Long running bt_conn_le_create_auto() breaks Bluetooth controller (nRF5340)
Background
For some time now I have been troubled by a bug in one of our products acting as a BLE central device. The bug manifests itself as the central reporting that it is connected to several peripherals, but it receives no data from the peripherals and no disconnect events are generated when the peripherals are power-cycled. The peripherals themselves advertise, indicating that they are in fact not connected to any central.
The central works by receiving a list of assigned periphal devices to which it maintains connections at all times. All peripherals are added to the filter accept list (FAL) upon assignment, and a connection supervision routine calls `bt_conn_le_create_auto()` when needed to connect/reconnect to the assigned peripherals.
Our naive use of the FAL and `bt_conn_le_create_auto()` means that if a device is assigned, but physically unavailable, we will forever have an outstanding `bt_conn_le_create_auto()` attempting to establish a connection to that unavailable node. This long running `bt_conn_le_create_auto()` attempt is what is causing the failure.
Description and How to Reproduce
I have found a small set of steps that can reliably reproduce the bug:
1. Set up FAL of to contain 3 addresses:
   - two devices running the peripheral_hr Zephyr sample on nRF5340 hardware
   - one address corresponding to a physically unavailable device
2. Continually call `bt_conn_le_create_auto()` whenever a device disconnects or reconnects.
3. Wait 50 minutes then power-cycle one of the peripherals.
4. The central will notice a disconnection event for the power-cycled device, but the second device will be silently dropped and outstanding `bt_conn_le_create_auto()` initiation attempt will not be able to connect to any more devices.
In the resulting state, our experience is that the BT controller will no longer function as expected and many BT operations results in assertion errors. This part is not demonstrated by the included sample.
See attached a sample application for nRF5340DK using latest NCS release (v3.2.4). See attached patch file (apply to the Zephyr repo at tag `ncs-v3.2.4`).
Additional Information
Our production application differs from the sample in significant ways. It's built on an older version of NCS (2.5.1), uses MPSL to run a proprietery protocol in addition to BLE, uses different connection and scan intervals. The common denominator is the long outstanding `bt_conn_le_create_auto()`. Still it takes 50 minutes (exact figure unknown but 40 minutes is too short) before the bug can be triggered.
It seems the problom can be worked around by avoiding long running `bt_conn_le_create_auto()` requests. By stopping with `bt_conn_create_auto_stop()` and restarting, the bug disappears. Calling `bt_conn_create_auto_stop()` and resuming works to avoid the bug even if 50 minutes has already passed.
Request
I would like a Nordic engineer to investigate this issue and determine whether this is a bug in the SoftDevice Controller (SDC) that requires a fix, or if the observed behavior is expected. If it is expected or if a fix will not be provided, I request confirmation that the workaround (periodically stopping and restarting `bt_conn_le_create_auto()`) is expected to work reliably given your insights into the SDC internals.
Thank you for your support.
0001-Sample-to-reproduce-error-with-long-running-bt_conn_.patch
  • Hi Alexander,
    I haven't set it up to test your firmware yet. But my understanding when looking at your patch is that you are calling bt_conn_le_create_auto() ever 5 seconds with this code:
    +	while (1) {
    +		start_auto_connect();
    +		k_sem_take(&conn_update_sem, K_SECONDS(5));
    +		print_status();
    Could you explain ?
    For example in our scanning_while_connecting sample, we only call this function if connection_establishment_ongoing ==false. My understanding is that you should only call it once and let it connect to all the devices in the FAL.
    https://github.com/nrfconnect/sdk-nrf/blob/main/samples/bluetooth/scanning_while_connecting/src/main.c#L214
    From what I can see this function is on the Zephyr host and not covered in our Softdevice controller. I did a quick search and it seems we have something similar reported:
     Issue with the auto connect feature
    It's about bt_le_set_auto_conn () function but the symptom is very similar.
  • Hi Hung,
    `bt_conn_le_create_auto()` only connects to one device in the FAL after which it needs to be restarted.
    Indeed `bt_conn_le_create_auto()` is called every 5 seconds in the sample I provided. That's just in an effort of trying to simplify the sample as much as possible. One could easily modify the sample to run the status printing task in a delayable work item or similar and remove the timeout from the `k_sem_take` in the main loop. The bug would still persist. In our product application we only refresh the call to `bt_conn_le_create_auto()` when needed. `bt_conn_le_create_auto()` does not seem to be negatively affected by being called when a connection attempt is already ongoing, it just returns `-EALREADY`. The sample works as expected, connecting and reconnecting without issues unless you wait 50 minutes since the last connect event, after which the bug can be triggered.
    The `bt_le_set_auto_conn()` operates differently from `bt_conn_le_create_auto()`. For one it does not use the FAL, in fact it depends explicitly on FAL support being disabled. At least that was the case for the version of NCS we used when initially developing our application. In recent versions of Zephyr it appears to have been removed.
    Could you be mixing them up? I believe `bt_le_set_auto_conn()` was implemented fully in the host stack without specific controller involvement. While I think `bt_conn_le_create_auto()` necessitates some controller involvement due to the way the FAL is used.
