I am using nrf52832, and I want to use SYSTEM ON Sleep.
Also , my wake up sourses are timer based, and also GPIO interrupt based.
But I observed that the device cannot go to sleep for more than approximately 4 minutes.
Code:
Code:
the RTC rolls over at 512 seconds (24^2 * 1/32768), but the kernel timer driver wraps around at half of it, to avoid a corner case:
https://github.com/zephyrproject-rtos/zephyr/blob/main/drivers/timer/nrf_rtc_timer.c#L690-L694
255 seconds = 4.25 minutes, which is similar to what you're observing.
"WFI" waits for any interrupt and wakes up. In a RTOS, these can be internal to the OS, so I would recommend that you use k_cpu_idle() (https://docs.zephyrproject.org/latest/doxygen/html/group__cpu__idle__apis.html) instead.
Håkon
Hello Hakon,
Thankyou for the response.
I tried to use k_cpu_idle() instead of WFI . But the same behaviour is seen.
After 4.5 minutes the device woke up again just like WFI.
I tried another configuration as well :
in prj.conf file:
Then, I tried to print the values of the ticks using this method, so i can spot the overflow at 4.5 minutes.
But it seemed to work fine here.
Dinna said:Also please let me know if there is a way to know what interrupt was received from WFI.
There is no specific register to read. You need to check if your wanted condition (ie. your interrupt) has occurred.
Dinna said:Then, I tried to print the values of the ticks using this method, so i can spot the overflow at 4.5 minutes.
The driver handles the overflow, but the nRF will generate a wake up condition.
k_cpu_idle is a wrapper for __WFI(), while k_sleep() is a sleep function with a specific timeout parameter.
Håkon
This is where the issue is, the device wakes up before the actual interrupt should occur, i.e., exactly 5 minutes or exactly 10 minutes.
The device wakes up before these conditions are met.
Do you have any suggestions on how to use SYSTEM ON sleep, with wake up on both timer expiry and GPIO interrupt generation.
Check out the zephyr/samples/basic/button sample.
Try to combine this with a k_timer instance:
Håkon
