Bug Report: Fuzzy Revision Fallback Fails for number Format in board_check_revision() (NCS 3.2.1 / Zephyr)
Summary
When a board's board.yml uses revision.format: number with exact: false, the fuzzy (fallback) revision matching silently fails and reports "Board revision not found" even when a valid lower revision exists.
Environment
  • nRF Connect SDK: v3.2.1
  • File: zephyr/cmake/modules/extensions.cmake, function board_check_revision()
  • Affected format: number
  • Not affected: major.minor.patch, letter
Root Cause
In the fallback loop, the NUMBER branch uses CMake's GREATER operator — an integer comparison — to find the closest revision not exceeding the requested one:
elseif((BOARD_REV_FORMAT STREQUAL NUMBER) AND
       (${BOARD_REVISION} GREATER ${TEST_REVISION}) AND
       (${TEST_REVISION} GREATER "${ACTIVE_BOARD_REVISION}")
  set(ACTIVE_BOARD_REVISION ${TEST_REVISION})
endif()
The problem is that ACTIVE_BOARD_REVISION must be initialized to a sentinel value before the loop so the first valid candidate can always satisfy the GREATER condition. For integer comparison, the correct sentinel is -1:
set(ACTIVE_BOARD_REVISION -1)
Without this, "${ACTIVE_BOARD_REVISION}" expands to an empty string "". CMake's GREATER performs integer arithmetic and cannot parse an empty string as a number, so ${TEST_REVISION} GREATER "" evaluates to FALSE. The condition never fires, no ACTIVE_BOARD_REVISION is set, and the build aborts.
