LittleFS on nRF5340 + MX25L51245G (64MB QSPI NOR): -14 (EFAULT) after ~1600 files, filesystem wiped on reboot
Environment
  • Board: nRF5340 custom PCB
  • SDK: nRF Connect SDK 3.0.2
  • External flash: MX25L51245GZ2I-08G (64MB NOR, QSPI interface)
  • Filesystem: LittleFS via Zephyr fstab
  • IDE: VS Code with nRF Connect extension
What I am doing
I am writing 2500 to 3000 files into a single LittleFS directory on external QSPI flash. Each file is approximately 1KB in size and stores pin code data. Files are named by their pin code value for example /external/pin_codes/12345678.
For each pin received over BLE I follow this exact sequence:
  1. Write the pin file using fs_write_pin_code_data_to_file()
  2. Verify the written size using fs_read_pin_code_data_file_size()
  3. Write a 12-byte GUID/transaction record into a separate session file using fs_write_current_ble_session_command_guids_data_on_file()
Total data written is roughly 2500 x 1KB = ~2.5MB. This is less than 4% of the 64MB flash. Storage space is not the issue.
Problem
After approximately 1600 file writes the following errors start occurring:
  • fs_open() or fs_write() returns -14 (EFAULT)
  • Occasionally -2 (ENOENT) on file open even though the directory exists
  • On the next reboot all files are completely wiped — all 1600+ pin files are gone with no warning
Key observation: if I comment out the call fs_write_current_ble_session_command_guids_data_on_file() at step 3, I can write 2500 to 3000 pin files without any error. The moment that call is active errors begin at around 1600 writes. The function fs_write_current_ble_session_command_guids_data_on_file() does internally on every single call — it opens the session file, seeks to the position, writes 12 bytes of GUID/transaction data, then closes the file. This means across 1600 pin writes the same session file is being opened, seeked, written and closed 1600 times.
Also observed: if I batch the session file writes — record every 20 records in a buffer and then write — the error does not appear for 3000 pins but it may appear after that.
The major concern is that the filesystem behaves very unpredictably — I am not confident about when it will randomly wipe out all files and data
DTS configuration
dts
&qspi {
    pinctrl-0 = <&qspi_default>;
    pinctrl-1 = <&qspi_sleep>;
    mx25l512: mx25l51245g@0 {
        compatible = "nordic,qspi-nor";
        reg = <0>;
        writeoc = "pp4io";
        readoc = "read4io";
        sck-frequency = <8000000>;
        jedec-id = [c2 20 1A];
        sfdp-bfp = [
            e5 20 fb ff  1f ff ff ff  44 eb 08 6b  08 3b 04 bb
            fe ff ff ff  ff ff 00 ff  ff ff 44 eb  0c 20 0f 52
            10 d8 00 ff  d6 49 c5 00  81 df 04 e3  44 03 67 38
            30 b0 30 b0  f7 bd d5 5c  4a 9e 29 ff  f0 50 f9 85
        size = <0x20000000>;
        has-dpd;
        t-enter-dpd = <10000>;
        t-exit-dpd = <30000>;
        external_partition: partition {
            label = "external";
fstab {
    compatible = "zephyr,fstab";
    lfs1: lfs1 {
        compatible = "zephyr,fstab,littlefs";
        mount-point = "/external";
        partition = <&external_partition>;
        read-size = <16>;
        prog-size = <256>;
        cache-size = <4096>;
        lookahead-size = <512>;
        block-cycles = <500>;
Functions being used
Below is the outer flow that runs once per BLE pin command. It ties all three steps together:
c
// Called once per pin received over BLE.
// Writes pin file, verifies it, then writes the transaction GUID.
void process_single_pin(uint32_t pin_code, uint8_t pin_length,
                        const uint8_t *data, uint16_t start,
                        uint16_t length, int32_t command_guid,
                        int32_t time_stamp)
    // Step 1 — write the pin data file (~1KB) to flash
    int write_res = fs_write_pin_code_data_to_file(
                        pin_code, pin_length, data, start, length);
    sb_print_log(LOG_DEBUG, "Pin write result: %d", write_res);
    // Step 2 — verify written size matches expected
    int pin_size = fs_read_pin_code_data_file_size(pin_code);
    if (pin_size != length)
        sb_print_log(LOG_ERR, "Size mismatch. Expected: %d Found: %d",
                     length, pin_size);
        fs_delete_pin_code_data(pin_code);
        return;
    // Step 3 — write 12-byte GUID record into separate session file.
    // Internally this opens the session file, seeks to the current
    // counter offset, writes 12 bytes, then closes the file.
