bt_hci_driver: Endpoint binding failed with -11
I'm developing software for the nRF5340 based on the NCS 3.2.4 "hello world" example.
Adding bt_enable() returns error code -11.
Please tell me how to implement bt_enable() so that it completes correctly.
The source code is as follows:
prj.conf
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_BT=y
CONFIG_BT_DEVICE_NAME="Thingy91X"
CONFIG_BT_CENTRAL=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
main.c
#include <stdio.h>
#include <zephyr/kernel.h>
#include <bluetooth/scan.h>
#define DEVICE_NAME	CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1)
#define TARGET_DEVICE_NAME "nRF54L15"
#define TARGET_DEVICE_NAME_LEN (sizeof(TARGET_DEVICE_NAME) - 1)
static void scan_filter_match(struct bt_scan_device_info *device_info,
			      struct bt_scan_filter_match *filter_match, bool connectable)
	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
	printk("Filters matched. Address: %s connectable: %d\n", addr, connectable);
static void scan_filter_no_match(struct bt_scan_device_info *device_info, bool connectable)
#if 0
static void scan_connecting_error(struct bt_scan_device_info *device_info)
	printk("Connecting failed\n");
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, scan_filter_no_match, scan_connecting_error, NULL);
static int scan_init(void)
	int err;
	struct bt_le_scan_param scan_param = {
		.type = BT_LE_SCAN_TYPE_PASSIVE,
		.options = BT_LE_SCAN_OPT_FILTER_DUPLICATE,
		.interval = 0x0010,
		.window = 0x0010,
	struct bt_scan_init_param scan_init_param = {
		.connect_if_match = true, .scan_param = &scan_param, .conn_param = NULL
	bt_scan_init(&scan_init);
	bt_scan_cb_register(&scan_cb);
	err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME, TARGET_DEVICE_NAME);
	if (err) {
		printk("bt_scan_filter_add() = %d\n", err);
		return err;
	err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
	if (err) {
		printk("bt_scan_filter_enable() = %d\n", err);
		return err;
	return 0;
static int scan_start(void)
	int err;
	err = bt_scan_start(BT_SCAN_TYPE_SCAN_PASSIVE);
	if (err) {
		printk("bt_scan_start() = %d\n", err);
		return err;
	return 0;
	int err;
#if 1
	err = bt_enable(NULL);
	if (err) {
		printk("bt_enable() = %d\n", err);
		return 0;
	err = scan_init();
	if (err) {
		printk("scan_init() = %d\n", err);
		return 0;
	err = scan_start();
	if (err) {
		printk("scan_start() = %d\n", err);
		return 0;
	for(;;) {
		static uint32_t c = 0;
		printk("Hello World! (%d) %s\n", c, CONFIG_BOARD_TARGET);
		c++;
		k_msleep(1000);
	return 0;
The following message is displayed in J-Link RTT Viewer V8.92:
00> *** Booting nRF Connect SDK v3.2.4-4c3fc0d44534 ***
00> *** Using Zephyr OS v4.2.99-9673eec75908 ***
00> [00:00:02.251,190] <err> bt_hci_driver: Endpoint binding failed with -11
00> [00:00:02.251,190] <err> bt_hci_core: HCI driver open failed (-11)
00> bt_enable() = -11
Disabling Bluetooth processing (changing `#if` on line 88 to 0) allows it to work correctly.
00> Hello World! (0) nrf5340dk/nrf5340/cpuapp
00> Hello World! (1) nrf5340dk/nrf5340/cpuapp
00> Hello World! (2) nrf5340dk/nrf5340/cpuapp
00> Hello World! (3) nrf5340dk/nrf5340/cpuapp
The procedure for writing is as follows:
C:\ncs\applications\hello_world_v3-2-4_rev2\build>nrfutil device recover --core Network
v Recovered 960033963
nrfutil device erase --core Network
v Erased 960033963
v Erased 960033963
nrfutil device program --firmware merged.hex
[00:00:01] ###### 100% [3/3 960033963] Programmed
nrfutil device reset
v Reset was applied to 960033963
Is build/merged.hex an image where Application and Network are combined?
  • Then I assume it must be built without "sysbuild" enabled (default) as is required for building multiple FW images in the same project. Please edit the build configuration in VS code and make sure to select the checkbox for enabling sysbuild at the end.
  • I tried building using sysbuild, but the problem was not resolved.
    Since merged.hex is not generated, I am writing <project name>/build/<project name>/zephyr/zephyr.hex.
  • And you are only having this problem with this particular project? Have you tested with any of the SDK samples? Do you have any build logs?
  • I've attached the build log.
    I also tried other sample projects (peripheral_lbs and central_bas), but they also returned -11 when I called bt_enable().
    I prepared a new PC and reinstalled everything from scratch, but the situation hasn't changed. I have two Thingy91X units, and both have the same problem.
     *  Executing task: nRF Connect: Build [pristine]: hello_world_v3-3-0/build
    Building hello_world_v3-3-0
    west build --build-dir c:/Works/nRF/hello_world_v3-3-0/build c:/Works/nRF/hello_world_v3-3-0 --pristine --board nrf5340dk/nrf5340/cpuapp/ns -- -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dhello_world_v3-3-0_DEBUG_THREAD_INFO=On
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/936afb6332/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.3.0/zephyr/.cache
    -- Found west (found suitable version "1.5.0", minimum required is "0.14.0")
    -- Board: nrf5340dk, qualifiers: nrf5340/cpuapp/ns
    warning: Deprecated symbol PARTITION_MANAGER is enabled.
