of nRF Security # CONFIG_NET_CORE_MONITOR is not set # # Audio Modules # # CONFIG_AUDIO_MODULE_TEST is not set # # Log levels # # end of Log levels # end of Audio Modules # # Audio Modules # # CONFIG_AUDIO_MODULE_TEMPLATE is not set # end of Audio Modules # CONFIG_UART_ASYNC_ADAPTER is not set # CONFIG_TRUSTED_STORAGE is not set # # Logging over RPC # # CONFIG_LOG_FORWARDER_RPC is not set # CONFIG_LOG_BACKEND_RPC is not set CONFIG_LOG_BACKED_RPC_CRASH_INFO_FILENAME_SIZE=255 # end of Logging over RPC # CONFIG_DULT is not set # CONFIG_NRF_COMPRESS is not set # # MCUboot IDs (informative only, do not change) # CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0 CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_EXTRA_1_IMAGE_NUMBER=-1 CONFIG_MCUBOOT_EXTRA_2_IMAGE_NUMBER=-1 # end of MCUboot IDs (informative only, do not change) # end of Subsystems # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set # CONFIG_WFA_QT_LOG_LEVEL_INF is not set # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y CONFIG_WFA_QT_LOG_LEVEL=3 # CONFIG_WFA_QT_CONTROL_APP is not set CONFIG_WFA_QT_THREAD_STACK_SIZE=5200 CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000 CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0" CONFIG_WPAS_READY_TIMEOUT_MS=10000 # # Libraries # # CONFIG_APP_JWT is not set # # Binary libraries # # end of Binary libraries CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=4960 # CONFIG_AT_MONITOR is not set # CONFIG_LTE_LINK_CONTROL is not set CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000 CONFIG_FPROTECT_BLOCK_SIZE=0x4000 # CONFIG_FPROTECT is not set # CONFIG_AT_CMD_CUSTOM is not set # CONFIG_DK_LIBRARY is not set # CONFIG_AT_PARSER is not set # CONFIG_RESET_ON_FATAL_ERROR is not set # CONFIG_SMS is not set # CONFIG_SUPL_CLIENT_LIB is not set CONFIG_DATE_TIME=y CONFIG_DATE_TIME_AUTO_UPDATE=y CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=0 CONFIG_DATE_TIME_TOO_OLD_SECONDS=0 CONFIG_DATE_TIME_RETRY_COUNT=5 CONFIG_DATE_TIME_RETRY_INTERVAL_SECONDS=5 CONFIG_DATE_TIME_NTP=y CONFIG_DATE_TIME_THREAD_STACK_SIZE=1600 CONFIG_DATE_TIME_NTP_QUERY_TIME_SECONDS=5 # CONFIG_DATE_TIME_LOG_LEVEL_OFF is not set # CONFIG_DATE_TIME_LOG_LEVEL_ERR is not set # CONFIG_DATE_TIME_LOG_LEVEL_WRN is not set # CONFIG_DATE_TIME_LOG_LEVEL_INF is not set # CONFIG_DATE_TIME_LOG_LEVEL_DBG is not set CONFIG_DATE_TIME_LOG_LEVEL_DEFAULT=y CONFIG_DATE_TIME_LOG_LEVEL=3 # CONFIG_HW_ID_LIBRARY is not set # CONFIG_RAM_POWER_DOWN_LIBRARY is not set # CONFIG_WAVE_GEN_LIB is not set CONFIG_HW_UNIQUE_KEY_SUPPORTED=y # CONFIG_HW_UNIQUE_KEY is not set CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0 # CONFIG_LOCATION is not set # CONFIG_QOS is not set # CONFIG_IDENTITY_KEY is not set # CONFIG_SFLOAT is not set # CONFIG_CONTIN_ARRAY is not set # CONFIG_PCM_MIX is not set # CONFIG_TONE is not set # CONFIG_PSCM is not set # CONFIG_DATA_FIFO is not set # CONFIG_FEM_AL_LIB is not set # CONFIG_SAMPLE_RATE_CONVERTER is not set CONFIG_NCS_BOOT_BANNER=y CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK" CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS" # end of Libraries # # Device Drivers # # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set CONFIG_ENTROPY_CC3XX=y # CONFIG_FLASH_RPC is not set CONFIG_HW_CC3XX=y # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0 # CONFIG_ETH_RTT is not set CONFIG_SENSOR=y # CONFIG_BH1749 is not set # CONFIG_SENSOR_SIM is not set # CONFIG_SENSOR_STUB is not set # CONFIG_PMW3360 is not set # CONFIG_PAW3212 is not set # CONFIG_BME68X_IAQ is not set # CONFIG_NRF_SW_LPUART is not set CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1 # CONFIG_IPC_UART is not set # end of Device Drivers # # External libraries # # CONFIG_GETOPT_LIB is not set # CONFIG_NRF_IPERF3 is not set # CONFIG_NRF_CURL is not set # end of External libraries # # Test # # CONFIG_UNITY is not set # # Mocks # # CONFIG_MOCK_NRF_MODEM_AT is not set # CONFIG_MOCK_NRF_RPC is not set # end of Mocks # end of Test # end of Nordic nRF Connect CONFIG_ZEPHYR_NRF_MODULE=y # end of nrf (C:/ncs/v3.2.4/nrf) # # hostap (C:/ncs/v3.2.4/modules/lib/hostap) # CONFIG_WIFI_NM_WPA_SUPPLICANT=y CONFIG_WIFI_NM_WPA_SUPPLICANT_GLOBAL_HEAP=y CONFIG_HEAP_MEM_POOL_ADD_SIZE_HOSTAP=30000 CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=5800 CONFIG_WIFI_NM_WPA_SUPPLICANT_WQ_STACK_SIZE=4400 CONFIG_WIFI_NM_WPA_SUPPLICANT_WQ_PRIO=7 CONFIG_WIFI_NM_WPA_SUPPLICANT_PRIO=0 # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=3 CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=5 # CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_SHOW_KEYS is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_ADVANCED_FEATURES is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_WEP is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_ALT is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_NONE is not set CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_EXT=y # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_MBEDTLS_PSA is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_AP is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_WPS is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_P2P is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_EAPOL is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_CLI is not set CONFIG_WIFI_NM_WPA_SUPPLICANT_INF_MON=y CONFIG_WIFI_NM_WPA_SUPPLICANT_BSS_MAX_IDLE_TIME=300 # CONFIG_WIFI_NM_WPA_SUPPLICANT_NO_DEBUG is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_DPP is not set # CONFIG_WPA_CLI is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_ROAMING is not set # CONFIG_WIFI_NM_WPA_SUPPLICANT_SKIP_DHCP_ON_ROAMING is not set CONFIG_SME=y CONFIG_NO_CONFIG_WRITE=y CONFIG_NO_CONFIG_BLOBS=y CONFIG_CTRL_IFACE=y CONFIG_CTRL_IFACE_ZEPHYR=y CONFIG_NO_RANDOM_POOL=y CONFIG_WIFI_NM_WPA_SUPPLICANT_NW_SEL_THROUGHPUT=y # CONFIG_WIFI_NM_WPA_SUPPLICANT_NW_SEL_RELIABILITY is not set # CONFIG_SAE_PWE_EARLY_EXIT is not set CONFIG_WIFI_NM_WPA_CTRL_RESP_TIMEOUT_S=15 CONFIG_ZEPHYR_HOSTAP_MODULE=y # end of hostap (C:/ncs/v3.2.4/modules/lib/hostap) # # mcuboot (C:/ncs/v3.2.4/bootloader/mcuboot) # # # MCUboot # # CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4 CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4 # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set # end of MCUboot # # Custom TLVs # CONFIG_NCS_MCUBOOT_PERIPHCONF_TLV_ID=0xA1 # end of Custom TLVs CONFIG_ZEPHYR_MCUBOOT_MODULE=y # end of mcuboot (C:/ncs/v3.2.4/bootloader/mcuboot) # # mbedtls (C:/ncs/v3.2.4/modules/crypto/mbedtls) # CONFIG_ZEPHYR_MBEDTLS_MODULE=y CONFIG_PSA_CRYPTO_CLIENT=y # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y CONFIG_PSA_WANT_ALG_CBC_PKCS7=y CONFIG_PSA_WANT_ALG_CCM=y # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set CONFIG_PSA_WANT_ALG_CMAC=y CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=y CONFIG_PSA_WANT_ALG_CTR=y CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA=y CONFIG_PSA_WANT_ALG_ECDH=y CONFIG_PSA_WANT_ALG_ECDSA=y # CONFIG_PSA_WANT_ALG_JPAKE is not set CONFIG_PSA_WANT_ALG_GCM=y CONFIG_PSA_WANT_ALG_HKDF=y # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set CONFIG_PSA_WANT_ALG_HMAC=y # CONFIG_PSA_WANT_ALG_MD5 is not set # CONFIG_PSA_WANT_ALG_PBKDF2_HMAC is not set # CONFIG_PSA_WANT_ALG_PBKDF2_AES_CMAC_PRF_128 is not set CONFIG_PSA_WANT_ALG_RSA_OAEP=y CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT=y CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN=y CONFIG_PSA_WANT_ALG_RSA_PSS=y CONFIG_PSA_WANT_ALG_SHA_1=y CONFIG_PSA_WANT_ALG_SHA_224=y CONFIG_PSA_WANT_ALG_SHA_256=y CONFIG_PSA_WANT_ALG_SHA_384=y CONFIG_PSA_WANT_ALG_SHA_512=y # CONFIG_PSA_WANT_ALG_SHA3_224 is not set # CONFIG_PSA_WANT_ALG_SHA3_256 is not set # CONFIG_PSA_WANT_ALG_SHA3_384 is not set # CONFIG_PSA_WANT_ALG_SHA3_512 is not set CONFIG_PSA_WANT_ALG_STREAM_CIPHER=y CONFIG_PSA_WANT_ALG_TLS12_PRF=y CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=y CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS=y # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set CONFIG_PSA_WANT_ECC_SECP_R1_256=y # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set CONFIG_PSA_WANT_KEY_TYPE_AES=y CONFIG_PSA_WANT_KEY_TYPE_CHACHA20=y CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE=y CONFIG_PSA_CRYPTO=y # CONFIG_PSA_CRYPTO_PROVIDER_MBEDTLS is not set CONFIG_PSA_CRYPTO_PROVIDER_CUSTOM=y CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_BASIC=y CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_BASIC=y # CONFIG_MBEDTLS_LIBRARY is not set CONFIG_DISABLE_MBEDTLS_BUILTIN=y # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y CONFIG_MBEDTLS_LOG_LEVEL=3 # CONFIG_MBEDTLS_DEBUG is not set # CONFIG_MBEDTLS_HEAP_CUSTOM_SECTION is not set CONFIG_MBEDTLS_INIT=y # CONFIG_MBEDTLS_ZEROIZE_ALT is not set CONFIG_APP_LINK_WITH_MBEDTLS=y # end of mbedtls (C:/ncs/v3.2.4/modules/crypto/mbedtls) # # oberon-psa-crypto (C:/ncs/v3.2.4/modules/crypto/oberon-psa-crypto) # CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y # end of oberon-psa-crypto (C:/ncs/v3.2.4/modules/crypto/oberon-psa-crypto) # # trusted-firmware-m (C:/ncs/v3.2.4/modules/tee/tf-m/trusted-firmware-m) # CONFIG_TFM_BOARD="C:/ncs/v3.2.4/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp" CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y # end of trusted-firmware-m (C:/ncs/v3.2.4/modules/tee/tf-m/trusted-firmware-m) CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y # # cjson (C:/ncs/v3.2.4/modules/lib/cjson) # CONFIG_CJSON_LIB=y CONFIG_ZEPHYR_CJSON_MODULE=y # end of cjson (C:/ncs/v3.2.4/modules/lib/cjson) # # azure-sdk-for-c (C:/ncs/v3.2.4/modules/lib/azure-sdk-for-c) # CONFIG_AZURE_SDK=y CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y # end of azure-sdk-for-c (C:/ncs/v3.2.4/modules/lib/azure-sdk-for-c) # # cirrus-logic (C:/ncs/v3.2.4/modules/hal/cirrus-logic) # # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y # end of cirrus-logic (C:/ncs/v3.2.4/modules/hal/cirrus-logic) # # openthread (C:/ncs/v3.2.4/modules/lib/openthread) # # CONFIG_OPENTHREAD is not set CONFIG_ZEPHYR_OPENTHREAD_MODULE=y # end of openthread (C:/ncs/v3.2.4/modules/lib/openthread) # # memfault-firmware-sdk (C:/ncs/v3.2.4/modules/lib/memfault-firmware-sdk) # # CONFIG_MEMFAULT is not set CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y # end of memfault-firmware-sdk (C:/ncs/v3.2.4/modules/lib/memfault-firmware-sdk) # # coremark (C:/ncs/v3.2.4/modules/benchmark/coremark) # # CONFIG_COREMARK is not set CONFIG_ZEPHYR_COREMARK_MODULE=y # end of coremark (C:/ncs/v3.2.4/modules/benchmark/coremark) # # canopennode (C:/ncs/v3.2.4/modules/lib/canopennode) # CONFIG_ZEPHYR_CANOPENNODE_MODULE=y # end of canopennode (C:/ncs/v3.2.4/modules/lib/canopennode) # # chre (C:/ncs/v3.2.4/modules/lib/chre) # CONFIG_ZEPHYR_CHRE_MODULE=y # CONFIG_CHRE is not set # end of chre (C:/ncs/v3.2.4/modules/lib/chre) # # lz4 (C:/ncs/v3.2.4/modules/lib/lz4) # CONFIG_ZEPHYR_LZ4_MODULE=y # CONFIG_LZ4 is not set # end of lz4 (C:/ncs/v3.2.4/modules/lib/lz4) CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y # # zscilib (C:/ncs/v3.2.4/modules/lib/zscilib) # # CONFIG_ZSL is not set CONFIG_ZEPHYR_ZSCILIB_MODULE=y # end of zscilib (C:/ncs/v3.2.4/modules/lib/zscilib) # # cmsis (C:/ncs/v3.2.4/modules/hal/cmsis) # CONFIG_ZEPHYR_CMSIS_MODULE=y CONFIG_HAS_CMSIS_CORE=y # end of cmsis (C:/ncs/v3.2.4/modules/hal/cmsis) # # cmsis-dsp (C:/ncs/v3.2.4/modules/lib/cmsis-dsp) # CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y # CONFIG_CMSIS_DSP is not set # end of cmsis-dsp (C:/ncs/v3.2.4/modules/lib/cmsis-dsp) # # cmsis-nn (C:/ncs/v3.2.4/modules/lib/cmsis-nn) # CONFIG_ZEPHYR_CMSIS_NN_MODULE=y # CONFIG_CMSIS_NN is not set # end of cmsis-nn (C:/ncs/v3.2.4/modules/lib/cmsis-nn) # # cmsis_6 (C:/ncs/v3.2.4/modules/hal/cmsis_6) # CONFIG_ZEPHYR_CMSIS_6_MODULE=y CONFIG_HAS_CMSIS_CORE_M=y # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set # end of cmsis_6 (C:/ncs/v3.2.4/modules/hal/cmsis_6) # # fatfs (C:/ncs/v3.2.4/modules/fs/fatfs) # CONFIG_ZEPHYR_FATFS_MODULE=y # end of fatfs (C:/ncs/v3.2.4/modules/fs/fatfs) # # hal_nordic (C:/ncs/v3.2.4/modules/hal/nordic) # CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y CONFIG_HAS_NORDIC_DRIVERS=y # # Nordic drivers # # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set # end of Nordic drivers CONFIG_HAS_NRFX=y # # nrfx drivers # # # nrfx drivers logging # # CONFIG_NRFX_CLOCK_LOG is not set # CONFIG_NRFX_GPIOTE_LOG is not set # CONFIG_NRFX_IPC_LOG is not set # CONFIG_NRFX_NVMC_LOG is not set # CONFIG_NRFX_QSPI_LOG is not set # CONFIG_NRFX_SAADC_LOG is not set # CONFIG_NRFX_SPIM_LOG is not set # CONFIG_NRFX_TIMER_LOG is not set # CONFIG_NRFX_TWIM_LOG is not set # end of nrfx drivers logging CONFIG_NRFX_CLOCK=y # CONFIG_NRFX_CLOCK_USE_LFRC_CALIBRATION is not set CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y # CONFIG_NRFX_CLOCK_LF_CAL_ENABLED is not set # CONFIG_NRFX_CLOCK_LF_SRC_RC is not set CONFIG_NRFX_CLOCK_LF_SRC_XTAL=y # CONFIG_NRFX_CLOCK_LF_SRC_SYNTH is not set # CONFIG_NRFX_COMP is not set # CONFIG_NRFX_EGU0 is not set # CONFIG_NRFX_EGU1 is not set # CONFIG_NRFX_EGU2 is not set # CONFIG_NRFX_EGU3 is not set # CONFIG_NRFX_EGU4 is not set # CONFIG_NRFX_EGU5 is not set CONFIG_NRFX_GPIOTE=y CONFIG_NRFX_GPIOTE0=y # CONFIG_NRFX_GPIOTE1 is not set CONFIG_NRFX_GPPI=y # CONFIG_NRFX_GPPI_V1 is not set # CONFIG_NRFX_I2S is not set CONFIG_NRFX_IPC=y # CONFIG_NRFX_LPCOMP is not set # CONFIG_NRFX_NFCT is not set CONFIG_NRFX_NVMC=y # CONFIG_NRFX_PDM is not set # CONFIG_NRFX_POWER is not set # CONFIG_NRFX_PWM is not set # CONFIG_NRFX_QDEC is not set CONFIG_NRFX_QSPI=y # CONFIG_NRFX_RTC0 is not set # CONFIG_NRFX_RTC1 is not set CONFIG_NRFX_SAADC=y CONFIG_NRFX_SPIM=y # CONFIG_NRFX_SYSTICK is not set CONFIG_NRFX_TIMER=y CONFIG_NRFX_TWIM=y # CONFIG_NRFX_TWIS is not set # CONFIG_NRFX_UARTE is not set # CONFIG_NRFX_USBREG is not set # # Peripheral Resource Sharing module # # CONFIG_NRFX_PRS_BOX_0 is not set # CONFIG_NRFX_PRS_BOX_1 is not set # CONFIG_NRFX_PRS_BOX_2 is not set # CONFIG_NRFX_PRS_BOX_3 is not set # CONFIG_NRFX_PRS_BOX_4 is not set # end of Peripheral Resource Sharing module CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_reserved_resources_ncs.h" # end of nrfx drivers # end of hal_nordic (C:/ncs/v3.2.4/modules/hal/nordic) # # hal_st (C:/ncs/v3.2.4/modules/hal/st) # CONFIG_ZEPHYR_HAL_ST_MODULE=y CONFIG_HAS_STMEMSC=y CONFIG_USE_STDC_LSM6DSO=y # end of hal_st (C:/ncs/v3.2.4/modules/hal/st) # # hal_tdk (C:/ncs/v3.2.4/modules/hal/tdk) # CONFIG_ZEPHYR_HAL_TDK_MODULE=y # # TDK drivers # # CONFIG_TDK_HAL is not set # end of TDK drivers # end of hal_tdk (C:/ncs/v3.2.4/modules/hal/tdk) CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y # # liblc3 (C:/ncs/v3.2.4/modules/lib/liblc3) # CONFIG_ZEPHYR_LIBLC3_MODULE=y # end of liblc3 (C:/ncs/v3.2.4/modules/lib/liblc3) CONFIG_ZEPHYR_LIBMETAL_MODULE=y # # littlefs (C:/ncs/v3.2.4/modules/fs/littlefs) # CONFIG_ZEPHYR_LITTLEFS_MODULE=y # end of littlefs (C:/ncs/v3.2.4/modules/fs/littlefs) # # loramac-node (C:/ncs/v3.2.4/modules/lib/loramac-node) # CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set # end of loramac-node (C:/ncs/v3.2.4/modules/lib/loramac-node) # # lvgl (C:/ncs/v3.2.4/modules/lib/gui/lvgl) # CONFIG_ZEPHYR_LVGL_MODULE=y # end of lvgl (C:/ncs/v3.2.4/modules/lib/gui/lvgl) CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y # # nanopb (C:/ncs/v3.2.4/modules/lib/nanopb) # CONFIG_ZEPHYR_NANOPB_MODULE=y CONFIG_NANOPB=y # CONFIG_NANOPB_ENABLE_MALLOC is not set CONFIG_NANOPB_MAX_REQUIRED_FIELDS=64 # CONFIG_NANOPB_NO_ERRMSG is not set # CONFIG_NANOPB_BUFFER_ONLY is not set # CONFIG_NANOPB_WITHOUT_64BIT is not set # CONFIG_NANOPB_ENCODE_ARRAYS_UNPACKED is not set # CONFIG_NANOPB_VALIDATE_UTF8 is not set # end of nanopb (C:/ncs/v3.2.4/modules/lib/nanopb) # # nrf_wifi (C:/ncs/v3.2.4/modules/lib/nrf_wifi) # CONFIG_ZEPHYR_NRF_WIFI_MODULE=y CONFIG_NRF70_BUSLIB=y CONFIG_NRF70_ON_SPI=y # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_OFF is not set # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_ERR is not set # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_WRN is not set # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_INF is not set # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_DBG is not set CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_DEFAULT=y CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL=3 CONFIG_NRF70_LOG_VERBOSE=y # end of nrf_wifi (C:/ncs/v3.2.4/modules/lib/nrf_wifi) CONFIG_ZEPHYR_OPEN_AMP_MODULE=y # # percepio (C:/ncs/v3.2.4/modules/debug/percepio) # # # Percepio Tracealyzer support can be enabled from the tracing subsystem # # CONFIG_PERCEPIO_DFM is not set CONFIG_ZEPHYR_PERCEPIO_MODULE=y # end of percepio (C:/ncs/v3.2.4/modules/debug/percepio) # # picolibc (C:/ncs/v3.2.4/modules/lib/picolibc) # # CONFIG_PICOLIBC_MODULE is not set CONFIG_ZEPHYR_PICOLIBC_MODULE=y # end of picolibc (C:/ncs/v3.2.4/modules/lib/picolibc) # # segger (C:/ncs/v3.2.4/modules/debug/segger) # CONFIG_ZEPHYR_SEGGER_MODULE=y CONFIG_HAS_SEGGER_RTT=y # CONFIG_USE_SEGGER_RTT is not set # end of segger (C:/ncs/v3.2.4/modules/debug/segger) # # uoscore-uedhoc (C:/ncs/v3.2.4/modules/lib/uoscore-uedhoc) # CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y # end of uoscore-uedhoc (C:/ncs/v3.2.4/modules/lib/uoscore-uedhoc) # # zcbor (C:/ncs/v3.2.4/modules/lib/zcbor) # CONFIG_ZEPHYR_ZCBOR_MODULE=y # CONFIG_ZCBOR is not set # end of zcbor (C:/ncs/v3.2.4/modules/lib/zcbor) # # nrfxlib (C:/ncs/v3.2.4/nrfxlib) # # # Nordic nrfxlib # # # nrf_modem (Modem library) # CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8 # end of nrf_modem (Modem library) # CONFIG_NFC_T2T_NRFXLIB is not set # CONFIG_NFC_T4T_NRFXLIB is not set # # Crypto libraries for nRF5x SOCs. # CONFIG_NRFXLIB_CRYPTO=y CONFIG_HAS_HW_NRF_CC3XX=y # CONFIG_NRF_OBERON is not set # CONFIG_NRF_CC310_BL is not set CONFIG_NRF_CC3XX_PLATFORM=y CONFIG_CC3XX_MUTEX_LOCK=y # CONFIG_CC3XX_ATOMIC_LOCK is not set # CONFIG_CC3XX_HW_MUTEX_LOCK is not set # end of Crypto libraries for nRF5x SOCs. # CONFIG_NRF_RPC is not set CONFIG_NRF_802154_SOURCE_NRFXLIB=y # CONFIG_GZLL is not set # CONFIG_NRF_DM is not set # CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set # CONFIG_NRF_FUEL_GAUGE is not set # end of Nordic nrfxlib CONFIG_ZEPHYR_NRFXLIB_MODULE=y # end of nrfxlib (C:/ncs/v3.2.4/nrfxlib) CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y # # connectedhomeip (C:/ncs/v3.2.4/modules/lib/matter) # # CONFIG_CHIP is not set # CONFIG_CHIP_CUSTOM_BLE_ADV_DATA is not set CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y # end of connectedhomeip (C:/ncs/v3.2.4/modules/lib/matter) CONFIG_LIBMETAL=y CONFIG_LIBMETAL_SRC_PATH="libmetal" # CONFIG_LVGL is not set # CONFIG_HAS_MEC_HAL is not set # CONFIG_HAS_MPFS_HAL is not set # CONFIG_HAS_MEC5_HAL is not set CONFIG_OPENAMP=y CONFIG_OPENAMP_SRC_PATH="open-amp" CONFIG_OPENAMP_MASTER=y CONFIG_OPENAMP_SLAVE=y # CONFIG_MIPI_SYST_LIB is not set # CONFIG_HAS_TELINK_DRIVERS is not set CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="C:/ncs/v3.2.4/bootloader/mcuboot/root-rsa-2048.pem" CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE="" CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="0.0.0+0" # CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set # CONFIG_MCUBOOT_IMGTOOL_UUID_VID is not set # CONFIG_MCUBOOT_IMGTOOL_UUID_CID is not set CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS="" # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set # # On board MCUboot operation mode # # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_OFFSET is not set CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_USING_MOVE=y # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD_WITH_REVERT is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP_RAM_LOAD is not set CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set # CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set # end of On board MCUboot operation mode CONFIG_MCUBOOT_BOOTUTIL_LIB=y CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3 # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set # # Unavailable modules, please install those via the project manifest. # # # hal_bouffalolab module not available. # # # hal_gigadevice module not available. # # # hal_nxp module not available. # # # libsbc module not available. # # # Trusted-firmware-a module not available. # # # LoRa Basics Modem module not available. # # # THRIFT module not available. # # CONFIG_ACPI is not set # end of Modules CONFIG_BOARD="milo_53" CONFIG_BOARD_REVISION="1.5.0" CONFIG_BOARD_TARGET="[email protected]/nrf5340/cpuapp" # CONFIG_NET_DRIVERS is not set CONFIG_BOARD_MILO_53_NRF5340_CPUAPP=y CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp" # # Board Options # CONFIG_BOARD_REVISION_1_5_0=y # end of Board Options # # Hardware Configuration # CONFIG_SOC="nrf5340" CONFIG_SOC_SERIES="nrf53" CONFIG_SOC_FAMILY="nordic_nrf" CONFIG_SOC_FAMILY_NORDIC_NRF=y CONFIG_SOC_SERIES_NRF53X=y CONFIG_SOC_NRF5340_CPUAPP=y CONFIG_SOC_NRF5340_CPUAPP_QKAA=y CONFIG_HWINFO=y # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set CONFIG_SOC_COMPATIBLE_NRF=y CONFIG_SOC_COMPATIBLE_NRF53X=y CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y CONFIG_SOC_NORDIC_BSP_NAME="stable" CONFIG_HAS_HW_NRF_CC312=y CONFIG_HAS_HW_NRF_CLOCK=y CONFIG_HAS_HW_NRF_CTRLAP=y CONFIG_HAS_HW_NRF_DCNF=y CONFIG_HAS_HW_NRF_DPPIC=y CONFIG_HAS_HW_NRF_EGU0=y CONFIG_HAS_HW_NRF_EGU1=y CONFIG_HAS_HW_NRF_EGU2=y CONFIG_HAS_HW_NRF_EGU3=y CONFIG_HAS_HW_NRF_EGU4=y CONFIG_HAS_HW_NRF_EGU5=y CONFIG_HAS_HW_NRF_GPIO0=y CONFIG_HAS_HW_NRF_GPIO1=y CONFIG_HAS_HW_NRF_GPIOTE0=y CONFIG_HAS_HW_NRF_KMU=y CONFIG_HAS_HW_NRF_MUTEX=y CONFIG_HAS_HW_NRF_NVMC_PE=y CONFIG_HAS_HW_NRF_POWER=y CONFIG_HAS_HW_NRF_QSPI=y CONFIG_HAS_HW_NRF_RESET=y CONFIG_HAS_HW_NRF_SAADC=y CONFIG_HAS_HW_NRF_SPU=y CONFIG_HAS_HW_NRF_UARTE0=y CONFIG_HAS_HW_NRF_VMC=y CONFIG_HAS_NORDIC_RAM_CTRL=y # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set # CONFIG_NRF_SYS_EVENT is not set # CONFIG_IS_IRONSIDE_SE_SECONDARY_IMAGE is not set # CONFIG_IS_GEN_UICR_IMAGE is not set # CONFIG_SOC_NRF53_ANOMALY_47_WORKAROUND is not set CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set CONFIG_SOC_NRF53_RTC_PRETICK=y CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10 CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11 CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x4000 CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000 CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x2000 # CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340 is not set CONFIG_SOC_NRF53_CPUNET_MGMT=y # CONFIG_SOC_NRF53_CPUNET_ENABLE is not set # CONFIG_BOARD_ENABLE_CPUNET is not set CONFIG_SOC_HFXO_CAP_DEFAULT=y # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set # CONFIG_SOC_HFXO_CAP_INTERNAL is not set CONFIG_NRF_ENABLE_CACHE=y CONFIG_NRF53_SYNC_RTC=y # CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set # CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set # CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set # CONFIG_SYNC_RTC_LOG_LEVEL_INF is not set # CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT=y CONFIG_SYNC_RTC_LOG_LEVEL=3 CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90 CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1 CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y CONFIG_NRF53_SYNC_RTC_IPM_OUT=7 CONFIG_NRF53_SYNC_RTC_IPM_IN=8 CONFIG_IPM_MSG_CH_8_ENABLE=y CONFIG_IPM_MSG_CH_8_RX=y # CONFIG_SOC_NRF54H20_PM_S2RAM_OVERRIDE is not set CONFIG_NRF_SOC_SECURE_SUPPORTED=y CONFIG_NRF_APPROTECT_USE_UICR=y # CONFIG_NRF_APPROTECT_LOCK is not set # CONFIG_NRF_APPROTECT_USER_HANDLING is not set CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set # CONFIG_NRF_TRACE_PORT is not set CONFIG_GPIO_INIT_PRIORITY=40 # CONFIG_SOC_LOG_LEVEL_OFF is not set # CONFIG_SOC_LOG_LEVEL_ERR is not set # CONFIG_SOC_LOG_LEVEL_WRN is not set # CONFIG_SOC_LOG_LEVEL_INF is not set # CONFIG_SOC_LOG_LEVEL_DBG is not set CONFIG_SOC_LOG_LEVEL_DEFAULT=y CONFIG_SOC_LOG_LEVEL=3 # end of Hardware Configuration CONFIG_ARCH="arm" # CONFIG_EXTRA_EXCEPTION_INFO is not set CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y CONFIG_CPU_CORTEX=y CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32 CONFIG_MPU_ALLOW_FLASH_WRITE=y # # ARM Options # CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y CONFIG_ARM_ON_EXIT_CPU_IDLE=y CONFIG_CPU_CORTEX_M=y # CONFIG_ARM_ZIMAGE_HEADER is not set CONFIG_ISA_THUMB2=y CONFIG_ASSEMBLER_ISA_THUMB2=y CONFIG_COMPILER_ISA_THUMB2=y CONFIG_STACK_ALIGN_DOUBLE_WORD=y # CONFIG_RUNTIME_NMI is not set # CONFIG_PLATFORM_SPECIFIC_INIT is not set CONFIG_FAULT_DUMP=2 CONFIG_BUILTIN_STACK_GUARD=y CONFIG_ARM_STACK_PROTECTION=y CONFIG_ARM_STORE_EXC_RETURN=y CONFIG_FP_HARDABI=y # CONFIG_FP_SOFTABI is not set CONFIG_FP16=y CONFIG_FP16_IEEE=y # CONFIG_FP16_ALT is not set CONFIG_CPU_CORTEX_M33=y CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y CONFIG_CPU_CORTEX_M_HAS_DWT=y CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y CONFIG_CPU_CORTEX_M_HAS_VTOR=y CONFIG_CPU_CORTEX_M_HAS_SPLIM=y CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y CONFIG_CPU_CORTEX_M_HAS_CMSE=y CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_MAINLINE=y CONFIG_ARMV8_M_SE=y CONFIG_ARMV7_M_ARMV8_M_FP=y CONFIG_ARMV8_M_DSP=y # # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options # # CONFIG_SW_VECTOR_RELAY is not set # CONFIG_CORTEX_M_DWT is not set # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set # CONFIG_TRAP_UNALIGNED_ACCESS is not set # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set CONFIG_ARM_TRUSTZONE_M=y # CONFIG_MPU_STACK_GUARD is not set # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set # CONFIG_CUSTOM_SECTION_ALIGN is not set CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32 CONFIG_CPU_HAS_NRF_IDAU=y CONFIG_HAS_SWO=y # end of ARM Options CONFIG_ARM=y CONFIG_ARCH_IS_SET=y # # General Architecture Options # # CONFIG_SEMIHOST is not set CONFIG_ARCH_SUPPORTS_ROM_OFFSET=y CONFIG_ARM_MPU=y # CONFIG_ARCH_LOG_LEVEL_OFF is not set # CONFIG_ARCH_LOG_LEVEL_ERR is not set # CONFIG_ARCH_LOG_LEVEL_WRN is not set # CONFIG_ARCH_LOG_LEVEL_INF is not set # CONFIG_ARCH_LOG_LEVEL_DBG is not set CONFIG_ARCH_LOG_LEVEL_DEFAULT=y CONFIG_ARCH_LOG_LEVEL=3 CONFIG_LITTLE_ENDIAN=y # CONFIG_TRUSTED_EXECUTION_SECURE is not set # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set # CONFIG_USERSPACE is not set # CONFIG_NOINIT_SNIPPET_FIRST is not set CONFIG_GEN_PRIV_STACKS=y # CONFIG_STACK_GROWS_UP is not set # CONFIG_FRAME_POINTER is not set # # Interrupt Configuration # # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set CONFIG_ARCH_DEVICE_STATE_ALIGN=4 CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set # CONFIG_SRAM_SW_ISR_TABLE is not set CONFIG_EXCEPTION_DEBUG=y # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set # end of Interrupt Configuration # end of General Architecture Options CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y CONFIG_ARCH_HAS_STACK_PROTECTION=y CONFIG_ARCH_HAS_USERSPACE=y CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y CONFIG_ARCH_SUPPORTS_COREDUMP=y CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y CONFIG_ARCH_SUPPORTS_ROM_START=y CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y CONFIG_ARCH_HAS_THREAD_ABORT=y CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y CONFIG_CPU_HAS_TEE=y CONFIG_CPU_HAS_FPU=y CONFIG_CPU_HAS_MPU=y CONFIG_MPU=y # CONFIG_MPU_LOG_LEVEL_OFF is not set # CONFIG_MPU_LOG_LEVEL_ERR is not set # CONFIG_MPU_LOG_LEVEL_WRN is not set # CONFIG_MPU_LOG_LEVEL_INF is not set # CONFIG_MPU_LOG_LEVEL_DBG is not set CONFIG_MPU_LOG_LEVEL_DEFAULT=y CONFIG_MPU_LOG_LEVEL=3 CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y CONFIG_MPU_GAP_FILLING=y CONFIG_SRAM_REGION_PERMISSIONS=y # # DSP Options # # end of DSP Options # # Floating Point Options # CONFIG_FPU_SHARING=y # end of Floating Point Options # # Cache Options # # end of Cache Options CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y # # General Kernel Options # # CONFIG_KERNEL_LOG_LEVEL_OFF is not set # CONFIG_KERNEL_LOG_LEVEL_ERR is not set # CONFIG_KERNEL_LOG_LEVEL_WRN is not set # CONFIG_KERNEL_LOG_LEVEL_INF is not set # CONFIG_KERNEL_LOG_LEVEL_DBG is not set CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y CONFIG_KERNEL_LOG_LEVEL=3 CONFIG_NUM_COOP_PRIORITIES=16 CONFIG_MAIN_THREAD_PRIORITY=0 CONFIG_COOP_ENABLED=y CONFIG_PREEMPT_ENABLED=y CONFIG_PRIORITY_CEILING=-127 # CONFIG_SCHED_DEADLINE is not set CONFIG_THREAD_STACK_INFO=y # CONFIG_THREAD_CUSTOM_DATA is not set # CONFIG_DYNAMIC_THREAD is not set # CONFIG_SCHED_DUMB is not set CONFIG_SCHED_SIMPLE=y # CONFIG_SCHED_SCALABLE is not set # CONFIG_SCHED_MULTIQ is not set # CONFIG_WAITQ_DUMB is not set # CONFIG_WAITQ_SCALABLE is not set CONFIG_WAITQ_SIMPLE=y # # Misc Kernel related options # CONFIG_ERRNO=y # end of Misc Kernel related options # # Kernel Debugging and Metrics # CONFIG_BOOT_DELAY=0 # CONFIG_BOOT_CLEAR_SCREEN is not set CONFIG_THREAD_MONITOR=y CONFIG_THREAD_NAME=y CONFIG_THREAD_MAX_NAME_LEN=32 # CONFIG_THREAD_RUNTIME_STATS is not set # end of Kernel Debugging and Metrics # CONFIG_OBJ_CORE is not set # CONFIG_WORKQUEUE_WORK_TIMEOUT is not set # # System Work Queue Options # # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set CONFIG_SYSTEM_WORKQUEUE_WORK_TIMEOUT_MS=5000 # end of System Work Queue Options # # Barrier Operations # CONFIG_BARRIER_OPERATIONS_ARCH=y # end of Barrier Operations # # Atomic Operations # CONFIG_ATOMIC_OPERATIONS_BUILTIN=y # end of Atomic Operations # # Timer API Options # CONFIG_TIMESLICING=y CONFIG_TIMESLICE_PRIORITY=0 # CONFIG_TIMESLICE_PER_THREAD is not set # end of Timer API Options # # Other Kernel Object Options # CONFIG_POLL=y CONFIG_MEM_SLAB_POINTER_VALIDATE=y # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set CONFIG_NUM_MBOX_ASYNC_MSGS=10 CONFIG_EVENTS=y CONFIG_HEAP_MEM_POOL_IGNORE_MIN=y # end of Other Kernel Object Options CONFIG_SWAP_NONATOMIC=y CONFIG_TIMEOUT_64BIT=y CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365 # # Security Options # CONFIG_STACK_POINTER_RANDOM=0 # end of Security Options # # Memory Domains # CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y # end of Memory Domains # # SMP Options # # CONFIG_TICKET_SPINLOCKS is not set # end of SMP Options CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y # CONFIG_THREAD_LOCAL_STORAGE is not set CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y # CONFIG_STATIC_INIT_GNU is not set # CONFIG_BOOTARGS is not set # end of General Kernel Options # # Device Options # # CONFIG_DEVICE_MUTABLE is not set # CONFIG_DEVICE_DT_METADATA is not set CONFIG_DEVICE_DEINIT_SUPPORT=y # end of Device Options # # Initialization Priorities # CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30 CONFIG_KERNEL_INIT_PRIORITY_LIBC=35 CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40 CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50 CONFIG_APPLICATION_INIT_PRIORITY=90 # end of Initialization Priorities # # Virtual Memory Support # # # MMU Features # # end of MMU Features # end of Virtual Memory Support # # SoC and Board Hooks # # CONFIG_SOC_EARLY_RESET_HOOK is not set # CONFIG_SOC_PREP_HOOK is not set CONFIG_SOC_EARLY_INIT_HOOK=y CONFIG_SOC_LATE_INIT_HOOK=y # CONFIG_SOC_PER_CORE_INIT_HOOK is not set # CONFIG_BOARD_EARLY_INIT_HOOK is not set # CONFIG_BOARD_LATE_INIT_HOOK is not set # end of SoC and Board Hooks # # Device Drivers # CONFIG_ADC=y CONFIG_ADC_CONFIGURABLE_INPUTS=y # CONFIG_ADC_ASYNC is not set # CONFIG_ADC_LOG_LEVEL_OFF is not set # CONFIG_ADC_LOG_LEVEL_ERR is not set # CONFIG_ADC_LOG_LEVEL_WRN is not set # CONFIG_ADC_LOG_LEVEL_INF is not set # CONFIG_ADC_LOG_LEVEL_DBG is not set CONFIG_ADC_LOG_LEVEL_DEFAULT=y CONFIG_ADC_LOG_LEVEL=3 CONFIG_ADC_NRFX_SAADC=y # CONFIG_AUDIO is not set # CONFIG_AUXDISPLAY is not set # CONFIG_BBRAM is not set CONFIG_BT_DRIVERS=y # # Bluetooth HCI Driver Options # CONFIG_BT_HCI_IPC_SEND_RETRY_COUNT=3 CONFIG_BT_HCI_IPC_SEND_RETRY_DELAY_US=75 CONFIG_BT_HCI_IPC_ENDPOINT_BOUND_TIMEOUT_MS=2000 CONFIG_BT_HCI_INIT_PRIORITY=50 # CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set CONFIG_BT_DRV_TX_STACK_SIZE=256 CONFIG_BT_DRV_RX_STACK_SIZE=512 # CONFIG_CAN is not set # CONFIG_CHARGER is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y CONFIG_CLOCK_CONTROL_LOG_LEVEL=3 CONFIG_CLOCK_CONTROL_NRF=y CONFIG_CLOCK_CONTROL_NRF_K32SRC_FREQUENCY=32768 # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM is not set # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM=y CONFIG_CLOCK_CONTROL_NRF_ACCURACY=20 # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set # CONFIG_COMPARATOR is not set CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128 CONFIG_CONSOLE_HAS_DRIVER=y # CONFIG_CONSOLE_HANDLER is not set CONFIG_CONSOLE_INIT_PRIORITY=60 CONFIG_UART_CONSOLE=y # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set # CONFIG_UART_CONSOLE_MCUMGR is not set # CONFIG_RAM_CONSOLE is not set # CONFIG_IPM_CONSOLE_SENDER is not set # CONFIG_IPM_CONSOLE_RECEIVER is not set # CONFIG_UART_MCUMGR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y CONFIG_UART_CONSOLE_LOG_LEVEL=3 # CONFIG_EFI_CONSOLE is not set # CONFIG_COREDUMP_DEVICE is not set # CONFIG_CRC_DRIVER is not set # CONFIG_CRYPTO is not set # CONFIG_DAC is not set # CONFIG_DAI is not set # CONFIG_DEBUG_DRIVER is not set # CONFIG_DISK_DRIVERS is not set # CONFIG_DISPLAY is not set # CONFIG_DMA is not set # CONFIG_DP_DRIVER is not set # CONFIG_EDAC is not set # CONFIG_EEPROM is not set CONFIG_ENTROPY_GENERATOR=y # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set # CONFIG_ENTROPY_LOG_LEVEL_INF is not set # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y CONFIG_ENTROPY_LOG_LEVEL=3 CONFIG_ENTROPY_INIT_PRIORITY=50 CONFIG_ENTROPY_BT_HCI=y # CONFIG_FAKE_ENTROPY_NATIVE_POSIX is not set CONFIG_ENTROPY_HAS_DRIVER=y # CONFIG_ESPI is not set CONFIG_ETH_DRIVER=y # CONFIG_ETHERNET_LOG_LEVEL_OFF is not set # CONFIG_ETHERNET_LOG_LEVEL_ERR is not set # CONFIG_ETHERNET_LOG_LEVEL_WRN is not set # CONFIG_ETHERNET_LOG_LEVEL_INF is not set # CONFIG_ETHERNET_LOG_LEVEL_DBG is not set CONFIG_ETHERNET_LOG_LEVEL_DEFAULT=y CONFIG_ETHERNET_LOG_LEVEL=3 # CONFIG_ETH_IVSHMEM is not set # CONFIG_DSA_DRIVERS is not set # # DWC XGMAC configuration # # end of DWC XGMAC configuration CONFIG_ETH_PHY_DRIVER=y # CONFIG_PHY_LOG_LEVEL_OFF is not set # CONFIG_PHY_LOG_LEVEL_ERR is not set # CONFIG_PHY_LOG_LEVEL_WRN is not set # CONFIG_PHY_LOG_LEVEL_INF is not set # CONFIG_PHY_LOG_LEVEL_DBG is not set CONFIG_PHY_LOG_LEVEL_DEFAULT=y CONFIG_PHY_LOG_LEVEL=3 CONFIG_PHY_INIT_PRIORITY=70 CONFIG_PHY_AUTONEG_TIMEOUT_MS=4000 CONFIG_PHY_MONITOR_PERIOD=500 # CONFIG_PHY_OA_TC14_PLCA_LIB is not set # CONFIG_PHY_VERIFY_DEVICE_IDENTIFICATION is not set CONFIG_ETH_INIT_PRIORITY=80 # # Firmware drivers # # CONFIG_ARM_SCMI is not set # end of Firmware drivers CONFIG_FLASH_HAS_DRIVER_ENABLED=y CONFIG_FLASH_HAS_EXPLICIT_ERASE=y CONFIG_FLASH_HAS_PAGE_LAYOUT=y CONFIG_FLASH_JESD216=y # CONFIG_FLASH_JESD216_API is not set CONFIG_FLASH_PAGE_LAYOUT=y # # MSPI flash device driver # # end of MSPI flash device driver CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=41 # CONFIG_NORDIC_QSPI_NOR_XIP is not set CONFIG_NORDIC_QSPI_NOR_TIMEOUT_MS=500 CONFIG_NORDIC_QSPI_NOR_ACTIVE_DWELL_MS=10 # CONFIG_SOC_FLASH_NRF_CUSTOM_CONTEXT is not set CONFIG_SOC_FLASH_NRF=y CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set # CONFIG_SOC_FLASH_NRF_UICR is not set # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set # CONFIG_FLASH_LOG_LEVEL_OFF is not set # CONFIG_FLASH_LOG_LEVEL_ERR is not set # CONFIG_FLASH_LOG_LEVEL_WRN is not set # CONFIG_FLASH_LOG_LEVEL_INF is not set # CONFIG_FLASH_LOG_LEVEL_DBG is not set CONFIG_FLASH_LOG_LEVEL_DEFAULT=y CONFIG_FLASH_LOG_LEVEL=3 # CONFIG_FPGA is not set # CONFIG_FUEL_GAUGE is not set # CONFIG_GNSS is not set # CONFIG_GPIO_LOG_LEVEL_OFF is not set # CONFIG_GPIO_LOG_LEVEL_ERR is not set # CONFIG_GPIO_LOG_LEVEL_WRN is not set # CONFIG_GPIO_LOG_LEVEL_INF is not set # CONFIG_GPIO_LOG_LEVEL_DBG is not set CONFIG_GPIO_LOG_LEVEL_DEFAULT=y CONFIG_GPIO_LOG_LEVEL=3 # CONFIG_GPIO_GET_DIRECTION is not set # CONFIG_GPIO_GET_CONFIG is not set # CONFIG_GPIO_HOGS is not set # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set CONFIG_GPIO_NRFX=y CONFIG_GPIO_NRFX_INTERRUPT=y # CONFIG_HAPTICS is not set # CONFIG_HWINFO_LOG_LEVEL_OFF is not set # CONFIG_HWINFO_LOG_LEVEL_ERR is not set # CONFIG_HWINFO_LOG_LEVEL_WRN is not set # CONFIG_HWINFO_LOG_LEVEL_INF is not set # CONFIG_HWINFO_LOG_LEVEL_DBG is not set CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y CONFIG_HWINFO_LOG_LEVEL=3 CONFIG_HWINFO_HAS_DRIVER=y CONFIG_HWINFO_NRF=y # CONFIG_HWSPINLOCK is not set CONFIG_I2C=y # CONFIG_I2C_CALLBACK is not set # CONFIG_I2C_RTIO is not set # CONFIG_I2C_TARGET is not set # CONFIG_I2C_DW_EXTENDED_SUPPORT is not set CONFIG_I2C_NRFX=y CONFIG_I2C_NRFX_TWIM=y CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500 CONFIG_I2C_INIT_PRIORITY=50 # CONFIG_I2C_LOG_LEVEL_OFF is not set # CONFIG_I2C_LOG_LEVEL_ERR is not set # CONFIG_I2C_LOG_LEVEL_WRN is not set # CONFIG_I2C_LOG_LEVEL_INF is not set # CONFIG_I2C_LOG_LEVEL_DBG is not set CONFIG_I2C_LOG_LEVEL_DEFAULT=y CONFIG_I2C_LOG_LEVEL=3 # CONFIG_I2S is not set # CONFIG_I3C is not set # CONFIG_IEEE802154 is not set # # Interrupt controller drivers # CONFIG_INTC_INIT_PRIORITY=40 # CONFIG_INTC_LOG_LEVEL_OFF is not set # CONFIG_INTC_LOG_LEVEL_ERR is not set # CONFIG_INTC_LOG_LEVEL_WRN is not set # CONFIG_INTC_LOG_LEVEL_INF is not set # CONFIG_INTC_LOG_LEVEL_DBG is not set CONFIG_INTC_LOG_LEVEL_DEFAULT=y CONFIG_INTC_LOG_LEVEL=3 # end of Interrupt controller drivers # CONFIG_IPM is not set # CONFIG_LED is not set # CONFIG_LED_STRIP is not set # CONFIG_LORA is not set CONFIG_MBOX=y CONFIG_MBOX_NRFX_IPC=y CONFIG_MBOX_TI_SECURE_PROXY_PRIORITY=30 CONFIG_MBOX_INIT_PRIORITY=40 # CONFIG_MBOX_LOG_LEVEL_OFF is not set # CONFIG_MBOX_LOG_LEVEL_ERR is not set # CONFIG_MBOX_LOG_LEVEL_WRN is not set # CONFIG_MBOX_LOG_LEVEL_INF is not set # CONFIG_MBOX_LOG_LEVEL_DBG is not set CONFIG_MBOX_LOG_LEVEL_DEFAULT=y CONFIG_MBOX_LOG_LEVEL=3 # CONFIG_MDIO is not set # CONFIG_MIPI_DBI is not set # # Miscellaneous Drivers # # CONFIG_TIMEAWARE_GPIO is not set # # Interconn Drivers # # end of Interconn Drivers # end of Miscellaneous Drivers # CONFIG_MM_DRV is not set # CONFIG_MSPI is not set # CONFIG_PCIE is not set # CONFIG_PCIE_ENDPOINT is not set # CONFIG_PECI is not set CONFIG_PINCTRL=y # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set # CONFIG_PINCTRL_LOG_LEVEL_INF is not set # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y CONFIG_PINCTRL_LOG_LEVEL=3 CONFIG_PINCTRL_STORE_REG=y # CONFIG_PINCTRL_DYNAMIC is not set CONFIG_PINCTRL_KEEP_SLEEP_STATE=y # CONFIG_PINCTRL_NPCX_EX is not set CONFIG_PINCTRL_NRF=y # CONFIG_PM_CPU_OPS is not set # CONFIG_PS2 is not set # CONFIG_PSI5 is not set # CONFIG_PTP_CLOCK is not set # CONFIG_PWM is not set # CONFIG_RETAINED_MEM is not set # CONFIG_RTC is not set # CONFIG_SDHC is not set # CONFIG_SENSOR_LOG_LEVEL_OFF is not set # CONFIG_SENSOR_LOG_LEVEL_ERR is not set # CONFIG_SENSOR_LOG_LEVEL_WRN is not set # CONFIG_SENSOR_LOG_LEVEL_INF is not set # CONFIG_SENSOR_LOG_LEVEL_DBG is not set CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y CONFIG_SENSOR_LOG_LEVEL=3 CONFIG_SENSOR_INIT_PRIORITY=90 CONFIG_SENSOR_ASYNC_API=y # CONFIG_SENSOR_INFO is not set CONFIG_SENSOR_CLOCK=y CONFIG_SENSOR_CLOCK_SYSTEM=y # CONFIG_SENSOR_CLOCK_COUNTER is not set # CONFIG_SENSOR_CLOCK_RTC is not set # # Device Drivers # CONFIG_LSM6DSO=y CONFIG_LSM6DSO_TRIGGER_NONE=y # CONFIG_LSM6DSO_TRIGGER_GLOBAL_THREAD is not set # CONFIG_LSM6DSO_TRIGGER_OWN_THREAD is not set CONFIG_LSM6DSO_ENABLE_TEMP=y # CONFIG_LSM6DSO_SENSORHUB is not set CONFIG_STMEMSC_I3C_I2C_WRITE_BUFFER_SIZE=16 # CONFIG_SENT is not set # # Capabilities # CONFIG_SERIAL_HAS_DRIVER=y CONFIG_SERIAL_SUPPORT_ASYNC=y CONFIG_SERIAL_SUPPORT_INTERRUPT=y CONFIG_SERIAL_INIT_PRIORITY=50 # CONFIG_UART_LOG_LEVEL_OFF is not set # CONFIG_UART_LOG_LEVEL_ERR is not set # CONFIG_UART_LOG_LEVEL_WRN is not set # CONFIG_UART_LOG_LEVEL_INF is not set # CONFIG_UART_LOG_LEVEL_DBG is not set CONFIG_UART_LOG_LEVEL_DEFAULT=y CONFIG_UART_LOG_LEVEL=3 # CONFIG_UART_ASYNC_API is not set # CONFIG_UART_LINE_CTRL is not set # CONFIG_UART_DRV_CMD is not set # CONFIG_UART_WIDE_DATA is not set # CONFIG_UART_PIPE is not set # CONFIG_UART_ASYNC_RX_HELPER is not set # # Serial Drivers # # CONFIG_UART_NATIVE_POSIX is not set # CONFIG_UART_NPCX_FIFO_EX is not set CONFIG_UART_NRFX=y CONFIG_UART_NRFX_UARTE=y # CONFIG_UART_NRFX_UARTE_NO_IRQ is not set CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y # CONFIG_UART_NRFX_UARTE_DIRECT_ISR is not set CONFIG_UART_0_ENHANCED_POLL_OUT=y # CONFIG_UART_0_NRF_PARITY_BIT is not set CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32 # CONFIG_SMBUS is not set # CONFIG_SPI_ASYNC is not set # CONFIG_SPI_RTIO is not set # CONFIG_SPI_SLAVE is not set # CONFIG_SPI_EXTENDED_MODES is not set CONFIG_SPI_INIT_PRIORITY=50 CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200 # CONFIG_SPI_LOG_LEVEL_OFF is not set # CONFIG_SPI_LOG_LEVEL_ERR is not set # CONFIG_SPI_LOG_LEVEL_WRN is not set # CONFIG_SPI_LOG_LEVEL_INF is not set # CONFIG_SPI_LOG_LEVEL_DBG is not set CONFIG_SPI_LOG_LEVEL_DEFAULT=y CONFIG_SPI_LOG_LEVEL=3 CONFIG_SPI_NRFX=y CONFIG_SPI_NRFX_SPIM=y CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8 CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200 # CONFIG_STEPPER is not set # # Timer drivers # # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0 CONFIG_TICKLESS_CAPABLE=y CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y CONFIG_NRF_RTC_TIMER=y # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set CONFIG_NRF_RTC_COUNTER_BIT_WIDTH=24 # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y # end of Timer drivers # CONFIG_USB_BC12 is not set # CONFIG_UDC_DRIVER is not set # CONFIG_UHC_DRIVER is not set # CONFIG_UVB is not set # CONFIG_USB_DEVICE_DRIVER is not set # # USB common # # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3 # CONFIG_NRF_USBD_COMMON is not set # end of USB common # CONFIG_USBC_TCPC_DRIVER is not set # CONFIG_USBC_LOG_LEVEL_OFF is not set # CONFIG_USBC_LOG_LEVEL_ERR is not set # CONFIG_USBC_LOG_LEVEL_WRN is not set # CONFIG_USBC_LOG_LEVEL_INF is not set # CONFIG_USBC_LOG_LEVEL_DBG is not set CONFIG_USBC_LOG_LEVEL_DEFAULT=y CONFIG_USBC_LOG_LEVEL=3 # CONFIG_USBC_VBUS_DRIVER is not set # CONFIG_USBC_PPC_DRIVER is not set # CONFIG_VIDEO is not set # CONFIG_VIRTIO is not set # CONFIG_VIRTIO_LOG_LEVEL_OFF is not set # CONFIG_VIRTIO_LOG_LEVEL_ERR is not set # CONFIG_VIRTIO_LOG_LEVEL_WRN is not set # CONFIG_VIRTIO_LOG_LEVEL_INF is not set # CONFIG_VIRTIO_LOG_LEVEL_DBG is not set CONFIG_VIRTIO_LOG_LEVEL_DEFAULT=y CONFIG_VIRTIO_LOG_LEVEL=3 # CONFIG_VIRTUALIZATION is not set # CONFIG_W1 is not set # CONFIG_WIFI_LOG_LEVEL_OFF is not set # CONFIG_WIFI_LOG_LEVEL_ERR is not set # CONFIG_WIFI_LOG_LEVEL_WRN is not set # CONFIG_WIFI_LOG_LEVEL_INF is not set # CONFIG_WIFI_LOG_LEVEL_DBG is not set CONFIG_WIFI_LOG_LEVEL_DEFAULT=y CONFIG_WIFI_LOG_LEVEL=3 CONFIG_WIFI_INIT_PRIORITY=80 # CONFIG_WIFI_OFFLOAD is not set CONFIG_WIFI_USE_NATIVE_NETWORKING=y # CONFIG_WIFI_SIMPLELINK is not set CONFIG_NET_TCP_WORKQ_STACK_SIZE=1024 CONFIG_NET_MGMT_EVENT_STACK_SIZE=4600 CONFIG_WIFI_MGMT_SCAN_CHAN_MAX_MANUAL=3 CONFIG_WIFI_NRF70=y CONFIG_WIFI_NRF7002=y CONFIG_NRF70_QSPI_LOW_POWER=y # CONFIG_NRF70_SCAN_ONLY is not set CONFIG_NRF70_SYSTEM_MODE=y # CONFIG_NRF70_RADIO_TEST is not set # CONFIG_NRF70_OFFLOADED_RAW_TX is not set CONFIG_NRF70_STA_MODE=y # CONFIG_NRF70_ENABLE_DUAL_VIF is not set # CONFIG_NRF70_P2P_MODE is not set # CONFIG_NRF70_SYSTEM_WITH_RAW_MODES is not set # CONFIG_NRF70_RAW_DATA_TX is not set # CONFIG_NRF70_RAW_DATA_RX is not set # CONFIG_NRF70_PROMISC_DATA_RX is not set CONFIG_NRF70_DATA_TX=y CONFIG_NRF_WIFI_IF_AUTO_START=y # CONFIG_NRF_WIFI_PATCHES_BUILTIN is not set CONFIG_NRF_WIFI_PATCHES_EXTERNAL=y CONFIG_NRF_WIFI_LOW_POWER=y CONFIG_NRF70_TCP_IP_CHECKSUM_OFFLOAD=y CONFIG_NRF70_REG_DOMAIN="00" # CONFIG_WIFI_NRF70_LOG_LEVEL_OFF is not set # CONFIG_WIFI_NRF70_LOG_LEVEL_ERR is not set # CONFIG_WIFI_NRF70_LOG_LEVEL_WRN is not set # CONFIG_WIFI_NRF70_LOG_LEVEL_INF is not set # CONFIG_WIFI_NRF70_LOG_LEVEL_DBG is not set CONFIG_WIFI_NRF70_LOG_LEVEL_DEFAULT=y CONFIG_WIFI_NRF70_LOG_LEVEL=3 CONFIG_NRF70_SR_COEX=y CONFIG_NRF70_SR_COEX_SLEEP_CTRL_GPIO_CTRL=y CONFIG_NRF70_SR_COEX_SWCTRL1_OUTPUT=0 CONFIG_NRF70_SR_COEX_BT_GRANT_ACTIVE_LOW=1 CONFIG_NRF70_WORKQ_STACK_SIZE=4096 CONFIG_NRF70_WORKQ_MAX_ITEMS=100 CONFIG_NRF70_MAX_TX_PENDING_QLEN=18 CONFIG_NRF70_PCB_LOSS_2G=0 CONFIG_NRF70_PCB_LOSS_5G_BAND1=0 CONFIG_NRF70_PCB_LOSS_5G_BAND2=0 CONFIG_NRF70_PCB_LOSS_5G_BAND3=0 CONFIG_NRF70_ANT_GAIN_2G=0 CONFIG_NRF70_ANT_GAIN_5G_BAND1=0 CONFIG_NRF70_ANT_GAIN_5G_BAND2=0 CONFIG_NRF70_ANT_GAIN_5G_BAND3=0 CONFIG_NRF70_BAND_2G_LOWER_EDGE_BACKOFF_DSSS=5 CONFIG_NRF70_BAND_2G_LOWER_EDGE_BACKOFF_HT=5 CONFIG_NRF70_BAND_2G_LOWER_EDGE_BACKOFF_HE=5 CONFIG_NRF70_BAND_2G_UPPER_EDGE_BACKOFF_DSSS=5 