BM-SDK-nRF54L15-IRQ
nRF54L15 DK Board
BM-SDK-V1.0
Hi:
I have debugged the IRQ according to the nrfx demo, but now there is an unresolvable error that requires assistance.
This is an error printed by RTT:
00> [00:00:04.744,266] <err> os: Unhandled IRQn: 219
00> [00:00:04.744,285] <err> os: >>> ZEPHYR FATAL ERROR 1: Unhandled interrupt on CPU 0
00> [00:00:04.807,684] <err> os: Halting system
This is my test code. When I use nRF54 DK press button 0 or 1, an error pops up:
 * Copyright (c) 2025 Nordic Semiconductor ASA
#include <zephyr/kernel.h> /* k_busy_wait() */
#include <zephyr/sys_clock.h> /* USEC_PER_MSEC */
#include <zephyr/logging/log_ctrl.h>
#include <nrfx_gpiote.h>
#include <hal/nrf_gpio.h>
LOG_MODULE_REGISTER(app, CONFIG_APP_LEDS_LOG_LEVEL);
// GPIOTE
#define BUTTON_0                        NRF_PIN_PORT_TO_PIN_NUMBER(13, 1)
#define BUTTON_1                        NRF_PIN_PORT_TO_PIN_NUMBER(9, 1)
#define BUTTON_2                        NRF_PIN_PORT_TO_PIN_NUMBER(8, 1)
#define BUTTON_3                        NRF_PIN_PORT_TO_PIN_NUMBER(4, 0)
#define GPIOTE_INST                     NRF_GPIOTE20
#define CONFIG_APP_GPIOTE_IRQ_PRIO      0
/* GPIOTE30 ʵ�� */
static nrfx_gpiote_t gpiote_inst = NRFX_GPIOTE_INSTANCE(GPIOTE_INST);
/* PORT �¼��ص���������Ź���ͬһ handler */
static void port_event_handler(nrfx_gpiote_pin_t pin,
                                nrfx_gpiote_trigger_t trigger,
                                void *context)
    /* nrfx �����ڲ����Զ�����¼� */
    if (pin == BUTTON_0) {
        LOG_INF("BUTTON_0");
        /* ���� BUTTON_0 �¼� */
    } else if (pin == BUTTON_1) {
        LOG_INF("BUTTON_1");
        /* ���� BUTTON_1 �¼� */
ISR_DIRECT_DECLARE(gpiote_30_direct_isr)
	//nrfx_gpiote_irq_handler(&gpiote_inst);
	 nrfx_gpiote_irq_handler(&gpiote_inst);  /* ��ʹ�� NRFX_GPIOTE_INST_HANDLER_GET(20) */
	return 0;
void Key_Init(void)
    int err;
    /* ��ʼ�� GPIOTE20 */
    IRQ_DIRECT_CONNECT(NRFX_IRQ_NUMBER_GET(GPIOTE_INST),
			   CONFIG_APP_GPIOTE_IRQ_PRIO,
			   gpiote_20_direct_isr, 0);
	irq_enable(NRFX_IRQ_NUMBER_GET(GPIOTE_INST));
    err = nrfx_gpiote_init(&gpiote_inst, CONFIG_APP_GPIOTE_IRQ_PRIO);
    if (err) {
        LOG_ERR("nrfx_gpiote_init error: 0x%08X", err);
        return;
    /* ʹ�� PORT �¼�������������ͨ����p_in_channel = NULL�� */
    nrf_gpio_pin_pull_t pull_config = NRF_GPIO_PIN_PULLUP;
    /* PORT �¼��������ã�p_in_channel ��Ϊ NULL ��ʾʹ�� PORT �¼��� */
    nrfx_gpiote_trigger_config_t trigger_config = {
        .trigger      = NRFX_GPIOTE_TRIGGER_HITOLO,
        .p_in_channel = NULL,  /* NULL = ʹ�� PORT �¼�����ռ�ö���ͨ�� */
    nrfx_gpiote_handler_config_t handler_config = {
        .handler   = port_event_handler,
        .p_context = NULL,
    nrfx_gpiote_input_pin_config_t input_config = {
        .p_pull_config    = &pull_config,
        .p_trigger_config = &trigger_config,
        .p_handler_config = &handler_config,
    /* ���� BUTTON_0 */
    err = nrfx_gpiote_input_configure(&gpiote_inst, BUTTON_0, &input_config);
    if (err) {
        LOG_ERR("BUTTON_0 configure error: 0x%08X", err);
        return;
    nrfx_gpiote_trigger_enable(&gpiote_inst, BUTTON_0, true);
    /* ���� BUTTON_1������ͬһ handler�� */
    err = nrfx_gpiote_input_configure(&gpiote_inst, BUTTON_1, &input_config);
    if (err) {
        LOG_ERR("BUTTON_1 configure error: 0x%08X", err);
        return;
    nrfx_gpiote_trigger_enable(&gpiote_inst, BUTTON_1, true);
	LOG_INF("LEDs sample started");
	/* Initialize the LED */
    Key_Init();
	while (true) {
		while (LOG_PROCESS()) {
		/* Turn the LED on *
		/* Turn the LED off */
	return 0;
5241.prj.conf
  • Please help me check if there are any issues. Thank you
  • Hi Iiu,
    In your ISR_DIRECT_DECLARE, you define gpiote_30_direct_isr, but in IRQ_DIRECT_CONNECT you reference gpiote_20_direct_isr, which doesn't exist. This means the IRQ vector is not properly connected, leading to the "Unhandled IRQn: 219" fatal error when the GPIOTE20 interrupt fires. Additionally, you are using GPIOTE_INST = NRF_GPIOTE20, but named your ISR gpiote_30_direct_isr.