    Parsing C:/ncs/v3.3.0/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/Works/nRF/hello_world_v3-3-0/build/_sysbuild/empty.conf'
    Merged configuration 'C:/Works/nRF/hello_world_v3-3-0/build/_sysbuild/empty.conf'
    Configuration saved to 'C:/Works/nRF/hello_world_v3-3-0/build/zephyr/.config'
    Kconfig header saved to 'C:/Works/nRF/hello_world_v3-3-0/build/_sysbuild/autoconf.h'
       * Running CMake for hello_world_v3-3-0 *
    -- Application: C:/Works/nRF/hello_world_v3-3-0
    -- CMake version: 4.2.1
    -- Zephyr version: 4.3.99 (C:/ncs/v3.3.0/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/936afb6332/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/936afb6332/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/936afb6332/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.3.0/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_ns.dts
    -- Found devicetree overlay: C:/Works/nRF/hello_world_v3-3-0/app.overlay
    -- Generated zephyr.dts: C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/include/generated/zephyr/devicetree_generated.h
    warning: Deprecated symbol PARTITION_MANAGER_ENABLED is enabled.
    warning: Experimental symbol TFM_EXPERIMENTAL is enabled.
    Parsing C:/ncs/v3.3.0/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.3.0/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_ns_defconfig'
    Merged configuration 'C:/Works/nRF/hello_world_v3-3-0/prj.conf'
    Merged configuration 'C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration 'C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/.config'
    Kconfig header saved to 'C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/936afb6332/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/936afb6332/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- libmetal version: 1.9.0 (C:/Works/nRF/hello_world_v3-3-0)
    -- Build type:
    -- Host:    Windows/AMD64
    -- Target:  Generic/arm
    -- Machine: arm
    -- Vendor: none
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.8.0 (C:/ncs/v3.3.0/modules/lib/open-amp/open-amp)
    -- Looking for include file fcntl.h
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h - found
    -- Found gen_kobject_list: C:/ncs/v3.3.0/zephyr/scripts/build/gen_kobject_list.py
    -- Configuring done (44.0s)
    -- Generating done (3.0s)
    -- Build files have been written to: C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0
    Dropping partition 'nonsecure_storage' since it is empty.
    CMake Warning at C:/ncs/v3.3.0/nrf/sysbuild/CMakeLists.txt:1150 (message):
          --- WARNING: SB_CONFIG_PARTITION_MANAGER is enabled, partition manager has been ---
          --- deprecated and boards should be updated to use DTS-based partitioning, see  ---
          --- the migration guide for more details on this.                               ---
      cmake/modules/sysbuild_extensions.cmake:808 (nrf_POST_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:808 (cmake_language)
      cmake/modules/sysbuild_images.cmake:46 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      C:/ncs/v3.3.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    -- Configuring done (66.5s)
    -- Generating done (0.2s)
    [4/327] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.3.99 (C:/ncs/v3.3.0/zephyr), build: ncs-v3.3.0
    [10/327] Generating ../../tfm/CMakeCache.txt
    -- Found Git: C:/ncs/toolchains/936afb6332/mingw64/bin/git.exe (found version "2.52.0.windows.1")
    -- Found Python3: C:/ncs/toolchains/936afb6332/opt/bin/python.exe (found version "3.12.4") found components: Interpreter
    CMake Warning (dev) at C:/ncs/v3.3.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf5340_cpuapp/CMakeLists.txt:21 (install):
      Policy CMP0177 is not set: install() DESTINATION paths are normalized.  Run
      "cmake --help-policy CMP0177" for policy details.  Use the cmake_policy
      command to set the policy and suppress this warning.
    This warning is for project developers.  Use -Wno-dev to suppress it.
    -- Configuring done (8.6s)
    -- Generating done (0.9s)
    -- Build files have been written to: C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/tfm
    [217/223] Linking C executable bin\tfm_s.axf
               FLASH:       81340 B       256 KB     31.03%
                 RAM:       48280 B       192 KB     24.56%
    [17/327] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [327/327] Linking C executable zephyr\zephyr.elf
               FLASH:       73976 B       720 KB     10.03%
                 RAM:       25172 B       256 KB      9.60%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from C:/Works/nRF/hello_world_v3-3-0/build/hello_world_v3-3-0/zephyr/zephyr.elf for board: nrf5340dk/nrf5340/cpuapp/ns
    [10/10] Generating ../merged.hex
  • I did not realise you were using the Thingy91x board. This board is not tested and validated with these bluetooth samples and may need someconfiguration changes to work. As a test, please build the peripheral_lbs sample for the nrf5340dk/nrf5340/cpuapp target instead, which is supported, then use nRF connect on iOS or Android to confirm that it becomes discoverable over Bluetooth.
    https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/samples/bluetooth/peripheral_lbs/README.html
    The only Bluetooth sample tested with the Thingy91x board configuration is the connectivity_bridge application you were using in the other ticket.
