Short Connection Default Interval not being set
Hi everyone,
I’m working with Zephyr 3.2.3 in a Windows environment and trying to run the shorter connection intervals sample:
https://github.com/nrfconnect/sdk-nrf/tree/v3.2.3/samples/bluetooth/shorter_conn_intervals
What I’m trying to achieve:
I would like to use the default connection parameters defined in the sample without explicitly requesting a connection parameter update.
In particular, I’m referring to the default configuration in:
https://github.com/nrfconnect/sdk-nrf/blob/v3.2.3/samples/bluetooth/shorter_conn_intervals/src/main.c#L432
I tried to remove the connection parameter update logic from:
github.com/.../main.c
Expected behavior:
  • The connection should use the default parameters (including the minimum interval).
Actual behavior:
  • Even when relying on default settings, the connection does not use the expected interval unless I explicitly trigger a connection parameter update.
Question:
Is this expected behavior?
Is there a way to enforce the default minimum connection interval without calling a connection parameter update?
Thanks in advance!
    Sorry for the late reply.
    You need to enter the connection using the default legacy connection interval of 7.5ms - 4 seconds. So unfortunately, no, this is not possible.
    Note that there is a proprietary mode called llpm (low latency packet mode). Using that, we have done some shortcuts, and it will enter the connection using a 1ms connection interval. This is partially proprietary, however, so this will not work with non-Nordic devices (or Nordic devices not compatilbe with LLPM).
    Edvin
  • Hello Edvin,
    thank you for your reply.
    I understand that LLPM allows shorter intervals, but I’m not interested in using proprietary solutions. I would prefer to stay within the standard BLE specification.
    What I would like to better understand is the following point:
    why does it make sense to call a “bt_conn_le_conn_rate_set_defaults” after a "bt_conn_le_conn_rate_request"?
    sdk-zephyr/include/zephyr/bluetooth/conn.h at ncs-v3.2.3 · nrfconnect/sdk-zephyr · GitHub
    Thanks in advance for your clarification.
    The bt_conn_le_conn_rate_set_defaults() sets the preferred connection rate for all future connection, while the bt_conn_le_conn_rate_request() requests connection parameter updates for the current connection.
    Edvin
  • Hello Edvin,
    thank you for the clarification.
    I understand that bt_conn_le_conn_rate_set_defaults() applies to future connections, while bt_conn_le_conn_rate_request() is used to update the parameters of the current one.
    However, I still have a doubt:
    if I remove the call to bt_conn_le_conn_rate_request() from the example, how can I ensure that the default values set with bt_conn_le_conn_rate_set_defaults() are actually respected for a new connection?
    In other words, what guarantees that the connection will start (or converge) to those default parameters without explicitly requesting an update?
    In practice, I know that both my central and peripheral are based on the same platform (nRF54L15) and use the same project configuration, so I can assume that a short connection interval (e.g., 750 µs SCI) is supported on both sides.
    For this reason, I would like to avoid the step where the devices negotiate or exchange supported connection intervals through a connection parameter update procedure. Instead, I would like the central to directly use the values set in the default parameters from the beginning of the connection.
    How can I achieve this behavior from the central side, ensuring that the connection is established directly with those parameters, without requiring a connection update request?
    Thanks again for your support.
    Sebastian Luntraru
  • It is not possible to avoid the update request. It is not allowed by the Bluetooth Specification, and hence not possible using the SoftDevice controller.
    Edvin
  • Hi Edvin,
    i am also interested in the matter (in use case enlighten by Sebastian):
    - if do not call bt_conn_le_conn_rate_set_defaults() but only bt_conn_le_conn_rate_request(), what happens?
    - In wich cases the central uses the parameters set in bt_conn_le_conn_rate_set_defaults()?
    Alessandro
  • You can do that. But it will still enter the connection using a legal connection interval, backwards compatible to BLE, of minimum 7.5ms.
