Light LC Server with Light CTL Server in nRF52840DK
I started from your
Bluetooth Mesh NLC: Lightness Controller/Energy Monitor sample
and I tried to insert a Light CTL Server model in the project.
After a lot of effort now I manage to build and to flash the FW in my nRF52840DK.
By means of another DK with Light CTL Client I can transmit a temp light value to the DK with CTL Server, but soon after receiving the value the system crashes with this error:
<err> os: ***** BUS FAULT *****
[00:01:52.372,619] <err> os:   Precise data bus error
[00:01:52.372,619] <err> os:   BFAR Address: 0x80b662ba
[00:01:52.372,650] <err> os:   Imprecise data bus error
[00:01:52.372,680] <err> os: r0/a1:  0x00000000  r1/a2:  0x00000000  r2/a3:  0x80b662b6
[00:01:52.372,680] <err> os: r3/a4:  0x2000e874 r12/ip:  0x00000000 r14/lr:  0x00063d29
[00:01:52.372,711] <err> os:  xpsr:  0x41000000
[00:01:52.372,711] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00007fff  s[ 3]:  0x200026e8
[00:01:52.372,741] <err> os: s[ 4]:  0x00000010  s[ 5]:  0x000516ab  s[ 6]:  0x00000000  s[ 7]:  0x2000e8e8
[00:01:52.372,772] <err> os: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x2000ea8c  s[11]:  0x00000001
[00:01:52.372,802] <err> os: s[12]:  0x00000082  s[13]:  0x00000000  s[14]:  0x2000e874  s[15]:  0x00000000
[00:01:52.372,802] <err> os: fpscr:  0x2000ea8c
[00:01:52.372,802] <err> os: Faulting instruction address (r15/pc): 0x0005e8a2
[00:01:52.372,863] <err> os: >>> ZEPHYR FATAL ERROR 26: Unknown error on CPU 0
[00:01:52.372,894] <err> os: Current thread: 0x20004f90 (BT RX WQ)
[00:01:52.491,973] <err> os: Halting system
I insert the most important snippets of FW so to show you what I'm talking about.
I hope that you can help me to make CTL server and Light CTRL server to live together.
Thank you in advance
static struct bt_mesh_elem elements[] = {
	BT_MESH_ELEM(1,
		     BT_MESH_MODEL_LIST(
			     BT_MESH_MODEL_CFG_SRV,
			     BT_MESH_MODEL_HEALTH_SRV(&health_srv, &health_pub),
			     BT_MESH_MODEL_LIGHTNESS_SRV(&my_ctx.lightness_srv),
				 BT_MESH_MODEL_LIGHT_CTL_SRV(&ctl_srv_inst),
				 BT_MESH_MODEL_LIGHT_TEMP_SRV(&ctl_srv_inst.temp_srv),
			     BT_MESH_MODEL_SCENE_SRV(&scene_srv),
				 BT_MESH_MODEL_SENSOR_CLI(&sensor_cli),
				 BT_MESH_MODEL_DFU_SRV(&dfu_srv)),
		     BT_MESH_MODEL_NONE),
	BT_MESH_ELEM(2,
		     BT_MESH_MODEL_LIST(
			     BT_MESH_MODEL_LIGHT_CTRL_SRV(&light_ctrl_srv)),
static void light_set(struct bt_mesh_lightness_srv *srv,
		      struct bt_mesh_msg_ctx *ctx,
		      const struct bt_mesh_lightness_set *set,
		      struct bt_mesh_lightness_status *rsp)
	struct lightness_ctx *l_ctx =
		CONTAINER_OF(srv, struct lightness_ctx, lightness_srv);
	start_new_light_trans(set, l_ctx);
	rsp->current = l_ctx->rem_time ? l_ctx->current_lvl : l_ctx->target_lvl;
	rsp->target = l_ctx->target_lvl;
	rsp->remaining_time = set->transition ? set->transition->time : 0;
static void light_get(struct bt_mesh_lightness_srv *srv,
	rsp->current = bt_mesh_lightness_clamp(&l_ctx->lightness_srv, l_ctx->current_lvl);
	rsp->remaining_time = l_ctx->rem_time;
static const struct bt_mesh_lightness_srv_handlers lightness_srv_handlers = {
	.light_set = light_set,
	.light_get = light_get,
static struct lightness_ctx my_ctx = {
	.lightness_srv = BT_MESH_LIGHTNESS_SRV_INIT(&lightness_srv_handlers)
/**** Snippet per CTL server ****/
static void handle_temp_set(struct bt_mesh_light_temp_srv *srv,
                            const struct bt_mesh_light_temp_set *set,
                            struct bt_mesh_light_temp_status *rsp)
    /* 1. Estrarre i dati dal pacchetto ricevuto */
    // set->temp è la temperatura colore in Kelvin (range 800 - 20000)
    uint16_t temperatura_kelvin = set->params.temp;
    // set->delta_uv è la deviazione dalla linea del corpo nero (solitamente 0)
    int16_t delta_uv = set->params.delta_uv;
    /* 2. Logica di controllo LED */
    printk("HCL Update: Temperatura = %u K, Delta_UV = %d\n",
            temperatura_kelvin, delta_uv);
    // Qui chiamerai la tua funzione driver per i LED fisici, ad esempio:
    // update_led_mixing(temperatura_kelvin, delta_uv);
    /* 3. Gestire la risposta (Status) */
    /* Se rsp non è NULL, lo stack invierà una risposta al client.
     * Dobbiamo riempire i campi con lo stato attuale dopo il cambiamento. */
    if (rsp) {
        rsp->current.temp = temperatura_kelvin;
        rsp->current.delta_uv = delta_uv;
        /* Se non c'è una transizione in corso (fade), target e current sono uguali */
        rsp->target.temp = temperatura_kelvin;
        rsp->target.delta_uv = delta_uv;
        rsp->remaining_time = 0;
static void handle_lightness_set(struct bt_mesh_lightness_srv *srv,
    uint16_t lightness = set->lvl; // Range 0 - 65535
    // Aggiorna i tuoi LED
    // update_led_brightness(lightness);
    if (rsp) {
        rsp->current = lightness;
        rsp->target = lightness;
// Callback per la Luminosità (Elemento 1)
static const struct bt_mesh_lightness_srv_handlers lightness_handlers = {
    .light_set = handle_lightness_set,
// Callback per la Temperatura (Elemento 2)
static const struct bt_mesh_light_temp_srv_handlers temp_handlers = {
    .set = handle_temp_set,
/* 3. Inizializza il CTL SRV */
static struct bt_mesh_light_ctl_srv ctl_srv_inst = {
    .lightness_srv = {
        .handlers = &lightness_handlers,
    .temp_srv = {
        .handlers = &temp_handlers,
/**** End Snippet per CTL server ****/
static struct bt_mesh_light_ctrl_srv light_ctrl_srv =
	BT_MESH_LIGHT_CTRL_SRV_INIT(&my_ctx.lightness_srv);
  • Hi Stefano
    I will look into this later this week but I need some time to get my bearings with the projects you link to and dive into this before getting back to you. I will give you more information on Friday at the latest.
    Also, please confirm which device you see this BUS FAULT error on, and when exactly in the application it occurs. Is it directly after connecting to the network and sending a light control request or similar, or do you get any successful data transmitted before it crashes?
    The full log file of when you see this issue would be useful.
    Simon
  • Hi Stefano
    We will follow up this in the private ticket you created. Closing this as a duplicate.
    Simon