    // This open/seek/write/close happens once per pin — so across
    // 1600 pins this function opens and closes the same file 1600 times.
    fs_write_current_ble_session_command_guids_data_on_file(command_guid, len);
Step 1 — Write pin file
c
int fs_write_pin_code_data_to_file(uint32_t pin_code, uint8_t pin_length,
                                    uint16_t length)
    int write_count = 0;
    char pin_code_file_name[15];
    char full_file_name[MAX_PATH_LEN];
    snprintf(pin_code_file_name, sizeof(pin_code_file_name), "%" PRIu32, pin_code);
    snprintf(full_file_name, sizeof(full_file_name), "%s/%s",
             PIN_CODES_DIRECTORY, pin_code_file_name);
    for (int i = 0; i < 3; i++)
        int result = __fs_write_bytes_to_file(fs_external_mount_point,
                                              full_file_name,
                                              data + start, length,
                                              &write_count);
        if (result < 0)
            k_sleep(K_MSEC(100));
                                              full_file_name,
                                              &write_count);
        if (result == APP_SUCCESS)
    return write_count;
int __fs_write_bytes_to_file(struct fs_mount_t *fs_mount_point,
                              const char *abs_path,
                              const char *data, int len, int *write_count)
    int rc;
    struct fs_file_t file;
    char fname[MAX_PATH_LEN];
    fs_file_t_init(&file);
    snprintf(fname, sizeof(fname), "%s/%s",
             fs_mount_point->mnt_point, abs_path);
    rc = fs_open(&file, fname, FS_O_CREATE | FS_O_WRITE);
    if (rc < 0)
        sb_print_log(LOG_DEBUG, "File Open Err: %d", rc);
        return rc;
    rc = fs_write(&file, data, len);
    fs_sync(&file);
    fs_close(&file);
    *write_count = rc;
    return rc < 0;
Step 2 — Verify written file size
c
int fs_read_pin_code_data_file_size(uint32_t pin_code)
    char pin_code_file_name[45];
    char file_name[MAX_PATH_LEN];
    snprintf(pin_code_file_name, sizeof(pin_code_file_name), "%u", pin_code);
    snprintf(file_name, sizeof(file_name), "%s/%s/%s",
             fs_external_mount_point->mnt_point,
    int rc;
    int size = 0;
        struct fs_dirent dirent;
        dirent.type = FS_DIR_ENTRY_FILE;
        rc = fs_stat(file_name, &dirent);
        if (rc == 0)
            size = dirent.size;
    if (rc < 0)
        sb_print_log(LOG_DEBUG, "Error %d for Fs Stat (%s)", rc, file_name);
        return rc;
    return size;
Step 3 — Write the 12 byte GUID data in session file
int8_t fs_write_current_ble_session_command_guids_data_on_file(uint8_t *data_to_write, uint8_t len)
     int8_t rc;
     TRANSACTIONS_BLE_SESSION_DATA_FILE);
     if (rc < 0)
        return -1;
   * Each record is of 12 bytes.
   * Seek to the correct position for this record.
    int32_t location_index = g_current_ble_session_transaction_counter * len;
    rc = fs_seek(&file, location_index, FS_SEEK_SET);
    if (rc != 0)
       sb_print_log(LOG_DEBUG, "File Seek Err: %d", rc);
       return rc;
   * Write the record data.
   rc = fs_write(&file, data_to_write, len);
   if (rc != len)
      sb_print_log(LOG_DEBUG, "Failed to Write Current Session GUIDs in file: %d", rc);
   fs_close(&file);
   * Update the counter to enable circular usage of the file.
    g_current_ble_session_transaction_counter++;
    if (g_current_ble_session_transaction_counter >= MAX_CURRENT_SESSION_TRANSACTIONS_COUNT)
       g_current_ble_session_transaction_counter = 0;
    return rc;
  • Try adding this in your dts for mx25l512 node.
    address-size-32;
    I think the qspi driver might be defaulting to a 24 bit addressing in the absense of this. and 24 bit addressing only covers 16MB. That could be a reason for it to roll over or something like that.
  • Hi Nordic Team,
    I am waiting for your reply on my previous post. In the meantime I have done an isolated stress test on a fresh LittleFS sample project to narrow down the issue.
    Environment
    • External flash: MX25L51245GZ2I-08G (64MB NOR, QSPI)
    What I am doing
    I am writing the same single file in a loop of 10,000 iterations — overwriting it every time. The file is always the same name and always the same size. Flash is fully erased before the test starts. Only DATA_SIZE changes between tests runs. Everything else is identical.
    Observation
    DATA_SIZE Result
    270 bytes -14 (EFAULT) at ~4000 writes
    800 bytes No error at 10000 writes
    1024 bytes No error at 10000 writes
    4000 bytes No error at 10000 writes
    Question:
    What is causing -14 (EFAULT) specifically when writing a 270 byte file repeatedly but not when writing the file with size 800, 1024 or 4000?