CONFIG_NRF70_BAND_2G_UPPER_EDGE_BACKOFF_HT=5 CONFIG_NRF70_BAND_2G_UPPER_EDGE_BACKOFF_HE=5 CONFIG_NRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HT=0 CONFIG_NRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HE=0 CONFIG_NRF70_RX_NUM_BUFS=16 CONFIG_NRF70_MAX_TX_AGGREGATION=1 CONFIG_NRF70_MAX_TX_TOKENS=8 CONFIG_NRF70_TX_MAX_DATA_SIZE=1600 CONFIG_NRF70_RX_MAX_DATA_SIZE=1600 # CONFIG_NRF70_TX_DONE_WQ_ENABLED is not set # CONFIG_NRF70_RX_WQ_ENABLED is not set CONFIG_NRF70_IRQ_WQ_PRIORITY=-15 CONFIG_NRF70_BH_WQ_PRIORITY=0 CONFIG_NRF70_IRQ_WQ_STACK_SIZE=832 CONFIG_NRF70_BH_WQ_STACK_SIZE=1184 CONFIG_NRF70_RPU_PS_IDLE_TIMEOUT_MS=10 # CONFIG_NRF70_RPU_EXTEND_TWT_SP is not set CONFIG_WIFI_FIXED_MAC_ADDRESS="" CONFIG_WIFI_OTP_MAC_ADDRESS=y # CONFIG_WIFI_FIXED_MAC_ADDRESS_ENABLED is not set # CONFIG_WIFI_RANDOM_MAC_ADDRESS is not set CONFIG_NRF70_RSSI_STALE_TIMEOUT_MS=1000 # CONFIG_NRF_WIFI_GLOBAL_HEAP is not set CONFIG_NRF_WIFI_CTRL_HEAP_SIZE=20000 CONFIG_NRF_WIFI_DATA_HEAP_SIZE=110000 CONFIG_NET_TC_TX_COUNT=1 CONFIG_NRF_WIFI_USE_VARIABLE_NET_BUFS=y CONFIG_WIFI_MGMT_SCAN_SSID_FILT_MAX=2 CONFIG_NRF_WIFI_SCAN_MAX_BSS_CNT=0 # CONFIG_NRF_WIFI_BEAMFORMING is not set CONFIG_WIFI_NRF70_SCAN_TIMEOUT_S=30 CONFIG_NRF_WIFI_ALL_BAND=y # CONFIG_NRF_WIFI_2G_BAND is not set # CONFIG_NRF_WIFI_5G_BAND is not set CONFIG_NRF_WIFI_IFACE_MTU=1500 # CONFIG_WIFI_NRF70_SKIP_LOCAL_ADMIN_MAC is not set # CONFIG_WIFI_NRF70_SCAN_DISABLE_DFS_CHANNELS is not set CONFIG_NET_INTERFACE_NAME_LEN=15 CONFIG_NRF_WIFI_AP_DEAD_DETECT_TIMEOUT=20 CONFIG_NRF_WIFI_RPU_RECOVERY=y CONFIG_NRF_WIFI_RPU_RECOVERY_PROPAGATION_DELAY_MS=2000 CONFIG_NET_MGMT_EVENT_QUEUE_SIZE=16 CONFIG_NRF_WIFI_RPU_RECOVERY_PS_ACTIVE_TIMEOUT_MS=50000 CONFIG_NRF_WIFI_RPU_MIN_TIME_TO_ENTER_SLEEP_MS=5000 # CONFIG_NRF_WIFI_RPU_RECOVERY_DEBUG is not set CONFIG_NRF_WIFI_RPU_RECOVERY_QUIET_PERIOD_MS=5000 CONFIG_NRF_WIFI_RPU_RECOVERY_MAX_RETRIES=0 CONFIG_NRF_WIFI_RPU_RECOVERY_RETRY_WINDOW_S=900 # CONFIG_NRF_WIFI_RPU_RECOVERY_PS_STATE_DEBUG is not set CONFIG_NRF_WIFI_FEAT_WMM=y CONFIG_NRF_WIFI_PS_POLL_BASED_RETRIEVAL=y # CONFIG_NRF_WIFI_QOS_NULL_BASED_RETRIEVAL is not set CONFIG_NRF_WIFI_MGMT_BUFF_OFFLOAD=y # CONFIG_NRF_WIFI_FEAT_KEEPALIVE is not set # CONFIG_NRF_WIFI_PS_EXIT_EVERY_TIM is not set CONFIG_NRF_WIFI_PS_INT_PS=y CONFIG_NRF_WIFI_DISPLAY_SCAN_BSS_LIMIT=150 # CONFIG_NRF_WIFI_COEX_DISABLE_PRIORITY_WINDOW_FOR_SCAN is not set # CONFIG_NRF_WIFI_ZERO_COPY_TX is not set CONFIG_NRF_WIFI_MAX_PS_POLL_FAIL_CNT=10 CONFIG_NRF_WIFI_RX_STBC_HT=y # CONFIG_NRF_WIFI_DYNAMIC_BANDWIDTH_SIGNALLING is not set # CONFIG_NRF_WIFI_DYNAMIC_ED is not set CONFIG_NRF_WIFI_TWT_SETUP_TIMEOUT_MS=250 CONFIG_WIFI_USAGE_MODE_STA=y # CONFIG_WIFI_USAGE_MODE_AP is not set # CONFIG_WIFI_USAGE_MODE_STA_AP is not set # CONFIG_WIFI_USAGE_MODE_SCAN_ONLY is not set # CONFIG_TEE is not set # end of Device Drivers CONFIG_REQUIRES_FULL_LIBC=y # CONFIG_REQUIRES_FLOAT_PRINTF is not set # CONFIG_LIBC_ALLOW_LESS_THAN_64BIT_TIME is not set CONFIG_FULL_LIBC_SUPPORTED=y CONFIG_MINIMAL_LIBC_SUPPORTED=y CONFIG_NEWLIB_LIBC_SUPPORTED=y CONFIG_PICOLIBC_SUPPORTED=y CONFIG_NATIVE_LIBC_INCOMPATIBLE=y # # C Library # # CONFIG_PICOLIBC is not set CONFIG_NEWLIB_LIBC=y # CONFIG_EXTERNAL_LIBC is not set CONFIG_HAS_NEWLIB_LIBC_NANO=y CONFIG_COMMON_LIBC_ABORT=y # CONFIG_COMMON_LIBC_ASCTIME_R is not set # CONFIG_COMMON_LIBC_CTIME_R is not set CONFIG_COMMON_LIBC_TIME=y CONFIG_COMMON_LIBC_MALLOC=y CONFIG_COMMON_LIBC_CALLOC=y CONFIG_COMMON_LIBC_REALLOCARRAY=y CONFIG_COMMON_LIBC_REMOVE=y CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=0 CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set # CONFIG_NEWLIB_LIBC_CUSTOM_SBRK is not set CONFIG_STDOUT_CONSOLE=y CONFIG_NEED_LIBC_MEM_PARTITION=y # end of C Library # # C++ Language Support # # CONFIG_CPP is not set # end of C++ Language Support # # Additional libraries # # # Hash Function Support # CONFIG_SYS_HASH_FUNC32=y CONFIG_SYS_HASH_FUNC32_DJB2=y CONFIG_SYS_HASH_FUNC32_MURMUR3=y # CONFIG_SYS_HASH_FUNC32_CHOICE_DJB2 is not set CONFIG_SYS_HASH_FUNC32_CHOICE_MURMUR3=y # CONFIG_SYS_HASH_FUNC32_CHOICE_IDENTITY is not set # end of Hash Function Support # # Hashmap (Hash Table) Support # # CONFIG_SYS_HASH_MAP is not set # end of Hashmap (Hash Table) Support # # Heap and Memory Allocation # # CONFIG_SYS_HEAP_VALIDATE is not set # CONFIG_SYS_HEAP_STRESS is not set # CONFIG_SYS_HEAP_INFO is not set CONFIG_SYS_HEAP_ALLOC_LOOPS=5 # CONFIG_SYS_HEAP_RUNTIME_STATS is not set CONFIG_SYS_HEAP_ARRAY_SIZE=0 # CONFIG_SYS_HEAP_LISTENER is not set # CONFIG_SYS_HEAP_SMALL_ONLY is not set # CONFIG_SYS_HEAP_BIG_ONLY is not set CONFIG_SYS_HEAP_AUTO=y # CONFIG_MULTI_HEAP is not set # CONFIG_SHARED_MULTI_HEAP is not set # end of Heap and Memory Allocation # # Memory Blocks # CONFIG_SYS_MEM_BLOCKS=y # CONFIG_SYS_MEM_BLOCKS_LISTENER is not set # CONFIG_SYS_MEM_BLOCKS_RUNTIME_STATS is not set # end of Memory Blocks CONFIG_NET_BUF=y # CONFIG_NET_BUF_LOG is not set # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set # CONFIG_NET_BUF_LOG_LEVEL_INF is not set # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y CONFIG_NET_BUF_LOG_LEVEL=3 # CONFIG_NET_BUF_POOL_USAGE is not set CONFIG_NET_BUF_ALIGNMENT=0 # # OS Support Library # CONFIG_FDTABLE=y CONFIG_ZVFS_OPEN_MAX=16 # CONFIG_PRINTK_SYNC is not set CONFIG_MPSC_PBUF=y # CONFIG_SPSC_PBUF is not set # CONFIG_MPSC_CLEAR_ALLOCATED is not set CONFIG_HAS_POWEROFF=y CONFIG_POWEROFF=y CONFIG_CBPRINTF_COMPLETE=y # CONFIG_CBPRINTF_NANO is not set CONFIG_CBPRINTF_FULL_INTEGRAL=y # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set CONFIG_CBPRINTF_FP_SUPPORT=y # CONFIG_CBPRINTF_FP_A_SUPPORT is not set # CONFIG_CBPRINTF_FP_ALWAYS_A is not set CONFIG_CBPRINTF_N_SPECIFIER=y # CONFIG_CBPRINTF_LIBC_SUBSTS is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3 # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y CONFIG_ZVFS=y CONFIG_ZVFS_EVENTFD=y CONFIG_ZVFS_EVENTFD_MAX=8 CONFIG_ZVFS_POLL=y CONFIG_ZVFS_POLL_MAX=6 CONFIG_ZVFS_SELECT=y # end of OS Support Library # # POSIX API Support # # # POSIX Options # CONFIG_POSIX_SYSTEM_HEADERS=y CONFIG_POSIX_API=y CONFIG_POSIX_AEP_CHOICE_NONE=y # CONFIG_POSIX_AEP_CHOICE_BASE is not set # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set CONFIG_POSIX_BASE_DEFINITIONS=y CONFIG_POSIX_AEP_REALTIME_MINIMAL=y CONFIG_POSIX_ASYNCHRONOUS_IO=y CONFIG_POSIX_BARRIERS=y CONFIG_MAX_PTHREAD_BARRIER_COUNT=5 # CONFIG_PTHREAD_CREATE_BARRIER is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3 CONFIG_POSIX_C_LANG_SUPPORT_R=y # CONFIG_POSIX_C_LIB_EXT is not set # # POSIX device I/O # CONFIG_POSIX_DEVICE_IO=y CONFIG_POSIX_DEVICE_IO_ALIAS_CLOSE=y CONFIG_POSIX_DEVICE_IO_ALIAS_OPEN=y CONFIG_POSIX_DEVICE_IO_ALIAS_READ=y CONFIG_POSIX_DEVICE_IO_ALIAS_WRITE=y CONFIG_POSIX_OPEN_MAX=16 # end of POSIX device I/O CONFIG_POSIX_FD_MGMT=y CONFIG_POSIX_FD_MGMT_ALIAS_LSEEK=y CONFIG_POSIX_FILE_SYSTEM_R=y CONFIG_POSIX_FILE_SYSTEM=y CONFIG_POSIX_FILE_SYSTEM_ALIAS_FSTAT=y # # POSIX memory # CONFIG_POSIX_PAGE_SIZE=0x40 CONFIG_POSIX_SHARED_MEMORY_OBJECTS=y CONFIG_POSIX_MAPPED_FILES=y CONFIG_POSIX_MEMLOCK=y CONFIG_POSIX_MEMLOCK_RANGE=y CONFIG_POSIX_MEMORY_PROTECTION=y # end of POSIX memory # CONFIG_POSIX_MESSAGE_PASSING is not set CONFIG_POSIX_NETWORKING=y CONFIG_POSIX_HOST_NAME_MAX=63 # CONFIG_POSIX_IPV6 is not set # CONFIG_POSIX_RAW_SOCKETS is not set CONFIG_POSIX_SINGLE_PROCESS=y CONFIG_POSIX_SYSCONF_IMPL_MACRO=y # CONFIG_POSIX_SYSCONF_IMPL_FULL is not set CONFIG_POSIX_UNAME_VERSION_LEN=70 CONFIG_POSIX_UNAME_NODENAME_LEN=6 # CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set # CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set # CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set # CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set # CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y CONFIG_POSIX_ENV_LOG_LEVEL=3 CONFIG_POSIX_MULTI_PROCESS=y CONFIG_POSIX_MULTI_PROCESS_ALIAS_GETPID=y CONFIG_POSIX_THREADS=y CONFIG_HEAP_MEM_POOL_ADD_SIZE_POSIX_THREADS=256 CONFIG_POSIX_THREAD_THREADS_MAX=5 CONFIG_MAX_PTHREAD_MUTEX_COUNT=5 CONFIG_MAX_PTHREAD_COND_COUNT=5 CONFIG_POSIX_THREAD_KEYS_MAX=5 CONFIG_PTHREAD_RECYCLER_DELAY_MS=100 CONFIG_POSIX_THREAD_ATTR_STACKADDR=y CONFIG_POSIX_THREAD_ATTR_STACKSIZE=y # CONFIG_POSIX_THREADS_EXT is not set CONFIG_POSIX_THREAD_PRIORITY_SCHEDULING=y CONFIG_POSIX_PTHREAD_ATTR_STACKSIZE_BITS=23 CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_BITS=9 CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_DEFAULT=0 CONFIG_POSIX_THREAD_PRIO_INHERIT=y CONFIG_POSIX_THREAD_PRIO_PROTECT=y CONFIG_POSIX_THREAD_SAFE_FUNCTIONS=y # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_LOG_LEVEL=3 # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3 # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_COND_LOG_LEVEL=3 # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_KEY_LOG_LEVEL=3 CONFIG_POSIX_READER_WRITER_LOCKS=y CONFIG_MAX_PTHREAD_RWLOCK_COUNT=5 # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_RWLOCK_LOG_LEVEL=3 # # POSIX scheduler options # # CONFIG_POSIX_PRIORITY_SCHEDULING is not set # end of POSIX scheduler options CONFIG_POSIX_SEMAPHORES=y CONFIG_POSIX_SEM_VALUE_MAX=32767 CONFIG_POSIX_SEM_NSEMS_MAX=256 CONFIG_POSIX_SEM_NAMELEN_MAX=16 CONFIG_HEAP_MEM_POOL_ADD_SIZE_POSIX_SEMAPHORES=256 # # POSIX signals # CONFIG_POSIX_REALTIME_SIGNALS=y CONFIG_POSIX_RTSIG_MAX=8 CONFIG_POSIX_SIGNALS=y CONFIG_POSIX_SIGNAL_STRING_DESC=y CONFIG_POSIX_SIGNALS_ALIAS_KILL=y # end of POSIX signals CONFIG_POSIX_SPIN_LOCKS=y CONFIG_MAX_PTHREAD_SPINLOCK_COUNT=5 # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3 # # POSIX synchronized I/O # CONFIG_POSIX_FSYNC=y CONFIG_POSIX_SYNCHRONIZED_IO=y # end of POSIX synchronized I/O CONFIG_POSIX_TIMERS=y CONFIG_POSIX_THREAD_CPUTIME=y CONFIG_POSIX_MONOTONIC_CLOCK=y # CONFIG_POSIX_CPUTIME is not set CONFIG_POSIX_CLOCK_SELECTION=y CONFIG_POSIX_DELAYTIMER_MAX=32 CONFIG_POSIX_TIMER_MAX=32 CONFIG_POSIX_TIMEOUTS=y CONFIG_TIMER_CREATE_WAIT=100 # CONFIG_TIMER_LOG_LEVEL_OFF is not set # CONFIG_TIMER_LOG_LEVEL_ERR is not set # CONFIG_TIMER_LOG_LEVEL_WRN is not set # CONFIG_TIMER_LOG_LEVEL_INF is not set # CONFIG_TIMER_LOG_LEVEL_DBG is not set CONFIG_TIMER_LOG_LEVEL_DEFAULT=y CONFIG_TIMER_LOG_LEVEL=3 # # X/Open system interfaces # # CONFIG_XSI_REALTIME is not set CONFIG_XSI_SINGLE_PROCESS=y # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_OFF is not set # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_ERR is not set # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_WRN is not set # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_INF is not set # CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DBG is not set CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL_DEFAULT=y CONFIG_XSI_SINGLE_PROCESS_LOG_LEVEL=3 # CONFIG_XOPEN_STREAMS is not set # CONFIG_XSI_SYSTEM_LOGGING is not set CONFIG_XSI_THREADS_EXT=y # end of X/Open system interfaces # # Miscellaneous POSIX-related options # CONFIG_EVENTFD=y # end of Miscellaneous POSIX-related options CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y # end of POSIX Options # # POSIX Shell Utilities # # end of POSIX Shell Utilities # end of POSIX API Support # CONFIG_OPENAMP_RSC_TABLE is not set # CONFIG_SMF is not set CONFIG_LIBGCC_RTLIB=y # # Utility Library # # CONFIG_JSON_LIBRARY is not set CONFIG_RING_BUFFER=y # CONFIG_RING_BUFFER_LARGE is not set CONFIG_NOTIFY=y # CONFIG_BASE64 is not set CONFIG_ONOFF=y # CONFIG_UTF8 is not set # CONFIG_COBS is not set # end of Utility Library # # Universally Unique Identifier (UUID) # # CONFIG_UUID is not set # end of Universally Unique Identifier (UUID) # CONFIG_MIN_HEAP is not set # end of Additional libraries # # Subsystems and OS Services # # CONFIG_BINDESC is not set CONFIG_BT=y CONFIG_BT_HCI=y # CONFIG_BT_CUSTOM is not set # CONFIG_BT_HCI_RAW is not set # CONFIG_BT_HCI_RAW_H4 is not set # CONFIG_BT_HCI_RAW_CMD_EXT is not set CONFIG_BT_CONN_TX=y # CONFIG_BT_LE_EXTENDED_FEAT_SET is not set # CONFIG_BT_SCA_UPDATE is not set # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set # CONFIG_BT_PATH_LOSS_MONITORING is not set # CONFIG_BT_SUBRATING is not set # CONFIG_BT_CHANNEL_SOUNDING is not set # CONFIG_BT_ISO_PERIPHERAL is not set # CONFIG_BT_ISO_BROADCASTER is not set # # Bluetooth buffer configuration # # end of Bluetooth buffer configuration # # Bluetooth Host # # # L2CAP Options # # end of L2CAP Options # # ATT and GATT Options # # end of ATT and GATT Options # # GATT Services # # end of GATT Services # # Bluetooth Classic Options # # end of Bluetooth Classic Options # end of Bluetooth Host # CONFIG_BT_EAD is not set # # Bluetooth logging # # # Common # # end of Common # # Libraries # # end of Libraries # # Host # # end of Host # # Services # # end of Services # end of Bluetooth logging # # Controller Area Network (CAN) bus subsystem # # end of Controller Area Network (CAN) bus subsystem # CONFIG_CONSOLE_SUBSYS is not set # CONFIG_CPU_LOAD_METRIC is not set # CONFIG_CPU_LOAD_LOG_LEVEL_OFF is not set # CONFIG_CPU_LOAD_LOG_LEVEL_ERR is not set # CONFIG_CPU_LOAD_LOG_LEVEL_WRN is not set # CONFIG_CPU_LOAD_LOG_LEVEL_INF is not set # CONFIG_CPU_LOAD_LOG_LEVEL_DBG is not set CONFIG_CPU_LOAD_LOG_LEVEL_DEFAULT=y CONFIG_CPU_LOAD_LOG_LEVEL=3 CONFIG_CRC=y # CONFIG_CRC_LOG_LEVEL_OFF is not set # CONFIG_CRC_LOG_LEVEL_ERR is not set # CONFIG_CRC_LOG_LEVEL_WRN is not set # CONFIG_CRC_LOG_LEVEL_INF is not set # CONFIG_CRC_LOG_LEVEL_DBG is not set CONFIG_CRC_LOG_LEVEL_DEFAULT=y CONFIG_CRC_LOG_LEVEL=3 # CONFIG_CRC_HW_HANDLER is not set # CONFIG_CRC32_K_4_2_TABLE_256 is not set # CONFIG_DAP is not set # # System Monitoring Options # # CONFIG_THREAD_ANALYZER is not set # end of System Monitoring Options # # Debugging Options # # CONFIG_DEBUG is not set # CONFIG_UBSAN is not set # CONFIG_STACK_USAGE is not set CONFIG_STACK_SENTINEL=y CONFIG_PRINTK=y CONFIG_EARLY_CONSOLE=y CONFIG_ASSERT_LEVEL=2 CONFIG_SPIN_VALIDATE=y # CONFIG_FORCE_NO_ASSERT is not set CONFIG_ASSERT_VERBOSE=y # CONFIG_ASSERT_NO_FILE_INFO is not set # CONFIG_ASSERT_NO_COND_INFO is not set # CONFIG_ASSERT_NO_MSG_INFO is not set # CONFIG_ASSERT_TEST is not set # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set CONFIG_DEBUG_THREAD_INFO=y # CONFIG_DEBUG_COREDUMP is not set # CONFIG_SYMTAB is not set # end of Debugging Options # CONFIG_MIPI_STP_DECODER is not set # CONFIG_CS_TRACE_DEFMT is not set # CONFIG_CPU_LOAD is not set CONFIG_CPU_LOAD_LOG_PERIODICALLY=0 CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x2000 CONFIG_IMG_BLOCK_BUF_SIZE=512 # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y CONFIG_IMG_MANAGER_LOG_LEVEL=3 # CONFIG_DISK_ACCESS is not set # CONFIG_DSP is not set # CONFIG_EMUL is not set # CONFIG_CHARACTER_FRAMEBUFFER is not set # # File Systems # CONFIG_FILE_SYSTEM_LIB_LINK=y CONFIG_FILE_SYSTEM=y CONFIG_FILE_SYSTEM_MAX_TYPES=2 CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1 CONFIG_FILE_SYSTEM_INIT_PRIORITY=99 # CONFIG_FILE_SYSTEM_MKFS is not set CONFIG_APP_LINK_WITH_FS=y # CONFIG_FS_LOG_LEVEL_OFF is not set # CONFIG_FS_LOG_LEVEL_ERR is not set # CONFIG_FS_LOG_LEVEL_WRN is not set # CONFIG_FS_LOG_LEVEL_INF is not set # CONFIG_FS_LOG_LEVEL_DBG is not set CONFIG_FS_LOG_LEVEL_DEFAULT=y CONFIG_FS_LOG_LEVEL=3 # CONFIG_FAT_FILESYSTEM_ELM is not set # CONFIG_FILE_SYSTEM_LITTLEFS is not set # CONFIG_FILE_SYSTEM_EXT2 is not set # CONFIG_EXT2_LOG_LEVEL_OFF is not set # CONFIG_EXT2_LOG_LEVEL_ERR is not set # CONFIG_EXT2_LOG_LEVEL_WRN is not set # CONFIG_EXT2_LOG_LEVEL_INF is not set # CONFIG_EXT2_LOG_LEVEL_DBG is not set CONFIG_EXT2_LOG_LEVEL_DEFAULT=y CONFIG_EXT2_LOG_LEVEL=3 # CONFIG_FUSE_CLIENT is not set CONFIG_FUSE_CLIENT_UID_VALUE=0 CONFIG_FUSE_CLIENT_GID_VALUE=0 CONFIG_FUSE_CLIENT_PID_VALUE=0 # CONFIG_FUSE_CLIENT_LOG_LEVEL_OFF is not set # CONFIG_FUSE_CLIENT_LOG_LEVEL_ERR is not set # CONFIG_FUSE_CLIENT_LOG_LEVEL_WRN is not set # CONFIG_FUSE_CLIENT_LOG_LEVEL_INF is not set # CONFIG_FUSE_CLIENT_LOG_LEVEL_DBG is not set CONFIG_FUSE_CLIENT_LOG_LEVEL_DEFAULT=y CONFIG_FUSE_CLIENT_LOG_LEVEL=3 # CONFIG_FILE_SYSTEM_VIRTIOFS is not set # CONFIG_VIRTIOFS_DEBUG is not set CONFIG_VIRTIOFS_MAX_FILES=1024 CONFIG_VIRTIOFS_MAX_VQUEUE_SIZE=1024 CONFIG_VIRTIOFS_NO_NOTIFICATION_QUEUE_SLOT=y CONFIG_VIRTIOFS_VIRTIOFSD_UNLINK_QUIRK=y CONFIG_VIRTIOFS_CREATE_MODE_VALUE=438 # CONFIG_VIRTIOFS_LOG_LEVEL_OFF is not set # CONFIG_VIRTIOFS_LOG_LEVEL_ERR is not set # CONFIG_VIRTIOFS_LOG_LEVEL_WRN is not set # CONFIG_VIRTIOFS_LOG_LEVEL_INF is not set # CONFIG_VIRTIOFS_LOG_LEVEL_DBG is not set CONFIG_VIRTIOFS_LOG_LEVEL_DEFAULT=y CONFIG_VIRTIOFS_LOG_LEVEL=3 # CONFIG_FCB is not set # CONFIG_NVS_DATA_CRC is not set # CONFIG_NVS_INIT_BAD_MEMORY_REGION is not set # CONFIG_NVS_LOG_LEVEL_OFF is not set # CONFIG_NVS_LOG_LEVEL_ERR is not set # CONFIG_NVS_LOG_LEVEL_WRN is not set # CONFIG_NVS_LOG_LEVEL_INF is not set # CONFIG_NVS_LOG_LEVEL_DBG is not set CONFIG_NVS_LOG_LEVEL_DEFAULT=y CONFIG_NVS_LOG_LEVEL=3 # end of File Systems # CONFIG_GNSS_RTK is not set # # Inter Processor Communication # # CONFIG_RPMSG_SERVICE is not set CONFIG_IPC_SERVICE=y CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46 CONFIG_IPC_SERVICE_BACKEND_RPMSG=y CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024 CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2 CONFIG_IPC_SERVICE_RPMSG=y CONFIG_IPC_SERVICE_STATIC_VRINGS=y CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4 # CONFIG_IPC_SERVICE_ICMSG is not set # CONFIG_IPC_SERVICE_ICMSG_ME is not set # CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set # CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set # CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set # CONFIG_IPC_SERVICE_LOG_LEVEL_INF is not set # CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT=y CONFIG_IPC_SERVICE_LOG_LEVEL=3 # end of Inter Processor Communication # CONFIG_JWT is not set # CONFIG_LLEXT is not set # CONFIG_LLEXT_EDK is not set # # Logging # CONFIG_LOG_CORE_INIT_PRIORITY=0 CONFIG_LOG_MODE_DEFERRED=y # CONFIG_LOG_MODE_IMMEDIATE is not set # CONFIG_LOG_MODE_MINIMAL is not set # CONFIG_LOG_FRONTEND is not set # CONFIG_LOG_FRONTEND_OPT_API is not set # CONFIG_LOG_CUSTOM_HEADER is not set # CONFIG_LOG_MULTIDOMAIN is not set CONFIG_LOG_FLUSH_SLEEP_US=10000 # # Logging levels filtering # # CONFIG_LOG_RUNTIME_FILTERING is not set CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_LOG_OVERRIDE_LEVEL=0 CONFIG_LOG_MAX_LEVEL=4 # end of Logging levels filtering # # Processing # CONFIG_LOG_PRINTK=y CONFIG_LOG_MODE_OVERFLOW=y # CONFIG_LOG_BLOCK_IN_THREAD is not set CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10 CONFIG_LOG_PROCESS_THREAD=y CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0 CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000 # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y # CONFIG_LOG_TIMESTAMP_64BIT is not set # CONFIG_LOG_TIMESTAMP_USE_REALTIME is not set # CONFIG_LOG_SPEED is not set # end of Processing # # Output Formatting # # # Prepend non-hexdump log message with function name # # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y # end of Prepend non-hexdump log message with function name # CONFIG_LOG_MIPI_SYST_ENABLE is not set # CONFIG_LOG_THREAD_ID_PREFIX is not set # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set CONFIG_LOG_BACKEND_SHOW_COLOR=y # CONFIG_LOG_INFO_COLOR_GREEN is not set # CONFIG_LOG_DBG_COLOR_BLUE is not set CONFIG_LOG_TAG_MAX_LEN=0 CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y # CONFIG_LOG_OUTPUT_FORMAT_DATE_TIMESTAMP is not set # CONFIG_LOG_OUTPUT_FORMAT_ISO8601_TIMESTAMP is not set # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set # end of Output Formatting # # Backends # # CONFIG_LOG_BACKEND_BLE is not set # CONFIG_LOG_BACKEND_FS is not set # CONFIG_LOG_BACKEND_MQTT is not set # CONFIG_LOG_BACKEND_NET is not set # CONFIG_LOG_BACKEND_SWO is not set CONFIG_LOG_BACKEND_UART=y CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1 CONFIG_LOG_BACKEND_UART_AUTOSTART=y CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0 # CONFIG_LOG_BACKEND_IPC_SERVICE is not set # end of Backends # # Misc # CONFIG_LOG_USE_VLA=y CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y # CONFIG_LOG_ALWAYS_RUNTIME is not set # CONFIG_LOG_FMT_SECTION is not set # CONFIG_LOG_FMT_STRING_VALIDATE is not set # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set # CONFIG_LOG_MEM_UTILIZATION is not set CONFIG_LOG_FAILURE_REPORT_PERIOD=1000 # end of Misc CONFIG_LOG_RATELIMIT=y CONFIG_LOG_RATELIMIT_INTERVAL_MS=5000 CONFIG_LOG_OUTPUT=y # end of Logging CONFIG_MEM_ATTR=y # CONFIG_MEM_ATTR_HEAP is not set # # Device Management # # # Host command handler subsystem # # CONFIG_EC_HOST_CMD is not set # end of Host command handler subsystem # CONFIG_OSDP is not set # end of Device Management # CONFIG_MODBUS is not set # CONFIG_MODEM_MODULES is not set # # Networking # CONFIG_NETWORKING=y CONFIG_NET_HOSTNAME_ENABLE=y CONFIG_NET_HOSTNAME="zephyr" CONFIG_NET_HOSTNAME_DYNAMIC=y CONFIG_NET_HOSTNAME_MAX_LEN=63 # CONFIG_NET_HOSTNAME_UNIQUE is not set CONFIG_NET_HOSTNAME_LOG_LEVEL=0 # # Link layer options # # CONFIG_NET_L2_DUMMY is not set # CONFIG_NET_L2_VIRTUAL is not set CONFIG_NET_L2_ETHERNET_LOG_LEVEL=0 # CONFIG_NET_L2_ETHERNET_RESERVE_HEADER is not set CONFIG_NET_L2_ETHERNET_MGMT=y # CONFIG_NET_L2_ETHERNET_ACCEPT_MISMATCH_L3_L2_ADDR is not set # CONFIG_NET_VLAN is not set CONFIG_NET_ARP=y CONFIG_NET_ARP_TABLE_SIZE=2 CONFIG_NET_ARP_GRATUITOUS=y # CONFIG_NET_ARP_GRATUITOUS_TRANSMISSION is not set CONFIG_NET_ARP_LOG_LEVEL=0 # CONFIG_NET_DSA is not set # CONFIG_NET_GPTP is not set # CONFIG_NET_LLDP is not set # CONFIG_NET_ETHERNET_BRIDGE is not set CONFIG_NET_ETHERNET_FORWARD_UNRECOGNISED_ETHERTYPE=y # CONFIG_NET_L2_PPP is not set # CONFIG_NET_L2_OPENTHREAD is not set # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set # CONFIG_NET_L2_CANBUS_RAW is not set CONFIG_NET_L2_WIFI_UTILS=y CONFIG_NET_L2_WIFI_MGMT=y CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL=0 # CONFIG_WIFI_MGMT_RAW_SCAN_RESULTS is not set CONFIG_WIFI_MGMT_TWT_CHECK_IP=y # CONFIG_WIFI_MGMT_FORCED_PASSIVE_SCAN is not set CONFIG_WIFI_SHELL_MAX_AP_STA=1 CONFIG_WIFI_NM=y CONFIG_WIFI_NM_MAX_MANAGED_INTERFACES=1 CONFIG_WIFI_NM_LOG_LEVEL=0 CONFIG_WIFI_MGMT_AP_STA_INACTIVITY_TIMEOUT=300 # CONFIG_WIFI_MGMT_AP_STA_SKIP_INACTIVITY_POLL is not set CONFIG_WIFI_ENT_IDENTITY_MAX_USERS=8 CONFIG_WIFI_MGMT_BSS_MAX_IDLE_TIME=300 # CONFIG_NET_L2_WIFI_SHELL is not set # CONFIG_NET_L2_PTP is not set # end of Link layer options # # IP stack # CONFIG_NET_IP=y CONFIG_NET_CONNECTION_SOCKETS=y CONFIG_NET_NATIVE=y CONFIG_NET_NATIVE_IP=y CONFIG_NET_NATIVE_IPV4=y CONFIG_NET_NATIVE_TCP=y CONFIG_NET_NATIVE_UDP=y # CONFIG_NET_OFFLOAD is not set CONFIG_NET_INIT_PRIO=90 CONFIG_NET_IP_DSCP_ECN=y CONFIG_NET_IPV4=y CONFIG_NET_IF_MAX_IPV4_COUNT=1 CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1 CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1 CONFIG_NET_IPV4_DEFAULT_NETMASK=24 CONFIG_NET_IPV4_MTU=576 CONFIG_NET_INITIAL_TTL=64 CONFIG_NET_INITIAL_MCAST_TTL=1 CONFIG_NET_INITIAL_IPV4_MCAST_LOOP=y CONFIG_NET_IF_MCAST_IPV4_SOURCE_COUNT=1 # CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set # CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set # CONFIG_NET_IPV4_IGMP is not set # CONFIG_NET_IPV4_ACD is not set # CONFIG_NET_IPV4_AUTO is not set # CONFIG_NET_IPV4_HDR_OPTIONS is not set # CONFIG_NET_IPV4_FRAGMENT is not set # CONFIG_NET_IPV4_PMTU is not set CONFIG_NET_IPV4_LOG_LEVEL=0 CONFIG_NET_ICMPV4_LOG_LEVEL=0 CONFIG_NET_IPV4_ACD_LOG_LEVEL=0 CONFIG_NET_TC_RX_COUNT=1 # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set # CONFIG_NET_TC_TX_SKIP_FOR_HIGH_PRIO is not set # CONFIG_NET_TC_RX_SKIP_FOR_HIGH_PRIO is not set CONFIG_NET_TC_THREAD_COOPERATIVE=y # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set CONFIG_NET_TC_NUM_PRIORITIES=16 # CONFIG_NET_TC_THREAD_PRIO_CUSTOM is not set CONFIG_NET_TC_MAPPING_STRICT=y CONFIG_NET_TX_DEFAULT_PRIORITY=1 CONFIG_NET_RX_DEFAULT_PRIORITY=0 # CONFIG_NET_ALLOW_ANY_PRIORITY is not set CONFIG_NET_IP_ADDR_CHECK=y CONFIG_NET_MAX_ROUTERS=1 CONFIG_NET_TCP=y CONFIG_NET_TCP_LOG_LEVEL=0 CONFIG_NET_TCP_WORKER_PRIO=2 CONFIG_NET_TCP_TIME_WAIT_DELAY=1500 CONFIG_NET_TCP_INIT_RETRANSMISSION_TIMEOUT=200 CONFIG_NET_TCP_RANDOMIZED_RTO=y CONFIG_NET_TCP_RETRY_COUNT=9 CONFIG_NET_TCP_MAX_SEND_WINDOW_SIZE=0 CONFIG_NET_TCP_MAX_RECV_WINDOW_SIZE=0 CONFIG_NET_TCP_RECV_QUEUE_TIMEOUT=2000 CONFIG_NET_TCP_PKT_ALLOC_TIMEOUT=100 CONFIG_NET_TCP_FAST_RETRANSMIT=y CONFIG_NET_TCP_CONGESTION_AVOIDANCE=y # CONFIG_NET_TCP_KEEPALIVE is not set CONFIG_NET_TCP_ISN_RFC6528=y CONFIG_NET_TCP_REJECT_CONN_WITH_RST=y # CONFIG_NET_TEST_PROTOCOL is not set CONFIG_NET_UDP=y CONFIG_NET_UDP_MISSING_CHECKSUM=y CONFIG_NET_UDP_LOG_LEVEL=0 CONFIG_NET_MAX_CONN=8 CONFIG_NET_CONN_PACKET_CLONE_TIMEOUT=100 CONFIG_NET_MAX_CONTEXTS=6 # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set CONFIG_NET_CONTEXT_SYNC_RECV=y CONFIG_NET_CONTEXT_CHECK=y # CONFIG_NET_CONTEXT_PRIORITY is not set # CONFIG_NET_CONTEXT_TXTIME is not set CONFIG_NET_CONTEXT_RCVTIMEO=y CONFIG_NET_CONTEXT_SNDTIMEO=y # CONFIG_NET_CONTEXT_RCVBUF is not set # CONFIG_NET_CONTEXT_SNDBUF is not set CONFIG_NET_CONTEXT_DSCP_ECN=y CONFIG_NET_CONTEXT_REUSEADDR=y CONFIG_NET_CONTEXT_REUSEPORT=y # CONFIG_NET_CONTEXT_RECV_PKTINFO is not set # CONFIG_NET_CONTEXT_RECV_HOPLIMIT is not set # CONFIG_NET_CONTEXT_TIMESTAMPING is not set # CONFIG_NET_CONTEXT_CLAMP_PORT_RANGE is not set # CONFIG_NET_TEST is not set CONFIG_NET_BUF_RX_COUNT=10 CONFIG_NET_BUF_TX_COUNT=16 # CONFIG_NET_BUF_FIXED_DATA_SIZE is not set CONFIG_NET_BUF_VARIABLE_DATA_SIZE=y CONFIG_NET_PKT_BUF_RX_DATA_POOL_SIZE=4096 CONFIG_NET_PKT_BUF_TX_DATA_POOL_SIZE=4096 CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4 CONFIG_NET_PKT_BUF_TX_DATA_ALLOC_ALIGN_LEN=0 CONFIG_NET_DEFAULT_IF_FIRST=y # CONFIG_NET_DEFAULT_IF_UP is not set # CONFIG_NET_DEFAULT_IF_ETHERNET is not set # CONFIG_NET_DEFAULT_IF_OFFLOADED_NETDEV is not set # CONFIG_NET_DEFAULT_IF_WIFI is not set CONFIG_NET_INTERFACE_NAME=y # CONFIG_NET_PKT_RXTIME_STATS is not set # CONFIG_NET_PKT_TXTIME_STATS is not set # CONFIG_NET_PKT_ALLOC_STATS is not set # CONFIG_NET_PROMISCUOUS_MODE is not set # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set # # Stack usage # # end of Stack usage CONFIG_NET_MGMT=y CONFIG_NET_MGMT_EVENT=y CONFIG_NET_MGMT_EVENT_THREAD=y # CONFIG_NET_MGMT_EVENT_SYSTEM_WORKQUEUE is not set # CONFIG_NET_MGMT_EVENT_DIRECT is not set CONFIG_NET_MGMT_EVENT_QUEUE=y CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000 CONFIG_NET_MGMT_EVENT_INFO=y CONFIG_NET_MGMT_EVENT_LOG_LEVEL=0 # CONFIG_NET_DEBUG_MGMT_EVENT_STACK is not set # CONFIG_NET_MGMT_THREAD_PRIO_CUSTOM is not set # CONFIG_NET_STATISTICS is not set # CONFIG_NET_LOG is not set CONFIG_NET_PKT_LOG_LEVEL=0 # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0 # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set CONFIG_NET_CORE_LOG_LEVEL=0 CONFIG_NET_IF_LOG_LEVEL=0 CONFIG_NET_TC_LOG_LEVEL=0 CONFIG_NET_UTILS_LOG_LEVEL=0 CONFIG_NET_CONTEXT_LOG_LEVEL=0 CONFIG_NET_CONN_LOG_LEVEL=0 CONFIG_NET_ROUTE_LOG_LEVEL=0 # end of IP stack # # Network Packet Filtering # # CONFIG_NET_PKT_FILTER is not set # end of Network Packet Filtering # # Network Protocols # # CONFIG_COAP is not set CONFIG_DNS_RESOLVER=y CONFIG_DNS_RESOLVER_AUTO_INIT=y # CONFIG_MDNS_RESOLVER is not set # CONFIG_LLMNR_RESOLVER is not set CONFIG_DNS_RESOLVER_ADDITIONAL_QUERIES=2 CONFIG_DNS_RESOLVER_AI_MAX_ENTRIES=2 CONFIG_DNS_RESOLVER_MAX_SERVERS=1 CONFIG_DNS_RESOLVER_MAX_ANSWER_SIZE=512 CONFIG_DNS_RESOLVER_MAX_QUERY_LEN=255 CONFIG_DNS_RESOLVER_MAX_NAME_LEN=20 CONFIG_DNS_RESOLVER_MAX_TEXT_LEN=64 # CONFIG_DNS_SERVER_IP_ADDRESSES is not set # CONFIG_DNS_RECONFIGURE_CLEANUP is not set CONFIG_DNS_NUM_CONCUR_QUERIES=1 CONFIG_DNS_RESOLVER_LOG_LEVEL=0 # CONFIG_DNS_RESOLVER_CACHE is not set # CONFIG_MDNS_RESPONDER is not set # CONFIG_LLMNR_RESPONDER is not set # CONFIG_DNS_SD is not set CONFIG_DNS_SOCKET_DISPATCHER=y CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2 CONFIG_DNS_SOCKET_DISPATCHER_LOG_LEVEL=0 # CONFIG_NET_LATMON is not set CONFIG_MQTT_LIB=y CONFIG_MQTT_LOG_LEVEL=0 CONFIG_MQTT_VERSION_3_1_1=y # CONFIG_MQTT_VERSION_5_0 is not set CONFIG_MQTT_KEEPALIVE=1767 CONFIG_MQTT_LIB_TLS=y # CONFIG_MQTT_LIB_TLS_USE_ALPN is not set # CONFIG_MQTT_LIB_WEBSOCKET is not set # CONFIG_MQTT_LIB_CUSTOM_TRANSPORT is not set # CONFIG_MQTT_CLEAN_SESSION is not set CONFIG_MQTT_USER_PROPERTIES_MAX=1 CONFIG_MQTT_SUBSCRIPTION_ID_PROPERTIES_MAX=1 CONFIG_MQTT_TOPIC_ALIAS_MAX=5 CONFIG_MQTT_TOPIC_ALIAS_STRING_MAX=64 # CONFIG_MQTT_SN_LIB is not set # CONFIG_PTP is not set # CONFIG_TFTP_LIB is not set # CONFIG_HTTP_PARSER is not set # CONFIG_HTTP_PARSER_URL is not set # CONFIG_HTTP_CLIENT is not set # CONFIG_HTTP_SERVER is not set CONFIG_NET_HTTP_LOG_LEVEL=0 CONFIG_NET_HTTP_SERVER_LOG_LEVEL=0 # CONFIG_WEBSOCKET_CLIENT is not set # CONFIG_LWM2M is not set # CONFIG_SOCKS is not set CONFIG_SNTP=y # CONFIG_SNTP_UNCERTAINTY is not set CONFIG_SNTP_LOG_LEVEL=0 # end of Network Protocols # # Network Libraries # CONFIG_NET_CONFIG_LOG_LEVEL=0 # CONFIG_NET_CONFIG_SETTINGS is not set # CONFIG_NET_CONFIG_CLOCK_SNTP_INIT is not set CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50 CONFIG_NET_SOCKETS_POLL_MAX=0 CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=30000 CONFIG_NET_SOCKETS_DNS_TIMEOUT=5000 CONFIG_NET_SOCKETS_DNS_BACKOFF_INTERVAL=5000 CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000 CONFIG_NET_SOCKETS_SERVICE=y CONFIG_NET_SOCKETS_SERVICE_THREAD_PRIO=15 CONFIG_NET_SOCKETS_SERVICE_STACK_SIZE=1200 CONFIG_NET_SOCKETS_SOCKOPT_TLS=y CONFIG_NET_SOCKETS_TLS_PRIORITY=45 CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y # CONFIG_NET_SOCKETS_ENABLE_DTLS is not set CONFIG_NET_SOCKETS_TLS_MAX_CONTEXTS=6 CONFIG_NET_SOCKETS_TLS_MAX_CREDENTIALS=4 CONFIG_NET_SOCKETS_TLS_MAX_CIPHERSUITES=4 CONFIG_NET_SOCKETS_TLS_MAX_CLIENT_SESSION_COUNT=1 # CONFIG_NET_SOCKETS_TLS_CERT_VERIFY_CALLBACK is not set # CONFIG_NET_SOCKETS_OFFLOAD is not set CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40 CONFIG_NET_SOCKETS_PACKET=y CONFIG_NET_SOCKETS_PACKET_DGRAM=y # CONFIG_NET_SOCKETS_INET_RAW is not set # CONFIG_NET_SOCKETS_CAN is not set CONFIG_NET_SOCKETPAIR=y CONFIG_NET_SOCKETPAIR_BUFFER_SIZE=64 # CONFIG_NET_SOCKETPAIR_STATIC is not set CONFIG_NET_SOCKETPAIR_HEAP=y CONFIG_HEAP_MEM_POOL_ADD_SIZE_SOCKETPAIR=296 # CONFIG_NET_SOCKETS_NET_MGMT is not set CONFIG_NET_SOCKETS_LOG_LEVEL=0 CONFIG_TLS_CREDENTIALS=y # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_OFF is not set # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_ERR is not set # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_WRN is not set # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_INF is not set # CONFIG_TLS_CREDENTIALS_LOG_LEVEL_DBG is not set CONFIG_TLS_CREDENTIALS_LOG_LEVEL_DEFAULT=y CONFIG_TLS_CREDENTIALS_LOG_LEVEL=3 CONFIG_TLS_CREDENTIALS_BACKEND_VOLATILE=y # CONFIG_NET_SHELL is not set # end of Network Libraries # # Network additional services # # CONFIG_NET_CAPTURE is not set CONFIG_NET_DHCPV4=y CONFIG_NET_DHCPV4_LOG_LEVEL=0 CONFIG_NET_DHCPV4_INITIAL_DELAY_MAX=10 # CONFIG_NET_DHCPV4_OPTION_CALLBACKS is not set # CONFIG_NET_DHCPV4_OPTION_CALLBACKS_VENDOR_SPECIFIC is not set CONFIG_NET_DHCPV4_ACCEPT_UNICAST=y # CONFIG_NET_DHCPV4_VENDOR_CLASS_IDENTIFIER is not set CONFIG_NET_DHCPV4_OPTION_NTP_SERVER=y CONFIG_NET_DHCPV4_OPTION_DNS_ADDRESS=y # CONFIG_NET_DHCPV4_OPTION_PRINT_IGNORED is not set CONFIG_NET_DHCPV4_DNS_SERVER_VIA_INTERFACE=y CONFIG_NET_DHCPV4_INIT_REBOOT=y # CONFIG_NET_DHCPV4_SERVER is not set CONFIG_NET_DHCPV6_DUID_MAX_LEN=22 CONFIG_NET_DHCPV6_OPTION_DNS_ADDRESS=y CONFIG_NET_DHCPV6_DNS_SERVER_VIA_INTERFACE=y # CONFIG_NET_TRICKLE is not set # CONFIG_NET_ZPERF is not set CONFIG_WIFI_CREDENTIALS=y # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_OFF is not set # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_ERR is not set # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_WRN is not set # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_INF is not set # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_DBG is not set CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_DEFAULT=y CONFIG_WIFI_CREDENTIALS_LOG_LEVEL=3 CONFIG_WIFI_CREDENTIALS_BACKEND_SETTINGS=y CONFIG_WIFI_CREDENTIALS_MAX_ENTRIES=1 CONFIG_WIFI_CREDENTIALS_SAE_PASSWORD_LENGTH=128 CONFIG_WIFI_CREDENTIALS_CONNECT_STORED=y CONFIG_WIFI_CREDENTIALS_CONNECT_STORED_CONNECTION_TIMEOUT=30 # CONFIG_WIFI_CREDENTIALS_STATIC is not set # end of Network additional services CONFIG_NET_CONNECTION_MANAGER=y CONFIG_NET_CONNECTION_MANAGER_LOG_LEVEL=0 CONFIG_NET_CONNECTION_MANAGER_MONITOR_PRIORITY=1 CONFIG_NET_CONNECTION_MANAGER_AUTO_IF_DOWN=y CONFIG_NET_CONNECTION_MANAGER_CONNECTIVITY_WIFI_MGMT=y CONFIG_CONNECTIVITY_WIFI_MGMT_APPLICATION=y # end of Networking # # Power Management # # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set # CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set # CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set # CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set # CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set # CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y CONFIG_PM_DEVICE_LOG_LEVEL=3 CONFIG_PM_DEVICE_RUNTIME_ASYNC=y CONFIG_PM_DEVICE_RUNTIME_USE_SYSTEM_WQ=y # CONFIG_PM_DEVICE_RUNTIME_USE_DEDICATED_WQ is not set # end of Power Management # # Platform Management Communications Infrastructure (PMCI) # # CONFIG_MCTP is not set # end of Platform Management Communications Infrastructure (PMCI) # # Portability # # end of Portability # CONFIG_PROFILING is not set # # Random Number Generators # # CONFIG_TEST_RANDOM_GENERATOR is not set CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789 # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set CONFIG_XOSHIRO_RANDOM_GENERATOR=y CONFIG_CSPRNG_AVAILABLE=y CONFIG_CSPRNG_ENABLED=y CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set # end of Random Number Generators CONFIG_RTIO=y CONFIG_RTIO_SUBMIT_SEM=y CONFIG_RTIO_CONSUME_SEM=y CONFIG_RTIO_SYS_MEM_BLOCKS=y CONFIG_RTIO_WORKQ=y CONFIG_RTIO_WORKQ_THREADS_POOL_PRIO=0 CONFIG_RTIO_WORKQ_THREADS_POOL_STACK_SIZE=1024 CONFIG_RTIO_WORKQ_THREADS_POOL=1 CONFIG_RTIO_WORKQ_POOL_ITEMS=4 # CONFIG_RTIO_LOG_LEVEL_OFF is not set # CONFIG_RTIO_LOG_LEVEL_ERR is not set # CONFIG_RTIO_LOG_LEVEL_WRN is not set # CONFIG_RTIO_LOG_LEVEL_INF is not set # CONFIG_RTIO_LOG_LEVEL_DBG is not set CONFIG_RTIO_LOG_LEVEL_DEFAULT=y CONFIG_RTIO_LOG_LEVEL=3 # # SD # # CONFIG_MMC_STACK is not set # CONFIG_SDMMC_STACK is not set # CONFIG_SDIO_STACK is not set # end of SD # CONFIG_SECURE_STORAGE is not set CONFIG_SETTINGS=y # CONFIG_SETTINGS_LOG_LEVEL_OFF is not set # CONFIG_SETTINGS_LOG_LEVEL_ERR is not set # CONFIG_SETTINGS_LOG_LEVEL_WRN is not set # CONFIG_SETTINGS_LOG_LEVEL_INF is not set # CONFIG_SETTINGS_LOG_LEVEL_DBG is not set CONFIG_SETTINGS_LOG_LEVEL_DEFAULT=y CONFIG_SETTINGS_LOG_LEVEL=3 # CONFIG_SETTINGS_RUNTIME is not set CONFIG_SETTINGS_DYNAMIC_HANDLERS=y # CONFIG_SETTINGS_FILE is not set CONFIG_SETTINGS_NVS=y # CONFIG_SETTINGS_NVS_NAME_CACHE is not set # CONFIG_SETTINGS_CUSTOM is not set # CONFIG_SETTINGS_NONE is not set CONFIG_SETTINGS_NVS_SECTOR_SIZE_MULT=1 CONFIG_SETTINGS_NVS_SECTOR_COUNT=4 # CONFIG_SETTINGS_ZMS_NO_LL_DELETE is not set # CONFIG_SETTINGS_ZMS_LOAD_SUBTREE_PATH is not set # CONFIG_SHELL is not set # CONFIG_STATS is not set # # Storage # CONFIG_FLASH_MAP=y # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set # CONFIG_FLASH_MAP_LABELS is not set CONFIG_STREAM_FLASH=y CONFIG_STREAM_FLASH_INSPECT=y CONFIG_STREAM_FLASH_POST_WRITE_CALLBACK=y CONFIG_STREAM_FLASH_ERASE=y # CONFIG_STREAM_FLASH_PROGRESS is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y CONFIG_STREAM_FLASH_LOG_LEVEL=3 # end of Storage # CONFIG_TASK_WDT is not set # # Testing # # CONFIG_ZTEST is not set # CONFIG_ZTEST_MOCKING is not set # CONFIG_ZTRESS is not set # CONFIG_TEST is not set # CONFIG_FORCE_COVERAGE is not set # CONFIG_TEST_USERSPACE is not set # end of Testing # CONFIG_TIMING_FUNCTIONS is not set # CONFIG_TRACING is not set # CONFIG_USB_DEVICE_STACK is not set # CONFIG_USB_DEVICE_STACK_NEXT is not set # CONFIG_USB_HOST_STACK is not set # CONFIG_USBC_STACK is not set # CONFIG_ZBUS is not set # CONFIG_MODULES is not set # end of Subsystems and OS Services CONFIG_TOOLCHAIN_ZEPHYR_0_17=y CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y # # Build and Link Features # # # Linker Options # # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set CONFIG_LINKER_ORPHAN_SECTION_WARN=y # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set CONFIG_FLASH_LOAD_SIZE=0x40000 CONFIG_ROM_END_OFFSET=0x2150 CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y CONFIG_LD_LINKER_TEMPLATE=y # CONFIG_CMAKE_LINKER_GENERATOR is not set # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set CONFIG_LINKER_SORT_BY_ALIGNMENT=y # # Linker Sections # # CONFIG_LINKER_USE_BOOT_SECTION is not set # CONFIG_LINKER_USE_PINNED_SECTION is not set CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y CONFIG_LINKER_LAST_SECTION_ID=y CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015 CONFIG_LINKER_USE_RELAX=y # end of Linker Sections CONFIG_LINKER_ITERABLE_SUBALIGN=4 CONFIG_LINKER_DEVNULL_SUPPORT=y # CONFIG_LINKER_DEVNULL_MEMORY is not set # end of Linker Options # # Compiler Options # CONFIG_REQUIRES_STD_C99=y CONFIG_REQUIRES_STD_C11=y CONFIG_STD_C11=y # CONFIG_STD_C17 is not set # CONFIG_STD_C23 is not set CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y # CONFIG_GNU_C_EXTENSIONS is not set # CONFIG_CODING_GUIDELINE_CHECK is not set # CONFIG_COMPILER_FREESTANDING is not set CONFIG_SIZE_OPTIMIZATIONS=y # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set # CONFIG_SPEED_OPTIMIZATIONS is not set # CONFIG_DEBUG_OPTIMIZATIONS is not set # CONFIG_NO_OPTIMIZATIONS is not set # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set # CONFIG_DEPRECATION_TEST is not set # CONFIG_COMPILER_SAVE_TEMPS is not set CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y CONFIG_COMPILER_COLOR_DIAGNOSTICS=y # CONFIG_FORTIFY_SOURCE_NONE is not set CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set CONFIG_COMPILER_OPT="" # CONFIG_MISRA_SANE is not set CONFIG_TOOLCHAIN_SUPPORTS_VLA_IN_STATEMENTS=y # end of Compiler Options # CONFIG_ASSERT_ON_ERRORS is not set # CONFIG_NO_RUNTIME_CHECKS is not set CONFIG_RUNTIME_ERROR_CHECKS=y # # Build Options # CONFIG_KERNEL_BIN_NAME="zephyr" CONFIG_OUTPUT_STAT=y # CONFIG_OUTPUT_SYMBOLS is not set CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set CONFIG_BUILD_GAP_FILL_PATTERN=0xFF # CONFIG_BUILD_NO_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_EXE is not set # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set # CONFIG_BUILD_OUTPUT_UF2 is not set # CONFIG_BUILD_OUTPUT_MOT is not set # CONFIG_BUILD_OUTPUT_STRIPPED is not set # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set # CONFIG_BUILD_ALIGN_LMA is not set # CONFIG_APPLICATION_DEFINED_SYSCALL is not set # CONFIG_MAKEFILE_EXPORTS is not set # CONFIG_BUILD_OUTPUT_META is not set CONFIG_BUILD_OUTPUT_STRIP_PATHS=y CONFIG_CHECK_INIT_PRIORITIES=y # CONFIG_EMIT_ALL_SYSCALLS is not set # end of Build Options CONFIG_DEPRECATED=y CONFIG_WARN_DEPRECATED=y CONFIG_EXPERIMENTAL=y CONFIG_ENFORCE_ZEPHYR_STDINT=y # end of Build and Link Features # # Boot Options # # CONFIG_IS_BOOTLOADER is not set # CONFIG_BOOTLOADER_BOSSA is not set # end of Boot Options # # Compatibility # CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y # end of Compatibility # end of Zephyr Kernel # CONFIG_MILO_FW_LOG_LEVEL_OFF is not set # CONFIG_MILO_FW_LOG_LEVEL_ERR is not set # CONFIG_MILO_FW_LOG_LEVEL_WRN is not set # CONFIG_MILO_FW_LOG_LEVEL_INF is not set # CONFIG_MILO_FW_LOG_LEVEL_DBG is not set CONFIG_MILO_FW_LOG_LEVEL_DEFAULT=y CONFIG_MILO_FW_LOG_LEVEL=3 # CONFIG_QUEVA_MEMFAULT_LOG_LEVEL_OFF is not set # CONFIG_QUEVA_MEMFAULT_LOG_LEVEL_ERR is not set # CONFIG_QUEVA_MEMFAULT_LOG_LEVEL_WRN is not set # CONFIG_QUEVA_MEMFAULT_LOG_LEVEL_INF is not set # CONFIG_QUEVA_MEMFAULT_LOG_LEVEL_DBG is not set CONFIG_QUEVA_MEMFAULT_LOG_LEVEL_DEFAULT=y CONFIG_QUEVA_MEMFAULT_LOG_LEVEL=3 # CONFIG_QUEVA_AZURE_LOG_LEVEL_OFF is not set # CONFIG_QUEVA_AZURE_LOG_LEVEL_ERR is not set # CONFIG_QUEVA_AZURE_LOG_LEVEL_WRN is not set # CONFIG_QUEVA_AZURE_LOG_LEVEL_INF is not set # CONFIG_QUEVA_AZURE_LOG_LEVEL_DBG is not set CONFIG_QUEVA_AZURE_LOG_LEVEL_DEFAULT=y CONFIG_QUEVA_AZURE_LOG_LEVEL=3 # CONFIG_BT_SERVICES_LOG_LEVEL_OFF is not set # CONFIG_BT_SERVICES_LOG_LEVEL_ERR is not set # CONFIG_BT_SERVICES_LOG_LEVEL_WRN is not set # CONFIG_BT_SERVICES_LOG_LEVEL_INF is not set # CONFIG_BT_SERVICES_LOG_LEVEL_DBG is not set CONFIG_BT_SERVICES_LOG_LEVEL_DEFAULT=y CONFIG_BT_SERVICES_LOG_LEVEL=3 # CONFIG_IO_SENSORS_LOG_LEVEL_OFF is not set # CONFIG_IO_SENSORS_LOG_LEVEL_ERR is not set # CONFIG_IO_SENSORS_LOG_LEVEL_WRN is not set # CONFIG_IO_SENSORS_LOG_LEVEL_INF is not set # CONFIG_IO_SENSORS_LOG_LEVEL_DBG is not set CONFIG_IO_SENSORS_LOG_LEVEL_DEFAULT=y CONFIG_IO_SENSORS_LOG_LEVEL=3 # CONFIG_INTER_IC_UART_LOG_LEVEL_OFF is not set # CONFIG_INTER_IC_UART_LOG_LEVEL_ERR is not set # CONFIG_INTER_IC_UART_LOG_LEVEL_WRN is not set # CONFIG_INTER_IC_UART_LOG_LEVEL_INF is not set # CONFIG_INTER_IC_UART_LOG_LEVEL_DBG is not set CONFIG_INTER_IC_UART_LOG_LEVEL_DEFAULT=y CONFIG_INTER_IC_UART_LOG_LEVEL=3
.config file net core:
# CONFIG_IPC_RADIO_802154 is not set
CONFIG_IPC_RADIO_BT=y
CONFIG_IPC_RADIO_BT_HCI_IPC=y
CONFIG_QUEUE_THREAD_STACK_SIZE=512
CONFIG_QUEUE_THREAD_PRIO=7
# CONFIG_SETTINGS is not set
CONFIG_BT_MAX_CONN=1
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_REGULATOR is not set
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
CONFIG_BT_LONG_WQ_STACK_SIZE=1024
CONFIG_MAIN_STACK_SIZE=512
CONFIG_BT_RX_STACK_SIZE=768
# CONFIG_SERIAL is not set
# CONFIG_SPI is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_MEMC is not set
# CONFIG_MODEM is not set
CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
CONFIG_BT_HCI_VS=y
CONFIG_SRAM_SIZE=64
CONFIG_BOARD_MILO_53=y
CONFIG_NUM_IRQS=30
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_FLASH_SIZE=256
CONFIG_FLASH_BASE_ADDRESS=0x1000000
CONFIG_MP_MAX_NUM_CPUS=1
CONFIG_SOC_RESET_HOOK=y
CONFIG_CLOCK_CONTROL=y
CONFIG_IDLE_STACK_SIZE=256
CONFIG_ISR_STACK_SIZE=2048
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ROM_START_OFFSET=0
CONFIG_KERNEL_ENTRY="__start"
CONFIG_BUILD_OUTPUT_BIN=y
CONFIG_XIP=y
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_COUNTER is not set
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_SHARED_INTERRUPTS is not set
# CONFIG_PM_DEVICE is not set
CONFIG_TICKLESS_KERNEL=y
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
# CONFIG_USE_DT_CODE_PARTITION is not set
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
CONFIG_ZERO_LATENCY_IRQS=y
CONFIG_ZERO_LATENCY_LEVELS=1
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_GEN_IRQ_VECTOR_TABLE=y
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_ISR_TABLES=y
# CONFIG_INIT_STACKS is not set
CONFIG_TIMESLICE_SIZE=20
CONFIG_FLASH_LOAD_OFFSET=0
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
# CONFIG_BUILD_OUTPUT_S19 is not set
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
# CONFIG_FLASH is not set
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
# CONFIG_HCI_NXP_SET_CAL_DATA is not set
CONFIG_BT_BUF_EVT_RX_COUNT=10
CONFIG_BT_BUF_ACL_TX_COUNT=7
# CONFIG_POWER_DOMAIN is not set
# CONFIG_MFD is not set
# CONFIG_HCI_NXP_RX_THREAD is not set
# CONFIG_GPIO is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
# CONFIG_CACHE is not set
# CONFIG_LOG is not set
CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_ROMSTART_RELOCATION_ROM is not set
CONFIG_DCACHE_LINE_SIZE=32
# CONFIG_RESET is not set
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
# CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET is not set
CONFIG_LOG_DOMAIN_NAME="net"
# CONFIG_ASSERT is not set
# CONFIG_DEVICE_DEPS is not set
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
# CONFIG_SYSCON is not set
# CONFIG_CONSOLE is not set
# CONFIG_WINSTREAM is not set
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_GEN_SW_ISR_TABLE=y
# CONFIG_REBOOT is not set
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_SRAM_OFFSET=0
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_BOOTLOADER_MCUBOOT is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_KERNEL_MEM_POOL=y
CONFIG_MULTITHREADING=y
# CONFIG_OUTPUT_DISASSEMBLY is not set
# CONFIG_WATCHDOG is not set
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_BT_BUF_CMD_TX_SIZE=65
CONFIG_BT_BUF_EVT_RX_SIZE=68
CONFIG_BT_BUF_ACL_TX_SIZE=151
CONFIG_BT_BUF_ACL_RX_SIZE=151
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF7002_COEX_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
# end of Devicetree Info
# Modules
# CONFIG_BUILD_ONLY_NO_BLOBS is not set
# Available modules.
# nrf (C:/ncs/v3.2.4/nrf)
# CONFIG_NRF_802154_RADIO_DRIVER is not set
CONFIG_MPSL_WORK_STACK_SIZE=1024
# CONFIG_MBEDTLS is not set
# Nordic nRF Connect
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=2048
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
CONFIG_BT_CTLR_DATA_LENGTH_MAX=151
