IPC/ICMSG breaks if buffer has contents on reboot, but only with very specific config
Hello Nordic support
I have encountered what I think is a bug in ICMSG. The attached sample shows the following behavior:
  1. The first time it runs, the app and flpr CPUs succesfully start and communicate via IPC.
  2. Then, on reboot, cpuflpr seemingly immediately read some info from the IPC channel and crash.
  3. On the next reboot everything works again.
From this behavior I conclude that the IPC library does not properly work if the IPC buffer contains information from the previous boot. You can reproduce this on an nrf54l15dk building with the command west build -b nrf54l15dk/nrf54l15/cpuapp --sysbuild. Something strange, which is noted in the README of the code, is that which logging backend is used on both cores seems to have an effect on whether this issue appears. Also, enabling multithreading on FLPR also makes the issue disappear.
Example FLPR output (working):
*** Using Zephyr OS v4.0.99-77f865b8f8d0 ***
I: Initializing...
D: initializing IPC...
D: Opening instance...
D: Registering endpoint...
D: Register endpoint
I: IPC initialized.
I: Waiting before sending IPC, so APP core gets unstuck
I: Received ipc of len 4
I: Setting level 20
I: Received 20, sending back 21!
I: Setting level 50
I: Received 50, sending back 51!
I: Setting level 80
I: Received 80, sending back 81!
I: Setting level 9
I: Received 9, sending back 10!
Example FLPR output (crash):
*** Booting nRF Connect SDK v3.0.1-9eb5615da66b ***
I: Initializing...
I: Setting level 20
I: Setting level 50
I: Setting level 80
I: Setting level 9
I: IPC initialized.
I: Received ipc of len 4g IPC, so APP core gets unstuck
I: Setting level 39
I: Setting level 69
I: Setting level 99
I: Setting level 28
I: Setting level 58
I: Setting level 88
I: Setting level 17
I: Setting level 47
I: Setting level 77
I: Setting level 6
I: Setting level 36
I: Setting level 66
I: Setting level 96
I: Setting level 25
I: Setting level 55
I: Received ipc of len E:
E:  mcause:
This was tested on NCS v3.0.1.
Best Regards,
Fridtjof
minimal_sample.zip