    One reason of my reasons for suspecting the SDC is that after triggering this bug in our production firmware I have observed failed assertions in the IPC layer (the specifics elude me but it was something about `net_buf` flags not being 0). Hitting that assert is not necessary for the controller to drop all connections though. It's just an additional way in which the controller firmware seems to break.
  • Hi Alexander,
    I tried a few times but haven't managed to reproduce the issue. Could you check the log and see if there is anything I should change ? I waited more than 50 minutes (also tried again after 3 hours). But it didn't seem to get to the state that it couldn't reconnect.
    [00:58:50.890,869] <inf> fal_central: Status:
    [00:58:50.890,960] <inf> fal_central: ED:16:9F:CF:23:DB (random): connected
    [00:58:50.891,021] <inf> fal_central: C1:0C:F6:A3:A4:66 (random): connected
    [00:58:50.891,113] <inf> fal_central: FF:FF:FF:FF:FF:FF (public): connecting
    [00:58:55.891,204] <inf> fal_central: Status:
    [00:58:55.891,296] <inf> fal_central: ED:16:9F:CF:23:DB (random): connected
    [00:58:55.891,357] <inf> fal_central: C1:0C:F6:A3:A4:66 (random): connected
    [00:58:55.891,448] <inf> fal_central: FF:FF:FF:FF:FF:FF (public): connecting
    [00:58:59.008,636] <inf> fal_central: Disconnected: ED:16:9F:CF:23:DB (random) (reason 0x08)
    [00:58:59.008,758] <inf> fal_central: Status:
    [00:58:59.008,850] <inf> fal_central: C1:0C:F6:A3:A4:66 (random): connected
    [00:58:59.008,911] <inf> fal_central: FF:FF:FF:FF:FF:FF (public): connecting
    [00:59:04.009,002] <inf> fal_central: Status:
    [00:59:04.009,094] <inf> fal_central: C1:0C:F6:A3:A4:66 (random): connected
    [00:59:18.399,963] <inf> fal_central: Status:
    [00:59:18.400,054] <inf> fal_central: FF:FF:FF:FF:FF:FF (public): connecting
    9.009,246] <inf> fal_central: Status:
    [00:59:18.400,115] <inf> fal_central: C1:0C:F6:A3:A4:66 (random): connected
    [00:59:18.400,207] <inf> fal_central: ED:16:9F:CF:23:DB (random): connected
    [00:59:23.400,299] <inf> fal_central: Status:
    [00:59:23.400,390] <inf> fal_central: FF:FF:FF:FF:FF:FF (public): connecting
    3.398,712] <inf> fal_central: Status:
    [00:59:23.400,451] <inf> fal_central: C1:0C:F6:A3:A4:66 (random): connected
    [00:59:23.400,543] <inf> fal_central: ED:16:9F:CF:23:DB (random): connected
    [00:59:28.400,634] <inf> fal_central: Status:
    started
    [00:59:28.400,726] <inf> fal_central: FF:FF:FF:FF:FF:FF (public): connecting
    [00:59:28.400,787] <inf> fal_central: C1:0C:F6:A3:A4:66 (random): connected
    [00:59:28.400,878] .0m<inf> fal_central: ED:16:9F:CF:23:DB (random): connected
    I haven't looked deep in the code, but not sure why FF:FF:FF:FF:FF:FF is the ghost address that it's trying to connect to.
    Have you reproduced the issue on all board/DK you used or only on some of them ? I was using 2 nRF54L DK as the peripheral. Not so sure if they have to be nRF5340.
  • Hi again,
    Thanks for testing. The log you sent is a little bit broken up even after stripping out terminal control codes. Can you confirm that you disconnected power to one device and then returned power to it while the other device had its connection unbroken?
    This is incredibly frustrating. In my tests the 50 minute wait has had a 100% success rate in reproducing the error across both the nRF5340DK and our own hardware.
    The FF:FF:FF:FF:FF:FF is a placeholder address used for the bt_conn object which is allocated as a placeholder by the Bluetooth host stack for the pending connection. Because we're using the FAL to connect to an unknown address it needs to use a placeholder address. We see it because bt_conn_foreach loops over all allocated bt_conn objects, not just the connected ones.
    These are the versions printed on boot by the board that I used last to test this. Can you compare with your output to see if there are differences?
