KConfig woes
I'm trying to slim down my application to fit in an nRF52832 (currently overflows RAM when building) so I'm carving things out using the prj.conf file. But I'm running into weirdness:
I set CONFIG_PRINTK=n hoping to suppress all the code and memory used by debug prints.  Except while building I get:
warning: PRINTK (defined at subsys/debug/Kconfig:145) was assigned the value 'n' but got the value
'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PRINTK and/or look up PRINTK in
the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
Ok, seems legit so I follow the link and read up on CONFIG_PRINTK. According to the documentation, it is selected by CONFIG_BOOT_BANNER, CONFIG_LOG, CONFIG_LOG_MODE_MINIMAL all three of which I explicitly set to "n" in the prj.conf file. Weird, let's go check the zephyr/.config file. Turns out the CONFIG_LOG is set to "y" in that file, even though I explicitly set it to "n" and the build never gave a warning that the value was being overridden.  Even stranger, none of the "selected by" options in the KConfig documentation for CONFIG_LOG are even present - one way or the other - in the .config file. So I add all to the prj.conf and set them to "n". No difference.
How do I make it actually remove printing/logging? I tried looking in the "nRF Kconfig GUI" in VS Code and "Logging" is unchecked and the "Send printk() to console" is checked but greyed out so I can't uncheck it.
