nrf9151 and nrf9160 PLMN selection criteria
Hey,
I was trying to look for information on how nrf9160 modem selects the network to use, since we are having slight trouble with some devices triggering full network re-selection when operating at the edge of multiple networks.
So on nrf9151 and nrf9160 what are the PLMN selection criteria when waking up from PSM and what are the requirements for the modem to trigger new attach to a different PLMN when multiple are available?
Also is there a way to steer/prioritize the modem to connect to a specific PLMN but not fully lock it?
  • Hi Thomas,
    Apologies for the delay. I am working on this with the team and will get back to you soon with an update. Thanks for your patience.
    Best Regards,
    Samruddhi
    Apologies for the delay in response. I have discussed this with the team and this is their feedback.
    After the modem wakes up, it does not change to using another PLMN easily as its goal is to find the network which was serving the device before. So, PSM wakeup doesn't result in an attempt to search networks with higher priority. It will connect to the same previous network which is less power consuming.
    There are many factors which could result in attach attempts to other networks such as equivalent PLMNs concept and different methods for home operator (SIM provider) can direct modem to another network via SIM USAT functionality.
    Manual PLMN selection by the application is the only way to lock device to network and in order to switch networks or to automatic network selection mode, out-of-service logic is needed and would be implemented by the application. Note that this will not prevent moving to those equivalent PLMNs.
    Do you have any log files which we could have a look at?
    Best Regards,
    Samruddhi
  • Hey,
    Sorry for the long delay.
    Unfortunately I don't have any specific logs to share, only mentions about the device switching between networks in short time frame from the operator.
    Also what does "equivalent PLMN" mean here
    "Equivalent PLMNs" here refers to a 3GPP feature. In this, when the registration process is ongoing, networks that are equivalent to another network are indicated for network selection. The device manages the cells from these networks. This is because they will belong to same network for network and cell selection as well as cell reselections.
    Best Regards,
    Samruddhi