    *** Booting nRF Connect SDK v3.2.4-4c3fc0d44534 ***
    *** Using Zephyr OS v4.2.99-cb8129641703 ***
    [00:00:00.287,170] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.287,200] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
    [00:00:00.287,231] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
    [00:00:00.289,154] <inf> bt_hci_core: HCI transport: IPC
    [00:00:00.289,245] <inf> bt_hci_core: Identity: C0:64:42:19:94:69 (random)
    [00:00:00.289,276] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2102, manufacturer 0x0059
    [00:00:00.289,306] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2102
    [00:00:00.289,306] <inf> fal_central: Bluetooth initialised
    [00:00:00.290,191] <inf> fal_central: FAL[0] D9:BE:DD:51:E8:F5  (real)
    [00:00:00.290,649] <inf> fal_central: FAL[1] E4:21:B1:13:70:F3  (real)
    [00:00:00.291,107] <inf> fal_central: FAL[2] DE:AD:DE:AD:DE:AD  (ghost)
    [00:00:00.291,839] <inf> fal_central: FAL initiator started
    [00:00:05.291,900] <inf> fal_central: Status:
    [00:00:05.291,992] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
    [00:00:10.292,083] <inf> fal_central: Status:
    [00:00:10.292,175] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
  • Hi Alexander,
    Please see the log with better formatting. You can find that 2 devices connected at the beginning and then I turned the power off on one of the board, resulting a disconnect. Only one is connected at this time. Then I turned it back on after a while and it get connected back on.
    [04:21:33.639,678] <inf> fal_central: Status:
    [04:21:33.639,770] <inf> fal_central:   C1:0C:F6:A3:A4:66 (random): connected
    [04:21:33.639,831] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:21:33.639,923] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
    [04:21:38.640,014] <inf> fal_central: Status:
    [04:21:38.640,106] <inf> fal_central:   C1:0C:F6:A3:A4:66 (random): connected
    [04:21:38.640,167] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:21:38.640,258] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
    [04:21:42.461,151] <inf> fal_central: Disconnected: C1:0C:F6:A3:A4:66 (random) (
    reason 0x08)
    [04:21:42.461,242] <inf> fal_central: Status:
    [04:21:42.461,334] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:21:42.461,395] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
    [04:21:47.461,517] <inf> fal_central: Status:
    [04:21:47.461,608] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:21:47.461,669] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connectng
    [04:21:52.461,761] <inf> fal_central: Status:
    [04:21:52.461,853] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:21:52.461,914] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
    [04:21:52.786,865] <inf> fal_central: Connected: C1:0C:F6:A3:A4:66 (random)
    [04:21:52.787,017] <inf> fal_central: Status:
    [04:21:52.787,109] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:21:52.787,170] <inf> fal_central:   C1:0C:F6:A3:A4:66 (random): connected
    [04:21:52.788,208] <inf> fal_central: FAL initiator started
    [04:21:57.788,299] <inf> fal_central: Status:
    [04:21:57.788,391] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
    [04:21:57.788,452] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:21:57.788,543] <inf> fal_central:   C1:0C:F6  3:A4:66 (random): connected
    [04:22:02.788,635] <inf> fal_central: Status:
    [04:22:02.788,726] <inf> fal_central:   FF:FF:FF:FF:FF:FF (public): connecting
    [04:22:02.788,787] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [04:22:02.788,879] <inf> fal_central:   C1:0C:F6:A3:A4:66 (random): connected
    Here is the log when booting it up:
    *** Using Zephyr OS v4.2.99-9673eec75908 ***
    [00:00:00.287,811] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.287,841] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
    [00:00:00.287,872] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0
    x00) Version 130.51898 Build 1015905744
    [00:00:00.290,405] <inf> bt_hci_core: HCI transport: IPC
    [00:00:00.290,496] <inf> bt_hci_core: Identity: C5:B3:9B:EE:C7:61 (random)
    [00:00:00.290,527] <inf> bt_hci_core: HCI: version 6.2 (0x10) revision 0x207e, m
    anufacturer 0x0059
    [00:00:00.290,557] <inf> bt_hci_core: LMP: version 6.2 (0x10) subver 0x207e
    [00:00:00.290,557] <inf> fal_central: Bluetooth initialised
    [00:00:00.291,717] <inf> fal_central: FAL[0] ED:16:9F:CF:23:DB  (real)
    [00:00:00.292,327] <inf> fal_central: FAL[1] C1:0C:F6:A3:A4:66  (real)
    [00:00:00.292,938] <inf> fal_central: FAL[2] DE:AD:DE:AD:DE:AD  (ghost)
    [00:00:00.293,701] <inf> fal_cennral: FAL initiator started
    [00:00:01.022,613] <inf> fal_central: Connected: ED:16:9F:CF:23:DB (random)
    [00:00:01.022,796] <inf> fal_central: Status:
    [00:00:01.022,888] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [00:00:01.024,261] <inf> fal_central: FAL initiator started
    [00:00:01.161,376] <inf> fal_central: Connected: C1:0C:F6:A3:A4:66 (random)
    [00:00:01.161,529] <inf> fal_central: Status:
    [00:00:01.161,621] <inf> fal_central:   ED:16:9F:CF:23:DB (random): connected
    [00:00:01.161,712] <inf> fal_central:   C1:0C:F6:A3:A4:66 (random): connected
    [00:00:01.162,719] <inf> fal_central: FAL initiator started
    anufacturer 0x0059
    There is some difference in the HCI version and LMP version. Could you give more information about the ipc_radio firmware you used for the netcore ? What configuration ? I don't see the netcore image included in your fal_central project.