# Subsystems
# Bootloader
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7800
# CONFIG_IS_SECURE_BOOTLOADER is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
CONFIG_SB_VALIDATE_FW_HASH=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
# CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
# CONFIG_NCS_MCUBOOT_BOOTLOADER_SIGN_MERGED_BINARY is not set
# CONFIG_NCS_MCUBOOT_MANIFEST_UPDATES is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_BT_COMPANY_ID_NORDIC=0x0059
CONFIG_BT_COMPANY_ID=0x0059
CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
CONFIG_BT_LL_SOFTDEVICE=y
CONFIG_BT_CTLR_DF_SUPPORT=y
# SoftDevice Controller
CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
CONFIG_BT_HCI_TX_STACK_SIZE=1536
# CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
# CONFIG_BT_CTLR_SDC_ALLOW_PARALLEL_SCANNING_AND_INITIATING is not set
CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
# CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
CONFIG_BT_CTLR_SDC_CONN_EVENT_EXTEND_DEFAULT=y
CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=7500
# CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
CONFIG_BT_CTLR_SDC_RX_PRIO=6
# CONFIG_BT_CTLR_DF is not set
CONFIG_BT_LL_SOFTDEVICE_MULTIROLE=y
CONFIG_BT_CTLR_FAL_SIZE=8
# CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
# CONFIG_BT_CTLR_SDC_CONN_ANCHOR_POINT_REPORT is not set
# CONFIG_BT_CTLR_FRAME_SPACE_UPDATE is not set
# CONFIG_BT_CTLR_CHANNEL_SOUNDING is not set
# CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING is not set
# CONFIG_BT_CTLR_SDC_LE_POWER_CLASS_1 is not set
CONFIG_BT_LL_SOFTDEVICE_INIT_PRIORITY=40
# end of SoftDevice Controller
# CONFIG_BT_RADIO_NOTIFICATION_CONN_CB is not set
# BLE Libraries
# CONFIG_BT_GATT_POOL is not set
# CONFIG_BT_GATT_DM is not set
# CONFIG_BT_ADV_PROV is not set
# CONFIG_BT_SCAN is not set
# CONFIG_BT_CONN_CTX is not set
# Bluetooth Services
# CONFIG_BT_AMS_CLIENT is not set
# CONFIG_BT_ANCS_CLIENT is not set
# CONFIG_BT_BAS_CLIENT is not set
# CONFIG_BT_BMS is not set
# CONFIG_BT_CTS_CLIENT is not set
# CONFIG_BT_DFU_SMP is not set
# CONFIG_BT_GATTP is not set
# CONFIG_BT_HIDS is not set
# CONFIG_BT_HOGP is not set
# CONFIG_BT_LBS is not set
# CONFIG_BT_NSMS is not set
# CONFIG_BT_NUS is not set
# CONFIG_BT_NUS_CLIENT is not set
# CONFIG_BT_RSCS is not set
# CONFIG_BT_THROUGHPUT is not set
# CONFIG_BT_LATENCY is not set
# CONFIG_BT_LATENCY_CLIENT is not set
# CONFIG_BT_HRS_CLIENT is not set
# CONFIG_BT_DDFS is not set
# CONFIG_BT_MDS is not set
# CONFIG_BT_CGMS is not set
# CONFIG_BT_FAST_PAIR is not set
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# end of Bluetooth Services
# BLE over nRF RPC
CONFIG_HEAP_MEM_POOL_SIZE=8192
# CONFIG_BT_SHELL is not set
CONFIG_BT_CONN_DYNAMIC_CALLBACKS=y
# CONFIG_BT_RPC_STACK is not set
CONFIG_BT_CENTRAL=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_CONN=y
CONFIG_BT_REMOTE_VERSION=y
CONFIG_BT_PHY_UPDATE=y
CONFIG_BT_DATA_LEN_UPDATE=y
# CONFIG_BT_EXT_ADV is not set
CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=1
CONFIG_BT_HAS_HCI_VS=y
# CONFIG_BT_HCI_MESH_EXT is not set
# CONFIG_BT_WAIT_NOP is not set
CONFIG_BT_RPA=y
CONFIG_BT_ASSERT=y
CONFIG_BT_ASSERT_VERBOSE=y
# CONFIG_BT_ASSERT_PANIC is not set
# CONFIG_BT_HCI_ERR_TO_STR is not set
CONFIG_BT_DEBUG_NONE=y
# CONFIG_BT_DEBUG_MONITOR_UART is not set
# CONFIG_BT_LONG_WQ is not set
# CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
CONFIG_BT_HCI_TX_PRIO=7
# CONFIG_BT_RECV_WORKQ_SYS is not set
CONFIG_BT_RECV_WORKQ_BT=y
CONFIG_BT_RX_PRIO=8
CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
# CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
# CONFIG_BT_HOST_CCM is not set
# CONFIG_BT_LOG_SNIFFER_INFO is not set
# CONFIG_BT_TESTING is not set
# CONFIG_BT_HCI_VS_EVT_USER is not set
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# CONFIG_NRF_CLOUD is not set
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOADER is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# CONFIG_OPENTHREAD_RPC is not set
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# CONFIG_NFC_RPC is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_NRF_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
CONFIG_PPI_TRACE_PIN_CNT=8
# end of Debug
# CONFIG_SHELL_BT_NUS is not set
# CONFIG_SHELL_IPC is not set
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
CONFIG_MPSL_FEM_API_AVAILABLE=y
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
CONFIG_MPSL_CX_ANY_SUPPORT=y
CONFIG_MPSL_CX_NRF70_SUPPORT=y
# CONFIG_MPSL_CX is not set
CONFIG_MPSL_THREAD_COOP_PRIO=6
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START is not set
CONFIG_MPSL_LOW_PRIO_IRQN=26
CONFIG_MPSL_HFCLK_LATENCY=1400
CONFIG_MPSL_INIT_PRIORITY=40
# CONFIG_MPSL_USE_EXTERNAL_CLOCK_CONTROL is not set
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_BASE_ADDRESS=0x21000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x21000000
CONFIG_PM_SRAM_SIZE=0x10000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# Additional MCUmgr configuration
# Additional MCUmgr group configuration
# Additional MCUmgr OS group management functionality
# end of Additional MCUmgr OS group management functionality
# Additional MCUmgr image management group functionality
# end of Additional MCUmgr image management group functionality
# end of Additional MCUmgr group configuration
# end of Additional MCUmgr configuration
# CONFIG_CAF is not set
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# Nordic-added meta types
# Nordic added alg types
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# CONFIG_PSA_WANT_ALG_HSS is not set
# CONFIG_PSA_WANT_ALG_LMS is not set
# CONFIG_PSA_WANT_ALG_ML_DSA is not set
# CONFIG_PSA_WANT_ALG_XMSS is not set
# CONFIG_PSA_WANT_ALG_XMSS_MT is not set
# CONFIG_PSA_WANT_ALG_ML_KEM is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_SHA_256_192 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CHACHA20 is not set
# CONFIG_PSA_WANT_ALG_XCHACHA20_POLY1305 is not set
# CONFIG_PSA_WANT_ALG_SHAKE128_256 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_192 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_256 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# CONFIG_PSA_WANT_ALG_AES_KW is not set
# CONFIG_PSA_WANT_ALG_AES_KWP is not set
# CONFIG_PSA_WANT_ALG_WPA3_SAE_H2E is not set
# CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
# Nordic added ECC curve types
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# Nordic addded RNG configuration
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# Nordic added key types
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
# CONFIG_PSA_WANT_KEY_TYPE_XCHACHA20 is not set
# CONFIG_PSA_WANT_KEY_TYPE_HSS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_LMS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_XMSS_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_XMSS_MT_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_44 is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_65 is not set
# CONFIG_PSA_WANT_ML_DSA_KEY_SIZE_87 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_DSA_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_512 is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_768 is not set
# CONFIG_PSA_WANT_ML_KEM_KEY_SIZE_1024 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ML_KEM_PUBLIC_KEY is not set
# end of nRF Security
# CONFIG_NET_CORE_MONITOR is not set
# Audio Modules
# CONFIG_AUDIO_MODULE_TEST is not set
# Log levels
# end of Log levels
# end of Audio Modules
# Audio Modules
# CONFIG_AUDIO_MODULE_TEMPLATE is not set
# CONFIG_TRUSTED_STORAGE is not set
# Logging over RPC
CONFIG_LOG_BACKED_RPC_CRASH_INFO_FILENAME_SIZE=1
# end of Logging over RPC
# CONFIG_DULT is not set
# CONFIG_NRF_COMPRESS is not set
# MCUboot IDs (informative only, do not change)
CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_EXTRA_1_IMAGE_NUMBER=-1
CONFIG_MCUBOOT_EXTRA_2_IMAGE_NUMBER=-1
# end of MCUboot IDs (informative only, do not change)
# end of Subsystems
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# CONFIG_APP_JWT is not set
# Binary libraries
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x800
CONFIG_FPROTECT_BLOCK_SIZE=0x800
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_PARSER is not set
CONFIG_MULTITHREADING_LOCK=y
# CONFIG_RESET_ON_FATAL_ERROR is not set
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x800
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_FLASH_RPC is not set
CONFIG_CLOCK_CONTROL_MPSL=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
# CONFIG_IPC_UART is not set
# end of Device Drivers
# External libraries
# end of External libraries
# Test
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# CONFIG_MOCK_NRF_RPC is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v3.2.4/nrf)
# hostap (C:/ncs/v3.2.4/modules/lib/hostap)
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_ZEPHYR_HOSTAP_MODULE=y
# end of hostap (C:/ncs/v3.2.4/modules/lib/hostap)
# mcuboot (C:/ncs/v3.2.4/bootloader/mcuboot)
# MCUboot
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
# end of MCUboot
# Custom TLVs
CONFIG_NCS_MCUBOOT_PERIPHCONF_TLV_ID=0xA1
# end of Custom TLVs
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v3.2.4/bootloader/mcuboot)
# mbedtls (C:/ncs/v3.2.4/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# CONFIG_PSA_CRYPTO is not set
# end of mbedtls (C:/ncs/v3.2.4/modules/crypto/mbedtls)
# oberon-psa-crypto (C:/ncs/v3.2.4/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (C:/ncs/v3.2.4/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (C:/ncs/v3.2.4/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (C:/ncs/v3.2.4/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
# cjson (C:/ncs/v3.2.4/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v3.2.4/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v3.2.4/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v3.2.4/modules/lib/azure-sdk-for-c)
# cirrus-logic (C:/ncs/v3.2.4/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v3.2.4/modules/hal/cirrus-logic)
# openthread (C:/ncs/v3.2.4/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v3.2.4/modules/lib/openthread)
# memfault-firmware-sdk (C:/ncs/v3.2.4/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v3.2.4/modules/lib/memfault-firmware-sdk)
# coremark (C:/ncs/v3.2.4/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (C:/ncs/v3.2.4/modules/benchmark/coremark)
# canopennode (C:/ncs/v3.2.4/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v3.2.4/modules/lib/canopennode)
# chre (C:/ncs/v3.2.4/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v3.2.4/modules/lib/chre)
# lz4 (C:/ncs/v3.2.4/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v3.2.4/modules/lib/lz4)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (C:/ncs/v3.2.4/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v3.2.4/modules/lib/zscilib)
# cmsis (C:/ncs/v3.2.4/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
# end of cmsis (C:/ncs/v3.2.4/modules/hal/cmsis)
# cmsis-dsp (C:/ncs/v3.2.4/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (C:/ncs/v3.2.4/modules/lib/cmsis-dsp)
# cmsis-nn (C:/ncs/v3.2.4/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (C:/ncs/v3.2.4/modules/lib/cmsis-nn)
# cmsis_6 (C:/ncs/v3.2.4/modules/hal/cmsis_6)
CONFIG_ZEPHYR_CMSIS_6_MODULE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis_6 (C:/ncs/v3.2.4/modules/hal/cmsis_6)
# fatfs (C:/ncs/v3.2.4/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v3.2.4/modules/fs/fatfs)
# hal_nordic (C:/ncs/v3.2.4/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
# CONFIG_NRFX_CLOCK is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_GPIOTE0 is not set
CONFIG_NRFX_GPPI=y
# CONFIG_NRFX_GPPI_V1 is not set
# CONFIG_NRFX_I2S is not set
CONFIG_NRFX_IPC=y
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
# CONFIG_NRFX_PWM is not set
# CONFIG_NRFX_QDEC is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SPIM is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER is not set
# CONFIG_NRFX_TWIM is not set
# CONFIG_NRFX_TWIS is not set
# CONFIG_NRFX_UARTE is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_reserved_resources_ncs.h"
# end of nrfx drivers
# end of hal_nordic (C:/ncs/v3.2.4/modules/hal/nordic)
# hal_st (C:/ncs/v3.2.4/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (C:/ncs/v3.2.4/modules/hal/st)
# hal_tdk (C:/ncs/v3.2.4/modules/hal/tdk)
CONFIG_ZEPHYR_HAL_TDK_MODULE=y
# TDK drivers
# CONFIG_TDK_HAL is not set
# end of TDK drivers
# end of hal_tdk (C:/ncs/v3.2.4/modules/hal/tdk)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
# liblc3 (C:/ncs/v3.2.4/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v3.2.4/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# littlefs (C:/ncs/v3.2.4/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v3.2.4/modules/fs/littlefs)
# loramac-node (C:/ncs/v3.2.4/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v3.2.4/modules/lib/loramac-node)
# lvgl (C:/ncs/v3.2.4/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v3.2.4/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
# nanopb (C:/ncs/v3.2.4/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v3.2.4/modules/lib/nanopb)
# nrf_wifi (C:/ncs/v3.2.4/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
# CONFIG_NRF70_BUSLIB is not set
# end of nrf_wifi (C:/ncs/v3.2.4/modules/lib/nrf_wifi)
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# percepio (C:/ncs/v3.2.4/modules/debug/percepio)
# Percepio Tracealyzer support can be enabled from the tracing subsystem
# CONFIG_PERCEPIO_DFM is not set
CONFIG_ZEPHYR_PERCEPIO_MODULE=y
# end of percepio (C:/ncs/v3.2.4/modules/debug/percepio)
# picolibc (C:/ncs/v3.2.4/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v3.2.4/modules/lib/picolibc)
# segger (C:/ncs/v3.2.4/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
# end of segger (C:/ncs/v3.2.4/modules/debug/segger)
# uoscore-uedhoc (C:/ncs/v3.2.4/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v3.2.4/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v3.2.4/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (C:/ncs/v3.2.4/modules/lib/zcbor)
# nrfxlib (C:/ncs/v3.2.4/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# end of nrf_modem (Modem library)
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
CONFIG_MPSL=y
CONFIG_MPSL_BUILD_TYPE_LIB=y
CONFIG_MPSL_LIB_DIR="nrf53"
CONFIG_MPSL_LIB_FLOAT_ABI_DIR="soft-float"
# Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v3.2.4/nrfxlib)
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
# connectedhomeip (C:/ncs/v3.2.4/modules/lib/matter)
# CONFIG_CHIP is not set
# CONFIG_CHIP_CUSTOM_BLE_ADV_DATA is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v3.2.4/modules/lib/matter)
CONFIG_LIBMETAL=y
CONFIG_LIBMETAL_SRC_PATH="libmetal"
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
CONFIG_OPENAMP=y
CONFIG_OPENAMP_SRC_PATH="open-amp"
CONFIG_OPENAMP_MASTER=y
CONFIG_OPENAMP_SLAVE=y
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# hal_bouffalolab module not available.
