SD Card Communication on nRF54LM20A High Speed SPIM Bus (SPI00) Fails to Initialize
Good day,
I have been making use of the nRF54LM20A SoC with ncs v3.2.0. I am currently trying to use the high-speed SPI (SPIM00) lines on Port 2 to communicate with an SD card. I intend to mount it and be able to write to and read from the card. I am using a custom board (Fanstel EV-BM20C), however that seems to be irrelevant to the issue at hand.
The problem is that the high-speed SPI lines on the chip seem to have a minimum clock speed of around 1-2MHz. This poses an issue because the SD card initializes at 400kHz. Zephyr RTOS seems to force the initialization process of an SD card to 400kHz, preventing the SPI lines from even starting communication.
This yields this error, along with many more after the fact:
<err> spi_nrfx_spim: Failed to initialize nrfx driver: -22
I then attempted to use the same pins as GPIO pins to first bitbang the SPI initialization sequence onto the SD card, before ultimately returning back to the high speed SPI bus. I used both manual bitbanging the commands to initialize the SD card, as well as the embedded spi-bitbang library within Zephyr. While both methods initialized smoothly, switching to the high speed bus during runtime proved to be problematic and throw a whole host of errors no matter what I did.
My overall question is, is it possible to mount the SD card properly on the nRF54LM20A SoC using the SPIM00 SPI lines? And if not, is it possible to mount the SD card some other way using bitbanging, while switching to the SPIM00 lines only after initialization?
prj.conf:
CONFIG_SPI=y
CONFIG_SPI_BITBANG=y
CONFIG_SPI_NRFX=y
CONFIG_LOG=y
CONFIG_PRINTK=y
CONFIG_DISK_DRIVER_SDMMC=y
CONFIG_DISK_ACCESS=y
CONFIG_FILE_SYSTEM=y
CONFIG_FAT_FILESYSTEM_ELM=y
CONFIG_MAIN_STACK_SIZE=4096
nrf54lm20dk_nrf54lm20a_cpuapp.overlay:
&spi00 {
    status = "okay";
    cs-gpios = <&gpio2 10 GPIO_ACTIVE_LOW>;
    pinctrl-0 = <&spi00_default>;
    pinctrl-1 = <&spi00_sleep>;
    max-frequency = <4000000>;
    sdhc0: sdhc@0 {
        status = "okay";
        compatible = "zephyr,sdhc-spi-slot";
        spi-max-frequency = <4000000>;
        reg = <0>;
        label = "SD";
        mmc {
            compatible = "zephyr,sdmmc-disk";
            disk-name = "SD";
            status = "okay";
&pinctrl {
    spi00_default: spi00_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 2, 6)>,
                    <NRF_PSEL(SPIM_MOSI, 2, 8)>,
                    <NRF_PSEL(SPIM_MISO, 2, 9)>;
    spi00_sleep: spi00_sleep {
        group1 {
            low-power-enable;
// If bitbanging is necessary
    /* Define the bit-bang SPI bus */
    spi_bb: spi-bitbang {
        compatible = "zephyr,spi-bitbang";
        status = "okay";
        #address-cells = <1>;
        #size-cells = <0>;
        clk-gpios  = <&gpio2 6 GPIO_ACTIVE_HIGH>;
        mosi-gpios = <&gpio2 8 GPIO_ACTIVE_HIGH>;
        miso-gpios = <&gpio2 9 GPIO_ACTIVE_HIGH>;
        sdhc_bb: sdhc@0 {
            reg = <0>;
            status = "okay";
            label = "SD_BB";
            mmc {
                status = "okay";
                disk-name = "SD_BB";
            spi-max-frequency = <400000>; // Keep it slow for bit-banging
main.c:
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/spi.h>
#include <string.h>
#include <zephyr/storage/disk_access.h>
#include <zephyr/fs/fs.h>
#include <ff.h>
#define LOG_LEVEL CONFIG_LOG_DEFAULT_LEVEL
LOG_MODULE_REGISTER(app);
static struct fs_mount_t fs_mnt;
	k_sleep(K_MSEC(200));
	static FATFS fat_fs;
	fs_mnt.type = FS_FATFS;
	fs_mnt.fs_data = &fat_fs;
	fs_mnt.mnt_point = "/SD:";
	fs_mount(&fs_mnt);
	k_msleep(500);
	char filename[255];
	struct fs_file_t file;
	int rc;
	fs_file_t_init(&file);
	snprintf(filename, sizeof(filename), "%s/test_file.txt", fs_mnt.mnt_point);
	rc = fs_open(&file, filename, FS_O_CREATE | FS_O_WRITE);
	if (rc < 0) {
		LOG_ERR("FAIL: open %s: %d", filename, rc);
		return rc;
	LOG_INF("File created!");
	rc = fs_write(&file, "Text written", 12);
	if (rc < 0) {
		LOG_ERR("FAIL: write %s: %d", filename, rc);
		return rc;
	LOG_INF("Data written");
	rc = fs_close(&file);
	return 0;
  • Sorry for late reply Damola,
    As you have already calculated, SPI00 has minimal speed of around 1 MHz due to its prescalar so requesting 400KHz with this instance is not possible directly with the Zephyr's layer. The options are either to
    • move the SD card wiring to Port 1 and use SPIM20/21/22
    • Stay on Port 2, use spi-bitbang only,
    You can technically manually init SD over GPIO bit bang and then use SPIM00 transfers but it is a bit chaotic and risky to do so. A lot of things can go wrong.
