Hello Support team,
I have an issue with two simultaneous heaps in my project. I use nrf Connect SDK 3.2.2 with the next configuration options:
Hello Support team,
Hi Egor,
you’re right — having two heaps is not ideal, and unfortunately there’s no built-in way to truly merge them into one.
Simple approach that works:
Redirect everything to the Zephyr (kernel) heap. heardle game
That means:
malloc, free, calloc, reallocnew / deletek_malloc / k_freeThis way you effectively use one heap only, and you can monitor it with Zephyr APIs.
Also, I’d avoid:
Better set a fixed size or fully redirect allocations, otherwise memory usage is hard to control.
In short:
You can’t truly combine both heaps, but you can force everything to use the kernel heap, which is the cleanest solution.
Hope that helps
Justin,
Thank you for this hints. I managed it with the next changes:
1. Override only C allocation functions malloc, calloc, realloc and free to kernel equivalents. Did several experiments and I see that C++ allocation is done via these C functions
2. Exclude Libc implementation of allocation functions and set heap arena size to 0 using next config:
config MCUMGR_GRP_SETTINGS_BUFFER_TYPE_HEAP bool "Heap (dynamic size)" depends on COMMON_LIBC_MALLOC_ARENA_SIZE > 0 help Use dynamic heap memory allocation through malloc, if there is insufficient heap memory for the allocation then the request will be rejected.
Hi Egor,
Could you try to allocate:
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=1
instead of leaving it 0 ? (It's just to satisfy the condition, but the actual allocation should go through your overriden method.)
Please try this and let me know how it goes.
-Priyanka
Hi Priyanka,
I tried it. To set any value to CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE I have to enable CONFIG_COMMON_LIBC_MALLOC. Enabling CONFIG_COMMON_LIBC_MALLOC leads to malloc function compilation and I have conflict with my malloc implementation
Hi Egor,
Apologies for the delayed response. I think it would be better then to keep using the stack buffer and increase the MCUmgr thread stack size if needed.
CONFIG_MCUMGR_GRP_SETTINGS_BUFFER_TYPE_STACK=y
CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=<larger value if needed>
If you really need MCUMgr to use heap memory instead, then I think that the Zephyr/MCUmgr would need a small code change so it uses k_malloc() directly, instead of depending on Zephyr’s libc malloc heap. But that means carrying a local patch. So, it might be better to use the stack buffer.
-Priyanka