# hal_gigadevice module not available.
# hal_nxp module not available.
# libsbc module not available.
# Trusted-firmware-a module not available.
# LoRa Basics Modem module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD="milo_53"
CONFIG_BOARD_REVISION="1.5.0"
CONFIG_BOARD_TARGET="[email protected]/nrf5340/cpunet"
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_MILO_53_NRF5340_CPUNET=y
CONFIG_BOARD_QUALIFIERS="nrf5340/cpunet"
# Board Options
CONFIG_BOARD_REVISION_1_5_0=y
# end of Board Options
# Hardware Configuration
CONFIG_SOC="nrf5340"
CONFIG_SOC_SERIES="nrf53"
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_SERIES_NRF53X=y
CONFIG_SOC_NRF5340_CPUNET=y
CONFIG_SOC_NRF5340_CPUNET_QKAA=y
# CONFIG_HWINFO is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF53X=y
CONFIG_SOC_COMPATIBLE_NRF5340_CPUNET=y
CONFIG_SOC_NORDIC_BSP_NAME="stable"
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CCM_HEADERMASK=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIOTE0=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_DFE=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_NORDIC_RAM_CTRL=y
# CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
# CONFIG_NRF_SYS_EVENT is not set
# CONFIG_IS_IRONSIDE_SE_SECONDARY_IMAGE is not set
# CONFIG_IS_GEN_UICR_IMAGE is not set
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
CONFIG_SOC_NRF53_RTC_PRETICK=y
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
CONFIG_NRF_ENABLE_CACHE=y
# CONFIG_NRF53_SYNC_RTC is not set
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
# CONFIG_SOC_NRF54H20_PM_S2RAM_OVERRIDE is not set
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
# end of Hardware Configuration
CONFIG_ARCH="arm"
# CONFIG_EXTRA_EXCEPTION_INFO is not set
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_CPU_CORTEX=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# ARM Options
CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
CONFIG_ARM_ON_ENTER_CPU_IDLE_PREPARE_HOOK=y
CONFIG_ARM_ON_EXIT_CPU_IDLE=y
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
# CONFIG_PLATFORM_SPECIFIC_INIT is not set
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_HAS_SWO=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_ARCH_SUPPORTS_ROM_OFFSET=y
CONFIG_ARM_MPU=y
CONFIG_LITTLE_ENDIAN=y
# CONFIG_USERSPACE is not set
# CONFIG_NOINIT_SNIPPET_FIRST is not set
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# CONFIG_FRAME_POINTER is not set
# Interrupt Configuration
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
CONFIG_ARCH_DEVICE_STATE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
# CONFIG_SRAM_SW_ISR_TABLE is not set
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_VECTOR_TABLE_RELOCATION=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
CONFIG_ARCH_SUPPORTS_COREDUMP_STACK_PTR=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# DSP Options
# end of DSP Options
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
# General Kernel Options
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
# CONFIG_SCHED_DUMB is not set
CONFIG_SCHED_SIMPLE=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_DUMB is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_SIMPLE=y
# Misc Kernel related options
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_CURRENT_THREAD_USE_TLS=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
# CONFIG_BOOT_CLEAR_SCREEN is not set
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# CONFIG_WORKQUEUE_WORK_TIMEOUT is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
CONFIG_SYSTEM_WORKQUEUE_WORK_TIMEOUT_MS=0
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_POLL=y
# CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_SWAP_NONATOMIC=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
# Security Options
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
# CONFIG_STATIC_INIT_GNU is not set
# CONFIG_BOOTARGS is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_MUTABLE is not set
# CONFIG_DEVICE_DT_METADATA is not set
CONFIG_DEVICE_DEINIT_SUPPORT=y
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# MMU Features
# end of MMU Features
# end of Virtual Memory Support
# SoC and Board Hooks
# CONFIG_SOC_EARLY_RESET_HOOK is not set
# CONFIG_SOC_PREP_HOOK is not set
CONFIG_SOC_EARLY_INIT_HOOK=y
CONFIG_SOC_LATE_INIT_HOOK=y
# CONFIG_SOC_PER_CORE_INIT_HOOK is not set
# CONFIG_BOARD_EARLY_INIT_HOOK is not set
# CONFIG_BOARD_LATE_INIT_HOOK is not set
# end of SoC and Board Hooks
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
CONFIG_BT_DRIVERS=y
# Bluetooth HCI Driver Options
CONFIG_BT_HCI_INIT_PRIORITY=50
# CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
CONFIG_BT_DRV_TX_STACK_SIZE=256
CONFIG_BT_DRV_RX_STACK_SIZE=512
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
CONFIG_CLOCK_CONTROL_NRF=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_FREQUENCY=32768
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
# CONFIG_COMPARATOR is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_CRC_DRIVER is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_DP_DRIVER is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
CONFIG_ENTROPY_GENERATOR=y
CONFIG_ENTROPY_INIT_PRIORITY=50
# CONFIG_FAKE_ENTROPY_NATIVE_POSIX is not set
CONFIG_ENTROPY_NRF5_RNG=y
# CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_ESPI is not set
# Firmware drivers
# CONFIG_ARM_SCMI is not set
# end of Firmware drivers
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_HAPTICS is not set
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
CONFIG_MBOX=y
CONFIG_MBOX_NRFX_IPC=y
CONFIG_MBOX_TI_SECURE_PROXY_PRIORITY=30
CONFIG_MBOX_INIT_PRIORITY=40
# CONFIG_MDIO is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# Interconn Drivers
# end of Interconn Drivers
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_MSPI is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
# CONFIG_PINCTRL is not set
# CONFIG_PM_CPU_OPS is not set
# CONFIG_PS2 is not set
# CONFIG_PSI5 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# CONFIG_SENT is not set
# CONFIG_SMBUS is not set
# CONFIG_STEPPER is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
CONFIG_NRF_RTC_TIMER=y
CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
CONFIG_NRF_RTC_COUNTER_BIT_WIDTH=24
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# USB common
# end of USB common
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTIO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_TEE is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
# CONFIG_LIBC_ALLOW_LESS_THAN_64BIT_TIME is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
# CONFIG_COMMON_LIBC_ASCTIME_R is not set
# CONFIG_COMMON_LIBC_CTIME_R is not set
CONFIG_COMMON_LIBC_TIME=y
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_COMMON_LIBC_REMOVE is not set
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# end of C++ Language Support
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
CONFIG_SYS_HEAP_ARRAY_SIZE=0
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NET_BUF_ALIGNMENT=0
# OS Support Library
# CONFIG_FDTABLE is not set
CONFIG_ZVFS_OPEN_MAX=4
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
# CONFIG_SPSC_PBUF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# CONFIG_ZVFS is not set
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
CONFIG_POSIX_AEP_CHOICE_NONE=y
# CONFIG_POSIX_AEP_CHOICE_BASE is not set
# CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
# CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_BARRIERS is not set
# CONFIG_POSIX_C_LANG_SUPPORT_R is not set
# CONFIG_POSIX_C_LIB_EXT is not set
# POSIX device I/O
# CONFIG_POSIX_DEVICE_IO is not set
CONFIG_POSIX_OPEN_MAX=4
# end of POSIX device I/O
# CONFIG_POSIX_FD_MGMT is not set
# CONFIG_POSIX_FILE_SYSTEM_R is not set
# CONFIG_POSIX_FILE_SYSTEM is not set
# POSIX memory
CONFIG_POSIX_PAGE_SIZE=0x40
# CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
# CONFIG_POSIX_MAPPED_FILES is not set
# CONFIG_POSIX_MEMORY_PROTECTION is not set
# end of POSIX memory
# CONFIG_POSIX_MESSAGE_PASSING is not set
# CONFIG_POSIX_SINGLE_PROCESS is not set
# CONFIG_POSIX_MULTI_PROCESS is not set
# CONFIG_POSIX_THREADS is not set
# CONFIG_POSIX_READER_WRITER_LOCKS is not set
# POSIX scheduler options
# CONFIG_POSIX_PRIORITY_SCHEDULING is not set
# end of POSIX scheduler options
# CONFIG_POSIX_SEMAPHORES is not set
# POSIX signals
# CONFIG_POSIX_REALTIME_SIGNALS is not set
# CONFIG_POSIX_SIGNALS is not set
# end of POSIX signals
# CONFIG_POSIX_SPIN_LOCKS is not set
# POSIX synchronized I/O
# CONFIG_POSIX_FSYNC is not set
# CONFIG_POSIX_SYNCHRONIZED_IO is not set
# end of POSIX synchronized I/O
# CONFIG_POSIX_TIMERS is not set
# X/Open system interfaces
# CONFIG_XSI_REALTIME is not set
# CONFIG_XSI_SINGLE_PROCESS is not set
# CONFIG_XOPEN_STREAMS is not set
# CONFIG_XSI_SYSTEM_LOGGING is not set
# CONFIG_XSI_THREADS_EXT is not set
# end of X/Open system interfaces
# Miscellaneous POSIX-related options
# CONFIG_EVENTFD is not set
# end of Miscellaneous POSIX-related options
CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
CONFIG_RING_BUFFER=y
# CONFIG_RING_BUFFER_LARGE is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_UTF8 is not set
# CONFIG_COBS is not set
# end of Utility Library
# Universally Unique Identifier (UUID)
# CONFIG_UUID is not set
# end of Universally Unique Identifier (UUID)
# CONFIG_MIN_HEAP is not set
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
CONFIG_BT=y
CONFIG_BT_HCI=y
# CONFIG_BT_CUSTOM is not set
CONFIG_BT_HCI_RAW=y
# CONFIG_BT_HCI_RAW_H4 is not set
# CONFIG_BT_HCI_RAW_CMD_EXT is not set
CONFIG_BT_CONN_TX=y
# CONFIG_BT_LE_EXTENDED_FEAT_SET is not set
# CONFIG_BT_SCA_UPDATE is not set
# CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
# CONFIG_BT_PATH_LOSS_MONITORING is not set
# CONFIG_BT_SUBRATING is not set
# CONFIG_BT_ISO_PERIPHERAL is not set
# CONFIG_BT_ISO_CENTRAL is not set
# CONFIG_BT_ISO_BROADCASTER is not set
# CONFIG_BT_ISO_SYNC_RECEIVER is not set
# Bluetooth buffer configuration
# end of Bluetooth buffer configuration
# Bluetooth Host
# Bluetooth Classic Options
# end of Bluetooth Classic Options
# end of Bluetooth Host
CONFIG_BT_CTLR_ENTROPY_SUPPORT=y
CONFIG_BT_CTLR_CRYPTO_SUPPORT=y
CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
CONFIG_BT_CTLR_ADV_EXT_CODING_SELECTION_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
CONFIG_BT_CTLR_LE_PATH_LOSS_MONITORING_SUPPORT=y
CONFIG_BT_CTLR_SUBRATING_SUPPORT=y
CONFIG_BT_CTLR_FRAME_SPACE_UPDATE_SUPPORT=y
CONFIG_BT_CTLR_EXTENDED_FEAT_SET_SUPPORT=y
CONFIG_BT_CTLR_SHORTER_CONNECTION_INTERVALS_SUPPORT=y
CONFIG_HAS_BT_CTLR=y
CONFIG_BT_CTLR_HCI=y
CONFIG_BT_CTLR_HCI_NUM_CMD_PKT_MAX=1
# Bluetooth Controller configuration
CONFIG_BT_CTLR_ENTROPY=y
CONFIG_BT_CTLR_CRYPTO=y
CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
# CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
# CONFIG_BT_CTLR_TX_PWR_PLUS_1 is not set
CONFIG_BT_CTLR_TX_PWR_0=y
# CONFIG_BT_CTLR_TX_PWR_MINUS_1 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_2 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_3 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_5 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_6 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_7 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
# CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
CONFIG_BT_CTLR_TX_PWR_DBM=0
CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
# CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
# Bluetooth Controller features
CONFIG_BT_CTLR_LE_ENC=y
CONFIG_BT_CTLR_EXT_REJ_IND=y
CONFIG_BT_CTLR_LE_PING=y
CONFIG_BT_CTLR_DATA_LENGTH=y
CONFIG_BT_CTLR_PHY=y
CONFIG_BT_CTLR_CONN_RSSI=y
# CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
CONFIG_BT_CTLR_FILTER_ACCEPT_LIST=y
CONFIG_BT_CTLR_PRIVACY=y
CONFIG_BT_CTLR_RL_SIZE=8
CONFIG_BT_CTLR_EXT_SCAN_FP=y
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_CTLR_CHAN_SEL_2=y
# CONFIG_BT_CTLR_ADV_EXT is not set
# CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
# CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
# CONFIG_BT_CTLR_SUBRATING is not set
# CONFIG_BT_CTLR_EXTENDED_FEAT_SET is not set
CONFIG_BT_CTLR_DF_CTE_TX_SUPPORT=y
CONFIG_BT_CTLR_ASSERT_DEBUG=y
# CONFIG_BT_CTLR_ASSERT_HANDLER is not set
# CONFIG_BT_CTLR_VS_SCAN_REQ_RX is not set
# CONFIG_BT_EAD is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_CPU_LOAD_METRIC is not set
# CONFIG_CRC is not set
# CONFIG_DAP is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_UBSAN is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# CONFIG_SYMTAB is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_CS_TRACE_DEFMT is not set
# CONFIG_CPU_LOAD is not set
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM_LIB_LINK is not set
# CONFIG_FILE_SYSTEM is not set
# end of File Systems
# CONFIG_GNSS_RTK is not set
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
CONFIG_IPC_SERVICE=y
CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
CONFIG_IPC_SERVICE_RPMSG=y
CONFIG_IPC_SERVICE_STATIC_VRINGS=y
CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
# CONFIG_IPC_SERVICE_ICMSG is not set
# CONFIG_IPC_SERVICE_ICMSG_ME is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# CONFIG_LLEXT_EDK is not set
# Logging
# CONFIG_LOG_OUTPUT is not set
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
# CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
# end of Power Management
# Platform Management Communications Infrastructure (PMCI)
# CONFIG_MCTP is not set
# end of Platform Management Communications Infrastructure (PMCI)
# Portability
# end of Portability
# CONFIG_PROFILING is not set
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRNG_AVAILABLE=y
CONFIG_CSPRNG_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# end of SD
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# Testing
# end of Testing
# Linker Options
# Linker Sections
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# Build Options
# Boot Options
# Compatibility
