RAI support in LTE-M and NB-IoT on nRF9151 (France operators)
I am currently testing the Release Assistance Indication (RAI) feature on the nRF9151 (SMA-DK) in order to minimize power consumption after data transmission.
I am using the %RAI command with value 2 to enable RAI and receive network feedback about its configuration:
AT%RAI=2
The notification I receive is:
%RAI: <cell_id>,<plmn>,<as_rai_configuration>,<cp_rai_configuration>
Test setup:
Module: nRF9151 (SMA-DK)
Firmware: v2.0.x (≥2)
Networks tested in France:
Orange
Bouygues Telecom
SFR
Observed behavior:
LTE-M:
For all three operators, I consistently get:
as_rai_configuration = 0
cp_rai_configuration = 0
NB-IoT:
Bouygues Telecom and SFR:
cp_rai_configuration = 1
Question:
Does this mean that:
RAI is not supported in LTE-M by these operators in France?
Only CP-RAI is supported in NB-IoT (and not AS-RAI)?
Or could this behavior be related to:
Network configuration limitations?
SIM/operator profile restrictions?
Or specific modem/firmware constraints?
Additional context:
My goal is to reduce current consumption by allowing the network to release the connection immediately after uplink transmission using RAI.
What I’m looking for:
Clarification on RAI support (LTE-M vs NB-IoT) in European / French networks
Confirmation if this behavior is expected
Any recommendations to effectively use RAI with nRF91 series
    Your setup is correct and the behavior you're seeing seems expected, as RAI feature can be used if network supports it. Actually the %RAI notification tells you what the network has configured, not what the modem is capable of.
    Your results for LTE-M (all three operators) shows that AS-RAI is simply not enabled by the operator on their LTE-M cells (CP-RAI feature is not for LTE-M). This is an operator/network infrastructure decision so the device cannot force it. However for NB-IoT (Bouygues, SFR) it shows that CP-RAI is available and you can use it. Just keep AT%RAI=2 and after enabling RAI, you can control it using the nrf_setsockopt() function with the NRF_SO_RAI socket option as mentioned here.
    For LTE-M without AS-RAI, your best option for power savings is tuning PSM and eDRX. If AS-RAI on LTE-M is a hard requirement, you'd need to raise it directly with the operators, it's outside what the device can control.
    Best Regard,
    Syed Maysum
