PWM-LED Configuration
Hello Team,
I am working with Thingy91x and I was checking whether is pwm led or pwm gpio can be configured for nRF5340 of Thingy 91x. If possible will you please let me know the steps I need to follow to configure pwm channel in Thingy 91x nrf5340 and get pwm output.
Kindly please let me know the limitations for this steps.
Thanks and regards
Vinay
  • Yes, PWM can be configured for the nRF5340 on the Thingy:91 X
    Step 1 :- PWM in prj.conf
    CONFIG_PWM=y
    CONFIG_PWM_LOG_LEVEL_DBG=y
    CONFIG_LED=y
    CONFIG_LED_PWM=y
    Step 2 :- Pin Control & PWM in Devicetree Overlay
    &pinctrl {
        pwm0_default_alt: pwm0_default_alt {
            group1 {
                psels = <NRF_PSEL(PWM_OUT0, 0, 30)>;
        pwm0_sleep_alt: pwm0_sleep_alt {
            group1 {
                low-power-enable;
    &pwm0 {
        status = "okay";
        pinctrl-0 = <&pwm0_default_alt>;
        pinctrl-1 = <&pwm0_sleep_alt>;
        pwmleds {
            compatible = "pwm-leds";
            led_pwm_0 {
                pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_NORMAL>;
                label = "PWM LED 0";
        aliases {
            pwm-led0 = &led_pwm_0;
    Step 3 :- application code
    #include <zephyr/device.h>
    #include <zephyr/drivers/pwm.h>
    #define PWM_PERIOD_NS   20000000
    #define PWM_PULSE_WIDTH 1400000
    static const struct pwm_dt_spec pwm_led0 =
        PWM_DT_SPEC_GET(DT_ALIAS(pwm_led0));
    int main(void) {
        if (!pwm_is_ready_dt(&pwm_led0)) {
            return 0;
        pwm_set_dt(&pwm_led0, PWM_PERIOD_NS, PWM_PULSE_WIDTH);
        return 0;
    Step 4 :- thingy91x_nrf9151_ns.overlay (external power fix)
    &exp_board_enable {
    /delete-property/ output-low;
    output-high;
    Build with west build -b thingy91x/nrf5340/cpuapp and flash. Let me know if you hit any issues!
  • Hello Nishant,
    Thank you for your reply. I really appreciate it.
    But I am facing issue while building this configuration.
    I am adding the logs and the project zip file which I have configured as per your guidance.
    Thingy91x_nrf5430_pwm.zip
    (v3.0.0) C:\ncs\v3.0.0\nrf> west build -b thingy91x/nrf5340/cpuapp C:\Users\11221\Downloads\Thingy91x_nrf5430_pwm -p always
    -- west build: making build dir C:\ncs\v3.0.0\nrf\build pristine
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.0/zephyr/.cache
    -- Board: thingy91x, qualifiers: nrf5340/cpuapp
    Parsing C:/ncs/v3.0.0/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/ncs/v3.0.0/nrf/build/_sysbuild/empty.conf'
    Merged configuration 'C:/ncs/v3.0.0/nrf/build/_sysbuild/empty.conf'
    Configuration saved to 'C:/ncs/v3.0.0/nrf/build/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.0/nrf/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.0/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf5340_cpuapp.dts
    -- Found devicetree overlay: C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Found devicetree overlay: C:/ncs/v3.0.0/nrf/modules/mcuboot/flash_sim.overlay
    -- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/v3.0.0/nrf/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/build/mcuboot/zephyr/dts.cmake
    warning: UART_NRFX (defined at drivers/serial\Kconfig.nrfx:6) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: (DT_HAS_NORDIC_NRF_UART_ENABLED ||
    DT_HAS_NORDIC_NRF_UARTE_ENABLED) (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_NRFX and/or look up UART_NRFX in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: LOG_DEFAULT_LEVEL (defined at subsys/logging\Kconfig.filtering:13) was assigned the value
    '0' but got the value ''. Check these unsatisfied dependencies: LOG (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_DEFAULT_LEVEL and/or look up
    LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: The choice symbol MCUBOOT_LOG_LEVEL_INF (defined at
    subsys/logging/Kconfig.template.log_config:17) was selected (set =y), but no symbol ended up as the
    choice selection. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_LOG_LEVEL_INF
    and/or look up MCUBOOT_LOG_LEVEL_INF in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging\Kconfig.mode:29) was selected
    (set =y), but no symbol ended up as the choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_MODE_MINIMAL and/or look up
    LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    warning: Deprecated symbol SOC_DCDC_NRF53X_APP is enabled.
    warning: Deprecated symbol SOC_DCDC_NRF53X_NET is enabled.
    warning: Deprecated symbol NFCT_PINS_AS_GPIOS is enabled.
    warning: Deprecated symbol DEPRECATED_UART_NRFX_UARTE_LEGACY_SHIM is enabled.
    Parsing C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/boards/thingy91x_nrf5340_cpuapp.conf'
    Merged configuration 'C:/ncs/v3.0.0/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration 'C:/ncs/v3.0.0/bootloader/mcuboot/boot/zephyr/external_crypto.conf'
    Merged configuration 'C:/ncs/v3.0.0/nrf/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/v3.0.0/nrf/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.0/nrf/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    MCUBoot bootloader key file: C:/ncs/v3.0.0/bootloader/mcuboot/root-ec-p256.pem
    CMake Warning at CMakeLists.txt:393 (message):
      WARNING: Using default MCUboot signing key file, this file is for debug use
      only and is not secure!