    Please also check out the example in the NCS BM v1.0.0 Release Notes for Interrupts
    Amanda H.
    // GPIOTE
                                    void *context)
    ISR_DIRECT_DECLARE(gpiote_20_direct_isr)
    	return 0;
    void Key_Init(void)
        int err;
        if (err) {
            return;
            .p_context = NULL,
        if (err) {
            return;
        if (err) {
            return;
    	/* Initialize the KEY */
        Key_Init();
    	while (true) {
    	return 0;
    Sorry, gpiote_30 is to confirm if the error is related to the IO port, from the results it doesn't seem to have anything to do with it. RTT still shows the same error. The above is the modified code. Initialization and instances are modified according to the reference documentation. Can you help me understand why this error is displayed? Are there any things to keep in mind when using the BM SDK?
    Thank you
    On nRF54L15, GPIOTE20 has two NVIC lines (see modules/hal/nordic/nrfx/bsp/stable/mdk/nrf54l15_application_peripherals.h):
      GPIOTE20_0_IRQn                        = 218,      /*!< 218 GPIOTE20_0                                                       */
      GPIOTE20_1_IRQn                        = 219,      /*!< 219 GPIOTE20_1                                                       */
    Your code only did:
    IRQ_DIRECT_CONNECT(NRFX_IRQ_NUMBER_GET(GPIOTE_INST), ...) // → 218
    So the vector table had a handler for 218, but button edges raise 219. Nothing was installed for 219, so Zephyr reported Unhandled IRQn: 219 when you pressed a button.
    It requires IRQ_DIRECT_CONNECT for both GPIOTE20_0_IRQn and GPIOTE20_1_IRQn, same ISR, so 219  can be handled. Also, add irq_enable(GPIOTE20_1_IRQn) after nrfx_gpiote_init(). The nrfx turns on NVIC line 0; line 1 still needs to be enabled for pin IRQs.
    The Bare Metal documentation reserves NVIC priorities 0–1 for the SoftDevice; the application should use 2–7, so "CONFIG_APP_GPIOTE_IRQ_PRIO" cannot be 0 when using the SoftDevice.  See Interrupt priority levels.
    Here is the updated main.c:
    #include <zephyr/irq.h>
    // GPIOTE
    #define CONFIG_APP_GPIOTE_IRQ_PRIO 4
    static volatile uint32_t last_button_pin = 0xFFFFFFFFU;
    static uint32_t reported_pin = 0xFFFFFFFFU;
    			       void *context)
    	ARG_UNUSED(trigger);
    	ARG_UNUSED(context);
    	last_button_pin = (uint32_t)pin;
    	return 0;
    void Key_Init(void)
    	int err;
    	uint8_t channel_0;
    	uint8_t channel_1;
    	IRQ_DIRECT_CONNECT(GPIOTE20_0_IRQn, CONFIG_APP_GPIOTE_IRQ_PRIO, gpiote_20_direct_isr, 0);
    	IRQ_DIRECT_CONNECT(GPIOTE20_1_IRQn, CONFIG_APP_GPIOTE_IRQ_PRIO, gpiote_20_direct_isr, 0);
    	if (err) {
    		return;
    	irq_enable(GPIOTE20_1_IRQn);
    	err = nrfx_gpiote_channel_alloc(&gpiote_inst, &channel_0);
    	if (err) {
    		LOG_ERR("channel_alloc BUTTON_0: 0x%08X", err);
    		return;
    	err = nrfx_gpiote_channel_alloc(&gpiote_inst, &channel_1);
    	if (err) {
    		LOG_ERR("channel_alloc BUTTON_1: 0x%08X", err);
    		return;
    	nrfx_gpiote_trigger_config_t trigger_config_0 = {
    		.p_in_channel = &channel_0,
    	nrfx_gpiote_trigger_config_t trigger_config_1 = {
    		.p_in_channel = &channel_1,
    		.p_context = NULL,
    	nrfx_gpiote_input_pin_config_t input_config_0 = {
    		.p_trigger_config = &trigger_config_0,
    	nrfx_gpiote_input_pin_config_t input_config_1 = {
    		.p_trigger_config = &trigger_config_1,
    	err = nrfx_gpiote_input_configure(&gpiote_inst, BUTTON_0, &input_config_0);
    	if (err) {
    		return;
    	err = nrfx_gpiote_input_configure(&gpiote_inst, BUTTON_1, &input_config_1);
    	if (err) {
    		return;
    	Key_Init();
    	while (true) {
    		uint32_t pin = last_button_pin;
    		if (pin != reported_pin) {
    			reported_pin = pin;
    			if (pin == (uint32_t)BUTTON_0) {
    			} else if (pin == (uint32_t)BUTTON_1) {
    	return 0;
    prj.conf:
    CONFIG_LOG=y
    CONFIG_LOG_BACKEND_BM_UARTE=y
    # Enabling SoftDevice is not strictly needed, though we are building with SoftDevice boards.
    CONFIG_SOFTDEVICE=y
    CONFIG_CLOCK_CONTROL=y
    # Enable GPIOTE
    CONFIG_NRFX_GPIOTE20=y
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=3
    -Amanda H.
  • Hi Amanda,
    Thank you very much for your support and assistance
