Short Connection Default Interval not being set
Hi everyone,
I’m working with Zephyr 3.2.3 in a Windows environment and trying to run the shorter connection intervals sample:
https://github.com/nrfconnect/sdk-nrf/tree/v3.2.3/samples/bluetooth/shorter_conn_intervals
What I’m trying to achieve:
I would like to use the default connection parameters defined in the sample without explicitly requesting a connection parameter update.
In particular, I’m referring to the default configuration in:
https://github.com/nrfconnect/sdk-nrf/blob/v3.2.3/samples/bluetooth/shorter_conn_intervals/src/main.c#L432
I tried to remove the connection parameter update logic from:
github.com/.../main.c
Expected behavior:
  • The connection should use the default parameters (including the minimum interval).
Actual behavior:
  • Even when relying on default settings, the connection does not use the expected interval unless I explicitly trigger a connection parameter update.
Question:
Is this expected behavior?
Is there a way to enforce the default minimum connection interval without calling a connection parameter update?
Thanks in advance!