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/v3.0.0/nrf/build/mcuboot
       * Running CMake for empty_net_core *
    -- Application: C:/ncs/v3.0.0/nrf/samples/nrf5340/empty_net_core
    -- Board: thingy91x, qualifiers: nrf5340/cpunet
    -- Found BOARD.dts: C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf5340_cpunet.dts
    -- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/build/empty_net_core/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/v3.0.0/nrf/build/empty_net_core/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/build/empty_net_core/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/build/empty_net_core/zephyr/dts.cmake
    warning: UART_CONSOLE (defined at drivers/console/Kconfig:42) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: SERIAL_HAS_DRIVER (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up UART_CONSOLE in
    the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
    Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    Parsing C:/ncs/v3.0.0/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.0.0/nrf/boards/nordic/thingy91x/thingy91x_nrf5340_cpunet_defconfig'
    Merged configuration 'C:/ncs/v3.0.0/nrf/samples/nrf5340/empty_net_core/prj.conf'
    Merged configuration 'C:/ncs/v3.0.0/nrf/build/empty_net_core/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/v3.0.0/nrf/build/empty_net_core/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.0/nrf/build/empty_net_core/zephyr/include/generated/zephyr/autoconf.h'
    CMake Warning at C:/ncs/v3.0.0/zephyr/CMakeLists.txt:1002 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
      No SOURCES given to Zephyr library: drivers__serial
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/v3.0.0/nrf/build/empty_net_core
       * Running CMake for b0n *
    -- Application: C:/ncs/v3.0.0/nrf/samples/nrf5340/netboot
    -- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/build/b0n/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/v3.0.0/nrf/build/b0n/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/build/b0n/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/build/b0n/zephyr/dts.cmake
    Parsing C:/ncs/v3.0.0/nrf/samples/nrf5340/netboot/Kconfig
    Merged configuration 'C:/ncs/v3.0.0/nrf/samples/nrf5340/netboot/prj.conf'
    Merged configuration 'C:/ncs/v3.0.0/nrf/build/b0n/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/v3.0.0/nrf/build/b0n/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.0/nrf/build/b0n/zephyr/include/generated/zephyr/autoconf.h'
    CMake Warning at C:/ncs/v3.0.0/zephyr/CMakeLists.txt:2180 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/v3.0.0/nrf/build/b0n
       * Running CMake for b0 *
    -- Application: C:/ncs/v3.0.0/nrf/samples/bootloader
    -- Generated zephyr.dts: C:/ncs/v3.0.0/nrf/build/b0/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/v3.0.0/nrf/build/b0/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/v3.0.0/nrf/build/b0/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v3.0.0/nrf/build/b0/zephyr/dts.cmake
    Merged configuration 'C:/ncs/v3.0.0/nrf/samples/bootloader/prj.conf'
    Merged configuration 'C:/ncs/v3.0.0/nrf/samples/bootloader/boards/thingy91x_nrf5340_cpuapp.conf'
    Merged configuration 'C:/ncs/v3.0.0/nrf/build/b0/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/v3.0.0/nrf/build/b0/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v3.0.0/nrf/build/b0/zephyr/include/generated/zephyr/autoconf.h'
    -- Configuring done
    -- Generating done
       * Running CMake for Thingy91x_nrf5430_pwm *
    -- Application: C:/Users/11221/Downloads/Thingy91x_nrf5430_pwm
    -- Found devicetree overlay: C:/Users/11221/Downloads/Thingy91x_nrf5430_pwm/thingy91x_nrf5340_cpuapp.overlay
    devicetree error: /aliases: undefined node label 'led_pwm_0'
    CMake Error at C:/ncs/v3.0.0/zephyr/cmake/modules/dts.cmake:305 (execute_process):
      execute_process failed command indexes:
        1: "Child return code: 1"
      C:/ncs/v3.0.0/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      C:/ncs/v3.0.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v3.0.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:2 (find_package)
    CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
      CMake configure failed for Zephyr project: Thingy91x_nrf5430_pwm
      Location: C:/Users/11221/Downloads/Thingy91x_nrf5430_pwm
      cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.0.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.0.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    See also "C:/ncs/v3.0.0/nrf/build/CMakeFiles/CMakeOutput.log".
    ←[91mFATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe '-BC:\ncs\v3.0.0\nrf\build' -GNinja -DBOARD=thingy91x/nrf5340/cpuapp '-SC:\ncs\v3.0.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\Users\11221\Downloads\Thingy91x_nrf5430_pwm'
    ←[0m
    Thanks and regards,
    Vinay
  • Your overlay is trying to use a pwm_led0 (or similar) alias that doesn't exist for the thingy91x/nrf5340/cpuapp board. This is similar to a known issue where a sample or application expects a specific DeviceTree node that the target board doesn't provide
    1 :Follow to fix this
    Define the alias in your overlay file. In your thingy91x_nrf5340_cpuapp.overlay, you need to properly define the led_pwm_0 node and add it under /aliases.
    aliases {
    led-pwm-0 = &pwm_led0;
    pwmleds {
    pwm_led0: pwm_led_0 {
    Adjust the PWM instance, channel, and period to match your hardware.
    1. Ensure the PWM peripheral is enabled in your prj.conf:
      CONFIG_PWM=y
      CONFIG_PWM_NRFX=y
  • Hi Nishant,
    Thank you for your response.
    Now I am able to build and flash pwm binary after the modification mentioned by you.
    But how I can check PWM Signal, as we have configured pwm0 channel to P0.30 how we can check the output channel of PWM output.
    Thanks and regards,
    Vinay
  • To confirm the PWM signal on P0.30, you would typically use an oscilloscope or logic analyzer connected to that pin on your board.
    i suggest you to go through in-depth guidance on PWM configuration and testing, the Nordic Developer Academy course on nRF Connect SDK Intermediate (Lesson 4). [PWM exercise]