    &qspi {
    reg = <0>;
    writeoc = "pp4io";
    readoc = "read4io";
    jedec-id = [c2 20 1a];
    sfdp-bfp = [
    e5 20 fb ff ff ff ff 1f 44 eb 08 6b 08 3b 04 bb
    has-dpd;
    label = "external";
    fstab {
    lfs1: lfs1 {
    read-size = <16>;
    prog-size = <256>;
    Proj.conf
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_HEAP_MEM_POOL_SIZE=20480
    CONFIG_MBEDTLS_HEAP_SIZE=18432
    CONFIG_FS_LITTLEFS_FC_HEAP_SIZE=16384
    # Debug
    CONFIG_DEBUG=y
    # Logging — use IMMEDIATE so logs aren't buffered/lost on quick exit
    CONFIG_LOG=y
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_LOG_BACKEND_UART=y
    # Console/Serial
    CONFIG_SERIAL=y
    CONFIG_UART_CONSOLE=y
    CONFIG_PRINTK=y
    # Storage
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    CONFIG_APP_LITTLEFS_STORAGE_FLASH=y
    CONFIG_CONSOLE=y
    CONFIG_REBOOT=y
    CONFIG_SPI=y
    CONFIG_FLASH_JESD216_API=y
    Refer the code below
    #define DATA_SIZE (270)
    int fs_write_bytes_to_file(struct fs_mount_t *fs_mount_point,
    int len)
    if (fs_mount_point == NULL || abs_path == NULL || data == NULL)
    LOG_ERR("%s: NULL argument", __func__);
    return -EINVAL;
    if (len <= 0)
    LOG_ERR("%s: invalid length %d", __func__, len);
    return -EINVAL;
    int path_len = snprintf(fname, sizeof(fname), "%s/%s",
    if (path_len < 0 || path_len >= (int)sizeof(fname))
    LOG_ERR("%s: path too long (%s/%s)",
    __func__, fs_mount_point->mnt_point, abs_path);
    return -ENAMETOOLONG;
    int rc = fs_open(&file, fname, FS_O_CREATE | FS_O_RDWR);
    if (rc < 0)
    LOG_ERR("%s: fs_open failed (%s) rc=%d", __func__, fname, rc);
    return rc;
    if (rc < 0)
    LOG_ERR("%s: fs_write failed (%s) rc=%d", __func__, fname, rc);
    goto cleanup;
    if (rc != len)
    LOG_ERR("%s: partial write (%s) wrote=%d expected=%d",
    __func__, fname, rc, len);
    rc = -EIO;
    goto cleanup;
    rc = fs_sync(&file);
    if (rc < 0)
    LOG_ERR("%s: fs_sync failed (%s) rc=%d", __func__, fname, rc);
    goto cleanup;
    rc = len;
    cleanup:
    int close_rc = fs_close(&file);
    if (close_rc < 0)
    LOG_ERR("%s: fs_close failed (%s) rc=%d", __func__, fname, close_rc);
    if (rc >= 0)
    rc = close_rc;
    return rc;
    int fs_write_data_file(const uint8_t *data, int size)
    return fs_write_bytes_to_file(fs_external_mount_point,
    LOCKER_RSA_PUB_KEY_FILE,
    data, size);
    static int little_fs_stress_test1(void)
    uint8_t dummy_data[DATA_SIZE];
    for (size_t i = 0; i < DATA_SIZE; i++)
    dummy_data[i] = (uint8_t)(i & 0xFF);
    for (int i = 0; i < 10000; i++)
    LOG_INF("Writing file counter =:: %d", i);
    fs_write_data_file(dummy_data, DATA_SIZE);
    return 0;
    struct fs_statvfs sbuf;
    int rc;
    rc = littlefs_mount(fs_external_mount_point);
    if (rc < 0)
    LOG_ERR("FAIL: mount external flash: %d", rc);
    return 0;
    rc = fs_statvfs(fs_external_mount_point->mnt_point, &sbuf);
    if (rc < 0)
    LOG_PRINTK("FAIL: statvfs: %d\n", rc);
    return 0;
    LOG_PRINTK("%s: bsize=%lu frsize=%lu blocks=%lu bfree=%lu\n",
    sbuf.f_bsize, sbuf.f_frsize,
    sbuf.f_blocks, sbuf.f_bfree);
    fs_flash_area_erase(fs_external_mount_point);
    little_fs_stress_test1();
    return 0;
  • Have you read my previous reply? Have you tried adding address-size-32 in your dts file for the mx25l512 node? I thought that if you add this to the node, then the addressing bit mode should change and should help with the -14 error, if it did not, then please help me reproduce this issue on the nRF5340 DK by giving me a minimalistic project.
