nRF52833 Unable to Use External 32 MHz Crystal
Hewy there:
I have a custom nRF52833 board with NCS v3.1.0, using ESB and USB CDC ACM. The external 32 MHz crystal is oscillating fine — we see a clean 32 MHz sine wave at 700 mVpp on the scope. Crystal is X201632MOB4SI (YSX211SL, CL=12 pF), with 12 pF caps on both pins.
But EVENTS_HFCLKSTARTED never fires. HFCLKSTAT still shows SRC=0 (internal RC). We also tried setting HFXODEBOUNCE to 0x40 before starting the task, no change.
The app hangs in lfclk_spinwait() when using CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y. With RC everything runs but USB fails (Windows error code 43) and ESB doesn't work.
Why would EVENTS_HFCLKSTARTED not trigger when the crystal is clearly oscillating at the right frequency and amplitude?
Thank you.
